title: How to Backup and Restore PostgreSQL Databases Using pg_dump and pg_restore
url: https://docs.vultr.com/how-to-backup-and-restore-postgresql-databases-using-pgdump-and-pgrestore
description: Learn how to securely backup and restore PostgreSQL databases using pg_dump and pg_restore commands with step-by-step instructions for data protection.
publish_date: 2023-01-03T00:00:00Z
last_updated: 2025-05-28T18:29:21.016424Z
author: Humphrey Mpairwe
header_image: https://docs.vultr.com/public/doc-assets/1506/cad849d7796767e0.png
`pg_dump` is a PostgreSQL backup utility that allows database administrators to export databases in various forms, including full, copy, incremental, and differential backups. Alongside `pg_dumpall`, this tool can export one or multiple databases in a single command, saving the output as a SQL script such as `.sql`, `.dump`, or as an archive file such as `.tar`, `.tgz`. These backups can be used to migrate databases between servers, recover from failures, or create point-in-time snapshots for development and testing.
This article explains how to back up PostgreSQL databases using `pg_dump` and `pg_dumpall`, and how to restore them using the `pg_restore` tool on a local or remote PostgreSQL server.
* Have access to an existing PostgreSQL server.
## Install PostgreSQL Client
In this section, you will install the PostgreSQL client, which includes essential command-line tools such as `pg_dump` and `pg_restore` used for backing up and restoring PostgreSQL databases. These tools allow you to interact with remote or local PostgreSQL servers, export data in various formats, and perform database migrations or recovery tasks efficiently.
???+ note "Install PostgreSQL Client on Ubuntu and Debian"
    Follow the steps below to install the PostgreSQL client on APT-based systems such as Ubuntu and Debian:
    1. Update the APT package index.
        $ sudo apt install -y postgresql-client
    1. Install the PostgreSQL client.
??? note "Install PostgreSQL Client on Rocky Linux and AlmaLinux"
    Run the following command to install the PostgreSQL client on RPM-based distributions like Rocky Linux and AlmaLinux:
    $ sudo dnf install -y postgresql
??? note "Install PostgreSQL Client on Windows"
    Visit the [PostgreSQL download page](https://www.postgresql.org/download/windows) and download the latest PostgreSQL client compatible with your Windows system. The installer includes `pg_dump`, `pg_restore`, and other command-line tools.
## Backup the PostgreSQL Database
You can use the `pg_dump` and `pg_dumpall` utilities to create backups of individual databases or all databases on a PostgreSQL server. Below is the general syntax for `pg_dump`:
pg_dump <options> --host=<database-server-host> --port=<port> --username=<user> --dbname=<database-name> -f <database-name>.dump
1. To back up a specific PostgreSQL database, use the following command. Replace the placeholder values as needed.
    $ pg_dump -Fd -v --host=db.example.com --port=5432 --username=db_user --dbname=example_db -f example_db.dump
    In the above command:
    * `-Fd`: Specifies the directory format for the output (you can use -Fc for a compressed custom format).
    * `-v`: Enables verbose output.
    * `-f`: Specifies the output file or directory.
1. To back up all databases on the PostgreSQL server, use the `pg_dumpall` utility.
    $ pg_dumpall -v --host=db.example.com --port=5432 --username=db_user > full-backup.sql
    >[!NOTE]
    > `pg_dumpall` only supports plain SQL format. For custom formats or parallel dumps, use `pg_dump` individually per database.
1. After the backup completes, verify that the backup file or directory exists in your working location.
    $ ls
## Restore the PostgreSQL Database
You can use `pg_restore` or `psql` to restore PostgreSQL database backups, depending on the format of your backup. Below is the general syntax for `pg_restore`.
pg_restore --host=<database-server-host> --port=<port> --username=<user> --dbname=<database-name> <database-name>.dump
1. Connect to your PostgreSQL server using the `psql` client.
    $ psql --host=db.example.com --port=5432 --username=db_user --dbname=postgres
1. Create a new target database with the same name as the source database.
    ```psql
    postgres=# CREATE DATABASE example_db;
    >[!NOTE]
    > If you're restoring a single database backup, you must manually create the target database before running `pg_restore`. For full backups using `pg_dumpall`, this step is not necessary as all databases are recreated automatically.
1. Exit the PostgreSQL prompt.
    ```psql
    postgres=# \q
1. Restore a single database using `pg_restore`.
    $ pg_restore --host=db.example.com --port=5432 --username=db_user --dbname=example_db backup.dump
1. To restore all the databases from a `pg_dumpall` full backup, use the `psql` utility.
    $ psql --host=db.example.com --port=5432 --username=db_user -f full-backup.sql
    In this above command:
    * `-f`: Specifies the SQL file to restore.
    * `--username`: A superuser is typically required to restore roles and permissions.
    * This command restores all databases and roles as they existed during the backup.
    >[!NOTE]
    > Ensure the target PostgreSQL database server is empty or does not contain conflicting roles or databases before restoring a `pg_dumpall` backup.
1. After the database restoration is complete, connect to the PostgreSQL server and switch to the restored database to verify the restoration.
    ```psql
    postgres=# \c example_db
1. List all the tables to confirm that the restoration is completed.
    ```psql
    postgres=# \dt
1. Verify that table data is available.
    ```psql
    postgres=# SELECT * FROM app_users;
    Replace `app_users` with the table name present in your database.
1. Exit the PostgreSQL client.
    ```psql
    postgres=# \q
In this article, you learned how to back up and restore PostgreSQL databases using the `pg_dump`, `pg_dumpall`, and `pg_restore` utilities. These tools offer a reliable way to export individual databases or entire PostgreSQL clusters for migration, testing, or disaster recovery. You installed the PostgreSQL client, performed single and full database backups, and restored data on a target server using both custom and plain SQL formats. For advanced backup strategies, refer to the official [PostgreSQL Documentation](https://www.postgresql.org/docs/current/backup.html).
