Efficient management and orchestration of containerized applications is important when working with Kubernetes clusters. Golang is a programming language for building scalable and high-performance applications. Its simplicity, efficiency, and strong concurrency support make it ideal for developing microservices and containerized applications. By harnessing the power of Kubernetes clusters, Golang applications run optimally efficiently, with scalability and resilience in a production environment.
This article explains how to deploy a Golang containerized application on a Vultr Kubernetes Engine (VKE) engine. To efficiently manage the application, you will containerize and push the image using the Vultr Container Registry.
- Deploy a Vultr Kubernetes Engine (VKE) cluster with at least three nodes.
- Deploy a Vultr OneClick Docker instance to use as the management system.
- Access the server using SSH as a non-root user with sudo privileges.
- Install and Configure Kubectl to access the cluster.
- Create a Vultr Container Registry to store Docker images.
Create a Golang Application
Install the latest Golang package
console$ sudo apt install golang
Create a new directory to store your application files.
console$ mkdir app
Switch to the new directory.
console$ cd app
Create a Golang main application file using a text editor such as Nano.
console$ nano main.go
gopackage main import ( "fmt" "net/http" ) func homePage(w http.ResponseWriter, r *http.Request) { fmt.Fprintf(w, "This is my Go App!") } func setupRoutes() { http.HandleFunc("/", homePage) } func main() { fmt.Println("Go Web App Started on Port 8000") setupRoutes() http.ListenAndServe(":8000", nil) }
The above application code performs the following functions:
import
: Imports thefmt
package for formatting and printing, and thenet/http
package to handle HTTP requests and responses.func homePage
: Defines a new HTTP handler. It takes two parameters:w
, which is anhttp.ResponseWriter
used to write the response, andr
, which is anhttp.Request
that contains information about the incoming request. In this case, it writes the stringThis is my Go App!
to the response writer.func setupRoutes
: Sets up the application's routes. In the application, it associates the root("/")
path with thehomePage
handler function.fmt.Println("Go Web App Started on Port 8000")
: Prints a message to the console indicating that the Go web application has started.setupRoutes()
: Calls thesetupRoutes
function to configure the application's routes.http.ListenAndServe(":8000", nil)
: Starts the HTTP server that actively listens for connections on the defined port8000
. The second parameter,nil
, specifies that the default server is used. This function blocks interferences and allows the HTTP server to continue running until an error occurs or the program is manually terminated.
Run the Golang application as a background task.
console$ go run main.go &
Using the Curl utility, test access to your server port
8000
to verify that the application runs correctly.console$ curl 127.0.0.1:8000
This is my Go App!
View the Golang application Job ID.
console$ jobs
Kill the application Job ID to stop the background process. For example, Job ID
1
console$ kill %1
Build the Golang Application Image
Create a Dockerfile within the application directory.
console$ nano Dockerfile
dockerfile# Latest golang image on apline linux FROM golang:1.12.0-alpine3.9 # Work directory RUN mkdir /app ADD . /app WORKDIR /app # Installing dependencies RUN go build -o main . # Starting our application CMD ["/app/main"]
The above Docker file configuration includes the following key components:
: Specifies the application image to use the official Golang image version1.12.0
based on Alpine Linux version3.9
to keep the overall image size small.RUN mkdir /app
: Creates a new directory named/app
in the Docker image to use as the working directory for subsequent commands.ADD . /app
: Copies the contents of the local application directory to the image/app
directory.WORKDIR /app
: Sets the working directory to/app
.RUN go build -o main .
: Runs thego build
command to compile the Go application. The-o
main flag specifies that the compiled binary should be namedmain
. The.
at the end of the command instructs the compiler to run the source code from the current directory.CMD ["/app/main"]
: Sets the command that executes when a container based on this image runs./app/main
specifies the path to the executable binary within the/app
directory.
Build the Docker image.
console$ docker build -t go-app .
When successful, view the created image and its size.
console$ docker images
REPOSITORY TAG IMAGE ID CREATED SIZE go-app latest 149ea0f60676 About a minute ago 355MB golang 1.12.0-alpine3.9 2205a315f9c7 4 years ago 347MB
Start a new container to test the image locally using Docker.
console$ docker run -dit -p 8000:8000 go-app:latest
View the list of running Docker containers to verify that the new container is running correctly on port
8080
.console$ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES 59b3a6a67bf5 go-app:latest "/app/main" 22 seconds ago Up 21 seconds 0.0.0.0:8000->8000/tcp, :::8000->8000/tcp beautiful_panini
Push Docker Image to Vultr Container Registry
To use your Golang container image in a Vultr Kubernetes Engine (VKE) cluster, push it to your Vultr Container Registry as described in the steps below.
Log in to the Vultr Container Registry using your repository username and password.
console$ docker login https://sjc.vultrcr.com/golangregistry -u vcr-user -p vcr-password
Replace
golangregistry
,vcr-user
andvcr-password
with your actual values displayed in the registry overview section.Tag the Docker Image with your Vultr Container Registry repository path.
console$ docker tag go-app:latest sjc.vultrcr.com/golangregistry/go-app:latest
View the list of Docker Images available on your server.
REPOSITORY TAG IMAGE ID CREATED SIZE go-app latest 149ea0f60676 7 minutes ago 355MB sjc.vultrcr.com/golangregistry/go-app latest 149ea0f60676 7 minutes ago 355MB
In the above output, two container images are listed. This means you can push the tagged
image to your Vultr Container Registry.Push your
go-app
Docker image to the Vultr Container Registry.console$ docker push sjc.vultrcr.com/golangregistry/go-app:latest
Deploy the Golang Application to your VKE Cluster
Create a new deployment resource file
deployment.yaml
.console$ nano deployment.yaml
yamlkind: Deployment apiVersion: apps/v1 metadata: name: go-app spec: replicas: 2 selector: matchLabels: app: go-app template: metadata: labels: app: go-app spec: containers: - name: go-app image: sjc.vultrcr.com/golangregistry/go-app:latest ports: - containerPort: 8000
Below is what the above Deployment resource directives represent:
: Sets the name of the deployment togo-app
.spec
: Describes the desired state of the deployment.replicas: 2
: Sets the number of replica Pods to2
.selector
: Defines how the deployment identifies the Pods to manage. In the configuration, it uses labels to match Pods with the labelapp: go-app
.template
: Describes the Pod template used to create new Pods managed by the Deployment.spec
: Specifies the specification of the Pods created from this template.containers
: Describes the containers within the Pod.name: go-app
: Sets the name of the container togo-app
.image: sjc.vultrcr.com/golangregistry/go-app:latest
: Specifies the image to use with thego-app
container,sjc.vultrcr.com/golangregistry/go-app
uses the latest image that uses thelatest
tag.ports
: Specifies the ports exposed by the container.
Apply the deployment to your cluster.
console$ kubectl apply -f deployment.yaml
View the deployment status and verify that it's available.
console$ kubectl get deployment
NAME READY UP-TO-DATE AVAILABLE AGE go-app 2/2 2 2 40s
Verify the pods created by your deployment.
console$ kubectl get pods
NAME READY STATUS RESTARTS AGE go-app-67b879b97-6zkxd 1/1 Running 0 37s go-app-67b879b97-vbq2r 1/1 Running 0 37s
As displayed in the above output, the Pods follow the go-app
naming scheme specified in the Deployment configuration, for example, the first Pod name is go-app-67b879b97-6zkxd
View the running Pod logs to verify the container output.
console$ kubectl logs go-app-67b879b97-6zkxd
Expose the Golang Application for External Access
After deploying your Golang application to the VKE cluster, use an Ingress Controller or create a Service resource configuration to expose your application for external access. In this case, VKE uses a linked Vultr Load Balancer resource and associates it with your cluster Service resource. This allows external users to access your application using the Load Balancer public IP Address.
Create a new Service resource file
service.yaml
.console$ nano service.yaml
yamlapiVersion: v1 kind: Service metadata: name: load-balancer labels: app: go-app spec: type: LoadBalancer ports: - port: 80 targetPort: 8000 protocol: TCP nodePort: 32000 selector: app: go-app
Below is what the above configuration values represent:
: Sets the service name toload-balancer
.type: LoadBalancer
: Specifies that the service is a Load Balancer resource. This results in the creation of a Vultr Load Balancer that forwards traffic to the target cluster resources.port: 80
: Specifies the external access port used by the service to handle connections. Incoming traffic requests on this cluster port are forwarded to the Service.targetPort: 8000
: The running Pods port to forward incoming traffic.protocol: TCP
: Specifies the protocol used for the Service, in this case, TCP.nodePort: 32000
: Specifies the node port for the Service. NodePort is a way to expose the Service on each node's IP at the specified port.selector
: Defines how the Service discovers the Pods to target and forward traffic. In this case, it targets Pods with the labelapp: go-app
Apply the configuration to your cluster.
console$ kubectl apply -f service.yaml
Wait for at least
3
minutes and view the cluster service resources to verify the new Load Balancer external IP address.console$ kubectl get svc
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE go-app LoadBalancer 10.108.248.240 192.168.0.11 80:32000/TCP 3m38s kubernetes ClusterIP 10.96.0.1 <none> 443/TCP 6m20s
Using a web browser such as Chrome, visit your Load Balancer IP to access your Golang application. Replace the example IP
192.168.0.11
with your actual Load Balancer external IP address.http://192.168.0.11
You have explored the end-to-end process of deploying a Golang application to a Vultr Kubernetes Engine cluster. Each step is important for a successful deployment allowing you to build containerized production applications you can push to the Vultr Container Registry for deployment in your cluster.
