title: Deploy Serverless Workloads on Vultr Kubernetes Engine with Knative Serving
url: https://docs.vultr.com/deploy-serverless-workloads-on-vultr-kubernetes-engine-with-knative-serving
description: Learn how to deploy serverless workloads on Vultr Kubernetes Engine using Knative Serving. Follow our step-by-step guide to implement efficient cloud-native solutions.
publish_date: 2023-11-12T00:00:00Z
last_updated: 2025-04-01T00:00:00Z
author: Hitesh Jethva
header_image: https://docs.vultr.com/public/doc-assets/1675/41082e1f660d282c.png
Knative is an open-source project that offers a set of components to simplify the configuration of services on Kubernetes. It allows developers to deploy, run, and manage serverless cloud-native applications fast without managing the underlying infrastructure directly. This reduces the execution time for common routine tasks such as creating pods, load balancing, auto-scaling, routing traffic, among other cluster operations.
Knative Serving offers a set of components that allow you to deploy and manage serverless workloads on Kubernetes. You can deploy an application and enable automatic scaling based on the incoming user traffic load. Below are the key components of Knative Serving:
* **Service**: A top-level resource that defines and manages serverless workloads. You can define container images, environment variables, and scaling settings in service resources
* **Route**: Maps external network traffic to a specific Knative Service. A route can distribute incoming requests among different revisions of the same service
* **Revision**: A snapshot of a specific Knative service version. A new revision is created after every deployment which enables versioning and allows you to roll back changes
* **Configurations**: Defines the state of a service that is associated with one or more revisions
In this tutorial, deploy serverless workloads on a Vultr Kubernetes Engine (VKE) cluster with Knative Serving. You are to deploy an Express application as a serverless workload using Knative serving.
* [Deploy a Vultr Kubernetes Engine (VKE) cluster](https://docs.vultr.com/vultr-kubernetes-engine/#How_to_Deploy_a_VKE_Cluster) with at least `5` nodes
* Deploy a [Ubuntu Server](https://vultr.com/servers/ubuntu) to work as your management machine
* Using [SSH](https://docs.vultr.com/how-to-use-ssh-with-vultr-servers/), access the server as a [non-root sudo user](https://docs.vultr.com/create-a-sudo-user-on-ubuntu-best-practices/)
* Install Kubectl on your local machine to access the cluster
## Install the Knative CLI Tool
1. Download the latest Knative CLI latest release for Linux systems
        $ wget https://github.com/knative/client/releases/download/knative-v1.11.0/kn-linux-amd64
    When using a different operating system, visit the Knative CLI release page to download the latest version
1. Move the downloaded binary file to the `/usr/local/bin/` directory to enable it as a system-wide command
        $ sudo mv kn-linux-amd64 /usr/local/bin/kn
1. Make the `kn` binary file executable
        $ sudo chmod +x /usr/local/bin/kn
1. Verify the Knative CLI version
        $ kn version
        Version:      v1.11.0
        Build Date:   2023-07-27 07:42:56
        Git Revision: b7508e67
        Supported APIs:
        * Serving
         - serving.knative.dev/v1 (knative-serving v1.11.0)
        * Eventing
## Install Knative Serving
To deploy and manage serverless applications in your Vultr Kubernetes Engine (VKE) cluster, install Knative Serving as described in the steps below.
* This article uses the Knative Serving version `1.11.0`. Visit the [Knative Serving Releases page](https://github.com/knative/serving/releases/) to verify the latest version to install in your cluster.
1. Install the Knative Custom Resource Definitions (CRDs) to define and control how your serverless workload behavior in the cluster
        $ kubectl apply -f https://github.com/knative/serving/releases/download/knative-v1.11.0/serving-crds.yaml
1. Install the Knative Serving core components
        $ kubectl apply -f https://github.com/knative/serving/releases/download/knative-v1.11.0/serving-core.yaml
1. Install the Knative Kourier controller and enable its Knative integration
        $ kubectl apply -f https://github.com/knative/net-kourier/releases/download/knative-v1.11.0/kourier.yaml
    The above command installs the Kourier controller that works as a networking layer to expose Knative applications to an external network. Knative Serving also supports other networking layers such as Istio, and Contour.
1. Using Kubectl, edit the `config-network` ConfigMap and configure Knative Serving to use Kourier as the networking layer
        $ kubectl patch configmap/config-network --namespace knative-serving --type merge --patch '{"data":{"ingress-class":"kourier.ingress.networking.knative.dev"}}'
1. Wait for at least 3 minutes to provision a load balancer, then, view the external address assigned to the Kourier Controller
        $ kubectl --namespace kourier-system get service kourier
        NAME      TYPE           CLUSTER-IP       EXTERNAL-IP      PORT(S)                      AGE
        kourier   LoadBalancer   10.105.102.208   172.20.2.1     80:32638/TCP,443:31165/TCP     2m41s
1. Install the Knative Serving DNS configuration to use the default domain `sslip.io`
        $ kubectl apply -f https://github.com/knative/serving/releases/download/knative-v1.11.0/serving-default-domain.yaml
    To replace the default `sslip.io` domain, point a domain record to your load balancer IP address to access the Knative Service services
1. Verify that the Knative Serving components are active and running
        $ kubectl get pods -n knative-serving
        NAME                                      READY   STATUS      RESTARTS   AGE
        activator-5c48bb4df9-btsx2                1/1     Running     0          4m58s
        autoscaler-85b4ddb94b-hdfgx               1/1     Running     0          4m56s
        controller-575457d5c-swzr4                1/1     Running     0          4m53s
        default-domain-pl9fp                      0/1     Completed   0          87s
        net-kourier-controller-7c7f588b78-n9m8k   1/1     Running     0          4m29s
        webhook-6859dd7cbf-9764l                  1/1     Running     0          4m48s
## Deploy a Serverless Application with Knative Serving
To implement Knative Serving in your cluster, deploy a serverless application and verify access using the default domain record. They're two methods you can apply to deploy a serverless application with Knative serving, using the Knative CLI or Kubernetes manifest files. In this section, deploy an Express application using any of the methods described below.
### Deploy a Serverless Application Using Knative CLI (Recommended)
The Knative CLI interacts with Knative components installed in your cluster. The tool enables the fast deployment and management of applications in a cluster. Deploy an Express application using Knative CLI as described below.
1. Create a new `knative-app` namespace for your application
        $ kubectl create namespace knative-app
1. Using Knative CLI, deploy your Express application to the `knative-app` namespace. Replace `karnadocker/express-app` with your desired Docker image source
        $ kn service create express-service --image karnadocker/express-app --port 8080 --namespace knative-app
        Creating service 'express-service' in namespace 'knative-app':
          4.821s Configuration "express-service" is waiting for a Revision to become ready.
          4.821s Ingress has not yet been reconciled.
          4.966s Waiting for load balancer to be ready
          5.099s Ready to serve.
        Service 'express-service' created to latest revision 'express-service-00001' is available at URL:
        http://express-service.knative-app.172.20.2.1.sslip.io
1. List Knative services and verify that the application is successfully created
        $ kn service list --namespace knative-app
        NAME              URL                                                         LATEST                  AGE   CONDITIONS   READY   REASON
        express-service   http://express-service.knative-app.172.20.2.1.sslip.io   express-service-00001      27s    3 OK / 3     True
1. Describe the service to view information about the Express application
        $ kn service describe express-service --namespace knative-app
        Namespace:  knative-app
        Age:        2m
        URL:        http://express-service.knative-app.172.20.2.1.sslip.io
        Revisions:
          100%  @latest (express-service-00001) [1] (2m)
                Image:     karnadocker/express-app (pinned to 8ab6c7)
                Replicas:  0/0
        Conditions:
          OK TYPE                   AGE REASON
          ++ Ready                   1m
          ++ ConfigurationsReady     1m
          ++ RoutesReady             1m
1. View the application URL
        $ kn route list --namespace knative-app
        NAME                URL        READY
        express-service     http://express-service.knative-app.172.20.2.1.sslip.io                 True
1. Using Curl, query the application URL and verify that it displays a result
        $ curl http://express-service.knative-app.172.20.2.1.sslip.io
        Express Hello World Application!
    To further test the application status, use a web browser and visit the application URL
    To delete the application, run `kn service` with the `delete` option
        $ kn service delete express-service --namespace knative-app
### Deploy a Serverless Application Using a YAML File
You can deploy serverless applications to your cluster using YAML files. This method allows you to implement version control for your application workloads. Deploy an Express application to your cluster as described below.
1. Using a text editor such as Vim, create a new YAML resource file `knative-service.yaml`
        $ nano knative-service.yaml
1. Add the following configurations to the file. Replace `karnadocker/express-app` with your desired Docker image source
        apiVersion: serving.knative.dev/v1
          namespace: knative-app
                - image: docker.io/karnadocker/express-app
                    - containerPort: 8081
    Save and close the file
1. Apply the resource to your cluster
        $ kubectl apply -f knative-service.yaml
1. Verify that the service is available in the `knative-app` namespace
        $ kubectl get ksvc  --namespace knative-app
        NAME                      URL        LATESTCREATED                LATESTREADY                       READY   REASON
        express-service           http://express-service.knative-app.172.20.2.1.sslip.io           express-service-00001        express-service-00001        True
        knative-express-service   http://knative-express-service.knative-app.172.20.2.1.sslip.io   knative-express-service-v1   knative-express-service-v1   True
        NAME                      URL        READY
        knative-express-service   http://knative-express-service.knative-app.172.20.2.1.sslip.io   True
1. Using Curl, visit the application URL
        $ curl http://knative-express-service.knative-app.172.20.2.1.sslip.io
    The above output verifies that the application is running correctly in your cluster
## Scaling a Knative Service in Kubernetes
Knative can scale services automatically based on incoming traffic and the configured scaling policies. It uses the Knative Pod Autoscaler (KPA) to scale the number of pods automatically. When incoming traffic increases, KPA scales up by creating new pods based on the available configuration. When there is no incoming traffic, KPA scales down by deleting pods to save cluster resources.
The KPA offers many configuration options to control the autoscaling behavior as implemented in this section.
### Set Scaling Limits
Knative Serving allows you to set scaling limits for your application to control the number of pods created for a revision to handle the requests. This allows you to manage the cluster resource utilization and prevent unexpected resource consumption. You can set scaling limits using `scale-min` and `scale-max` options as described below.
1. Set your `express-service` application minimum and maximum scaling limit
        $ kn service update express-service --scale-min 1 --scale-max 20 --namespace knative-app
        Updating Service 'express-service' in namespace 'knative-app':
          1.447s Traffic is not yet migrated to the latest revision.
          1.447s Ingress has not yet been reconciled.
          1.448s Waiting for load balancer to be ready
          1.449s Ready to serve.
        Service 'express-service' updated to latest revision 'express-service-00002' is available at URL:
1. Verify the application scaling limit
        $ kn revision describe express-service-00002 --namespace knative-app
         Annotations:  autoscaling.knative.dev/max-scale=20, autoscaling.knative.dev/min-scale=1
         Age:          1m
         Image:        index.docker.io/karnadocker/express-app@sha256:8ab6c7d772bdc8f8121b88754a4b82ba5083660d2a66cd8a2c3b93d6a1c660a3 (at 8ab6c7)
         Replicas:     1/1
         Port:         8080
         Scale:        1 ... 20
         Service:      express-service
         Conditions:
           OK TYPE                  AGE REASON
           ++ Ready                  1m
           ++ ContainerHealthy       1m
           ++ ResourcesAvailable     1m
           ++ Active                 1m
    As displayed in the above output, the max scale and min scale annotations match your scaling limits
### Set Concurrency Limits
Using concurrency limits, you can control the number of concurrent requests each pod can process. When the concurrency rate exceeds the defined limit, Knative scales up the application by creating additional pods to handle the load. If the concurrency drops below the given limit, the application scales down by deleting unused pods. In this section, set the concurrency limits as described below.
To set the `express-service` application concurrency limit to `10`, update the service with the `concurrency-limit` value
    $ kn service update express-service --concurrency-limit 10 --namespace knative-app
    2.360s Traffic is not yet migrated to the latest revision.
    2.360s Ingress has not yet been reconciled.
    2.361s Waiting for load balancer to be ready
    2.420s Ready to serve.
    Service 'express-service' updated to latest revision 'express-service-00003' is available at URL:
### Verify Auto Scaling
To test auto scaling on your application, use a concurrent request tool such as [Hey](https://github.com/rakyll/hey) to send continuous requests to your application as described below.
1. Install the hey CLI tool.
        $ sudo apt install hey -y
1. View the list of running pods in the `knative-app` namespace
        $ kubectl get pods -n knative-app
        express-service-00002-deployment-6fbdc5b5b8-4nvb6   1/1     Running   0          3m39s
        express-service-00003-deployment-5776757969-l5tbk   1/1     Running   0          34m
1. Send `300` seconds of traffic while maintaining `5000` concurrent requests to your application using the following command
        $ hey -z 300s -c 5000  "http://express-service.knative-app.172.20.2.1.sslip.io?sleep=100&prime=10000&bloat=500" --namespace knative-app
1. Verify that the pods are scaling up
         express-service-00001-deployment-7dcd484688-kwnjx   2/2     Running   0          9s
         express-service-00001-deployment-7dcd484688-qst6c   2/2     Running   0          12s
         express-service-00002-deployment-6fbdc5b5b8-4nvb6   2/2     Running   0          3m39s
         express-service-00003-deployment-5776757969-l5tbk   2/2     Running   0          34m
## Route Traffic to Revisions
Each time you create or update a service, Knative creates a new revision. Route incoming traffic to revisions as described in the steps below.
1. List all `express-service` application revisions
        $ kn revision list --namespace knative-app
        NAME                         SERVICE                   TRAFFIC   TAGS   GENERATION   AGE     CONDITIONS   READY   REASON
        express-service-00003        express-service           100%             3            82s     4 OK / 4     True
        express-service-00002        express-service                            2            5m25s   3 OK / 4     True
        express-service-00001        express-service                            1            34m     3 OK / 4     True
    Verify the percentage of requests routed to specific revisions in the `TRAFFIC` column. In the above output, Knative has mapped all requests by `100%` to only the `express-service-00003` revision.
1. View detailed information about the `express-service-00003` revision
        $ kn revision describe express-service-00003 --namespace knative-app
        Age:          25s
        Replicas:     1/1
        Port:         8080
        Scale:        1 ... 20
        Concurrency:
          Limit:      10
        Conditions:
          OK TYPE                  AGE REASON
          ++ Ready                 23s
          ++ ContainerHealthy      23s
          ++ ResourcesAvailable    23s
          ++ Active                23s
1. To distribute traffic among all three service revisions, apply the `--traffic` option to update the service using the following command
        $ kn service update express-service --traffic express-service-00001=25 --traffic express-service-00002=35 --traffic express-service-00003=40 --namespace knative-app
1. Verify that the traffic is distributed among all revisions
         express-service-00003        express-service           40%              3            23m   4 OK / 4     True
         express-service-00002        express-service           35%              2            27m   4 OK / 4     True
         express-service-00001        express-service           25%              1            56m   3 OK / 4     True
    Verify the traffic distribution values displayed in the `TRAFFIC` column
You have deployed a serverless application on a Vultr Kubernetes Engine (VKE) cluster. You implemented the different deployment methods and scaled the serverless application using concurrency and scaling limits. By using Knative Serving, you can streamline the process of building, deploying, and scaling serverless workloads in your cluster. For more information about Knative Service, visit the [Knative Serving documentation](https://knative.dev/docs/serving/).
