title: How to Build ML Web Apps using Gradio
url: https://docs.vultr.com/how-to-build-ml-web-apps-using-gradio
description: Learn how to create interactive machine learning web applications with Gradio. This step-by-step guide covers everything from basic setup to deployment.
publish_date: 2023-10-16T00:00:00Z
last_updated: 2026-01-31T18:30:00Z
author: Ashish Kumar Panda
header_image: https://docs.vultr.com/public/doc-assets/1638/c23c3a88254d09a0.png
Gradio is a Python package that allows developers to create customizable and interactive interfaces for Machine Learning models. Deployed as a web application, Gradio allows you to build a production-ready application on top of your machine learning model and avail to Internet users using your Server IP address or domain name.
This article explains how to build machine learning web applications using Gradio. You will create a Gradio interface, integrate a working machine learning model into the web application interface, and implement additional interface features using a Vultr Cloud Server.
* Deploy a [Ubuntu A100 Cloud GPU server](https://www.vultr.com/servers/ubuntu/).
* [Using SSH, access the server](https://docs.vultr.com/how-to-use-ssh-with-vultr-servers/)
* Create a non-root user with sudo privileges. For example `gradio_user`
* Switch to the sudo user account
        # su gradio_user
## Create the Gradio Interface
To build a new interface, install Gradio on the server, and set up your application as described in the steps below.
1. Using the Python `pip` package manager, install the Gradio package
        $ pip3 install gradio
1. Using a text editor such as `Nano`, create a new Python file `app.py`
        $ nano app.py
1. Add the following code to the file
        import gradio as gr
        def test(name):
            return "Hi " + name + "! Welcome to the App"
        interface = gr.Interface(fn=test, inputs= gr.Textbox(), outputs= gr.Textbox())
        interface.launch(server_name="0.0.0.0", server_port=8080)
    Save and close the file
    Below is what the application code does:
    * `import`: Imports the installed Gradio package
    * `def test(name)`: Defines a function `test()` with one parameter `name` which consists of a name given as an input to the function by the user
    * `interface`: Defines the function interface which includes:
        * `gr.Interface`: A Gradio library class used to define and configure user interfaces
        * `fn = test`: Passes the defined function `test()`. The function can consist of the machine learning model, takes inputs and produces outputs
        * `inputs`: Specifies the input type the user adds to the `test()` function. It's set to `gr.Textbox()` which means the input data is text
        * `outputs="text"`: Specifies the type of output returned by the `test()` function. It's set to `gr.Textbox()` which means the output is text data
    * `interface.launch()`: Specifies the Gradio interface launch platforms with the following variables:
        * `server_name`: Specifies Gradio listening interface. When set to `0.0.0.0`, Gradio accepts incoming connections from all Server IP Addresses. Set the value to `127.0.0.1` when using a reverse proxy such as Nginx
        * `server_port`: Set the Gradio port `8080`
1. To accept incoming connections to the Gradio interface, allow the listening port `8080` through the UFW firewall
        $ sudo ufw allow 8080
1. Restart the firewall to save changes
        $ sudo ufw reload
1. Using Python, run the Gradio application file
        $ python3 app.py
    When successful, your output should look like the one below:
        Running on local URL:  http://0.0.0.0:8080
1. Using a web browser such as Firefox, visit your public Server IP Address on port `8080`
        http://SERVER-IP:8080
    ![Sample Image](https://docs.vultr.com/public/doc-assets/1638/b8cd40e27059e60c.png)
    Verify that the Gradio web application loads successfully. Then, enter your name in the **name** field and click **Submit** to view the output. In your terminal session, press :key_ctrl: + :key_c: to stop the application.
## Example: Build an Image Restoration Web Application using Gradio
To leverage the power of your Gradio web application, build and integrate the [GFPGAN model](https://docs.vultr.com/ai-face-restoration-using-gfpgan-on-vultr-cloud-gpu/) to perform image restoration tasks with the ability to upscale any low-resolution image as described below.
1. Using `pip`, install the latest PyTorch package
        $ pip3 install torch torchvision --index-url https://download.pytorch.org/whl/cu118
1. Install GFPGAN and the model dependency packages
        $ pip3 install realesrgan gfpgan basicsr
1. Create a new Python application file `model.py`
        $ nano model.py
        import gradio as gr
        from gfpgan import GFPGANer
        from basicsr.archs.rrdbnet_arch import RRDBNet
        from realesrgan import RealESRGANer
        import numpy as np
        import cv2
        import requests
        def enhance_image(input_image):
            arch = 'clean'
            model_name = 'GFPGANv1.4'
            gfpgan_checkpoint = 'https://github.com/TencentARC/GFPGAN/releases/download/v1.3.4/GFPGANv1.4.pth'
            realersgan_checkpoint = 'https://github.com/xinntao/Real-ESRGAN/releases/download/v0.2.1/RealESRGAN_x2plus.pth'
            rrdbnet = RRDBNet(num_in_ch=3, num_out_ch=3, num_feat=64, num_block=23, num_grow_ch=32, scale=2)
            bg_upsampler = RealESRGANer(
                scale=2,
                model_path=realersgan_checkpoint,
                model=rrdbnet,
                tile=400,
                tile_pad=10,
                pre_pad=0,
                half=True
            restorer = GFPGANer(
                model_path=gfpgan_checkpoint,
                upscale=2,
                arch=arch,
                channel_multiplier=2,
                bg_upsampler=bg_upsampler
            input_image = input_image.astype(np.uint8)
            cropped_faces, restored_faces, restored_img = restorer.enhance(input_image)
            return restored_faces[0], restored_img
            fn=enhance_image,
            inputs=gr.Image(),
            outputs=[gr.Image(), gr.Image()],
            live=True,
            title="Face Enhancement with GFPGAN",
            description="Upload an image of a face and see it enhanced using GFPGAN. Two outputs will be displayed: restored_faces and restored_img."
    Below is what the above code does:
    * `import`: Imports all the model-specific libraries
    * `def enhance_image()`: Stores the model checkpoints and enables the following functions:
        * `restorer`: Stores the image enhancement model parameters
        * `bg_upsampler`: Handles background enhancement model parameters
        * `input_image`: Handles image preprocessing
        * `arch`: When set to `clean`, it uses the clean version without the StyleGAN2-specific compiled CUDA extensions
        * `model_name`, `gfpgan_checkpoint`, `realersgan_checkpoint`: Consists of the URL that points to the checkpoints
        * `bg_upsampler`: Enables background enhancement
        * `restorer`: Allows face enhancement
        * `input_image`: Converts the input data type array to `numpy.uint8`
        * `restorer.enhance(input_image)`: Stores three input types, a cropped image, restored face, and the restored image
        * `return`: Returns the two array variable as Gradio output
    * `interface`: Specifies the variable that stores the `gr.Interface()` function and its parameters including:
        * `fn`: Sets the function name Gradio needs to process. In this case, `enhance_image`
        * `inputs`: Specifies that the input type is an image.
        * `outputs`: Specifies that the output type is an image. Two `gr.Image()` functions return two images, a restored face and the restored image.
        * `live`: Specifies that when an input image loads, it immediately processes the output without the need to click a **Submit** button.
        * `title`: Sets the interface heading
        * `description`: Sets the interface description that appears below the title
    * `interface.launch(server_name="0.0.0.0", server_port=8080)`: Specifies the compilation of the interface and sets the launch code
2. Run the Python application file
        $ python3 model.py
3. In a new web browser window, access the Gradio web application interface
        https://SERVER-IP:8080
    ![Sample Image](https://docs.vultr.com/public/doc-assets/1638/89304e0fb56985bf.png)
    Verify that you can upload an input image and two restored images display in your output.
## Customize the Gradio Interface
The example web application in this article uses the `image` Gradio type to generate the interface. To customize your application, you can implement any of the following supported Gradio input and output functions:
* Text: `gr.Textbox()`
* Audio: `gr.Audio()`
* Video: `gr.Video()`
* Image: `gr.Image()`
For example, to implement `Text` input and output type, apply the function to your respective interface as below:
        fn=FUNCTION_NAME,  # Your Desired Function Name
        inputs=gr.Textbox(),
        outputs=gr.Textbox()
To implement more than one function in a single interface, set your interface to the following
        inputs=[gr.Image(), gr.Audio()],
        outputs=[gr.Video(), gr.Textbox()]
Depending on your model requirements, you can change the `inputs` and `outputs` types. Before implementing a function, verify if it's available for either input or output. For more input and output types, visit the [Gradio Interface documentation](https://www.gradio.app/docs/interface).
In this article, you installed Gradio and created a sample image restoration application on a Vultr Cloud GPU server. You can customize your Gradio interface with more models, and server the web application using your domain name by integrating a reverse proxy such as Nginx for public access. To implement login functionality, [visit the Gradio login button documentation page](https://www.gradio.app/docs/loginbutton).
## More Information
* [Gradio Quickstart Guide](https://www.gradio.app/guides/quickstart)
* [Gradio Additional Parameter Guide](https://www.gradio.app/guides/key-features#progress-bars)
* [Gradio Supported Input and Output Types](https://www.gradio.app/docs/interface)
* [AI Face Restoration using GFPGAN on Vultr Cloud GPU](https://docs.vultr.com/ai-face-restoration-using-gfpgan-on-vultr-cloud-gpu/)
* [How to Configure Apache as a Reverse Proxy with mod_proxy](https://docs.vultr.com/how-to-configure-apache-as-a-reverse-proxy-with-mod-proxy-54152/)
