title: How to deploy a Self-Hosted OAuth2 Provider on Vultr Using Authentik and Docker Compose
url: https://docs.vultr.com/how-to-deploy-a-self-hosted-oauth2-provider-on-vultr-using-authentik-and-docker-compose
description: Learn how to deploy a self-hosted OAuth2 provider using Authentik and Docker Compose on Vultr. Step-by-step guide for secure identity management.
publish_date: 2025-10-29T14:56:46.524182Z
last_updated: 2025-10-29T16:11:06.036658Z
author: Ayomide olofinsawe
header_image: https://lhr1.vultrobjects.com/docs-main-doc-assets-1/2356/5c58dd7a-7b5c-4a83-aa00-394649f0399a.png
Authentik is an open-source identity provider (IdP) that implements OAuth 2.0, OpenID Connect (OIDC), and SAML. Deploying Authentik on a Vultr Cloud Compute instance gives you full control over authentication, enables single sign-on (SSO) across internal tools, and keeps user data on your own infrastructure.
In this guide, you deploy Authentik with Docker Compose, secure it behind a reverse proxy (Caddy or NGINX) with HTTPS, harden the server, and register an OAuth 2.0 client to protect a sample web application. When you finish, you’ll have a production-ready, self-hosted authentication service running on Vultr.
Before you begin,
* Have access to an [Ubuntu 24.04](https://www.vultr.com/servers/ubuntu/) server as a [non-root user with `sudo` privileges](https://docs.vultr.com/limited-user-login).
* Create a [DNS A record](https://docs.vultr.com/products/network/dns/provisioning) pointing to your server's IP address, such as `auth.example.com`. Replace all occurrences of `auth.example.com` in this guide with your actual domain.
* Install [Docker](https://docs.vultr.com/how-to-install-docker-on-ubuntu-24-04) and Docker Compose.
## Deploy Authentik Using Docker Compose
1. Create a dedicated project directory for Authentik in your home directory.
    $ mkdir ~/authentik && cd ~/authentik
1. Generate a 64-character hexadecimal secret key for Authentik.
    $ openssl rand -hex 32
    Copy the generated key for use in the next step.
1. Create a `.env` file to store the secrets.
    $ nano .env
    Add the following content in the `.env` file:
    ```ini
    # Database (mapped by the Compose file to AUTHENTIK_POSTGRESQL__*)
    PG_DB=authentik
    PG_USER=authentik
    PG_PASS=<POSTGRES_USER_PASSWORD>
    # Authentik secret key (required)
    AUTHENTIK_SECRET_KEY=<64_CHAR_SECRET_KEY>
    # Optional: Pin image tag (defaults provided in compose)
    # AUTHENTIK_TAG=2025.8.4
    # Use ip:hostport format to avoid exposing ports publicly
    COMPOSE_PORT_HTTP=127.0.0.1:9000
    COMPOSE_PORT_HTTPS=127.0.0.1:9443
    Replace `<POSTGRES_USER_PASSWORD>` and `<64_CHAR_SECRET_KEY>` with the alphanumeric password and the secret key you generated earlier, respectively.
    Save and exit the file.
1. Download the official `docker-compose.yml` manifest for Authentik.
    $ wget -O docker-compose.yml https://docs.goauthentik.io/docker-compose.yml
1. Start the stack in detached mode.
    $ sudo docker compose up -d
1. List the running services and verify that all services are healthy.
    $ sudo docker compose ps
    NAME                     IMAGE                                  COMMAND                  SERVICE      CREATED          STATUS                    PORTS
    authentik-postgresql-1   docker.io/library/postgres:16-alpine   "docker-entrypoint.s…"   postgresql   25 minutes ago   Up 25 minutes (healthy)   5432/tcp
    authentik-redis-1        docker.io/library/redis:alpine         "docker-entrypoint.s…"   redis        25 minutes ago   Up 25 minutes (healthy)   6379/tcp
    authentik-server-1       ghcr.io/goauthentik/server:2025.8.4    "dumb-init -- ak ser…"   server       25 minutes ago   Up 25 minutes (healthy)   127.0.0.1:9000->9000/tcp, 127.0.0.1:9443->9443/tcp
    authentik-worker-1       ghcr.io/goauthentik/server:2025.8.4    "dumb-init -- ak wor…"   worker       25 minutes ago   Up 25 minutes (healthy)
## Configure NGINX or Caddy with HTTPS
Ensure your domain resolves to the public IP of your Vultr instance that runs Authentik. TLS issuance will fail if DNS is wrong or ports are closed.
1. View the `ufw` status.
    $ sudo ufw status
    * If the status of `ufw` displays `inactive` then run the below command.
        $ sudo ufw enable && sudo ufw allow 22
1. Allow the required HTTP and HTTPS ports.
    $ sudo ufw allow 80
    $ sudo ufw allow 443
    $ sudo ufw status verbose
???+ note "Using Caddy Web Server"
    1. Install the Caddy web server using `apt`.
        $ sudo apt install -y caddy
    1. Create and configure the `Caddyfile` to reverse proxy to Authentik.
        $ sudo nano /etc/caddy/Caddyfile
        Remove the existing content and add the following:
        ```ini
        auth.example.com {
            reverse_proxy 127.0.0.1:9000
    1. Format the `Caddyfile` configuration file.
        $ sudo caddy fmt --overwrite /etc/caddy/Caddyfile
    1. Validate the configuration and reload the Caddy service.
        $ sudo caddy validate --config /etc/caddy/Caddyfile
        $ sudo systemctl reload caddy
        Caddy automatically issues and renews TLS certificates when DNS is correctly configured and ports 80/443 are accessible.
    1. Open the Initial Setup flow to create the first administrator account.
        https://auth.example.com/if/flow/initial-setup/
        On the setup page, enter your email and a strong password to complete the admin account setup.
        If the application is not reachable, check the Caddy web server logs.
        $ sudo journalctl -u caddy --no-pager -n 100
??? note "Using NGINX Web Server"
    1. Install the NGINX web server using `apt`.
        $ sudo apt install -y nginx
    1. Create a server block that proxies traffic to the Authentik Docker container.
        $ sudo nano /etc/nginx/sites-available/authentik.conf
    1. Add the following NGINX configuration into the file.
        ```ini
        server {
            listen 80;
            server_name auth.example.com;
            location / {
                proxy_set_header Host $host;
                proxy_set_header X-Real-IP $remote_addr;
                proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
                proxy_set_header X-Forwarded-Proto $scheme;
                proxy_pass http://127.0.0.1:9000;
    1. Enable the server block by creating a symlink.
        $ sudo ln -s /etc/nginx/sites-available/authentik.conf /etc/nginx/sites-enabled/authentik.conf
    1. Test the NGINX configuration.
        $ sudo nginx -t
    1. Reload NGINX to apply changes.
        $ sudo systemctl reload nginx
    1. Install Certbot and the NGINX plugin.
        $ sudo apt install -y certbot python3-certbot-nginx
    1. Obtain and install a TLS certificate using Certbot's NGINX plugin.
        $ sudo certbot --nginx -d auth.example.com -m admin@example.com --agree-tos --no-eff
        Certbot updates the NGINX server block for TLS and configures automatic renewal.
    1. Verify that the automatic renewal is active.
        $ sudo systemctl status certbot.timer
## Connect a Sample App to Authentik
In this section, you’ll register an OAuth 2.0 client in Authentik, then run a minimal Node.js app that uses it to validate authentication.
### Register an OAuth2 Client
1. Sign in to the Authentik Admin UI.
    https://auth.example.com/if/admin/
1. Create an OAuth2/OpenID Provider for the sample application.
    * Navigate: **Applications > Providers > Create > OAuth2/OpenID Provider**
    * At the top, set:
        * **Name:** `Sample App Provider`
        * **Authorization flow:** `default-provider-authorization-explicit-consent`
    * Under **Protocol settings**:
        * **Client type:** `Confidential`
        * **Redirect URIs/Origins (RegEx):** `https://app.example.com/auth/callback`
        * Generate and **save** the **Client ID** and **Client Secret**
    * Under **Advanced flow settings**:
        * **Authentication flow:** `default-authentication-flow`
        * **Invalidation flow:** leave default (optional)
    * Under **Advanced protocol settings**:
        * **Subject mode:** `Based on the User's hashed ID`
1. Create the application and link it to the provider you just created.
    * Navigate: **Applications > Applications > Create**
    * **Name:** `Sample Web App`
    * **Slug:** `sample-web-app`
    * **Provider:** select `Sample App Provider`
    * **Policy engine mode:** `ANY`
    * Under **UI settings**:
        * **Launch URL:** `https://auth.example.com`
### Sample Node.js OAuth2 Integration Application
Follow the steps below to provision a minimal web application and validate the Authorization Code flow against Authentik.
1. Clone the sample repository and enter the project directory.
    $ git clone https://github.com/vultr-marketing/code-samples.git
    $ cd code-samples/authentik-oauth2-demo-app
1. Install `npm`.
    $ sudo apt install -y npm
1. Install runtime dependencies.
    $ npm install
1. Generate a session secret.
1. Configure environment variables.
    $ nano .env
    Paste the following and set the values precisely:
    ```ini
    AUTHENTIK_URL=https://auth.example.com
    PUBLIC_BASE_URL=https://app.example.com
    CLIENT_ID=<CLIENT_ID_FROM_AUTHENTIK_PROVIDER>
    CLIENT_SECRET=<CLIENT_SECRET_FROM_AUTHENTIK_PROVIDER>
    SESSION_SECRET=<RANDOM_SESSION_SECRET_GENERATED_ABOVE>
    PORT=3000
    In the above file:
    * Replace `https://auth.example.com` with the URL of your Authentik instance.
    * Replace `https://app.example.com` with the URL where your sample app will run.
    * Replace `<CLIENT_ID_FROM_AUTHENTIK_PROVIDER>` and `<CLIENT_SECRET_FROM_AUTHENTIK_PROVIDER>` with the values generated when you created the OAuth2/OpenID Provider in Authentik.
    * Replace `<RANDOM_SESSION_SECRET_GENERATED_ABOVE>` with the session secret you generated in the previous step.
    Make sure all values are set correctly before starting the application.
1. Start the application.
    $ npm start &
    Ensure that you configure a reverse proxy and SSL for the app, similar to how you configured `auth.example.com` but for port `3000`.
1. Navigate to `https://app.example.com` and click **Login with Authentik**.
    ![Login with Authentik](https://lhr1.vultrobjects.com/docs-main-doc-assets-1/2356/114c50b6-edb8-4dc7-86d5-d513b594df0d.png)
1. Enter your OAuth2 user credentials.
    ![image.png](https://lhr1.vultrobjects.com/docs-main-doc-assets-1/2356/548e48ce-98b7-4cab-a009-2ee827131863.png)
1. After authentication, the app exchanges the authorization code for tokens and redirects to `/protected`.
    ![Application After Login](https://lhr1.vultrobjects.com/docs-main-doc-assets-1/2356/7aa0c465-1860-439f-875c-76ef8e9717fb.png)
### Troubleshooting
If you encounter issues while connecting your sample app to Authentik, follow these steps:
1. Check the OAuth2 Provider and Application settings,eEnsure that your Authentik Provider and Application are configured correctly, particularly the **Redirect URI**.
1. Authentik server logs can provide insight into errors during login or token exchange. Use the following command to view the logs in real-time.
    $ sudo docker compose logs -f server
    Look for any warnings or errors related to OAuth2 flows, redirect URIs, or authentication failures.
1. Confirm that your reverse proxy (Caddy or NGINX) forwards requests correctly to `127.0.0.1:9000` and that HTTPS is properly configured. Misconfigured proxy settings can prevent callback URLs from reaching Authentik.
1. OAuth2 state mismatches may occur due to stale sessions. Try logging in using a private or incognito browser window to ensure a clean session.
You successfully deployed a self-hosted Authentik instance on Vultr with Docker Compose, secured it behind HTTPS, and verified OAuth2 SSO with a sample Node.js app. With this foundation, you can now onboard additional applications, enable email flows, and scale your authentication infrastructure while keeping full control over user data.
