title: How to Deploy Apache Flink on Kubernetes Engine as Alternative to GCP Dataflow
url: https://docs.vultr.com/how-to-deploy-apache-flink-on-kubernetes-engine-as-alternative-to-gcp-dataflow
description: Deploy Apache Flink on Kubernetes using the Flink Kubernetes Operator with checkpointing and Kafka, as a self-hosted alternative to Google Cloud Dataflow.
publish_date: 2026-09-09T03:24:55.956757Z
last_updated: 2026-09-24T21:06:09.052350Z
author: Darshan  Siroya
header_image: https://lhr1.vultrobjects.com/docs-main-doc-assets-1/2664/c3f518c0-3267-4740-80d5-c33946620ac9.png
[Google Cloud Dataflow](https://cloud.google.com/dataflow) is a managed stream and batch processing service built on Apache Beam. It offers autoscaling, event-time processing, windowing, stateful computations, and exactly-once guarantees, but it ties deployments to Google Cloud services and ongoing managed service costs.
[Apache Flink](https://flink.apache.org/) is an open-source distributed processing engine for stateful computations over bounded and unbounded data streams, and it covers the same ground as a self-hosted deployment without ongoing managed service costs. It supports stateful processing, checkpointing, savepoints, event-time windowing, and [Apache Beam](https://beam.apache.org/) pipelines through the Flink Runner, while the Flink Kubernetes Operator deploys and manages Flink clusters using native Kubernetes resources.
This article explains how to deploy Apache Flink as an alternative to Google Cloud Dataflow. It covers Session and Application Cluster deployments using the Flink Kubernetes Operator, state management, checkpointing, exactly-once processing with Kafka, Apache Beam integration, monitoring, high availability, security, and migration strategies from Google Cloud Dataflow.
## Understanding Flink Architecture
Apache Flink provides many of the stream and batch processing capabilities available in Google Cloud Dataflow through a self-managed Kubernetes deployment. The following table compares Dataflow components and features with their closest Apache Flink equivalents:
| Google Cloud Dataflow | Apache Flink Equivalent | Description |
| Dataflow Job | Flink Job or `FlinkDeployment` CR | Defines and manages stream or batch processing applications |
| Dataflow Worker | TaskManager | Executes processing tasks and maintains operator state |
| Dataflow Control Plane | JobManager | Coordinates job execution, scheduling, checkpoints, and cluster operations |
| Dataflow Autoscaling | Flink Autoscaler, Reactive Mode, or Horizontal Pod Autoscaler | Adjusts processing capacity based on workload and resource demand |
| Dataflow Windowing | Flink Windowing | Supports tumbling, sliding, and session windows |
| Dataflow Exactly-Once Processing | Checkpointing and Exactly-Once Sinks | Provides consistent state recovery and end-to-end processing guarantees |
| Dataflow Stateful Processing | Keyed State and State Backends | Maintains state across events and processing operations |
| Dataflow Beam Runner | Flink Runner | Executes Apache Beam pipelines on Flink clusters |
| Dataflow Snapshots | Savepoints | Creates application state snapshots for recovery, upgrades, and migration |
| Cloud Monitoring | Prometheus and Grafana | Collects and visualizes cluster, job, and resource metrics |
| Dataflow Templates | Application JARs and `FlinkSessionJob` CRs | Packages and deploys reusable processing workloads |
Key components of Apache Flink include:
* **JobManager:** Coordinates job scheduling, checkpoints, recovery, and TaskManager operations.
* **TaskManager:** Executes processing tasks and maintains application state assigned to its task slots.
* **Flink Kubernetes Operator:** Automates the deployment, upgrade, scaling, recovery, and lifecycle management of Flink clusters and applications.
* **State Backend:** Manages the working state used by stateful Flink operators.
* **Checkpoint Storage:** Stores checkpoint and savepoint data in durable storage for recovery and application upgrades.
* **Checkpoints:** Automatically created state snapshots used for fault recovery and exactly-once processing.
* **Savepoints:** Manually triggered state snapshots used for controlled upgrades, migration, and operational recovery.
* Have access to a Kubernetes cluster, such as [Vultr Kubernetes Engine](https://www.vultr.com/kubernetes/), running Kubernetes 1.31 or later with at least 4 CPU cores and 16 GB of RAM per node. A minimum of three worker nodes is recommended.
* Install [`kubectl`](https://kubernetes.io/docs/tasks/tools/) and configure access to the cluster.
* Install [Helm 3](https://helm.sh/docs/intro/install/) on your management workstation.
* Install [Java 11 or later](https://openjdk.org/install/) and [Apache Maven](https://maven.apache.org/install.html).
* Configure a default Kubernetes [`StorageClass`](https://kubernetes.io/docs/concepts/storage/storage-classes/) for persistent Kafka storage.
* Create a bucket on an S3-compatible object storage service, such as [Vultr Object Storage](https://docs.vultr.com/products/storage/object-storage). Record the bucket name, hostname, access key, and secret key.
* Have a basic understanding of Kubernetes resources and stream-processing concepts.
## Install the Flink Kubernetes Operator
The Apache Flink Kubernetes Operator extends Kubernetes with custom resources that simplify the deployment and lifecycle management of Apache Flink clusters and applications. It automates operations such as upgrades, scaling, savepoint management, and recovery while allowing you to manage Flink deployments using native Kubernetes resources.
### Install cert-manager
The Flink Kubernetes Operator uses admission webhooks that require TLS certificates. Install [`cert-manager`](https://cert-manager.io/) before deploying the operator.
1. Verify the Kubernetes cluster connection.
    $ kubectl cluster-info
1. Verify that all worker nodes are in the `Ready` state.
    $ kubectl get nodes
1. Add the Jetstack Helm repository.
    $ helm repo add jetstack https://charts.jetstack.io
1. Update the Helm repository cache.
    $ helm repo update
1. Install `cert-manager`, create the `cert-manager` namespace, and install the required Custom Resource Definitions.
    $ helm install cert-manager jetstack/cert-manager \
        --namespace cert-manager \
        --create-namespace \
        --version v1.21.1 \
        --set crds.enabled=true
1. Verify that all `cert-manager` pods are running.
    $ kubectl get pods -n cert-manager
    NAME                                       READY   STATUS    RESTARTS   AGE
    cert-manager-559776c68d-7vqzx              1/1     Running   0          9m5s
    cert-manager-cainjector-7cdf9b4bd8-th5g2   1/1     Running   0          9m5s
    cert-manager-webhook-5f7fd7899-pxt99       1/1     Running   0          9m5s
### Install the Apache Flink Kubernetes Operator
1. Add the Apache Flink Helm repository for version `1.15.0`. This article uses the Flink Kubernetes Operator version `1.15.0`. Visit the [Flink Kubernetes Operator downloads page](https://flink.apache.org/downloads/#apache-flink-kubernetes-operator) to confirm the latest release, and replace the version in the repository URL if a newer version is available.
    $ helm repo add flink-operator https://downloads.apache.org/flink/flink-kubernetes-operator-1.15.0/
    $ helm repo update
1. Create a dedicated namespace for the Flink Kubernetes Operator.
    $ kubectl create namespace flink-operator
1. Install version `1.15.0` of the Flink Kubernetes Operator in the `flink-operator` namespace.
    $ helm install flink-kubernetes-operator \
        flink-operator/flink-kubernetes-operator \
        --namespace flink-operator \
        --version 1.15.0 \
        --set image.tag=1.15.0
1. Verify that the operator deployment is available.
    $ kubectl get deployments -n flink-operator
    NAME                        READY   UP-TO-DATE   AVAILABLE   AGE
    flink-kubernetes-operator   1/1     1            1           38s
1. Verify that the operator pod is running.
    $ kubectl get pods -n flink-operator
    flink-kubernetes-operator-85cbbc449-4cwjr   2/2     Running   0          59s
## Deploy a Flink Session Cluster
A Flink Session Cluster runs a long-lived JobManager and TaskManager deployment that can accept multiple Flink jobs. This mode is useful when you want to submit and manage several jobs without creating a separate cluster for each workload.
1. Create a working directory for the Flink manifests.
    $ mkdir -p ~/flink-dataflow
1. Switch to the working directory.
    $ cd ~/flink-dataflow
1. Create a namespace for Flink workloads.
1. Create a service account for Flink.
    $ kubectl create serviceaccount flink -n flink
1. Create a role binding that allows the Flink service account to manage resources in the `flink` namespace.
    $ kubectl create rolebinding flink-role-binding \
        --clusterrole=edit \
        --serviceaccount=flink:flink \
        --namespace=flink
1. Create a `session-cluster.yaml` manifest.
    $ nano session-cluster.yaml
    Add the following configuration to the file.
    apiVersion: flink.apache.org/v1beta1
    kind: FlinkDeployment
      namespace: flink
      image: flink:1.20
      flinkVersion: v1_20
      serviceAccount: flink
      flinkConfiguration:
        taskmanager.numberOfTaskSlots: "2"
        state.checkpoints.dir: file:///opt/flink/checkpoints
        state.savepoints.dir: file:///opt/flink/savepoints
      jobManager:
        resource:
          memory: "2048m"
          cpu: 1
      taskManager:
        replicas: 2
        resource:
          memory: "2048m"
          cpu: 1
    > The local checkpoint and savepoint directories validate the Session Cluster configuration but do not preserve state after pod replacement. The **Configure State Management** section replaces these paths with durable Object Storage.
    The configuration:
    * Deploys a reusable Flink Session Cluster using the Flink Kubernetes Operator.
    * Allocates CPU and memory resources to the JobManager and TaskManagers.
    * Configures two task slots for each TaskManager.
    * Sets local checkpoint and savepoint directories for deployment testing.
    * Uses the `flink` service account to manage resources in the `flink` namespace.
1. Apply the Flink Session Cluster manifest.
    $ kubectl apply -f session-cluster.yaml
1. Verify that the Flink deployment is created.
    $ kubectl get flinkdeployment -n flink
    Verify that the `flink-session-cluster` resource displays a `STABLE` lifecycle state.
1. Verify that the Flink Session Cluster pods are running.
1. Verify the Flink services.
    $ kubectl get svc -n flink
    The output displays the services created for the Flink Session Cluster, including the REST service used to access the Flink Web UI.
## Submit a Flink Job
A `FlinkSessionJob` submits an application to an existing Flink Session Cluster without creating a separate Flink cluster for each workload. The application is packaged as a Java Archive (JAR) file and managed as a Kubernetes custom resource, making deployments and updates consistent with standard Kubernetes workflows.
1. Create a directory for the sample Flink application.
    $ mkdir -p ~/flink-dataflow/sample-job/src/main/java/com/example
1. Switch to the project directory.
    $ cd ~/flink-dataflow/sample-job
1. Create the Maven project configuration file.
    $ nano pom.xml
    ```xml
    <project xmlns="http://maven.apache.org/POM/4.0.0"
             xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
             xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 https://maven.apache.org/xsd/maven-4.0.0.xsd">
        <modelVersion>4.0.0</modelVersion>
        <groupId>com.example</groupId>
        <artifactId>flink-session-job</artifactId>
        <version>1.0.0</version>
        <properties>
            <maven.compiler.release>11</maven.compiler.release>
            <flink.version>1.20.0</flink.version>
            <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
        </properties>
        <dependencies>
            <dependency>
                <groupId>org.apache.flink</groupId>
                <artifactId>flink-streaming-java</artifactId>
                <version>${flink.version}</version>
                <scope>provided</scope>
            </dependency>
            <dependency>
                <artifactId>flink-clients</artifactId>
            </dependency>
        </dependencies>
        <build>
            <plugins>
                <plugin>
                    <groupId>org.apache.maven.plugins</groupId>
                    <artifactId>maven-compiler-plugin</artifactId>
                    <version>3.13.0</version>
                </plugin>
            </plugins>
        </build>
    </project>
    The configuration:
    * Defines a Maven project for the sample Flink application.
    * Uses Apache Flink 1.20 libraries.
    * Configures Java 11 as the build target.
    * Packages the application into a deployable JAR.
1. Create a sample streaming application.
    $ nano src/main/java/com/example/DataflowMigrationJob.java
    Add the following application.
    ```java
    package com.example;
    import org.apache.flink.streaming.api.environment.StreamExecutionEnvironment;
    public class DataflowMigrationJob {
        public static void main(String[] args) throws Exception {
            StreamExecutionEnvironment env =
                    StreamExecutionEnvironment.getExecutionEnvironment();
            env.fromElements(
                    "Apache Flink",
                    "Kubernetes",
                    "Stream Processing")
                    .map(String::toUpperCase)
                    .print();
            env.execute("Sample Streaming Job");
    The application:
    * Creates a Flink streaming execution environment.
    * Processes a sample stream of events.
    * Converts each event to uppercase.
    * Prints the processed events to the application logs.
1. Build the application.
    $ mvn clean package
1. Verify that Maven creates the application JAR.
    $ ls target
    Verify that the output includes the `flink-session-job-1.0.0.jar` file.
    > The sample application demonstrates how to package a Flink job into a deployable JAR. The following steps submit an official Apache Flink example application hosted on Maven Central. Using a publicly accessible JAR provides a reproducible deployment without requiring additional artifact storage or container image customization. Later sections configure durable storage for Flink applications and state.
1. Switch to the Flink manifest directory.
1. Create the session job manifest.
    $ nano session-job.yaml
    kind: FlinkSessionJob
      namespace: flink
      deploymentName: flink-session-cluster
      job:
        jarURI: https://repo1.maven.org/maven2/org/apache/flink/flink-examples-streaming/1.20.0/flink-examples-streaming-1.20.0-TopSpeedWindowing.jar
        parallelism: 2
        upgradeMode: stateless
        state: running
    The configuration:
    * Submits a streaming application to the existing Flink Session Cluster.
    * Downloads the application JAR from Maven Central.
    * Runs the application with a parallelism of 2.
    * Uses the stateless upgrade mode for application updates.
1. Apply the session job manifest.
    $ kubectl apply -f session-job.yaml
1. Verify that the session job is created.
    $ kubectl get flinksessionjobs -n flink
    NAME                   JOB STATUS   LIFECYCLE STATE
    sample-streaming-job   RUNNING      STABLE
1. Verify that the Session Cluster runs the submitted job.
    $ kubectl get flinkdeployments -n flink
1. Set up port forwarding to access the Flink dashboard.
    $ kubectl port-forward svc/flink-session-cluster-rest -n flink 8081:8081
1. Open `http://localhost:8081` in your web browser to access the Apache Flink dashboard.
    ![Flink dashboard](https://lhr1.vultrobjects.com/docs-main-doc-assets-1/2664/4e76c75d-ca36-4c79-9ee0-9bfa66654e0d.png)
    The Flink dashboard displays running jobs, TaskManagers, checkpoints, and cluster resources. Verify that the submitted job appears in the **Running Jobs** section with a `RUNNING` status. Select the job to view execution details and task metrics.
## Deploy a Flink Application Cluster
A Flink Application Cluster creates a dedicated cluster for a single application. It deploys the application with a JobManager and TaskManagers. Each application uses dedicated resources and has an independent lifecycle.
1. Create a Kubernetes Secret using your Object Storage credentials. Replace `YOUR_ACCESS_KEY` with your Object Storage access key and `YOUR_SECRET_KEY` with your Object Storage secret key.
    $ kubectl create secret generic flink-object-storage \
        --namespace flink \
        --from-literal=AWS_ACCESS_KEY_ID='YOUR_ACCESS_KEY' \
        --from-literal=AWS_SECRET_ACCESS_KEY='YOUR_SECRET_KEY'
1. Verify that the Secret exists.
    $ kubectl get secret flink-object-storage -n flink
    NAME                   TYPE     DATA   AGE
    flink-object-storage   Opaque   2      31s
1. Create the application cluster manifest.
    $ nano flink-application.yaml
    Add the following configuration. Replace `YOUR_BUCKET_NAME` with your Object Storage bucket name and `YOUR_OBJECT_STORAGE_HOSTNAME` with your Object Storage hostname.
      namespace: flink
      image: flink:1.20
      flinkVersion: v1_20
      mode: native
      flinkConfiguration:
        state.backend.type: rocksdb
        execution.checkpointing.interval: "60 s"
        execution.checkpointing.mode: EXACTLY_ONCE
        execution.checkpointing.dir: s3://YOUR_BUCKET_NAME/checkpoints
        execution.checkpointing.savepoint-dir: s3://YOUR_BUCKET_NAME/savepoints
        execution.checkpointing.incremental: "true"
        execution.checkpointing.externalized-checkpoint-retention: RETAIN_ON_CANCELLATION
        state.checkpoints.num-retained: "3"
        s3.endpoint: YOUR_OBJECT_STORAGE_HOSTNAME
        s3.path.style.access: "true"
        restart-strategy.type: fixed-delay
        restart-strategy.fixed-delay.attempts: "3"
        restart-strategy.fixed-delay.delay: "10 s"
      podTemplate:
          initContainers:
            - name: enable-s3-plugin
              image: flink:1.20
              command:
                - /bin/sh
                - -c
                  mkdir -p /flink-plugins/s3-fs-presto
                  cp /opt/flink/opt/flink-s3-fs-presto-*.jar \
                    /flink-plugins/s3-fs-presto/
              volumeMounts:
                - name: flink-plugins
                  mountPath: /flink-plugins
            - name: flink-main-container
              env:
                - name: AWS_ACCESS_KEY_ID
                  valueFrom:
                    secretKeyRef:
                      key: AWS_ACCESS_KEY_ID
                - name: AWS_SECRET_ACCESS_KEY
                  valueFrom:
                    secretKeyRef:
                      key: AWS_SECRET_ACCESS_KEY
              volumeMounts:
                  mountPath: /opt/flink/plugins
          volumes:
              emptyDir: {}
      job:
        jarURI: local:///opt/flink/examples/streaming/StateMachineExample.jar
        parallelism: 2
        upgradeMode: savepoint
        state: running
      jobManager:
        resource:
          cpu: 1
          memory: "2048m"
      taskManager:
        replicas: 2
        resource:
          cpu: 1
          memory: "2048m"
    The configuration:
    * Creates a dedicated Flink Application Cluster.
    * Uses RocksDB as the state backend.
    * Creates an incremental checkpoint every 60 seconds.
    * Stores checkpoints and savepoints in Object Storage.
    * Retains completed checkpoints when the application is canceled.
    * Loads Object Storage credentials from a Kubernetes Secret.
    * Enables the Flink S3 filesystem plugin.
    * Uses savepoints to preserve application state during updates.
    * Retries failed jobs three times with a ten-second delay.
1. Apply the manifest.
    $ kubectl apply -f flink-application.yaml
1. Verify that the `FlinkDeployment` reaches the `STABLE` lifecycle state.
    flink-application-cluster   RUNNING      STABLE
    flink-session-cluster                    STABLE
1. Verify that the JobManager and TaskManager pods are running.
    flink-application-cluster-6d9cd654c7-gx7vj   1/1     Running   0          11m
    flink-application-cluster-taskmanager-1-1    1/1     Running   0          10m
    flink-application-cluster-taskmanager-1-2    1/1     Running   0          10m
    flink-session-cluster-7cb847b8cf-wx5px       1/1     Running   0          117m
    flink-session-cluster-taskmanager-1-1        1/1     Running   0          22m
1. Verify the services created for the Application Cluster.
    The `flink-application-cluster-rest` service exposes the Flink REST API and Web UI.
## Configure State Management
Apache Flink uses a state backend to manage application state during processing. The HashMap state backend keeps state in JVM memory and works well for smaller workloads. [RocksDB](https://rocksdb.org/) stores working state on TaskManager disks and supports incremental checkpoints for larger workloads. The Application Cluster uses RocksDB with Object Storage to preserve checkpoints and savepoints outside the Kubernetes cluster.
1. Verify the state backend, checkpoint directory, and incremental checkpointing configured for the Application Cluster.
    $ kubectl get flinkdeployment flink-application-cluster \
        -n flink \
        -o jsonpath='backend={.spec.flinkConfiguration.state\.backend\.type} dir={.spec.flinkConfiguration.execution\.checkpointing\.dir} incremental={.spec.flinkConfiguration.execution\.checkpointing\.incremental}{"\n"}'
    backend=rocksdb dir=s3://YOUR_BUCKET_NAME/checkpoints incremental=true
1. Verify that the application creates checkpoints successfully.
    $ kubectl logs deployment/flink-application-cluster \
        -n flink \
        --since=10m | grep "Completed checkpoint"
    INFO  CheckpointCoordinator [] - Completed checkpoint 182 for job 462df3b4543929748a7ede4b313ab797 (784937 bytes, checkpointDuration=14773 ms, finalizationTime=1 ms).
    INFO  CheckpointCoordinator [] - Completed checkpoint 183 for job 462df3b4543929748a7ede4b313ab797 (288117 bytes, checkpointDuration=7367 ms, finalizationTime=1 ms).
    The output confirms that Flink creates checkpoints successfully. The checkpoint directory verified earlier stores the completed checkpoints in Object Storage.
1. Trigger a savepoint for the running application.
    $ kubectl patch flinkdeployment flink-application-cluster \
        -n flink \
        --type merge \
        -p '{"spec":{"job":{"savepointTriggerNonce":1}}}'
1. Monitor the state snapshots.
    $ kubectl get flinkstatesnapshots -n flink --watch
    Wait until the latest snapshot reaches the `COMPLETED` state. Press :key_ctrl:+:key_c: to stop monitoring.
1. Store the latest state snapshot name in a variable.
    $ SNAPSHOT_NAME=$(kubectl get flinkstatesnapshots \
        -n flink \
        --sort-by=.metadata.creationTimestamp \
        -o jsonpath='{.items[-1:].metadata.name}')
1. Verify the snapshot state.
    $ kubectl get flinkstatesnapshot "$SNAPSHOT_NAME" \
        -n flink \
        -o jsonpath='{.status.state}{"\n"}'
    COMPLETED
1. View the savepoint location.
        -n flink \
        -o jsonpath='{.status.path}{"\n"}'
    s3://YOUR_BUCKET_NAME/savepoints/savepoint-xxxxxxxxxxxxxxxx
## Set Up Windowing and Event-Time Processing
Apache Flink uses event timestamps and watermarks to process records that arrive out of order. Windowing groups records by time, while allowed lateness and side outputs handle delayed records.
1. Switch to the sample application directory.
1. Create an event-time windowing application.
    $ nano src/main/java/com/example/EventTimeWindowingJob.java
    ```java
    import java.time.Duration;
    import org.apache.flink.api.common.eventtime.WatermarkStrategy;
    import org.apache.flink.api.common.functions.ReduceFunction;
    import org.apache.flink.api.common.typeinfo.Types;
    import org.apache.flink.streaming.api.datastream.DataStream;
    import org.apache.flink.streaming.api.datastream.SingleOutputStreamOperator;
    import org.apache.flink.streaming.api.windowing.assigners.EventTimeSessionWindows;
    import org.apache.flink.streaming.api.windowing.assigners.SlidingEventTimeWindows;
    import org.apache.flink.streaming.api.windowing.assigners.TumblingEventTimeWindows;
    import org.apache.flink.util.OutputTag;
    public class EventTimeWindowingJob {
        private static final OutputTag<Event> LATE_EVENTS =
                new OutputTag<Event>("late-events") {};
            long baseTime = 1_700_000_000_000L;
            DataStream<Event> events = env
                    .fromElements(
                            new Event("checkout", 10L, baseTime),
                            new Event("checkout", 15L, baseTime + 10_000),
                            new Event("payment", 20L, baseTime + 20_000),
                            new Event("checkout", 12L, baseTime + 30_000),
                            new Event("payment", 25L, baseTime + 40_000),
                            // Advances the watermark beyond the first window.
                            new Event("checkout", 30L, baseTime + 120_000),
                            // Arrives after the watermark and allowed-lateness period.
                            new Event("checkout", 5L, baseTime + 5_000))
                    .returns(Types.POJO(Event.class));
            WatermarkStrategy<Event> watermarkStrategy =
                    WatermarkStrategy
                            .<Event>forBoundedOutOfOrderness(
                                    Duration.ofSeconds(5))
                            .withTimestampAssigner(
                                    (event, previousTimestamp) ->
                                            event.timestamp);
            DataStream<Event> timestampedEvents =
                    events.assignTimestampsAndWatermarks(
                            watermarkStrategy);
            SingleOutputStreamOperator<Event> tumblingResults =
                    timestampedEvents
                            .keyBy(event -> event.type)
                            .window(
                                    TumblingEventTimeWindows.of(
                                            Duration.ofMinutes(1)))
                            .allowedLateness(Duration.ofSeconds(30))
                            .sideOutputLateData(LATE_EVENTS)
                            .reduce(new SumEvents())
                            .name("One-minute tumbling window");
            DataStream<Event> slidingResults =
                    timestampedEvents
                            .window(
                                    SlidingEventTimeWindows.of(
                                            Duration.ofMinutes(5),
                            .name("Five-minute sliding window");
            DataStream<Event> sessionResults =
                    timestampedEvents
                            .window(
                                    EventTimeSessionWindows.withGap(
                                            Duration.ofMinutes(2)))
                            .name("Two-minute session window");
            DataStream<Event> lateEvents =
                    tumblingResults.getSideOutput(LATE_EVENTS);
            tumblingResults.print("Tumbling window");
            slidingResults.print("Sliding window");
            sessionResults.print("Session window");
            lateEvents.print("Late event");
            env.execute("Event-Time Windowing Job");
        public static class Event {
            public String type;
            public long value;
            public long timestamp;
            public Event() {
            public Event(String type, long value, long timestamp) {
                this.type = type;
                this.value = value;
                this.timestamp = timestamp;
            @Override
            public String toString() {
                return "Event{"
                        + "type='" + type + '\''
                        + ", value=" + value
                        + ", timestamp=" + timestamp
        public static class SumEvents
                implements ReduceFunction<Event> {
            @Override
            public Event reduce(Event first, Event second) {
                return new Event(
                        first.type,
                        first.value + second.value,
                        Math.max(first.timestamp, second.timestamp));
    The application:
    * Extracts the event time from each record.
    * Allows records to arrive up to five seconds out of order.
    * Groups records into one-minute tumbling windows.
    * Creates five-minute sliding windows every minute.
    * Groups records into sessions using a two-minute inactivity gap.
    * Accepts records until the watermark advances 30 seconds beyond the end of a tumbling window.
    * Sends records that exceed the allowed lateness to a side output.
    $ mvn clean package
    $ ls -lh target/flink-session-job-1.0.0.jar
    -rw-r--r-- 1 user user 8.5K Jul 13 00:15 target/flink-session-job-1.0.0.jar
## Configure Exactly-Once Processing
Apache Flink combines checkpoints with transactional sinks to provide end-to-end exactly-once processing. A Kafka transactional sink writes records inside a transaction and commits it only after the corresponding checkpoint completes, so a job that fails and restarts from the last checkpoint never emits duplicate output to downstream consumers.
### Deploy Apache Kafka
End-to-end exactly-once processing requires a message broker with transactional support. Deploy a three-node [Apache Kafka](https://kafka.apache.org/) cluster with the Strimzi operator to provide the transactional source and sink for the Flink application.
1. Create a namespace for Kafka resources.
    $ kubectl create namespace kafka
1. Add the [Strimzi](https://strimzi.io/) Helm repository.
    $ helm repo add strimzi https://strimzi.io/charts/
1. Update the Helm repository information.
    $ helm repo update
1. Install the Strimzi Kafka Operator.
    $ helm install strimzi-kafka-operator \
        strimzi/strimzi-kafka-operator \
        --namespace kafka \
        --version 1.1.0
1. Verify that the Strimzi operator is running.
    $ kubectl get pods -n kafka
    strimzi-cluster-operator-687687c99b-l695z   1/1     Running   0          17m
1. Create a Kafka cluster manifest.
    $ nano kafka-cluster.yaml
    apiVersion: kafka.strimzi.io/v1
    kind: KafkaNodePool
      namespace: kafka
        strimzi.io/cluster: flink-kafka
      replicas: 3
      roles:
        - controller
        - broker
      storage:
        type: jbod
        volumes:
          - id: 0
            type: persistent-claim
            deleteClaim: false
      resources:
        requests:
          cpu: 500m
          memory: 1Gi
        limits:
          cpu: "1"
          memory: 2Gi
        pod:
          affinity:
            podAntiAffinity:
              preferredDuringSchedulingIgnoredDuringExecution:
                - weight: 100
                  podAffinityTerm:
                    topologyKey: kubernetes.io/hostname
                    labelSelector:
    kind: Kafka
      namespace: kafka
      kafka:
        version: 4.3.0
        listeners:
          - name: plain
            port: 9092
            type: internal
            tls: false
        config:
          auto.create.topics.enable: false
          default.replication.factor: 3
          min.insync.replicas: 2
          offsets.topic.replication.factor: 3
          transaction.state.log.replication.factor: 3
          transaction.state.log.min.isr: 2
      entityOperator:
        topicOperator: {}
        userOperator: {}
    The node pool runs three Kafka nodes with persistent storage. Each node acts as a broker and KRaft controller. The replication and in-sync replica settings allow the cluster to continue processing transactions when one broker is unavailable. Strimzi requires Kafka and KafkaNodePool resources for KRaft-based clusters.
1. Deploy the Kafka cluster.
    $ kubectl apply -f kafka-cluster.yaml
1. Wait for the Kafka cluster to become ready.
    $ kubectl wait kafka/flink-kafka \
        -n kafka \
        --for=condition=Ready \
        --timeout=600s
1. Verify the Kafka pods.
    $ kubectl get pods -n kafka \
        -l strimzi.io/cluster=flink-kafka
    flink-kafka-dual-role-0                        1/1     Running   0          98s
    flink-kafka-dual-role-1                        1/1     Running   0          98s
    flink-kafka-dual-role-2                        1/1     Running   0          98s
    flink-kafka-entity-operator-5d6b58bffc-nq7vz   2/2     Running   0          34s
1. Verify the internal Kafka bootstrap service.
    $ kubectl get service flink-kafka-kafka-bootstrap \
        -n kafka
### Create the Kafka Topics
Create the input topic for incoming events and the output topic for window results. Each topic uses three partitions and three replicas, and requires at least two in-sync replicas to acknowledge writes, so it tolerates one unavailable broker.
1. Create the Kafka topics manifest.
    $ nano flink-topics.yaml
    kind: KafkaTopic
      namespace: kafka
      partitions: 3
      replicas: 3
      config:
        retention.ms: 604800000
    kind: KafkaTopic
      namespace: kafka
      partitions: 3
      replicas: 3
      config:
1. Create both topics.
    $ kubectl apply -f flink-topics.yaml
1. Wait for both topics to become ready.
    $ kubectl wait kafkatopic/flink-events kafkatopic/flink-window-results \
        -n kafka \
        --timeout=180s
1. Verify both topics.
    $ kubectl get kafkatopic -n kafka
    NAME                   CLUSTER       PARTITIONS   REPLICATION FACTOR   READY
    flink-events           flink-kafka   3            3                    True
    flink-window-results   flink-kafka   3            3                    True
### Enable Exactly-Once Checkpointing
1. Configure the Flink Session Cluster to create exactly-once checkpoints every 60 seconds.
    $ kubectl patch flinkdeployment flink-session-cluster \
        -n flink \
        --type merge \
        -p '{
          "spec": {
            "flinkConfiguration": {
              "execution.checkpointing.interval": "60 s",
              "execution.checkpointing.mode": "EXACTLY_ONCE"
1. Wait for the Session Cluster to become stable.
    $ kubectl wait flinkdeployment/flink-session-cluster \
        -n flink \
        --for=jsonpath='{.status.lifecycleState}'=STABLE \
        --timeout=300s
1. Verify the checkpointing mode and interval.
    $ kubectl get flinkdeployment flink-session-cluster \
        -n flink \
        -o jsonpath='mode={.spec.flinkConfiguration.execution\.checkpointing\.mode} interval={.spec.flinkConfiguration.execution\.checkpointing\.interval}{"\n"}'
    mode=EXACTLY_ONCE interval=60 s
### Add the Kafka Connector
1. Open the Maven project configuration.
    $ nano pom.xml
    Append the following dependencies to the existing `<dependencies>` block.
    ```xml
    <dependency>
        <artifactId>flink-connector-base</artifactId>
    </dependency>
    <dependency>
        <artifactId>flink-connector-kafka</artifactId>
        <version>3.4.0-1.20</version>
    </dependency>
    The connector base dependency provides the `DeliveryGuarantee` class. The Kafka connector provides the transactional sink and supports Apache Flink 1.20.
    Append the following plugin to the existing `<plugins>` block.
    ```xml
    <plugin>
        <artifactId>maven-shade-plugin</artifactId>
        <version>3.6.0</version>
        <executions>
            <execution>
                <phase>package</phase>
                <goals>
                    <goal>shade</goal>
                </goals>
                <configuration>
                    <createDependencyReducedPom>false</createDependencyReducedPom>
                    <filters>
                        <filter>
                            <artifact>*:*</artifact>
                            <excludes>
                                <exclude>META-INF/*.SF</exclude>
                                <exclude>META-INF/*.DSA</exclude>
                                <exclude>META-INF/*.RSA</exclude>
                            </excludes>
                        </filter>
                    </filters>
                    <transformers>
                        <transformer implementation="org.apache.maven.plugins.shade.resource.ManifestResourceTransformer">
                            <mainClass>com.example.EventTimeWindowingJob</mainClass>
                        </transformer>
                    </transformers>
                </configuration>
            </execution>
        </executions>
    </plugin>
    The Maven Shade plugin packages the Kafka connector and its required libraries in the application JAR. The Flink runtime and connector base dependencies remain provided by the Flink cluster.
### Configure the Kafka Source and Transactional Sink
1. Open the event-time windowing application.
    Append the following imports to the existing import statements.
    ```java
    import org.apache.flink.api.common.serialization.SimpleStringSchema;
    import org.apache.flink.connector.base.DeliveryGuarantee;
    import org.apache.flink.connector.kafka.sink.KafkaRecordSerializationSchema;
    import org.apache.flink.connector.kafka.sink.KafkaSink;
    import org.apache.flink.connector.kafka.source.KafkaSource;
    import org.apache.flink.connector.kafka.source.enumerator.initializer.OffsetsInitializer;
    Locate the following class declaration:
    ```java
    Append the following constant immediately after the class declaration:
    ```java
    private static final String KAFKA_BOOTSTRAP_SERVERS =
            "flink-kafka-kafka-bootstrap.kafka.svc.cluster.local:9092";
    Locate the hardcoded event source that begins with:
    ```java
    Remove the `baseTime` declaration and the complete `env.fromElements()` block. Replace them with the following Kafka source configuration.
    ```java
    KafkaSource<String> kafkaSource = KafkaSource.<String>builder()
            .setBootstrapServers(KAFKA_BOOTSTRAP_SERVERS)
            .setTopics("flink-events")
            .setGroupId("flink-windowing-job")
            .setStartingOffsets(OffsetsInitializer.earliest())
            .setValueOnlyDeserializer(new SimpleStringSchema())
            .build();
            .fromSource(
                    kafkaSource,
                    WatermarkStrategy.noWatermarks(),
                    "Kafka input source")
            .map(Event::fromCsv)
    The Kafka source reads comma-separated event records from the `flink-events` topic. Flink stores the consumed Kafka offsets in checkpoints so the application can resume consistently after a restart or failure.
    Locate the following existing watermark block:
    ```java
            WatermarkStrategy
                                    event.timestamp);
    Replace it with:
    ```java
            WatermarkStrategy
                                    event.timestamp)
                    .withIdleness(Duration.ofSeconds(30));
    Locate the following constructor inside the `Event` class:
    ```java
        this.type = type;
        this.value = value;
    Append the following method after the constructor:
    ```java
    public static Event fromCsv(String record) {
        String[] fields = record.trim().split(",");
        if (fields.length != 3) {
            throw new IllegalArgumentException(
                    "Expected record format: type,value,timestamp");
        return new Event(
                fields[0].trim(),
                Long.parseLong(fields[1].trim()),
                Long.parseLong(fields[2].trim()));
    Locate the following declaration:
    ```java
    Append the following Kafka sink configuration after the declaration.
    ```java
    KafkaSink<String> kafkaSink = KafkaSink.<String>builder()
            .setRecordSerializer(
                    KafkaRecordSerializationSchema.builder()
                            .setTopic("flink-window-results")
                            .setValueSerializationSchema(
                            .build())
            .setDeliveryGuarantee(
                    DeliveryGuarantee.EXACTLY_ONCE)
            .setTransactionalIdPrefix(
                    "flink-windowing-")
            .setProperty(
                    "transaction.timeout.ms",
                    "900000")
            .build();
    The bootstrap address connects the Flink application to the internal Kafka service. The transactional ID prefix must be unique for each running Flink application that writes to the Kafka cluster.
    The transaction timeout is set to 15 minutes. This gives Flink enough time to recover and complete a checkpoint before Kafka expires an open transaction.
    Locate the following statement:
    ```java
    Append the following sink after the statement and before `env.execute()`.
    ```java
    tumblingResults
            .map(Event::toString)
            .returns(Types.STRING)
            .sinkTo(kafkaSink)
            .name("Exactly-once Kafka sink");
    The sink writes tumbling-window results to Kafka transactions. Flink commits each transaction only after the corresponding checkpoint completes. Consumers using the `read_committed` isolation level do not receive records from aborted transactions.
    The application:
    * Uses exactly-once checkpoints to maintain consistent state.
    * Writes window results to the `flink-window-results` topic.
    * Commits Kafka transactions after successful checkpoints.
    * Aborts incomplete transactions during recovery.
    * Allows consumers configured with the `read_committed` isolation level to ignore uncommitted and aborted records.
    $ mvn clean package
1. Verify that Maven compiled the application for Java 11.
    $ javap -verbose \
        target/classes/com/example/EventTimeWindowingJob.class \
        | grep "major version"
    The output shows `major version: 55`, which corresponds to Java 11.
1. Verify that the JAR bundles the Kafka connector classes.
    $ jar tf target/flink-session-job-1.0.0.jar | grep -E 'kafka/(sink/KafkaSink|source/KafkaSource)\.class'
    The output lists the `KafkaSink` and `KafkaSource` classes, which confirms the connector is shaded into the JAR.
### Deploy the Updated Flink Application
The Maven build stores the updated JAR on the local computer. Upload and run the JAR on the Flink Session Cluster.
1. Verify that the Flink REST service exists.
    $ kubectl get service flink-session-cluster-rest \
        -n flink
1. Forward local port 8081 to the Flink REST service.
    $ kubectl port-forward \
        service/flink-session-cluster-rest \
        -n flink \
        8081:8081 > /tmp/flink-port-forward.log 2>&1 &
1. Store the port-forward process ID.
    $ PORT_FORWARD_PID=$!
1. Wait for the Flink REST endpoint.
    $ until curl --silent --fail \
        http://localhost:8081/overview > /dev/null; do
        sleep 2
    done
1. Upload the application JAR.
    $ UPLOAD_RESPONSE=$(curl --silent --show-error --fail \
        --request POST \
        --header "Expect:" \
        --form "jarfile=@target/flink-session-job-1.0.0.jar" \
        http://localhost:8081/jars/upload)
1. Display the upload response.
    $ echo "$UPLOAD_RESPONSE"
    {"filename":"/tmp/flink-web-f92ea68e-87f4-453b-ad8f-e97f6b6cb6ff/flink-web-upload/6467357d-4412-400a-8f1a-d4652ce3dddf_flink-session-job-1.0.0.jar","status":"success"}
1. Extract the uploaded JAR identifier.
    $ JAR_ID=$(printf '%s' "$UPLOAD_RESPONSE" \
        | sed -E 's/.*"filename":"[^"]*\/([^"]+)".*/\1/')
1. Verify the JAR identifier.
    $ echo "$JAR_ID"
1. Submit the event-time application.
    $ RUN_RESPONSE=$(curl --silent --show-error --fail \
        --request POST \
        --header "Content-Type: application/json" \
        --data '{
          "entryClass": "com.example.EventTimeWindowingJob",
          "parallelism": 2
        "http://localhost:8081/jars/${JAR_ID}/run")
1. Display the submission response.
    $ echo "$RUN_RESPONSE"
    {"jobid":"cd7f0424cc4ce10e7e797cd0c55470a7"}
1. Extract the Flink job ID.
    $ JOB_ID=$(printf '%s' "$RUN_RESPONSE" \
        | sed -E 's/.*"jobid":"([^"]+)".*/\1/')
1. Verify the job ID.
    $ echo "$JOB_ID"
1. Check the application state.
    $ curl --silent --show-error \
        "http://localhost:8081/jobs/${JOB_ID}" \
        | grep -o '"state":"[^"]*"'
    "state":"RUNNING"
    A `RUNNING` state confirms that Flink submitted the application successfully and started its processing tasks.
1. Stop port forwarding.
    $ kill "$PORT_FORWARD_PID"
    Stopping the local port-forward does not stop the Flink job. It only closes the local connection to the Flink REST service.
## Run Apache Beam Pipelines on Flink
Apache Beam separates pipeline code from the processing engine that runs it. The Flink Runner translates a Beam pipeline into a Flink job and submits it to an existing Flink cluster.
### Create the Apache Beam Project
1. Switch to the main project directory.
1. Create a Maven project for the Beam pipeline.
    $ mkdir -p beam-job/src/main/java/com/example
1. Switch to the Beam project directory.
    $ cd beam-job
1. Create the Maven project configuration.
    $ nano pom.xml
    ```xml
        <artifactId>beam-flink-job</artifactId>
        <properties>
            <beam.version>2.75.0</beam.version>
        </properties>
        <dependencies>
            <dependency>
                <groupId>org.apache.beam</groupId>
                <artifactId>beam-sdks-java-core</artifactId>
                <version>${beam.version}</version>
            </dependency>
            <dependency>
                <artifactId>beam-runners-flink-1.20</artifactId>
            </dependency>
            <dependency>
                <groupId>org.slf4j</groupId>
                <artifactId>slf4j-simple</artifactId>
                <version>2.0.16</version>
                <scope>runtime</scope>
            </dependency>
        </dependencies>
        <build>
            <plugins>
                <plugin>
                </plugin>
                <plugin>
                    <executions>
                        <execution>
                            <goals>
                                <goal>shade</goal>
                            </goals>
                            <configuration>
                                <filters>
                                    <filter>
                                        <excludes>
                                        </excludes>
                                    </filter>
                                </filters>
                                <transformers>
                                        <mainClass>com.example.BeamFlinkPipeline</mainClass>
                                    </transformer>
                                    <transformer implementation="org.apache.maven.plugins.shade.resource.ServicesResourceTransformer"/>
                                </transformers>
                            </configuration>
                        </execution>
                    </executions>
                </plugin>
            </plugins>
        </build>
    </project>
    The configuration:
    * Java 11 keeps the application compatible with the Flink cluster.
    * The Beam SDK provides the pipeline API and transforms.
    * The Flink Runner submits Beam pipelines to Flink 1.20.x.
    * SLF4J provides command-line logging for the Beam client.
    * The Maven Shade plugin creates a runnable JAR with the required dependencies.
    * The transformers set the main class and preserve the service files required by Beam.
### Create the Beam Pipeline
1. Create the Beam application.
    $ nano src/main/java/com/example/BeamFlinkPipeline.java
    ```java
    import java.util.Arrays;
    import org.apache.beam.runners.flink.FlinkPipelineOptions;
    import org.apache.beam.runners.flink.FlinkRunner;
    import org.apache.beam.sdk.Pipeline;
    import org.apache.beam.sdk.PipelineResult;
    import org.apache.beam.sdk.options.PipelineOptionsFactory;
    import org.apache.beam.sdk.transforms.Count;
    import org.apache.beam.sdk.transforms.Create;
    import org.apache.beam.sdk.transforms.FlatMapElements;
    import org.apache.beam.sdk.transforms.MapElements;
    import org.apache.beam.sdk.values.TypeDescriptors;
    public class BeamFlinkPipeline {
        public static void main(String[] args) {
            FlinkPipelineOptions options =
                            .fromArgs(args)
                            .withValidation()
                            .as(FlinkPipelineOptions.class);
            options.setRunner(FlinkRunner.class);
            Pipeline pipeline = Pipeline.create(options);
            pipeline
                    .apply(
                            "Create records",
                            Create.of(
                                    "flink processes streaming data",
                                    "beam runs on flink",
                                    "flink provides fault tolerance"))
                    .apply(
                            "Split words",
                            FlatMapElements
                                    .into(TypeDescriptors.strings())
                                    .via(line -> Arrays.asList(
                                            line.toLowerCase().split("\\s+"))))
                    .apply(
                            "Count words",
                            Count.perElement())
                    .apply(
                            "Format results",
                            MapElements
                                    .via(result ->
                                            result.getKey()
                                                    + result.getValue()));
            PipelineResult result = pipeline.run();
            result.waitUntilFinish();
    The pipeline:
    * Creates a bounded collection of text records.
    * Splits each record into words.
    * Counts each word.
    * Formats the word-count results.
    * Waits until the bounded pipeline finishes.
### Build the Beam Pipeline
1. Build the application JAR.
    $ mvn clean package
    The Maven Shade plugin may display warnings about overlapping manifests, licenses, classes, and metadata. The build is successful when Maven returns:
    BUILD SUCCESS
1. Verify that Maven created the application JAR.
    $ ls -lh target/beam-flink-job-1.0.0.jar
    -rw-r--r--  1 darshansiroya  staff   162M 15 Jul 02:09 target/beam-flink-job-1.0.0.jar
    $ javap -verbose \
        target/classes/com/example/BeamFlinkPipeline.class \
    major version: 55
1. Verify that the application JAR contains the Flink Runner.
    $ jar tf target/beam-flink-job-1.0.0.jar \
        | grep 'FlinkRunner.class' \
        | head -n 1
    org/apache/beam/runners/flink/FlinkRunner.class
### Configure the Flink Runner
1. Verify that the Flink Session Cluster REST service exists.
        -n flink
        -n flink \
        8081:8081 > /tmp/beam-flink-port-forward.log 2>&1 &
    $ BEAM_PORT_FORWARD_PID=$!
        sleep 2
    done
### Submit the Beam Pipeline
1. Create a unique identifier for the submission.
    $ RUN_ID=$(date +%Y%m%d%H%M%S)
1. Create a unique Beam job name.
    $ BEAM_JOB_NAME="beam-flink-word-count-${RUN_ID}"
1. Verify the generated job name.
    $ echo "$BEAM_JOB_NAME"
    beam-flink-word-count-20260715021037
1. Submit the pipeline through the Flink Runner.
    $ java -jar target/beam-flink-job-1.0.0.jar \
        --runner=FlinkRunner \
        --flinkMaster=localhost:8081 \
        --parallelism=2 \
        --jobName="${BEAM_JOB_NAME}" \
        2>&1 | tee /tmp/beam-submission.log
    > Do not stop the command with :key_ctrl:+:key_c:. The Beam client translates the pipeline, submits it to Flink, and waits for the bounded job to finish.
1. Extract the Flink job ID from the submission log.
    $ BEAM_JOB_ID=$(sed -nE \
        "s/.*Successfully submitted job.*\(([0-9a-f]{32})\).*/\1/p" \
        /tmp/beam-submission.log \
        | tail -n 1)
    $ test -n "$BEAM_JOB_ID" && \
        echo "$BEAM_JOB_ID"
    a690d68afc390fcebddb6fff968a5304
### Verify the Beam Pipeline
1. Verify the name of the submitted job.
    $ curl --silent \
        "http://localhost:8081/jobs/${BEAM_JOB_ID}" \
        | grep -o '"name":"[^"]*"'
1. Check the job state.
    $ curl --silent \
    "state":"FINISHED"
    A `FINISHED` state confirms that the Flink Runner translated and executed the bounded Beam pipeline successfully.
    $ kill "$BEAM_PORT_FORWARD_PID"
## Set Up Monitoring and Observability
[Prometheus](https://prometheus.io/) collects metrics from Flink components and stores them as time-series data. [Grafana](https://grafana.com/) uses these metrics to display dashboards, while Alertmanager processes alerts generated by Prometheus.
### Install Prometheus and Grafana
1. Create a namespace for the monitoring resources.
    $ kubectl create namespace monitoring
1. Add the Prometheus Community Helm repository.
    $ helm repo add prometheus-community \
        https://prometheus-community.github.io/helm-charts
    $ helm repo update
1. Install the `kube-prometheus-stack` Helm chart.
    $ helm install monitoring \
        prometheus-community/kube-prometheus-stack \
        --namespace monitoring \
        --version 72.0.0 \
        --wait \
        --timeout 15m
    > Do not stop the installation with :key_ctrl:+:key_c:. The chart installs multiple workloads and Custom Resource Definitions and may take several minutes to complete.
    > This article pins version `72.0.0`. If you change the version, confirm the Grafana sidecar loads dashboards, because some newer chart releases ship a sidecar image that fails TLS verification against the Kubernetes API server and silently loads no dashboards. Check the [chart releases](https://github.com/prometheus-community/helm-charts/releases) for the latest version.
    The `kube-prometheus-stack` chart installs Prometheus Operator, Prometheus, Alertmanager, Grafana, Kubernetes metrics exporters, dashboards, and alerting rules.
1. Verify the Helm release.
    $ helm status monitoring \
1. Verify the monitoring pods.
    $ kubectl get pods \
    alertmanager-monitoring-kube-prometheus-alertmanager-0   2/2     Running   0          22h
    monitoring-grafana-59768694d4-z9vmm                      3/3     Running   0          22h
    monitoring-kube-prometheus-operator-54cddb4bcf-7w5tk     1/1     Running   0          22h
    monitoring-kube-state-metrics-797d5dd89-v6mrh            1/1     Running   0          22h
    monitoring-prometheus-node-exporter-mv28t                1/1     Running   0          22h
    monitoring-prometheus-node-exporter-phdzw                1/1     Running   0          22h
    monitoring-prometheus-node-exporter-tbc6k                1/1     Running   0          22h
    prometheus-monitoring-kube-prometheus-prometheus-0       2/2     Running   0          22h
1. Verify that the Prometheus Operator Custom Resource Definitions exist.
    $ kubectl get crd \
        servicemonitors.monitoring.coreos.com \
        prometheusrules.monitoring.coreos.com
    NAME                                    CREATED AT
    servicemonitors.monitoring.coreos.com   2026-07-17T22:22:43Z
    prometheusrules.monitoring.coreos.com   2026-07-17T22:22:42Z
### Enable the Prometheus Reporter in Flink
The Flink Prometheus reporter exposes JobManager and TaskManager metrics in a format that Prometheus can collect. The Flink image used by the Session Cluster already includes the Prometheus metrics plugin.
1. Verify that the Prometheus reporter JAR exists.
    $ kubectl exec \
        -n flink \
        deploy/flink-session-cluster -- \
        sh -c \
        'find /opt/flink/plugins -iname "flink-metrics-prometheus-*.jar"'
    /opt/flink/plugins/metrics-prometheus/flink-metrics-prometheus-1.20.5.jar
1. Configure the Session Cluster to expose Prometheus metrics on port 9249.
        -n flink \
        --type merge \
        -p '{
          "spec": {
              "metrics.reporter.prom.factory.class": "org.apache.flink.metrics.prometheus.PrometheusReporterFactory",
              "metrics.reporter.prom.port": "9249"
            "jobManager": {
              "podTemplate": {
                "spec": {
                  "containers": [
                      "name": "flink-main-container",
                      "ports": [
                          "name": "metrics",
                          "containerPort": 9249,
                          "protocol": "TCP"
            "taskManager": {
              "podTemplate": {
                "spec": {
                  "containers": [
                      "ports": [
                          "name": "metrics",
                          "protocol": "TCP"
    The configuration:
    * Enables the Prometheus reporter in the Flink Session Cluster.
    * Uses port 9249 for the metrics endpoint.
    * Adds a named metrics port to the JobManager and TaskManager containers.
    * Preserves the existing checkpointing and resource settings.
    Flink loads metric reporters through the `metrics.reporter.<name>.factory.class` setting. The Prometheus reporter exposes a pull-based endpoint and uses port 9249 by default.
1. Wait for the `FlinkDeployment` to become stable.
        -n flink \
        --timeout=600s
1. Verify that the Session Cluster pods are running.
        -n flink \
        -l app=flink-session-cluster
    flink-session-cluster-5754dddff9-h2rvx   1/1     Running   0          50s
    flink-session-cluster-taskmanager-1-1    1/1     Running   0          16s
1. Verify the reporter configuration.
        -n flink \
        -o jsonpath='{.spec.flinkConfiguration.metrics\.reporter\.prom\.factory\.class}{"\n"}{.spec.flinkConfiguration.metrics\.reporter\.prom\.port}{"\n"}'
    9249
1. Verify that the Flink pods expose the metrics port.
        -n flink \
        -l app=flink-session-cluster \
        -o jsonpath='{range .items[*]}{.metadata.name}{"\t"}{range .spec.containers[*].ports[*]}{.name}{": "}{.containerPort}{" "}{end}{"\n"}{end}'
    flink-session-cluster-5754dddff9-h2rvx	metrics: 9249 rest: 8081 jobmanager-rpc: 6123 blobserver: 6124
    flink-session-cluster-taskmanager-1-1	metrics: 9249 taskmanager-rpc: 6122
1. Test the Prometheus endpoint on each Flink pod.
    $ for POD in $(kubectl get pods \
        -n flink \
        -o jsonpath='{.items[*].metadata.name}'); do
        echo "Checking ${POD}"
        kubectl exec -n flink "$POD" -- \
            sh -c 'wget -qO- http://localhost:9249/metrics | head -n 5'
    done
### Configure Prometheus Scraping
A ServiceMonitor-based configuration requires a Kubernetes Service to discover the Flink metrics endpoints. The `ServiceMonitor` then instructs the Prometheus Operator to scrape the named metrics port exposed by that Service.
1. Create a metrics Service manifest.
    $ nano flink-metrics-service.yaml
      namespace: flink
        app: flink-session-cluster
        monitoring: flink
      clusterIP: None
        - name: metrics
          port: 9249
          targetPort: metrics
          protocol: TCP
    The Service:
    * Selects the Session Cluster JobManager and TaskManager pods.
    * Exposes the Flink Prometheus endpoint on port 9249.
    * Uses the named metrics container port configured earlier.
    * Uses a headless Service so Prometheus can discover each Flink pod as a separate target.
1. Create the metrics Service.
    $ kubectl apply -f flink-metrics-service.yaml
1. Verify the Service.
    $ kubectl get service flink-session-cluster-metrics \
        -n flink
    NAME                            TYPE        CLUSTER-IP   EXTERNAL-IP   PORT(S)    AGE
    flink-session-cluster-metrics   ClusterIP   None         <none>        9249/TCP   12s
1. Verify that the Service discovered the Flink pods.
    $ kubectl get endpointslices \
        -n flink \
        -l kubernetes.io/service-name=flink-session-cluster-metrics
    NAME                                  ADDRESSTYPE   PORTS   ENDPOINTS                 AGE
    flink-session-cluster-metrics-9rn5v   IPv4          9249    10.125.0.13,10.125.2.14   23s
1. Create a ServiceMonitor manifest.
    $ nano flink-service-monitor.yaml
    apiVersion: monitoring.coreos.com/v1
    kind: ServiceMonitor
      namespace: monitoring
        release: monitoring
      namespaceSelector:
        matchNames:
          - flink
          monitoring: flink
      endpoints:
        - port: metrics
          path: /metrics
          interval: 30s
          scrapeTimeout: 10s
    The `ServiceMonitor`:
    * Discovers the Flink metrics Service in the `flink` namespace.
    * Selects the Service using the `monitoring: flink` label.
    * Scrapes the named metrics port every 30 seconds.
    * Uses the `release: monitoring` label so Prometheus selects the resource.
1. Create the ServiceMonitor.
    $ kubectl apply -f flink-service-monitor.yaml
1. Verify the ServiceMonitor.
    $ kubectl get servicemonitor flink-session-cluster \
        -n monitoring
    NAME                    AGE
    flink-session-cluster   10s
1. Verify that its selector matches the metrics Service.
        -n monitoring \
        -o jsonpath='{.spec.selector.matchLabels.monitoring}{"\n"}{.spec.endpoints[0].port}{"\n"}'
    flink
    metrics
1. Wait for Prometheus to discover the new targets.
    $ sleep 30
1. Forward local port 9090 to the Prometheus Service.
        service/monitoring-kube-prometheus-prometheus \
        -n monitoring \
        9090:9090 > /tmp/prometheus-port-forward.log 2>&1 &
    $ PROMETHEUS_PORT_FORWARD_PID=$!
1. Wait for the Prometheus API.
        http://localhost:9090/-/ready > /dev/null; do
        sleep 2
    done
1. Query the Flink scrape targets.
    $ curl --silent --get \
        http://localhost:9090/api/v1/query \
        --data-urlencode \
        'query=up{namespace="flink",service="flink-session-cluster-metrics"}'
    A value of `"1"` confirms that the target is reachable and healthy.
1. Verify that Prometheus stores Flink metrics.
        --data-urlencode \
        'query=count({__name__=~"flink_.+"})'
    A value greater than zero confirms that Prometheus is collecting Flink metrics.
    $ kill "$PROMETHEUS_PORT_FORWARD_PID"
### Access Grafana and Verify Prometheus
Grafana visualizes the Flink metrics stored in Prometheus. The monitoring stack includes a preconfigured Prometheus data source, so Grafana can query the metrics without requiring an additional connection.
1. Retrieve the Grafana administrator password.
    $ GRAFANA_PASSWORD=$(kubectl get secret \
        monitoring-grafana \
        -n monitoring \
        -o jsonpath='{.data.admin-password}' | base64 --decode)
1. Display the password.
    $ echo "$GRAFANA_PASSWORD"
    Copy the displayed password. Use it to sign in to Grafana.
1. Forward local port 3000 to the Grafana service.
        service/monitoring-grafana \
        -n monitoring \
        3000:80 > /tmp/grafana-port-forward.log 2>&1 &
    $ GRAFANA_PORT_FORWARD_PID=$!
1. Wait until Grafana becomes available.
        http://localhost:3000/api/health > /dev/null; do
        sleep 2
    done
1. Verify the Grafana health status.
    $ curl --silent \
    ```json
      "database": "ok",
      "version": "13.1.0",
      "commit": "b309c9bb3b81a748c3a75289236a27309ed2566a"
1. Open `http://localhost:3000` in a web browser. The Grafana login screen appears.
    Sign in using the following credentials:
    * **Username:** `admin`
    * **Password:** The value displayed by the `echo "$GRAFANA_PASSWORD"` command.
    ![Flink Grafana](https://lhr1.vultrobjects.com/docs-main-doc-assets-1/2664/b0d4dd2d-adee-4213-bc58-57b8d749e56b.png)
1. Verify that the Prometheus data source is available.
    $ curl --silent \
        --user "admin:${GRAFANA_PASSWORD}" \
        http://localhost:3000/api/datasources/name/Prometheus
1. Retrieve the actual Prometheus data source UID.
    $ PROMETHEUS_UID=$(curl --silent \
        http://localhost:3000/api/datasources/name/Prometheus |
        python3 -c 'import sys,json; print(json.load(sys.stdin)["uid"])')
1. Query the Flink targets using the Prometheus data source UID.
    $ curl --silent \
        --get \
        "http://localhost:3000/api/datasources/proxy/uid/${PROMETHEUS_UID}/api/v1/query" \
        --data-urlencode \
### Deploy a Flink Grafana Dashboard
Create a Grafana dashboard for Flink availability, failed checkpoints, job restarts, and backpressure. Store it in a labeled Kubernetes ConfigMap so Grafana loads it automatically.
1. Create the dashboard manifest.
    $ nano flink-grafana-dashboard.yaml
    kind: ConfigMap
        grafana_dashboard: "1"
    data:
      flink-monitoring.json: |
          "title": "Apache Flink Monitoring",
          "uid": "flink-monitoring",
          "editable": true,
          "refresh": "30s",
          "schemaVersion": 39,
          "version": 1,
          "timezone": "browser",
          "time": { "from": "now-1h", "to": "now" },
          "panels": [
              "id": 1,
              "title": "JobManager Availability",
              "type": "stat",
              "datasource": { "type": "prometheus", "uid": "prometheus" },
              "gridPos": { "h": 6, "w": 12, "x": 0, "y": 0 },
              "targets": [ { "expr": "flink_jobmanager_numRunningJobs", "legendFormat": "Running jobs" } ]
              "id": 2,
              "title": "Failed Checkpoints",
              "type": "timeseries",
              "gridPos": { "h": 6, "w": 12, "x": 12, "y": 0 },
              "targets": [ { "expr": "flink_jobmanager_job_numberOfFailedCheckpoints", "legendFormat": "{{job_name}}" } ]
              "id": 3,
              "title": "Job Restarts",
              "gridPos": { "h": 6, "w": 12, "x": 0, "y": 6 },
              "targets": [ { "expr": "flink_jobmanager_job_numRestarts", "legendFormat": "{{job_name}}" } ]
              "id": 4,
              "title": "Max Task Backpressure",
              "gridPos": { "h": 6, "w": 12, "x": 12, "y": 6 },
              "targets": [ { "expr": "max(flink_taskmanager_job_task_backPressuredTimeMsPerSecond)", "legendFormat": "Backpressure ms/s" } ]
    The dashboard:
    * Displays the availability of the Flink JobManager and TaskManager targets.
    * Displays the failed checkpoints and job restarts reported by the running Flink jobs.
    * Displays the highest backpressure value reported by a Flink task.
    * Refreshes the dashboard every 30 seconds.
1. Create the dashboard ConfigMap.
    $ kubectl apply -f flink-grafana-dashboard.yaml
1. Verify the ConfigMap.
    $ kubectl get configmap flink-grafana-dashboard \
        -n monitoring
    NAME                      DATA   AGE
    flink-grafana-dashboard   1      8s
1. Verify that the dashboard label exists.
        -n monitoring \
        -o jsonpath='{.metadata.labels.grafana_dashboard}{"\n"}'
1. Wait for the Grafana dashboard sidecar to load the dashboard.
    $ sleep 30
1. Verify that Grafana registered the dashboard.
    $ curl --silent \
        "http://localhost:3000/api/search?query=Apache%20Flink%20Monitoring"
1. Open the following URL in a web browser.
    ```http
    http://localhost:3000/d/flink-monitoring/apache-flink-monitoring
    The Apache Flink Monitoring dashboard appears with panels for target availability, failed checkpoints, job restarts, and backpressure.
    ![Flink Monitoring](https://lhr1.vultrobjects.com/docs-main-doc-assets-1/2664/f67b75a9-eb58-4d37-a099-2ba5680f8d02.png)
### Configure Flink Alerts
Create Prometheus alerting rules for failed checkpoints, job restarts, and sustained backpressure. Prometheus evaluates these rules and sends active alerts to Alertmanager.
1. Create the alert rules manifest.
    $ nano flink-alert-rules.yaml
    kind: PrometheusRule
        release: monitoring
      groups:
        - name: flink.rules
            - alert: FlinkCheckpointFailure
              expr: increase(flink_jobmanager_job_numberOfFailedCheckpoints[10m]) > 0
              for: 1m
                severity: warning
                summary: "Flink checkpoint failure detected"
                description: "The Flink job {{ $labels.job_name }} recorded a failed checkpoint during the last 10 minutes."
            - alert: FlinkJobRestart
              expr: increase(flink_jobmanager_job_numRestarts[10m]) > 0
              for: 1m
                severity: warning
                summary: "Flink job restart detected"
                description: "The Flink job {{ $labels.job_name }} restarted during the last 10 minutes."
            - alert: FlinkTaskBackpressure
              expr: max by (job_name, task_name) (flink_taskmanager_job_task_backPressuredTimeMsPerSecond) > 500
              for: 5m
                severity: warning
                summary: "Flink task backpressure detected"
                description: "The task {{ $labels.task_name }} in job {{ $labels.job_name }} has remained backpressured for more than 500 milliseconds per second for five minutes."
    The alert rules:
    * Detect a failed checkpoint recorded during the last 10 minutes.
    * Detect a Flink job restart recorded during the last 10 minutes.
    * Detect task backpressure above 500 milliseconds per second for five minutes.
    * Use the `release: monitoring` label so Prometheus selects the resource.
    The `backPressuredTimeMsPerSecond` metric reports how many milliseconds during each second a task spent under backpressure. A value above 500 means the task remained backpressured for more than half of the measured period.
1. Create the `PrometheusRule`.
    $ kubectl apply -f flink-alert-rules.yaml
1. Verify the alert rules resource.
    $ kubectl get prometheusrule flink-alert-rules \
        -n monitoring
    NAME                AGE
    flink-alert-rules   4s
1. Verify the rule group and alert names.
        -n monitoring \
        -o jsonpath='{.spec.groups[0].name}{"\n"}{range .spec.groups[0].rules[*]}{.alert}{"\n"}{end}'
    flink.rules
    FlinkJobRestart
1. Forward local port 9090 to Prometheus.
        -n monitoring \
1. Wait until Prometheus becomes available.
        sleep 2
    done
1. Verify that Prometheus loaded the Flink rules.
    $ curl --silent \
        http://localhost:9090/api/v1/rules |
        python3 -c '
    import json, sys
    data = json.load(sys.stdin)
    for group in data["data"]["groups"]:
        for rule in group["rules"]:
            name = rule.get("name", "")
            if name.startswith("Flink"):
                print(name)
    FlinkJobRestart
1. Stop the Prometheus port-forward process.
1. Stop the Grafana port-forward process.
    $ kill "$GRAFANA_PORT_FORWARD_PID"
## Configure High Availability
### Enable the S3 Filesystem Plugin
Flink requires an S3 filesystem plugin to access Object Storage paths. The Flink image includes the S3 plugin in the `/opt/flink/opt` directory, but Flink only loads plugins from `/opt/flink/plugins`.
1. Verify that the Object Storage credentials secret exists.
    $ kubectl get secret flink-object-storage \
        -n flink
    NAME                   TYPE     DATA   AGE
    flink-object-storage   Opaque   2      9d
1. Verify that the Flink image includes the S3 filesystem plugin.
    $ kubectl exec \
        -n flink \
        deploy/flink-session-cluster \
        -c flink-main-container -- \
        find /opt/flink/opt \
        -name 'flink-s3-fs-hadoop-*.jar'
    /opt/flink/opt/flink-s3-fs-hadoop-1.20.5.jar
1. Configure an init container that copies the existing Flink plugins and the S3 filesystem plugin into a shared volume.
        -n flink \
        --type merge \
        -p '{
          "spec": {
            "podTemplate": {
              "spec": {
                "initContainers": [
                    "name": "enable-s3-plugin",
                    "image": "flink:1.20",
                    "command": [
                      "sh",
                      "-c",
                      "cp -R /opt/flink/plugins/. /flink-plugins/ && mkdir -p /flink-plugins/s3-fs-hadoop && cp /opt/flink/opt/flink-s3-fs-hadoop-*.jar /flink-plugins/s3-fs-hadoop/"
                    "volumeMounts": [
                        "name": "flink-plugins",
                        "mountPath": "/flink-plugins"
                "containers": [
                    "envFrom": [
                        "secretRef": {
                          "name": "flink-object-storage"
                    "volumeMounts": [
                        "mountPath": "/opt/flink/plugins"
                "volumes": [
                    "emptyDir": {}
    The configuration:
    * Copies the existing Flink plugins into a shared volume.
    * Adds the S3 filesystem plugin to the active plugin directory.
    * Loads the Object Storage credentials from the existing Kubernetes Secret.
    * Applies the plugin configuration to the JobManager and TaskManager pods.
        -n flink \
        --timeout=600s
1. Verify that the S3 filesystem plugin is available in the active plugin directory.
    $ kubectl exec \
        -n flink \
        find /opt/flink/plugins/s3-fs-hadoop \
    /opt/flink/plugins/s3-fs-hadoop/flink-s3-fs-hadoop-1.20.5.jar
1. Verify that the Prometheus plugin remains available.
    $ kubectl exec \
        -n flink \
        find /opt/flink/plugins/metrics-prometheus \
        -name 'flink-metrics-prometheus-*.jar'
1. Verify that the Object Storage credentials are loaded without displaying their values.
    $ kubectl exec \
        -n flink \
        sh -c '
          test -n "$AWS_ACCESS_KEY_ID" &&
          test -n "$AWS_SECRET_ACCESS_KEY" &&
          echo "Object Storage credentials loaded"
### Configure Kubernetes High Availability
Kubernetes high availability uses Kubernetes ConfigMaps for leader election. The configuration runs two JobManager replicas and stores recovery metadata in Object Storage so a standby JobManager can restore the cluster state after the active JobManager fails.
1. Configure high availability on the Session Cluster. Replace `YOUR_BUCKET_NAME` with your Object Storage bucket name and `YOUR_OBJECT_STORAGE_HOSTNAME` with your Object Storage hostname without the `https://` prefix.
        -n flink \
        --type merge \
        -p '{
          "spec": {
              "high-availability.type": "kubernetes",
              "high-availability.storageDir": "s3://YOUR_BUCKET_NAME/ha",
              "s3.endpoint": "YOUR_OBJECT_STORAGE_HOSTNAME",
              "s3.path.style.access": "true"
            "jobManager": {
              "replicas": 2
    The configuration:
    * Enables Kubernetes-based high availability.
    * Stores recovery metadata in the `YOUR_BUCKET_NAME` Object Storage bucket.
    * Connects Flink to the S3-compatible Object Storage endpoint.
    * Runs two JobManager replicas for leader and standby roles.
        -n flink \
        --timeout=600s
1. Verify the high-availability configuration.
        -n flink \
        -o jsonpath='{.spec.flinkConfiguration.high-availability\.type}{"\n"}{.spec.flinkConfiguration.high-availability\.storageDir}{"\n"}{.spec.flinkConfiguration.s3\.endpoint}{"\n"}{.spec.flinkConfiguration.s3\.path\.style\.access}{"\n"}{.spec.jobManager.replicas}{"\n"}'
    kubernetes
    true
    2
1. Verify the JobManager deployment status.
        -n flink \
        -o jsonpath='{.status.jobManagerDeploymentStatus}{"\n"}{.status.error}{"\n"}'
    READY
1. Verify the JobManager pods.
        -n flink \
        -l app=flink-session-cluster,component=jobmanager
    flink-session-cluster-7b76c4b74d-9fk26   1/1     Running   0          45h
    flink-session-cluster-7b76c4b74d-kb8jg   1/1     Running   0          45h
1. Verify the ConfigMaps used for high-availability coordination.
    $ kubectl get configmaps \
        -n flink \
    NAME        DATA   AGE
    flink-config-flink-session-cluster                                  2      45h
    flink-session-cluster-6edae41fdf49cfa041659b86ee1ce10a-config-map   2      45h
    flink-session-cluster-cluster-config-map                            5      45h
    pod-template-flink-session-cluster                                  1      45h
### Verify JobManager Pod Recovery
Delete one JobManager pod to verify that Kubernetes restores the replica count and that the Flink REST service becomes available after the pod is replaced.
1. Store the name of one JobManager pod.
    $ JOBMANAGER_POD=$(kubectl get pods \
        -n flink \
        -l app=flink-session-cluster,component=jobmanager \
        -o jsonpath='{.items[0].metadata.name}')
1. Display the stored pod name.
    $ echo "$JOBMANAGER_POD"
    flink-session-cluster-7b76c4b74d-5p5c8
1. Delete the selected JobManager pod.
    $ kubectl delete pod \
        -n flink \
        "$JOBMANAGER_POD"
1. Wait for the JobManager Deployment to restore both replicas.
    $ kubectl rollout status \
        -n flink \
        --timeout=600s
        -n flink \
    NAME                                     READY   STATUS    RESTARTS   AGE
    flink-session-cluster-7b76c4b74d-29v5s   1/1     Running   0          87s
    flink-session-cluster-7b76c4b74d-kb8jg   1/1     Running   0          46h
    The newer pod replaces the deleted JobManager replica.
1. Verify that the `FlinkDeployment` remains stable.
        -n flink \
        -o jsonpath='{.status.lifecycleState}{"\n"}{.status.jobManagerDeploymentStatus}{"\n"}{.status.error}{"\n"}'
    STABLE
    READY
        -n flink \
        8081:8081
    Keep this terminal open. Open a second terminal and query the cluster overview.
    $ curl --silent --fail \
    A successful response confirms that the Session Cluster REST endpoint is available after Kubernetes replaces the deleted JobManager pod.
### Configure Checkpoint Recovery
Store checkpoints and savepoints in Object Storage so Flink can recover job state after a pod failure.
1. Configure Object Storage as the checkpoint and savepoint location. Replace `YOUR_BUCKET_NAME` with your Object Storage bucket name.
        -n flink \
        --type merge \
        -p '{
          "spec": {
              "state.checkpoints.dir": null,
              "state.savepoints.dir": null,
              "execution.checkpointing.storage": "filesystem",
              "execution.checkpointing.dir": "s3://YOUR_BUCKET_NAME/checkpoints",
              "execution.checkpointing.savepoint-dir": "s3://YOUR_BUCKET_NAME/savepoints",
              "execution.checkpointing.externalized-checkpoint-retention": "RETAIN_ON_CANCELLATION",
              "execution.checkpointing.num-retained": "3"
    The configuration:
    * Removes the local checkpoint and savepoint paths.
    * Stores checkpoint data in Object Storage.
    * Stores savepoints in a separate Object Storage path.
    * Retains externalized checkpoints when a job is canceled.
    * Keeps the three most recent completed checkpoints.
        -n flink \
        --timeout=600s
1. Verify the checkpoint recovery configuration.
        -n flink \
        -o jsonpath='{.spec.flinkConfiguration.execution\.checkpointing\.storage}{"\n"}{.spec.flinkConfiguration.execution\.checkpointing\.dir}{"\n"}{.spec.flinkConfiguration.execution\.checkpointing\.savepoint-dir}{"\n"}{.spec.flinkConfiguration.execution\.checkpointing\.externalized-checkpoint-retention}{"\n"}{.spec.flinkConfiguration.execution\.checkpointing\.num-retained}{"\n"}'
    filesystem
    3
1. Verify that the local checkpoint and savepoint settings were removed.
        -n flink \
        -o jsonpath='{.spec.flinkConfiguration.state\.checkpoints\.dir}{"\n"}{.spec.flinkConfiguration.state\.savepoints\.dir}{"\n"}'
    The command returns two empty lines.
        -n flink \
        8081:8081
    Keep this terminal open. Open a second terminal and submit a long-running example job.
    $ JOB_SUBMISSION=$(kubectl exec \
        -n flink \
        /opt/flink/bin/flink run \
        -d \
        /opt/flink/examples/streaming/StateMachineExample.jar)
1. Display the submission result.
    $ echo "$JOB_SUBMISSION"
    The output includes the submitted job ID.
1. Store the job ID.
    $ JOB_ID=$(printf '%s\n' "$JOB_SUBMISSION" |
        grep -Eo '[0-9a-f]{32}' |
        tail -n 1)
1. Verify the stored job ID.
    $ echo "$JOB_ID"
1. Wait for Flink to complete at least one checkpoint.
    $ sleep 70
1. Query the latest completed checkpoint.
        "http://localhost:8081/jobs/${JOB_ID}/checkpoints" |
        python3 -c '
    import json, sys
    latest = data.get("latest", {}).get("completed")
    if not latest:
        raise SystemExit("No completed checkpoint found")
    print("Checkpoint ID:", latest["id"])
    print("Status:", latest["status"])
    print("External path:", latest["external_path"])
    Checkpoint ID: 10
    Status: COMPLETED
    External path: s3://YOUR_BUCKET_NAME/checkpoints/d06ad801e7ff022a1811e2ab16533cdf/chk-10
1. Cancel the example job after verification.
    $ kubectl exec \
        -n flink \
        /opt/flink/bin/flink cancel "$JOB_ID"
    Return to the first terminal and press :key_ctrl:+:key_c: to stop port forwarding.
## Configure Security
### Configure Namespace-Scoped RBAC
The Flink JobManager uses the `flink` service account to manage TaskManager pods and high-availability ConfigMaps. Create namespace-scoped permissions so the service account can manage these resources only in the `flink` namespace.
1. Verify that the Flink service account exists.
    $ kubectl get serviceaccount flink \
        -n flink
    NAME    AGE
    flink   13d
1. Create an RBAC manifest.
    $ nano flink-runtime-rbac.yaml
    apiVersion: rbac.authorization.k8s.io/v1
    kind: Role
      namespace: flink
      - apiGroups:
        resources:
          - pods
          - configmaps
        verbs:
          - get
          - list
          - watch
          - create
          - update
          - patch
          - delete
      - apiGroups:
          - apps
        resources:
          - deployments
          - deployments/finalizers
        verbs:
          - get
          - list
          - watch
          - create
          - update
          - patch
          - delete
    kind: RoleBinding
      namespace: flink
    subjects:
      - kind: ServiceAccount
        namespace: flink
    roleRef:
      apiGroup: rbac.authorization.k8s.io
      kind: Role
    The configuration:
    * Grants access only in the `flink` namespace.
    * Allows the JobManager to manage TaskManager pods and high-availability ConfigMaps.
    * Allows Flink to manage the Kubernetes Deployment used by the Session Cluster.
    * Binds the permissions to the existing `flink` service account.
1. Create the Role and RoleBinding.
    $ kubectl apply -f flink-runtime-rbac.yaml
1. Verify that the RoleBinding references the `flink-runtime` Role.
    $ kubectl get rolebinding flink-runtime \
        -n flink
    NAME            ROLE                 AGE
    flink-runtime   Role/flink-runtime   19s
1. Verify that the service account can create TaskManager pods in the `flink` namespace.
    $ kubectl auth can-i create pods \
        -n flink \
        --as=system:serviceaccount:flink:flink
    yes
1. Verify that the same permission does not apply in the `default` namespace.
        -n default \
    no
### Protect Object Storage Credentials
Store Object Storage credentials in a Kubernetes Secret instead of adding them directly to the `FlinkDeployment`. The Session Cluster loads the Secret values as environment variables without displaying the credential values in the deployment configuration.
1. Verify that the Secret contains the required keys without displaying their values.
        -n flink \
        -o go-template='{{range $key, $value := .data}}{{printf "%s\n" $key}}{{end}}'
    AWS_ACCESS_KEY_ID
1. Verify that the Session Cluster references the Object Storage Secret.
        -n flink \
        -o jsonpath='{.spec.podTemplate.spec.containers[?(@.name=="flink-main-container")].envFrom[0].secretRef.name}{"\n"}'
### Restrict Flink Network Access
Apply a Kubernetes NetworkPolicy to control inbound and outbound traffic for the Session Cluster. The policy allows Flink component communication, Prometheus metrics collection, Kafka access, DNS queries, and outbound HTTPS connections.
1. Verify that the Kubernetes NetworkPolicy API is available.
    $ kubectl api-resources \
        --api-group=networking.k8s.io |
        grep NetworkPolicy
    networkpolicies   netpol       networking.k8s.io/v1   true         NetworkPolicy
    > The NetworkPolicy API may be available even when the cluster network plugin does not enforce NetworkPolicy resources. Verify that your cluster uses a compatible network plugin before relying on the policy for traffic isolation.
1. Create a NetworkPolicy manifest.
    $ nano flink-network-policy.yaml
    kind: NetworkPolicy
      namespace: flink
      podSelector:
      policyTypes:
        - Ingress
        - Egress
      ingress:
            - podSelector: {}
            - namespaceSelector:
                  kubernetes.io/metadata.name: monitoring
            - protocol: TCP
              port: 9249
      egress:
        - to:
            - podSelector: {}
        - to:
                  kubernetes.io/metadata.name: kafka
            - protocol: TCP
              port: 9092
        - to:
                  kubernetes.io/metadata.name: kube-system
              podSelector:
                  k8s-app: kube-dns
            - protocol: UDP
              port: 53
            - protocol: TCP
              port: 53
        - to:
            - ipBlock:
                cidr: 0.0.0.0/0
            - protocol: TCP
              port: 443
    The policy:
    * Allows communication between Flink pods and other pods in the `flink` namespace.
    * Allows pods in the `monitoring` namespace to collect Prometheus metrics on port 9249.
    * Allows Flink jobs to connect to services in the `kafka` namespace on port 9092.
    * Allows DNS queries to the cluster DNS pods.
    * Allows outbound HTTPS connections on port 443, including connections to Object Storage.
1. Create the NetworkPolicy.
    $ kubectl apply -f flink-network-policy.yaml
1. Verify the NetworkPolicy.
    $ kubectl get networkpolicy flink-session-cluster \
        -n flink
    NAME                    POD-SELECTOR                AGE
    flink-session-cluster   app=flink-session-cluster   9s
1. Wait for the Session Cluster to remain stable.
        -n flink \
        --timeout=600s
1. Verify that the JobManager and TaskManager pods remain ready.
        -n flink \
    flink-session-cluster-64d45f7d57-sjkjf   1/1     Running   0          3d
    flink-session-cluster-64d45f7d57-vx2s7   1/1     Running   0          3d
    flink-session-cluster-taskmanager-1-1    1/1     Running   0          3d
    flink-session-cluster-taskmanager-1-2    1/1     Running   0          3d
## Verify the Deployment
### Verify the Flink Cluster Status
Verify the Session Cluster resources and confirm that the configured processing capacity is available.
1. Verify that the Session Cluster has reached the stable state.
        -n flink \
    STABLE
    READY
    The empty third line confirms that the `FlinkDeployment` does not report an error.
1. Verify the JobManager and TaskManager pods.
        -n flink \
1. Verify the Flink services.
    $ kubectl get services \
        -n flink \
    flink-session-cluster-metrics   ClusterIP   None            <none>        9249/TCP   7d23h
    flink-session-cluster-rest      ClusterIP   34.118.235.78   <none>        8081/TCP   3d
1. Verify the configured TaskManager replicas and task slots.
        -n flink \
        -o jsonpath='{.spec.taskManager.replicas}{"\n"}{.spec.flinkConfiguration.taskmanager\.numberOfTaskSlots}{"\n"}'
    2
    The Session Cluster runs two TaskManager replicas with two task slots each, providing four task slots in total.
### Produce Test Events
Create a temporary Kafka client pod and produce timestamped events to the `flink-events` topic.
1. Create a temporary Kafka client pod.
    $ kubectl run kafka-client \
        -n kafka \
        --image=quay.io/strimzi/kafka:1.1.0-kafka-4.3.0 \
        --restart=Never \
        --command -- sleep infinity
1. Wait for the pod to become ready.
    $ kubectl wait pod/kafka-client \
        -n kafka \
        --timeout=120s
1. Create a timestamp aligned with the current minute.
    $ BASE_TIME=$(( $(date +%s) / 60 * 60 * 1000 ))
1. Produce test events to the `flink-events` topic.
    $ printf "test:checkout,10,$((BASE_TIME + 5000))\n\
    test:checkout,15,$((BASE_TIME + 15000))\n\
    test:payment,20,$((BASE_TIME + 20000))\n\
    test:checkout,12,$((BASE_TIME + 30000))\n\
    test:payment,25,$((BASE_TIME + 40000))\n\
    test:checkout,30,$((BASE_TIME + 120000))\n" |
    kubectl exec -i kafka-client \
        -n kafka -- \
        bin/kafka-console-producer.sh \
        --bootstrap-server flink-kafka-kafka-bootstrap:9092 \
        --topic flink-events \
        --property parse.key=true \
        --property key.separator=:
    The producer uses `test` as the Kafka record key. Each record value contains the event type, numeric value, and event-time timestamp. The final record advances event time so Flink can complete the earlier window.
### Verify Window Results
1. Wait for the one-minute window and the next checkpoint to complete.
    $ sleep 90
1. Read committed results from the output topic.
    $ kubectl exec -i kafka-client \
        -n kafka -- \
        bin/kafka-console-consumer.sh \
        --topic flink-window-results \
        --from-beginning \
        --consumer-property isolation.level=read_committed \
        --max-messages 2 \
        --timeout-ms 30000
    Confirm that the consumer displays the aggregated `checkout` and `payment` events. The `read_committed` isolation level hides incomplete and aborted Kafka transactions.
### Test Failure Recovery
Delete a TaskManager pod to simulate a failure, and verify that Kubernetes replaces the pod and Flink returns the streaming job to the `RUNNING` state.
1. Store the name of a running TaskManager pod.
    $ TASKMANAGER_POD=$(kubectl get pods \
        -n flink \
        -o name | grep taskmanager | head -n 1)
1. Delete the TaskManager pod to simulate a failure.
    $ kubectl delete "$TASKMANAGER_POD" -n flink
1. Wait for two TaskManager pods to reach the `Running` state.
    $ until [ "$(kubectl get pods \
        -n flink \
        --field-selector=status.phase=Running \
        -o name | grep -c taskmanager)" -eq 2 ]; do
        sleep 5
    done
1. Verify that the replacement TaskManager pod is running.
        -n flink \
        -n flink \
        8081:8081 > /tmp/flink-recovery-port-forward.log 2>&1 &
    $ RECOVERY_PORT_FORWARD_PID=$!
1. Wait for the REST endpoint to become available.
        sleep 2
    done
1. Retrieve the running Flink job ID.
    $ JOB_ID=$(curl --silent \
        http://localhost:8081/jobs/overview \
        | python3 -c 'import sys,json; jobs=json.load(sys.stdin)["jobs"]; print(next(job["jid"] for job in jobs if job["name"] == "Event-Time Windowing Job" and job["state"] == "RUNNING"))')
    $ echo "$JOB_ID"
1. Verify that the Flink job returned to the `RUNNING` state.
    $ kill "$RECOVERY_PORT_FORWARD_PID"
1. Delete the temporary Kafka client pod.
    $ kubectl delete pod kafka-client -n kafka
## Migrate from GCP Dataflow to Apache Flink
Migrating from GCP Dataflow to Apache Flink involves changing the pipeline runner, replacing Google Cloud-specific services, and adapting deployment, state, scaling, and monitoring workflows to Kubernetes.
### Beam Pipeline Migration
Apache Beam pipelines can run on Flink when they use Beam-portable transforms and connectors.
* **Migration:** Replace `DataflowRunner` with `FlinkRunner` in the pipeline options.
* **Connector changes:** Replace Google Cloud-specific sources and sinks, such as Pub/Sub, BigQuery, and GCS connectors, with portable alternatives such as Kafka, JDBC-compatible databases, and Object Storage.
* **Validation:** Run the pipeline locally or on a test Flink Session Cluster before migrating production workloads. Verify serialization, dependency packaging, parallelism, and event-time behavior.
### Stateful Pipeline Migration
Dataflow state cells and timers must be reviewed before moving stateful processing to Flink.
* **Migration:** Map per-key Dataflow state to Flink keyed state, such as `ValueState`, `ListState`, `MapState`, or `ReducingState`.
* **State access:** Apply `keyBy()` before accessing keyed state and confirm that the selected key produces the same state partitioning used by the Dataflow pipeline.
* **Recovery:** Configure durable checkpoints and savepoints before migrating stateful production jobs. Test application restarts and upgrades using representative state volumes.
### Windowing and Trigger Migration
Apache Beam window definitions are portable, but runner-specific timing behavior may differ.
* **Migration:** Retain compatible tumbling, sliding, and session window assignments when moving Beam pipelines to the Flink Runner.
* **Late data:** Verify watermarks, allowed lateness, accumulation modes, and side outputs using delayed and out-of-order events.
* **Triggers:** Test processing-time, event-time, and composite triggers because firing frequency and pane timing can differ between runners.
### Template and Scheduling Migration
Dataflow Templates package reusable pipelines for repeatable execution.
* **Migration:** Replace Dataflow Templates with versioned Flink application JARs or container images.
* **Deployment:** Submit reusable jobs through `FlinkSessionJob` resources, the Flink REST API, or dedicated `FlinkDeployment` application clusters.
* **Scheduling:** Replace Cloud Scheduler-based submissions with Kubernetes CronJobs or an external workflow orchestrator such as Apache Airflow.
### Data Storage Considerations
Dataflow workloads commonly depend on Google Cloud storage and messaging services.
* **Google Cloud Storage:** Migrate pipeline files, checkpoints, and intermediate data to S3-compatible Object Storage. Update storage paths, endpoints, and credentials in the Flink configuration.
* **Pub/Sub:** Replace Pub/Sub sources and sinks with Kafka topics when the workload requires portable event streaming.
* **BigQuery:** Replace BigQuery sinks with a compatible database, data warehouse, JDBC destination, or Object Storage format based on the workload requirements.
* **Credentials:** Replace Google service-account credentials with Kubernetes Secrets, workload-specific service accounts, and storage access keys.
### Things to Take Care During Migration
* **Google Cloud connectors:** Beam connectors designed specifically for GCP may not work with the Flink Runner without replacement or additional configuration.
* **Autoscaling:** Dataflow manages worker scaling automatically. Flink requires Reactive Mode, Kubernetes Horizontal Pod Autoscaling, or operator-managed scaling policies.
* **Streaming Engine:** Dataflow Streaming Engine optimizations do not have a direct Flink equivalent. Re-evaluate memory, network, state backend, and checkpoint settings.
* **Access control:** Replace Google Cloud IAM roles with Kubernetes RBAC, namespace permissions, service accounts, and external storage policies.
* **Monitoring:** Replace Cloud Monitoring and Dataflow metrics with Prometheus, Grafana, Flink metrics, and Kubernetes alerts.
* **Large state:** Tune checkpoint intervals, timeouts, incremental checkpoints, state backend storage, and restart strategies before migrating workloads with large state.
* **Parallelism:** Dataflow worker counts do not map directly to Flink parallelism. Benchmark source partitions, task slots, operator parallelism, and backpressure before production migration.
* **Delivery guarantees:** Verify that every source and sink supports the required delivery guarantee. End-to-end exactly-once processing requires checkpoint-compatible sources and transactional or idempotent sinks.
You have successfully deployed Apache Flink on Kubernetes Engine as a self-hosted alternative to GCP Dataflow. The deployment includes Session and Application Clusters, durable state management with Object Storage, event-time windowing, exactly-once Kafka processing, Apache Beam pipelines, Prometheus and Grafana monitoring, high availability, security controls, and migration guidance for existing Dataflow workloads. For more information, refer to the [official Apache Flink documentation](https://nightlies.apache.org/flink/flink-docs-stable/) and the [official Apache Flink Kubernetes Operator documentation](https://nightlies.apache.org/flink/flink-kubernetes-operator-docs-release-1.15/).
