Modern serverless platforms demand fast startup times, low resource overhead, and efficient concurrency. Kotlin, with its modern syntax and coroutine-based concurrency, and Ktor, its lightweight asynchronous web framework, provide an ideal combination for building high-performance serverless APIs.
This article demonstrates how to build a Product Catalog CRUD API using Kotlin and Ktor. You’ll learn how to structure a coroutine-driven application, handle concurrent requests efficiently, and package it for deployment across cloud providers in fully serverless or containerized environments.
Before you begin,
./gradlew). Installing Gradle system-wide is optional.Verify Java and Gradle.
Generate a new project at start.ktor.io with:
io.demoproduct-apiio.demo.productcatalogUnpack and open the project.
Run the template to confirm the toolchain.
In another terminal:
Ensure JSON serialization is enabled (add if missing).
Wire the plugin in the application.
Ktor uses non-blocking I/O and Kotlin coroutines to handle high concurrency with low memory overhead, ideal for short-lived, autoscaled serverless workloads.
call or application scope) to avoid leaks across requests.Dispatchers.Default/custom pools.Build a Product Catalog CRUD API to demonstrate routing, JSON serialization, and coroutine-friendly data access.
Create the project structure.
Create the model file at src/main/kotlin/io/demo/productcatalog/model/Product.kt and add the following code.
Create the in-memory repository file (simulated async) at src/main/kotlin/io/demo/productcatalog/repository/ProductRepository.kt and add the following code.
Create the routing configuration file at src/main/kotlin/io/demo/productcatalog/Routing.kt and add the following code.
Edit the application file and the following module configuration in src/main/kotlin/io/demo/productcatalog/Application.kt.
This enables JSON serialization and registers the routing configuration
Run the application using Gradle.
Verify the base routes.
Ktor serves each request on a lightweight coroutine, so a handful of threads can handle heavy concurrency. Tune the app to stay non-blocking, predictable, and fast.
Keep handlers non-blocking. Use withContext(Dispatchers.IO) for blocking work (file I/O, JDBC) so you don’t stall the event loop.
Use structured concurrency in routes. Launch child coroutines in a scope and await() them together. If one fails, Ktor cancels siblings and the request.
Right-size dispatchers (only when needed). Let Ktor manage event loops. If you must isolate heavy I/O/CPU work, bound the pool and close it on shutdown.
Remove artificial delays in production. Replace delay() in repositories with real async I/O (database, HTTP client).
Add low-cost server features. Compression, caching headers, and request timeouts improve latency and protect the app.
Connect to databases and APIs with suspendable, time-bounded calls. Add retries sparingly, log context, and protect upstreams.
Configure a resilient Ktor HTTP client with JSON, timeouts, and limited retries.
Add client dependencies to your build file.
Close the shared client on shutdown to prevent resource leaks.
Inject the client and base URL for testability. Example with a repository and a MockEngine-based test setup:
Call the client from a repository; keep functions suspend, add per-call timeouts if a dependency is flaky.
Per-call timeout override:
If an upstream often times out, short-circuit for a brief window. Keep it simple without extra libs.
withContext(Dispatchers.IO). Keep pools small but sufficient.X-Request-ID header.Ship a portable artifact, run it the same way everywhere, and expose health/metrics for hands-off ops.
Serverless/container platforms don’t resolve Gradle deps, so build a fat JAR.
Add the following content in libs.versions.toml.
Add the following content in build.gradle.kts.
Build & smoke-test locally.
Configure the application port and external services in resources/application.yaml.
This configuration allows the application to bind to a dynamic port provided by the cloud platform and defines an external service base URL through environment variables.
Add lightweight ops features.
These changes make the application suitable for cloud platforms by supporting dynamic port binding, health probes for orchestration systems, request logging, response compression, and graceful request timeouts.
Structured logs:
Prometheus metrics:
wrk/k6 to tune timeouts, thread pools, and memory.In this article, you built a lightweight Product Catalog CRUD API with Kotlin and Ktor, validated it locally, and packaged it as a portable shadow JAR for serverless or container platforms. You leveraged coroutines and non-blocking I/O to handle concurrent load efficiently with a small runtime footprint. Next steps include adding authentication/authorization, persisting data with an async-friendly driver, integrating external services, and wiring metrics and tracing for production readiness.
