title: How to Deploy GitHub Copilot Projects on Vultr Using Dokploy
url: https://docs.vultr.com/how-to-deploy-github-copilot-projects-on-vultr-using-dokploy
description: Create app with GitHub Copilot, push to GitHub, and deploy on Dokploy with HTTPS.
publish_date: 2026-04-02T16:43:27.646227Z
last_updated: 2026-04-16T00:00:00.077250Z
author: Martin Sustak
header_image: https://lhr1.vultrobjects.com/docs-main-doc-assets-1/2532/415cb8db-6fd0-4d50-ac56-410986e48ebb.png
GitHub Copilot is an AI-powered developer tool integrated into VS Code that uses natural language prompts to generate code and automate tasks such as application creation, feature implementation, and environment configuration. Dokploy is an open-source platform-as-a-service that automates infrastructure provisioning and Docker orchestration for self-hosted environments.
This guide explains how to create a full-stack application using GitHub Copilot, export the source code to GitHub, and deploy it on Vultr using Dokploy.
* Have a [GitHub](https://github.com/) account with [GitHub Copilot](https://github.com/features/copilot/plans) enabled. A free tier is available; paid plans offer higher usage limits.
* Have access to an [Ubuntu 24.04 server](https://www.vultr.com/servers/ubuntu/) as a [non-root user with sudo privileges](https://docs.vultr.com/how-to-create-a-sudo-user-in-linux).
* [Install Dokploy and create your administrator account](https://docs.vultr.com/how-to-deploy-dokploy-self-hosted-paas-for-docker-applications).
* Set up a domain name, such as `app.example.com`, and point it to your server's public IP address using an A record.
* Download and install [Visual Studio Code](http://code.visualstudio.com). After launching, click the **Copilot icon** in the Status Bar and sign in with your GitHub account. VS Code installs the GitHub Copilot and GitHub Copilot Chat extensions automatically.
Prompt the GitHub Copilot agent to generate the project files and push the codebase to a remote GitHub repository.
1. Create a new empty directory and open it in VS Code.
1. Open the Chat View by pressing :key_ctrl: + :key_alt: + :key_i:.
1. In the prompt field, describe your application and request the agent to make it compatible with Dokploy. Specify all required features and the preferred service stack. Ask for a `docker-compose.yml` if the application involves multiple services.
1. Wait for the GitHub Copilot agent to generate the application files.
1. Optionally, test the application locally. The generated `README.md` file contains steps to run the application on your machine.
1. Provision a new, empty repository on GitHub via the web interface.
1. Initialize the local Git repository.
    $ git init
1. Stage the generated files for commit.
    $ git add .
1. Commit the files to the local repository.
    $ git commit -m "Initial commit"
1. Set the default branch to main.
    $ git branch -M main
1. Add your GitHub repository as a remote. Replace `YOUR_REPOSITORY_URL` with your repository's URL.
    $ git remote add origin YOUR_REPOSITORY_URL
1. Push the source code to GitHub.
    $ git push -u origin main
## Connect GitHub Repository
Connect your GitHub account with Dokploy to grant it access to pull code from your repositories.
1. Navigate to your instance's IP address on port `3000` (like 192.0.2.1:3000) in a web browser to open the Dokploy dashboard.
1. Log in to the administrator account.
1. Select **Git** under **Settings** in the left sidebar.
1. Click **GitHub**, then click **Create GitHub App**.
1. Follow the GitHub OAuth prompts to authorize the app and select the repositories Dokploy can access.
## Create a New Project
Projects in Dokploy isolate different application environments.
1. Click **Projects** in the left sidebar.
1. Click **Create Project**, enter a project name, and click **Create**.
1. Click on the newly created project to open it.
## Connect the Code Repository
Deploy the application by specifying the source repository and creating a new Docker Compose service.
1. On your project page, click **Create Service** and select **Compose**.
1. Enter a name for your service and click **Create**.
1. Open your new Compose service.
1. Locate the **Github** configuration section.
1. Select your GitHub account and repository.
1. Set the correct **Branch**.
1. Click **Save** to apply the repository settings.
1. Open the `docker-compose.yml` file in your local repository and make the following two adjustments to the web service before deploying:
    * Remove any `ports:` mappings. Dokploy routes traffic through Traefik, so the web service does not need to bind a port on the host.
    * Add `dokploy-network` to the service's networks so Traefik can reach the container:
    services:
      web:
        networks:
          - default
          - dokploy-network
    networks:
      dokploy-network:
        external: true
    Replace `web` with the actual service name from your compose file.
1. Commit and push the changes to your repository.
## Start the Deployment
Dokploy fetches the source code and builds the Docker containers when you trigger a deployment. If your application requires environment variables such as API keys or database credentials, set them under the **Environment** tab before deploying.
1. Switch to the **General** settings tab.
1. Click **Deploy**, then click **Confirm**.
1. Click **View** to monitor the real-time deployment logs.
## Verify Deployment
Connect your domain for a production-ready URL and encrypted traffic. Dokploy provisions a Let's Encrypt SSL certificate through Traefik when you enable HTTPS.
1. Navigate to the **Domains** tab and click **Add Domain**.
1. Select the name of your web service container in the **Service Name** field, for example `web`.
1. Type your custom domain into the **Host** field.
1. Enable the **HTTPS** toggle.
1. Select **Let's Encrypt** from the **Certificate Provider** dropdown.
1. Click **Create**.
1. Click **Validate DNS** to verify your domain's DNS configuration.
## Add a Database
Dokploy supports deploying managed database containers within the same project. The internal connection URL connects the database directly to your application over Docker's internal network without exposing it to the internet.
1. Navigate to your project page.
1. Click **Create Service** and select **Database**.
1. Select the database type that matches your application's requirements.
1. Enter a name for the database and click **Create**.
1. Open the database service page and click **Deploy**.
1. Copy the **Internal Connection URL**.
1. Go to the **Environment** tab in your application's configuration page.
1. Create or update the `DATABASE_URL` variable and paste the copied connection URL as the value.
1. Click **Save**.
You have successfully created an application using GitHub Copilot, exported the generated source code to GitHub, and deployed it to a Vultr instance using Dokploy. For more information and advanced configuration options, refer to the [official Dokploy documentation](https://docs.dokploy.com/docs/core).
