title: How to Deploy GitLab CE – DevOps Management Suite
url: https://docs.vultr.com/how-to-deploy-gitlab-ce-devops-management-suite
description: Deploy GitLab CE with Docker Compose and Traefik for secure, production-ready DevOps workflows.
publish_date: 2025-12-11T21:45:00.204515Z
last_updated: 2026-09-11T16:40:09.175351Z
author: Jivendra Sah
header_image: https://docs.vultr.com/public/doc-assets/2422/27f0f1a1-4f84-4b26-8c1e-6b4e484b022a.png
GitLab CE (Community Edition) is a complete, open-source DevOps platform. Unlike lightweight alternatives, GitLab provides a comprehensive suite of tools in a single application, including source code management, CI/CD pipelines, security testing, and project planning.
This article demonstrates how to deploy GitLab CE on Ubuntu 24.04 using Docker Compose and secure it with HTTPS via a Traefik reverse proxy.
* Have access to an [Ubuntu 24.04 server](https://www.vultr.com/servers/ubuntu/) as a [non-root user with sudo privileges](https://docs.vultr.com/how-to-create-a-sudo-user-in-linux). Refer the [official Gitlab installation requirements page](https://docs.gitlab.com/install/requirements/) to estimate the system requirements for your workload.
* [Install Docker and Docker Compose](https://docs.vultr.com/how-to-install-docker-on-ubuntu-24-04#install-docker).
* Configure a domain name, such as `gitlab.example.com`, to point to your server’s public IP address.
## Set Up the Directory Structure and Environment Variables
Set up the project directory to store persistent GitLab configuration, logs, data, and Let's Encrypt certificates.
1. Create folders to store GitLab volumes and Let's Encrypt certificates.
    $ mkdir -p ~/gitlab/{config,logs,data,letsencrypt}
    * `config` - GitLab configuration files.
    * `logs` - Logs for the various bundled services.
    * `data` - Repositories and database data.
    * `letsencrypt` - Traefik ACME certificates.
1. Navigate to the root GitLab directory.
    $ cd ~/gitlab
1. Create a file named `.env` in the project directory to store the environment variables.
    $ nano .env
    Add these values:
    ```ini
    GITLAB_DOMAIN=gitlab.example.com
    LETSENCRYPT_EMAIL=admin@example.com
    Replace `gitlab.example.com` with your domain and `admin@example.com` with your email. Save and close the file.
## Deploy with Docker Compose
Deploy GitLab with Docker Compose using the official Omnibus image and Traefik as the reverse proxy.
1. Add your user account to the docker user group.
    $ sudo usermod -aG docker $USER
1. Apply new group membership.
    $ newgrp docker
1. Create and edit a Docker Compose manifest file.
    $ nano docker-compose.yml
1. Add the following contents:
    services:
      traefik:
        image: traefik:latest
        container_name: traefik
        restart: unless-stopped
        environment:
          DOCKER_API_VERSION: "1.44"
        command:
          - "--providers.docker=true"
          - "--providers.docker.exposedbydefault=false"
          - "--entrypoints.web.address=:80"
          - "--entrypoints.websecure.address=:443"
          - "--entrypoints.web.http.redirections.entrypoint.to=websecure"
          - "--entrypoints.web.http.redirections.entrypoint.scheme=https"
          - "--certificatesresolvers.le.acme.httpchallenge=true"
          - "--certificatesresolvers.le.acme.httpchallenge.entrypoint=web"
          - "--certificatesresolvers.le.acme.email=${LETSENCRYPT_EMAIL}"
          - "--certificatesresolvers.le.acme.storage=/letsencrypt/acme.json"
          - "80:80"
          - "443:443"
        volumes:
          - /var/run/docker.sock:/var/run/docker.sock:ro
          - ./letsencrypt:/letsencrypt
      gitlab:
        image: gitlab/gitlab-ce:latest
        container_name: gitlab
        restart: always
        hostname: ${GITLAB_DOMAIN}
        shm_size: '256m'
        environment:
          GITLAB_OMNIBUS_CONFIG: |
            external_url 'https://${GITLAB_DOMAIN}'
            nginx['listen_port'] = 80
            nginx['listen_https'] = false
            nginx['proxy_set_headers'] = {
              "X-Forwarded-Proto" => "https",
              "X-Forwarded-Ssl" => "on"
            gitlab_rails['gitlab_shell_ssh_port'] = 2222
          - "2222:22"
        volumes:
          - ./config:/etc/gitlab
          - ./logs:/var/log/gitlab
          - ./data:/var/opt/gitlab
          - "traefik.enable=true"
          - "traefik.http.routers.gitlab.rule=Host(`${GITLAB_DOMAIN}`)"
          - "traefik.http.routers.gitlab.entrypoints=websecure"
          - "traefik.http.routers.gitlab.tls=true"
          - "traefik.http.routers.gitlab.tls.certresolver=le"
          - "traefik.http.services.gitlab.loadbalancer.server.port=80"
    Save and close the file. This Docker Compose file deploys **GitLab CE** behind **Traefik**, enabling secure HTTPS access using Let’s Encrypt. Each service has a specific purpose:
    **gitlab service**
    * Runs the official `gitlab/gitlab-ce` Omnibus image, providing the full GitLab platform including repositories, issues, CI/CD pipelines, container registry, and administrative tools.
    * Stores configuration, logs, and persistent application data in the `./config`, `./logs`, and `./data` directories.
    * Uses the `GITLAB_OMNIBUS_CONFIG` environment block to:
        * Set the external URL to your domain.
        * Disable GitLab’s internal HTTPS listener so Traefik can handle TLS termination.
        * Pass required reverse proxy headers so GitLab recognizes HTTPS correctly.
        * Configure the SSH service to use port **2222** on the host to avoid conflicts with the host operating system’s SSH server.
    * Exposes port **80** internally for the web interface, while Traefik routes external HTTPS traffic to this internal port.
    **traefik service**
    * Listens on ports **80** and **443** on the host, allowing it to receive and route all incoming HTTP/HTTPS traffic.
    * Automatically provisions and renews TLS certificates using Let’s Encrypt via the ACME HTTP-01 challenge.
    * Uses Docker labels on the GitLab container to discover the service and route traffic for your domain (`${GITLAB_DOMAIN}`) to GitLab over HTTPS.
    * Stores certificates in the `./letsencrypt` directory.
    * Ensures all HTTP requests are redirected to HTTPS for secure access.
1. Start all services in detached mode.
    $ docker compose up -d
1. Check container status.
    $ docker compose ps
    GitLab takes a few minutes to start the first time. The container status may say `health: starting` for several minutes before the web interface is accessible.
    > For more information on managing a Docker Compose stack, see the [How To Use Docker Compose](https://docs.vultr.com/how-to-use-docker-compose) article.
## Access and Configure GitLab
1. Retrieve the initial root password. GitLab generates a random password for the `root` user on the first run.
    $ sudo docker exec -it gitlab grep 'Password:' /etc/gitlab/initial_root_password
    Copy the password string displayed in the output.
    > This file is automatically deleted after 24 hours. Ensure you change your password immediately after logging in.
1. Open your browser and visit your GitLab domain `https://gitlab.example.com`.
    ![Login Page](https://docs.vultr.com/public/doc-assets/2422/62b52022-d082-470a-8fcf-21feaa9ac435.png)
1. Log in using the username **root** and the password you retrieved in the previous step.
1. Once logged in, navigate to **Admin area** > **Users** to create a new user and set a new, secure password.
    ![Create User](https://docs.vultr.com/public/doc-assets/2422/f49351de-50df-4438-9dae-f2f1bb852eb1.png)
By following this article, you successfully deployed GitLab CE on Ubuntu 24.04 using Docker Compose. You have configured Traefik to handle HTTPS termination and mapped a custom SSH port for repository interaction. For more information, refer to [GitLab Docs](https://docs.gitlab.com/).
