title: How to Deploy a Next.js Application with Vultr Kubernetes Engine and Vultr Load Balancer
url: https://docs.vultr.com/how-to-deploy-a-next-js-application-with-vultr-kubernetes-engine-and-vultr-load-balancer
description: Learn how to deploy a Next.js application using Vultr Kubernetes Engine and Vultr Load Balancer with our step-by-step guide for optimal performance.
publish_date: 2022-09-23T00:00:00Z
author: Quan Hua Hong
header_image: https://docs.vultr.com/public/doc-assets/1220/2a2cae0ff2f62565.png
Next.js is a popular React framework for developing static websites and modern web applications. Next.js application usually deploys to a serverless platform. However, there are some scenarios that you want to deploy to your controlled server and scale it in your infrastructure. This tutorial explains how to deploy a full-stack Next.js application to Vultr Kubernetes Engine. The example application is built with Next.js and uses Prisma to connect with a MySQL database.
Here are a few advantages of this approach:
* Deploy the Next.js application as close as possible to the database.
* Avoid the cold-starts problem in the serverless approach.
* Predictable pricing of cloud servers and bandwidth compared to serverless platforms.
There are three separated parts in this tutorial:
* Part 1: Build and push the Docker image to Docker Hub Image Registry
* Part 2: Deploy and scale the Next.js application with Vultr Kubernetes Engine
* Part 3: Expose the Next.js application with secure SSL certificates
* Have an external MySQL Database
* Deploy a [Vultr Kubernetes Cluster](https://console.vultr.com/kubernetes/) with at least 3 nodes.
* Configure `kubectl` and `git` in your machine.
* Install Docker on your machine
* Register a Docker Hub account to store the Docker Image
## Part 1 - Build and push the Docker image to Docker Hub Image Registry
The Next.js application used in this tutorial is a full-stack application called `next-short-urls`. The source code for this application can be found at [this repository](https://github.com/quanhua92/next-short-urls). Vultr has also [archived the repo here](https://www.vultr.com/vultr-docs-graphics/6994/next-short-urls-main.zip).
This is a simple URL Shortener built with Next.js, TypeScript, and Prisma. Prisma is an open-source ORM that helps you build and manage the MySQL database.
1. Clone the source code of the example application:
        $ git clone -b v1.10.0 https://github.com/quanhua92/next-short-urls
1. Prepare a `.env` file environment with the below content. This `.env` file is used in the building stage of the Docker image to generate static pages. The final production Docker image does not contain in this file.
        DATABASE_URL="DATABASE_URL_HERE"
        SECRET_COOKIE_PASSWORD="SOME_SECRET_PASSWORD_WITH_MIN_LENGTH_32"
        AWAIT_HISTORY_UPDATE="0"
    Here is a brief explanation of the content of `.env` file:
    * `DATABASE_URL` is a database connection string started with `mysql://`
    * `SECRET_COOKIE_PASSWORD` is an application specified password with a minimum length of 32
    * `AWAIT_HISTORY_UPDATE` is an environment variable that the application needs.
1. Make sure that the `DockerFile` file contains the below content. This is a multi-stage DockerFile with `deps`, `builder` and `runner` stages.
        # Install dependencies only when needed
        FROM node:16-alpine AS deps
        # Check https://github.com/nodejs/docker-node/tree/b4117f9333da4138b03a546ec926ef50a31506c3#nodealpine to understand why libc6-compat might be needed.
        RUN apk add --no-cache libc6-compat
        WORKDIR /app
        COPY package.json yarn.lock ./
        RUN yarn install --frozen-lockfile
        # If using npm with a `package-lock.json` comment out above and use below instead
        # COPY package.json package-lock.json / 
        # RUN npm install
        # Rebuild the source code only when needed
        FROM node:16-alpine AS builder
        WORKDIR /app
        COPY --from=deps /app/node_modules ./node_modules
        COPY . .
        # generate the prisma type
        RUN npx prisma generate
        RUN yarn build && yarn install --production --ignore-scripts --prefer-offline
        # Production image, copy all the files and run next
        FROM node:16-alpine AS runner
        WORKDIR /app
        ENV NODE_ENV production
        RUN addgroup -g 1001 -S nodejs
        RUN adduser -S nextjs -u 1001
        # Prepare the cache folder for next/image
        RUN mkdir -p /app/.next/cache/images && chown nextjs:nodejs /app/.next/cache/images
        VOLUME /app/.next/cache/images
        # You only need to copy next.config.js if you are NOT using the default configuration
        COPY --from=builder /app/next.config.js ./
        COPY --from=builder /app/public ./public
        COPY --from=builder --chown=nextjs:nodejs /app/.next ./.next
        COPY --from=builder /app/package.json ./package.json
        COPY --from=builder /app/node_modules ./node_modules
        USER nextjs
        EXPOSE 3000
        ENV PORT 3000
        # Next.js collects completely anonymous telemetry data about general usage.
        # Learn more here: https://nextjs.org/telemetry
        # Uncomment the following line in case you want to disable telemetry.
        # ENV NEXT_TELEMETRY_DISABLED 1
        CMD ["node_modules/.bin/next", "start"]
    Here are some configurations that are specified to the `next-short-urls`  application. In the builder stage, `RUN npx prisma generate` to generate the types from the Prisma schema. In the runner stage, make a folder `/app/.next/cache/images` and prepare the folder permission. This is used for the Automatic Image Optimization feature in Next.js.
1. Build the Docker Image
        $ docker build . -t next-short-urls
1. Login to Docker Hub
        $ docker login
1. Tag the Docker Image with your Docker Hub ID and Push to Docker Hub. Replace `<YOUR_DOCKER_HUB_ID>` with your Docker Hub account id.
        $ docker tag next-short-urls <YOUR_DOCKER_HUB_ID>/next-short-urls:latest
        $ docker push <YOUR_DOCKER_HUB_ID>/next-short-urls:latest
1. Run Docker local to verify the docker image. Navigate to [http://localhost:3000](http://localhost:3000) to access the application
        $ docker run --rm -p 3000:3000 <YOUR_DOCKER_HUB_ID>/next-short-urls
1. (Optional) Go to your Docker Hub dashboard and make sure that your image is private.
## Part 2 - Deploy and scale the Next.js application with Vultr Kubernetes Engine
In this part, you will create a secret that contains your Docker Hub credentials and create a Deployment to deploy some pods that run your Next.js application.
1. Create Docker Hub secret named `regcred`. Replace parameters in the command with your Docker Hub credentials
        $ kubectl create secret docker-registry regcred \
            --docker-username=YOUR_DOCKER_HUB_USERNAME \ 
            --docker-password=YOUR_DOCKER_HUB_PASSWORD \
            --docker-email=YOUR_DOCKER_HUB_EMAIL
1. Create a Secret manifest file `secrets.yaml` with the data as the previously created `.env`.
        kind: Secret
          namespace: default
        type: Opaque
        stringData:
          DATABASE_URL: "DATABASE_URL_HERE"
          SECRET_COOKIE_PASSWORD: "SOME_SECRET_PASSWORD_WITH_MIN_LENGTH_32"
          AWAIT_HISTORY_UPDATE: "0"
1. Run the command to create the secret.
        $ kubectl apply -f secrets.yaml
1. Create a Deployment file `deployment.yaml` with the following content. Replace `<YOUR_DOCKER_HUB_ID>` with your Docker Hub account ID.
          replicas: 3
              imagePullSecrets:
                - name: regcred
                - name: next-short-urls
                  image: <YOUR_DOCKER_HUB_ID>/next-short-urls:latest
                  imagePullPolicy: Always
                    - containerPort: 3000
                  envFrom:
                  - secretRef:
            - name: http
              protocol: TCP
              targetPort: 3000
1. Run the command to create the Deployment and Service.
        $ kubectl apply -f deployment.yaml
1. Run the command `kubectl get pods` to see the newly created pods. The result should look similar to:
        NAME                                      READY   STATUS    RESTARTS   AGE
        next-short-urls-deploy-764d658d49-26b5w   1/1     Running   0          62s
        next-short-urls-deploy-764d658d49-hql7q   1/1     Running   0          62s
        next-short-urls-deploy-764d658d49-nv6tr   1/1     Running   0          62s
1. Run the command `kubectl get services` to see the newly created service. The result should look similar to:
        NAME                      TYPE        CLUSTER-IP     EXTERNAL-IP   PORT(S)   AGE
        kubernetes                ClusterIP   10.96.0.1      <none>        443/TCP   94m
        next-short-urls-service   ClusterIP   10.99.247.34   <none>        80/TCP    39s
1. Scale your application to 10 replicas using the following command.
        $ kubectl scale --replicas=10 deployment/next-short-urls-deploy
        next-short-urls-deploy-764d658d49-26b5w   1/1     Running   0          3m
        next-short-urls-deploy-764d658d49-5r25t   1/1     Running   0          25s
        next-short-urls-deploy-764d658d49-hql7q   1/1     Running   0          3m
        next-short-urls-deploy-764d658d49-j6qlf   1/1     Running   0          25s
        next-short-urls-deploy-764d658d49-lvrgp   1/1     Running   0          25s
        next-short-urls-deploy-764d658d49-nv6tr   1/1     Running   0          3m
        next-short-urls-deploy-764d658d49-vkl98   1/1     Running   0          25s
        next-short-urls-deploy-764d658d49-wkclv   1/1     Running   0          25s
        next-short-urls-deploy-764d658d49-xgzs6   1/1     Running   0          25s
        next-short-urls-deploy-764d658d49-zhcdj   1/1     Running   0          25s
1. Perform port-forwarding to access your application through the service. Navigate to [http://localhost:8080](http://localhost:8080) to access your application.
        $ kubectl port-forward services/next-short-urls-service 8080:80
You have successfully deployed the Next.js application with MySQL Database to Vultr Kubernetes Engine with 10 replicas in your cluster.
## Part 3 - Expose the Next.js application with secure SSL certificates
In this part, you will install NGINX Ingress Controller and expose your application through a domain name with secure SSL certificates.
1. Install `ingress-nginx`.
        $ kubectl apply -f https://raw.githubusercontent.com/kubernetes/ingress-nginx/controller-v1.1.1/deploy/static/provider/cloud/deploy.yaml 
1. Go to your Load Balancers dashboard at [https://console.vultr.com/loadbalancers/](https://console.vultr.com/loadbalancers/)  and get the IP Address of the newly created Load Balancer. This is the Load Balancer created for the NGINX ingress.
1. Create an A record in your domain DNS that points to the above IP address.
1. Install `cert-manager` to manage SSL certificates
        $ kubectl apply -f https://github.com/jetstack/cert-manager/releases/download/v1.7.0/cert-manager.yaml
1. Create a manifest file `letsencrypt.yaml` to handle Let's Encrypt certificates. Replace <YOUR_EMAIL> with your actual email.
        kind: ClusterIssuer
          acme:
            # The ACME server URL
            server: https://acme-staging-v02.api.letsencrypt.org/directory
            preferredChain: "ISRG Root X1"
            # Email address used for ACME registration
            email: <YOUR_EMAIL>
            # Name of a secret used to store the ACME account private key
            privateKeySecretRef:
            solvers:
              - http01:
                  ingress:
                    class: nginx
        kind: ClusterIssuer
          acme:
            server: https://acme-v02.api.letsencrypt.org/directory
            email: <YOUR_EMAIL>
            solvers:
              - http01:
                  ingress:
                    class: nginx
1. Run the command to install the above Let’s Encrypt issuers.
        $ kubectl apply -f letsencrypt.yaml
1. Create an Ingress manifest file `ingress.yaml` with the following content. Replace <YOUR_DOMAIN> with the domain that you have created A record in the above step.
        kind: Ingress
            kubernetes.io/ingress.class: nginx
            cert-manager.io/cluster-issuer: letsencrypt-prod
          tls:
            - secretName: next-short-urls-tls
              hosts:
                - <YOUR_DOMAIN>
            - host: <YOUR_DOMAIN>
              http:
                paths:
                  - path: /
                    pathType: Prefix
                    backend:
                      service:
                        port:
                          number: 80
1. Run the command to create the ingress.
        $ kubectl apply -f ingress.yaml
1. Run the command `kubectl get ingress` to see the newly created ingress. The result should look similar to:
        NAME                      CLASS    HOSTS               ADDRESS        PORTS     AGE
        next-short-urls-ingress   <none>   <YOUR_DOMAIN>      140.82.41.69   80, 443   37s
1. Navigate to `https://<YOUR_DOMAIN` to access your application.
## More Information
* [Vultr Webhook for Cert Manager](https://artifacthub.io/packages/helm/vultr/cert-manager-webhook-vultr)
* [with-docker example from Next.js](https://github.com/vercel/next.js/tree/canary/examples/with-docker)
