title: How to Deploy Cursor Projects on Vultr Using Coolify
url: https://docs.vultr.com/how-to-deploy-cursor-projects-on-vultr-using-coolify
description: Generate app with Cursor, deploy via Coolify on Vultr, and automate deployments with GitHub CI/CD.
publish_date: 2026-04-02T17:00:49.870505Z
last_updated: 2026-04-16T00:00:00.077250Z
author: Martin Sustak
header_image: https://lhr1.vultrobjects.com/docs-main-doc-assets-1/2536/9f3a0476-edd5-41f8-bc2a-90a9aeb9f110.png
[Cursor](https://www.cursor.com/) is an AI-powered code editor built on VS Code that uses large language models to generate, refactor, and debug full-stack applications through natural language prompts. [Coolify](https://coolify.io/) is a self-hosted platform-as-a-service that orchestrates Docker containers, manages Traefik reverse proxy routing, and provisions Let's Encrypt TLS certificates automatically.
This guide explains how to set up Cursor, generate a full-stack application with AI assistance, push the code to GitHub, and deploy it on Vultr using Coolify.
* Have a [Cursor](https://cursor.com/) account.
* Have a [GitHub](https://github.com) account.
* [Deploy the Vultr Marketplace Application for Coolify](https://docs.vultr.com/how-to-use-vultr-s-coolify-marketplace-application#deploy-the-vultr-marketplace-application-for-coolify) with at least 2 GB RAM and 1 CPU core.
* Configure a [DNS A record](https://docs.vultr.com/products/network/dns/management/manage-records) pointing to your server's IP address (for example, `app.example.com`).
## Set Up Cursor
Cursor functions as a standalone code editor with integrated AI capabilities. Install and authenticate the application before creating a new project.
1. Download and install [Cursor](https://cursor.com/download).
1. Launch the application and sign in with your Cursor account.
1. Complete the initial environment preferences configuration when prompted.
Cursor generates application code directly in the editor through its AI chat interface. The generated project needs a Dockerfile so Coolify can build and deploy the containers. For multi-service applications, include a `docker-compose.yml` file.
1. Open a new, empty project directory in Cursor.
1. Open the AI chat panel. Press :key_ctrl: + :key_i: on Windows or Linux, or :key_cmd: + :key_i: on macOS.
1. Enter a detailed prompt describing your application. Specify the technology stack, required features, and request a Dockerfile for containerized deployment. For applications with multiple services, also request a `docker-compose.yml` file. Cursor generates the source code, project structure, and container configurations based on your description.
1. Review the generated files to verify the project structure and Docker configuration.
1. Optionally, test the application locally using the generated Docker configuration. Refer to the generated README for local setup instructions.
1. Open the integrated terminal. Press :key_ctrl: + `` ` `` on Windows or Linux, or :key_cmd: + `` ` `` on macOS.
1. Initialize a Git repository.
    $ git init
1. Stage all generated files.
    $ git add .
1. Commit the files to your local repository.
    $ git commit -m "Initial application generated with Cursor"
1. Create a new repository on [GitHub](https://github.com/new).
1. Add the GitHub repository as a remote. Replace `YOUR_USERNAME` and `my-cursor-app` with your GitHub username and repository name.
    $ git remote add origin https://github.com/YOUR_USERNAME/my-cursor-app.git
1. Set the default branch to main.
    $ git branch -M main
1. Push the code to your GitHub repository.
    $ git push -u origin main
## Access the Coolify Dashboard
Coolify serves its administration interface on port 8000. The initial login creates the administrator account that controls all deployments and server settings.
1. Open your instance's Management Page in the [Vultr Console](https://console.vultr.com/) and scroll down to **App Instructions**. The Coolify endpoint URL appears there in the format `http://SERVER_IP:8000`.
1. Open the URL in a browser. The first-run wizard prompts you to create an administrator account. Complete the required fields and submit the form.
1. Coolify opens the dashboard after the account is created. The administrator account controls all deployments, team members, and server settings.
## Connect GitHub Repository
A GitHub source entry tells Coolify where to pull code from during builds. Adding the source once makes it available to every project on the server.
1. Click **Sources** in the Coolify dashboard.
1. Click **Add Source** and select **GitHub**.
1. Coolify redirects to GitHub for OAuth authorization. Click **Authorize** to grant access.
1. GitHub redirects back to Coolify after successful authorization. Coolify displays your GitHub account in the Sources list.
## Create a New Project
Coolify uses projects to group related applications, databases, and services. Resources within the same project share a common Docker network.
1. Click **Projects** in the Coolify dashboard.
1. Click **Add Project**.
1. Enter a project name, such as `my-cursor-app`.
1. Click **Create**. Coolify displays the project details page.
## Deploy the Application
Coolify fetches source code from the GitHub repository, builds Docker images based on the Dockerfile or `docker-compose.yml`, and starts the containers with Traefik routing configured automatically.
1. Click **Add Resource** in the project details page.
1. Select **Application** as the resource type.
1. Choose **GitHub** as the source.
1. Select your Cursor application repository from the dropdown.
1. Enter the branch name, typically `main`.
1. Coolify analyzes the repository and detects the Docker configuration. Select **Docker Compose** as the build pack for multi-container applications.
1. Click **Continue**.
1. Coolify generates a temporary domain in the format `RANDOM_ID.SERVER_IP.sslip.io` for immediate testing. Configure a custom domain later for production use.
1. Click **Save**. Coolify redirects to the application configuration page.
## Configure Environment Variables
Sensitive configuration values such as API keys and database credentials belong in Coolify's environment variable storage rather than in source code. Coolify passes these values to containers at runtime.
1. Open the application details page.
1. Click **Environment Variables**.
1. Click **+Add** to create a new variable.
1. Enter the variable name and value. Common variables for Cursor applications include:
    * `DATABASE_URL`: PostgreSQL connection string, such as `postgresql://user:pass@db:5432/dbname`
    * `API_KEY`: External service API key, such as `sk_live_abc123`
    * `NODE_ENV`: Runtime environment, such as `production`
    * `NEXT_PUBLIC_API_URL`: Frontend API endpoint, such as `https://api.example.com`
1. Click **Save** after adding all required variables.
## Start the Deployment
Once the repository and environment variables are configured, initiate the build to create and launch the application containers.
1. Click **Deploy** to trigger the deployment process.
1. Coolify schedules the build. Select **Logs** to track each stage as it runs.
    Each deployment runs through the following sequence:
    1. Cloning the repository
    1. Building Docker images for each service
    1. Starting containers
    1. Configuring Traefik routing rules
    1. Requesting TLS certificates
    The full sequence takes 3-5 minutes for a typical application.
1. When deployment completes successfully, the application status changes to **Running**.
## Verify Deployment
Test that the application loads correctly using the temporary domain before switching to production.
1. Click **Links** in the application details page to view accessible URLs.
1. Click the Coolify-generated domain link to open your application.
1. Your application loads at `http://RANDOM_ID.SERVER_IP.sslip.io`. Verify that all features function correctly.
## Configure Custom Domain with HTTPS
Replace the temporary `sslip.io` domain with your custom domain for production use. Coolify automatically provisions Let's Encrypt TLS certificates.
1. Navigate to the application details page.
1. Click **Configuration** in the left sidebar.
1. Edit the **Domains** field, removing the temporary domain and replacing it with your custom domain. Enter the value as `https://app.example.com` so Coolify knows to provision HTTPS.
1. Enable **Automatic HTTPS** to provision Let's Encrypt certificates.
1. Click **Save**.
1. Click **Redeploy** to apply the domain configuration.
1. Coolify rebuilds and reconfigures Traefik with the new hostname, then requests a certificate from Let's Encrypt. This takes 2-3 minutes.
1. Load the custom domain in your browser and check that the address bar shows a padlock, confirming the TLS certificate is valid.
## Add a Database
Coolify deploys database containers within the same project, connected over an internal Docker network. The internal connection URL keeps database traffic isolated from the public internet.
1. Navigate back to the project details page.
1. Click **Add Resource**.
1. Select **Database**.
1. Choose **PostgreSQL** as the database type.
1. Type a name for the database, such as `app-db`.
1. Click **Create**. Coolify starts the container and generates login credentials.
1. Copy the connection string shown on the database details page.
1. Open the **Environment Variables** section for your application.
1. Add `DATABASE_URL` as a new variable and paste the connection string as the value.
1. Click **Restart** so the application picks up the updated database configuration.
## Configure CI/CD Pipeline
Coolify supports continuous deployment through GitHub webhooks, automatically rebuilding and redeploying your application on every push.
### Enable Automatic Deployments
1. Click **Settings**.
1. Enable **Automatic Deployment**.
1. Coolify shows the generated webhook URL. Copy it.
1. Open the GitHub repository that holds your application code.
1. Go to **Settings**, then click **Webhooks** and select **Add webhook**.
1. Enter the Coolify webhook URL in the **Payload URL** field.
1. Select **application/json** as the content type.
1. Choose **Just the push event**.
1. Click **Add webhook** to register it.
1. GitHub sends an initial test event. Check that a green checkmark appears next to the webhook entry.
### Test the CI/CD Pipeline
Confirm that pushing code to GitHub triggers an automatic rebuild and deployment in Coolify.
1. Edit any file in your application code.
1. Stage the changes.
    $ git add .
1. Commit the changes.
    $ git commit -m "Update application feature"
1. Push to GitHub.
    $ git push origin main
1. Coolify detects the push event and starts a new deployment automatically.
1. Open the application details page in Coolify.
1. Click **Deployments** to view the deployment history.
1. The most recent entry appears at the top with a **Building** status.
1. Click **Logs** to follow the build output in real time.
1. When the build completes, the deployment status changes to **Finished** and the application restarts with the updated code.
### Configure GitHub Actions for Testing
Set up a GitHub Actions workflow to run automated tests before every deployment. Coolify receives the webhook only after all checks pass, blocking broken code from reaching production.
1. Create the GitHub Actions workflow directory.
    $ mkdir -p .github/workflows
1. Open a new workflow file in a text editor.
    $ nano .github/workflows/ci.yaml
1. Paste the following configuration into the file. Update the test commands to match your application stack.
    on:
      push:
        branches: [ main ]
      pull_request:
        branches: [ main ]
    jobs:
      test:
        runs-on: ubuntu-latest
        steps:
          - uses: actions/checkout@v4
          - name: Run tests
            run: |
              # Add your test commands here
              # Example for Node.js:
              # npm install && npm test
              # Example for Go:
              # go test ./...
              echo "Tests passed"
1. Stage the workflow file.
    $ git add .github/workflows/ci.yaml
    $ git commit -m "Add CI workflow"
1. Push to GitHub.
1. GitHub Actions runs the tests on every push. Coolify deploys the application only after the workflow completes successfully.
You have successfully created a full-stack application with Cursor, pushed the code to GitHub, and deployed it on Vultr using Coolify. The application now serves traffic over a custom domain with automatic HTTPS and redeploys on every push to the repository. For more information, visit the [official Coolify documentation](https://coolify.io/docs).
