Authenticate a Python Application with Vultr Managed Databases for PostgreSQL and Redis®
![Authenticate a Python Application with Vultr Managed Databases for PostgreSQL and Redis® header image](https://docs.vultr.com/public/doc-assets/1466/378d5d16d3422e70.png)
Authentication is the process of verifying the user's credentials before granting access to an application. To log in to an application, end-users enter their usernames and passwords. Under the hood, a background process compares the users' credentials with database values to check if there is a match.
The whole authentication process requires a round-trip to a disk-based database like PostgreSQL every time a user accesses the application. When the application's user base grows, the disk-based databases encounter scalability issues. To overcome the challenge, this is where an in-memory database like Redis® comes to play.
You can use the Redis® database to cache authentication details when a user logs in to an application for the first time. Then, during the following requests, you can query the Redis® server to check the authentication status instead of hitting the disk-based database. Redis® is several times faster than disk-based databases. This approach makes your application faster and more scalable in the end.
This guide describes the process of authenticating a Python application with Vultr Managed Database for PostgreSQL and Vultr Managed Database for Caching. Vultr provides a secure and highly scalable managed database that works right out of the box to automate all the difficult tasks of your database administration.
To follow this guide:
Deploy the following Managed Databases in the same Vultr location:
Locate the Connection Details for each Managed Database in the Vultr Customer Portal under the Overview tab. This guide uses the following sample connection details:
Redis® server:
- username:
default
- password:
EXAMPLE_REDIS_PASSWORD
- host:
SAMPLE_REDIS_DB_HOST_STRING.vultrdb.com
- port:
16752
- username:
PostgreSQL server:
- username:
vultradmin
- password:
EXAMPLE_POSTGRESQL_PASSWORD
- host:
SAMPLE_POSTGRESQL_DB_HOST_STRING.vultrdb.com
- port:
16751
- username:
1. Set Up a Sample Database
This guide uses the Vultr Managed Database for PostgreSQL to store data permanently on a disk. For this sample application, you require a database and two tables. The first table stores products. Then, a Python script queries the table to return the products in JSON format when users send requests to the application. The second table stores users and their authentication credentials. Follow the steps below to set up the database:
Update the package information index.
Install the
postgresql-client
package. Because this application uses the PostgreSQL-managed database from Vultr, you only require the PostgreSQL command-line client to query the database.$ sudo apt install -y postgresql-client
Use the
psql
command to log in to the managed PostgreSQL database. ReplaceSAMPLE_POSTGRESQL_DB_HOST_STRING.vultrdb.com
with the correct name of thehost
.$ psql -h SAMPLE_POSTGRESQL_DB_HOST_STRING.vultrdb.com -p 16751 -U vultradmin defaultdb
Ensure you get the following password prompt.
Password for user vultradmin:
Enter the password for the managed PostgreSQL user and press Enter to proceed. Then, verify the following output.
defaultdb=>
Enter the following command to create a sample
my_company
database.defaultdb=> CREATE DATABASE my_company;
CREATE DATABASE
Switch to the new
my_company
database.defaultdb=> \c my_company;
You are now connected to database "my_company" as user "vultradmin". my_company=>
Create a
products
table. This guide uses a single table. In a production environment, you might have tens or hundreds of tables depending on the complexity of your application.my_company=> CREATE TABLE products ( product_id SERIAL PRIMARY KEY, product_name VARCHAR (50), retail_price NUMERIC(5, 2) );
CREATE TABLE
Populate the
products
table.my_company=> INSERT INTO products (product_name, retail_price) VALUES ('1L FOUNTAIN DRINKING WATER', 2.55); INSERT INTO products (product_name, retail_price) VALUES ('PINK COTTON BUDS', 4.85); INSERT INTO products (product_name, retail_price) VALUES ('WINE GLASS', 9.75);
... INSERT 0 1
Query the
products
table to ensure the data is in place.my_company=> SELECT product_id, product_name, retail_price FROM products;
product_id | product_name | retail_price ------------+----------------------------+-------------- 1 | 1L FOUNTAIN DRINKING WATER | 2.55 2 | PINK COTTON BUDS | 4.85 3 | WINE GLASS | 9.75 (3 rows)
Create a
users
table. Theusers
table stores users' information such asuser_id
,username
, andpwd
(password).my_company=> CREATE TABLE users ( user_id SERIAL PRIMARY KEY, username VARCHAR (50), pwd VARCHAR (255) );
CREATE TABLE
Issue the following command to enable the
pgcrypto
extension. You require this extension to hash passwords before inserting them into theusers
table.my_company=> CREATE EXTENSION pgcrypto;
CREATE EXTENSION
Populate the
users
table with sample data. This guide usesEXAMPLE_PASSWORD
andEXAMPLE_PASSWORD_2
. Remember to use strong passwords to prevent brute-force attacks in a production environment.my_company=> INSERT INTO users (username, pwd) VALUES ('john_doe', crypt('EXAMPLE_PASSWORD', gen_salt('bf'))); INSERT INTO users (username, pwd) VALUES ('mary_smith', crypt('EXAMPLE_PASSWORD_2', gen_salt('bf')));
... INSERT 0 1
Query the
users
table to verify the records and the workings of thepgcrypto
extension.my_company=> SELECT user_id, username, pwd FROM users;
user_id | username | pwd ---------+------------+-------------------------------------------------------------- 1 | john_doe | $2a$06$spijfwl34nCdBpApp1C68OWa//j0buReiQ4SHAJVCV4sm627iyyZW 2 | mary_smith | $2a$06$g6FjH7PXSCMT75uIKB94ZOUWHbeth0SsHebOqcykjXM4Dq6mtlxtG (2 rows)
Log out from the managed PostgreSQL server.
my_company=> \q
Proceed to the next step to create a database class for the PostgreSQL server.
2. Create a PostgreSQL Database Class
This step shows you how to create a central PostgreSQL class that you can use from your application to access database functions. Follow the steps below to create the class:
Create a
project
directory to separate your source code from system files.$ mkdir project
Switch to the new
project
directory.$ cd project
Open a new
posgresql_gateway.py
file in a text editor.$ nano postgresql_gateway.py
Enter the following information into the
file. Replace thedb_pass
anddb_host
values with the correcthost
andpassword
for the managed PostgreSQL database.import psycopg2 import bcrypt class PostgresqlGateway: def __init__(self): db_host = 'SAMPLE_POSTGRESQL_DB_HOST_STRING.vultrdb.com' db_port = 16751 db_name = 'my_company' db_user = 'vultradmin' db_pass = 'EXAMPLE_POSTGRESQL_PASSWORD' self.postgresql_client = psycopg2.connect(host = db_host, database = db_name, user = db_user, password = db_pass, port = db_port) def get_products(self): sql_string = 'select product_id, product_name, retail_price from products' cur = self.postgresql_client.cursor() cur.execute(sql_string) rows = cur.fetchall() products = [] dt_columns = list(cur.description) for row in rows: row_data = {} for i, col in enumerate(dt_columns): row_data[col.name] = str(row[i]) products.append(row_data) return products def authenticate_user(self, username, password): sql_string = "select username, pwd from users where username = %s" cur = self.postgresql_client.cursor() cur.execute(sql_string, (username,)) if cur.rowcount < 1 : return False else: row = cur.fetchone() if bcrypt.checkpw(password.encode('utf8'), row[1].encode('utf8')): self.hashed_password = row[1].encode('utf8') return True else: return False
Save and close the
file.
The postgresql_gateway.py
file explained:
The
import
section declares two libraries. Thepsycopg2
is a popular Python library for the PostgreSQL database. Thebcrypt
is a password-hashing library.import psycopg2 import bcrypt ...
The
PostgresqlGateway
class has three methods.class PostgresqlGateway: def __init__(self): ... def get_products(self): ... def authenticate_user(self, username, password): ...
The
_init_()
method establishes a database connection to the PostgreSQL database when you instantiate the class.The
get_products(...)
method queries theproducts
table to retrieve a list of products from the database.The
authenticate_user(...)
method queries theusers
table to find a match when a user tries to log in to the application. If a user's credentials match a record in theusers
table, the authenticate_user method returnsTrue
.The
statement compares the user's password with the database value using thebcrypt
library.
class is now ready. To use it in other Python files, use the following syntax:
import postgresql_gateway
pg = postgresql_gateway.PostgresqlGateway()
... = pg.get_products()
... = pg.authenticate_user(username, password)
Follow the next step to create a Redis database class.
3. Create a Redis® Database Class
This step focuses on creating a Redis® database class. The class provides Redis® functionalities for creating and retrieving keys. Execute the steps below to create the class:
Open a new
redis_gateway.py
file in a text editor.$ nano redis_gateway.py
redis_gateway.py
file. Replace thedb_host
anddb_pass
andpassword
from your Vultr Managed Database for Caching.import redis import bcrypt class RedisGateway: def __init__(self): db_host = 'SAMPLE_REDIS_DB_HOST_STRING.vultrdb.com' db_port = 16752 db_pass = 'EXAMPLE_REDIS_PASSWORD' self.redis_client = redis.Redis(host = db_host, port = db_port, password = db_pass, ssl = 'true') def cache_user(self, username, password): self.redis_client.set(username, password) def authenticate_user(self, username, password): if self.redis_client.exists(username): hashed_password = self.redis_client.get(username) if bcrypt.checkpw(password.encode('utf8'), hashed_password): return True else: return False
Save and close the
redis_gateway.py
file.
The redis_gateway.py
file explained:
The
import
section declares two Python libraries. Theredis
library provides an interface between Python and the Redis® server. Thebcrypt
library compares the plain-text password provided by a user and the hashed pass from Redis®.... import redis import bcrypt
The
RedisGateway
class has three methods.... class RedisGateway: def __init__(self): ... def cache_user(self, username, password): ... def authenticate_user(self, username, password): ...
The
_init_()
method establishes a connection to the Redis® server.The
cache_user()
method saves the user's authentication details to the Redis® server using theself.redis_client.set(username, password)
function. Each user has a uniqueusername
that acts as a Redis® key while thepassword
is a Redis® value.The
method queries the Redis® server to check if a key (hashed_password
) named with the givenusername
exists using theif self.redis_client.exists(username):
statement. If the user's password is available from the Redis® server, theauthenticate_user(...)
function returnsTrue
. Otherwise, the function returnsFalse
The RedisGateway
class is now ready. You can import and use the class in other Python files using the following syntax:
import redis_gateway
rg = redis_gateway.RedisGateway()
rg.cache_user(username, pg.hashed_password)
Follow the next step to finish coding your application.
4. Create the Application's Entry Point
The final step is creating an entry point to the sample application. This guide uses a main.py
file as the application's start-up file. Follow the steps below to create the file:
Open a new
main.py
file in a text editor.$ nano main.py
main.py
file.import http.server from http import HTTPStatus import socketserver import json import base64 import postgresql_gateway import redis_gateway class httpHandler(http.server.SimpleHTTPRequestHandler): def do_GET(self): authHeader = self.headers.get('Authorization').split(' '); username, password = base64.b64decode(authHeader[1]).decode('utf8').split(':') self.send_response(HTTPStatus.OK) self.send_header('Content-type', 'application/json') self.end_headers() pg = postgresql_gateway.PostgresqlGateway() rg = redis_gateway.RedisGateway() data = dict() if rg.authenticate_user(username, password) == True: products = pg.get_products() data = {'authenticated_by' : 'Redis Server', 'data': products} else: if pg.authenticate_user(username, password) == True: rg.cache_user(username, pg.hashed_password) products = pg.get_products() data = {'authenticated_by' : 'PostgreSQL Server', 'data': products} else: data = {'error': 'Authentication failed.'} resp = json.dumps(data, indent = 4, separators = (',', ': ')) self.wfile.write(bytes(resp + '\r\n', "utf8")) httpServer = socketserver.TCPServer(('', 8080), httpHandler) print("HTTP server started at port 8080...") try: httpServer.serve_forever() except KeyboardInterrupt: httpServer.server_close() print("The server is stopped.")
Save and close the
main.py
file.
The main.py
file explained:
The
import
section declares the HTTP server (http.server
,HTTPStatus
, andsocketserver
),json
,base64
,postgresql_gateway
, andredis_gateway
libraries.import http.server from http import HTTPStatus import socketserver import json import base64 import postgresql_gateway import redis_gateway ...
The
httpHandler
is an HTTP handler class for the application with onedo_GET(self)
method. This method fires when a user sends aGET
request to the application. Thedo_GET
method outputs a JSON output.class httpHandler(http.server.SimpleHTTPRequestHandler): def do_GET(self): ... resp = json.dumps(data, indent = 4, separators = (',', ': ')) self.wfile.write(bytes(resp + '\r\n', "utf8"))
The
do_GET()
method declares the two custom PostgreSQL and Redis® libraries that you created earlier using the following syntax.pg = postgresql_gateway.PostgresqlGateway() rg = redis_gateway.RedisGateway()
The main logic of the application lies in the following code.
... if rg.authenticate_user(username, password) == True: products = pg.get_products() data = {'authenticated_by' : 'Redis Server', 'data': products} else: if pg.authenticate_user(username, password) == True: rg.cache_user(username, pg.hashed_password) products = pg.get_products() data = {'authenticated_by' : 'PostgreSQL Server', 'data': products} else: data = {'error': 'Authentication failed.'} ...
The
logic queries the Redis® server to check whether the user's details are already cached. If the function returnsTrue
, the logic calls theproducts = pg.get_products()
to output the products from the PostgreSQL database.If the user's details are not found on the Redis® server, the
logic looks for the user's credentials from the PostgreSQL database. If the user details are correct, the logic calls therg.cache_user(username, pg.hashed_password)
to cache the user's details to the Redis® server for other calls and then runs thepg.get_products()
function to output the products from the PostgreSQL database.The statements
{'authenticated_by' : 'Redis® Server', 'data': products}
and{'authenticated_by' : 'PostgreSQL Server', 'data': products}
allow you to identify how the user authenticates to the application. This is for demonstration purposes only, and you can remove theauthenticated_by
values in a production environment.The statement below starts a web server that listens for incoming connections on port
8080
and declares thehttpHandler
function as the handler function.... httpServer = socketserver.TCPServer(('', 8080), httpHandler) print("HTTP server started at port 8080...") try: httpServer.serve_forever() except KeyboardInterrupt: httpServer.server_close() print("The server is stopped.")
Your application is now ready for testing.
5. Test the Application Logic
The final step is installing all the third-party libraries required by the application and testing the authentication logic. Follow the steps below to complete those steps:
Install the Python
pip
package.$ sudo apt install -y python3-pip
Use the
pip
package to install thepsycopg2
module. For testing and development, use the binary package (psycopg2-binary
). However, in a production environment, consider using thepsycopg2
package.$ pip install psycopg2-binary
... Successfully installed psycopg2-binary-2.9.5
Install the
redis
module for Python.$ pip install redis
... Successfully installed async-timeout-4.0.2 packaging-21.3 pyparsing-3.0.9 redis-4.3.5
Install the
bcrypt
module for Python.$ pip install bcrypt
... Successfully installed bcrypt-4.0.1
Use the
python3
command to run the application.$ python3 main.py
Establish another SSH connection to your server and issue the following Linux
curl
commands to send twoGET
requests to the application.john_doe
:$ curl -X GET -u john_doe:EXAMPLE_PASSWORD http://localhost:8080/ $ curl -X GET -u john_doe:EXAMPLE_PASSWORD http://localhost:8080/
mary_smith
:$ curl -X GET -u mary_smith:EXAMPLE_PASSWORD_2 http://localhost:8080/ $ curl -X GET -u mary_smith:EXAMPLE_PASSWORD_2 http://localhost:8080/
Note the following outputs. In the first output, the
authenticated_by
value readsPostgreSQL Server
. However, in the second request, theauthenticated_by
value readsRedis® Server
.Output 1.
... { "authenticated_by": "PostgreSQL Server", "data": [ { "product_id": "1", "product_name": "1L FOUNTAIN DRINKING WATER", "retail_price": "2.55" }, { "product_id": "2", "product_name": "PINK COTTON BUDS", "retail_price": "4.85" }, { "product_id": "3", "product_name": "WINE GLASS", "retail_price": "9.75" } ] }
Output 2.
... { "authenticated_by": "Redis Server", "data": [ { "product_id": "1", "product_name": "1L FOUNTAIN DRINKING WATER", "retail_price": "2.55" }, { "product_id": "2", "product_name": "PINK COTTON BUDS", "retail_price": "4.85" }, { "product_id": "3", "product_name": "WINE GLASS", "retail_price": "9.75" } ] }
Your application logic is working as expected.
This guide uses Vultr Managed Database for Caching and Vultr Managed Database for PostgreSQL to speed up authenticating a Python application on Ubuntu 20.04 server. Use this guide's sample source code files to scale your application on your next Python project.
Read more guides about the Redis® server by following the links below:
