Bidirectional Encoder Representations from Transformers (BERT) is a pre-trained Natural Language Processing Model (NLP) used to understand and generate human language text. Its bidirectional approach allows it to capture the meaning of words more comprehensively. NVIDIA GPU Cloud (NGC) offers a variety of GPU-accelerated containers that take maximum advantage of NVIDIA GPUs and come pre-installed with GPU drivers, libraries, and frameworks that improve development efficiency.
This article explains how to use the NGC PyTorch container with the BERT model to make a movie recommendation system by generating embeddings on a Vultr Cloud GPU Server.
Install and run the PyTorch GPU container
The above command installs and runs the GPU-accelerated docker container with the following options:
--gpus all: Allocates all available host GPUs to the container, this makes sure that all GPU resources handle GPU-accelerated tasks-p 9000:8888: Maps the host port 9000 to the container port 8888.--it: Run the container in interactive modeWhen successful, verify that you can access the container root shell:
To run the BERT model on your Cloud GPU server, initialize the BERT model. Then, import the necessary modules, prepare the movie data and user data, create embeddings, and calculate similarity scores to retrieve the top movie suggestions based on user preferences as described in the steps below.
Access your Jupyter Notebook web interface
In the middle top right corner, click the New dropdown to reveal a list of options
Click Notebook, and select Python 3 (ipykernel) to open a new file
Within the new Notebook file, install transformers dependency package
The above command installs transformers package that simplifies the process of working with NLP models.
Click Run or press Ctrl + Enter to run the code cell
Import the necessary modules
The above command imports the following modules:
BertTokenizer for tokenizationBertModel for inferencenumpy for mathematical calculationsInitialize the model
The above command initializes the bert-base-uncased model and its tokenizer
Prepare the movies data
The above command prepares a dataset of movies along with the genres the movies belong to. You can add as many movies as you require and genre tags for a particular movie to match your needs.
Prepare the user profiles
The above command creates three user profiles along with preferences for each user. This assists the model in matching which movies are best suitable to suggest by calculating the similarity of the embeddings you created earlier.
Encode the movie names
The above command processes each movie name through a tokenizer to represent it numerically. Then, it stores the numerical data in a list of encoded movie names encoded_data.
Generate embeddings from the encoded data
The above command processes each encoded movie name through a PyTorch model for computing average embeddings and stores them in the embeddings list. The list is then used in the similarity calculations.
Calculate the similarity score
The above command defines a genre_similarity function that calculates the similarity score between a user's genre preference and a movie's genre. The score represents the overlap between a user's preference and the movie genres.
Select the user
The above command sets a condition that prompts you to enter the user's name you want to retrieve the movie recommendations.
Generate movie recommendations
The above command generates movie recommendations for the specified user based on the similarity between the user's genre preference and the genre for each movie. Then, all the recommendations get stored in the recommendations list.
Print the results
The above command sorts the movie recommendations in an ascending list based on similarity scores. Then it prompts you to enter the number of recommendations you want and prints the top_n number of movies along with similarity scores.
You have built a BERT-based movie recommendation system on a Vultr Cloud GPU server. You created the system using embeddings and calculating similarity scores between different movie genres and user preferences within the PyTorch NGC GPU accelerated container. For more information, visit the following documentation resources:
