title: How to Deploy MLFlow on the Vultr Kubernetes Engine
url: https://docs.vultr.com/how-to-deploy-mlflow-on-the-vultr-kubernetes-engine
description: Learn how to deploy MLFlow on Vultr Kubernetes Engine with our step-by-step guide. Optimize your machine learning workflow with this powerful tracking platform.
publish_date: 2023-11-12T00:00:00Z
last_updated: 2025-04-01T00:00:00Z
author: Dejan Lukić
header_image: https://docs.vultr.com/public/doc-assets/1659/393a0218e8946f61.png
MLflow is a versatile open-source Machine Learning (ML) platform for model lifecycle management. It supports experimentation, duplicability, deployment, and a central model registry. MLflow is used to track machine learning workload experiments, packaging and deployment of code, and collaborative management. Frequently used by data scientists and by MLOps professionals.
This article explains how to deploy MLflow on a Vultr Kubernetes Engine (VKE) cluster with a working environment and demo application.
* Deploy a [Vultr Kubernetes Engine(VKE) cluster](https://docs.vultr.com/vultr-kubernetes-engine/)
* Deploy a [Vultr Ubuntu instance](http://vultr.com/servers/ubuntu) to use as your management server
* Using [SSH](https://docs.vultr.com/how-to-use-ssh-with-vultr-servers/), access the server
* Install and configure Kubectl to access the cluster
* Install the Helm package manager
        $ sudo snap install helm --classic
## Deploy Persistent Volume and Persistent Volume Claims (PVCs)
MLflow requires persistent storage to store artifacts and experiment data. In this section, deploy a PV and PVC to the cluster as described in the steps below.
1. Create a new file `mlflow-pv-pvc.yaml`
        $ touch mlflow-pv-pvc.yaml
1. Using a text editor such as `nano`, edit the file
        $ nano mlflow-pv-pvc.yaml
1. Add the following contents to the file
        kind: PersistentVolume
            type: local
          storageClassName: manual
          capacity:
            storage: 10Gi
          accessModes:
            - ReadWriteOnce
          hostPath:
            path: "/mnt/data"
        kind: PersistentVolumeClaim
          accessModes:
            - ReadWriteOnce
          resources:
            requests:
              storage: 10Gi
    Save the file
1. Apply the configuration to your cluster
        $ kubectl apply -f mlflow-pv-pvc.yaml
1. Verify the deployed Cluster PVs
        $ kubectl get pv
        NAME        CAPACITY   ACCESS MODES   RECLAIM POLICY   STATUS   CLAIM                STORAGECLASS   REASON   AGE
        mlflow-pv   10Gi       RWO            Retain           Bound    default/mlflow-pvc   manual
1. Verify the deployed Cluster PVCs
        $ kubectl get pvc
        NAME         STATUS   VOLUME      CAPACITY   ACCESS MODES   STORAGECLASS   AGE
        mlflow-pvc   Bound    mlflow-pv   10Gi       RWO            manual         24s
## Install MLflow
1. Using Helm, add `community-charts` to your repositories
        $ helm repo add community-charts https://community-charts.github.io/helm-charts
1. Update the Helm repository index
        $ helm repo update
1. Install MLflow. Replace `vultr` with your desired MLflow label
        $ helm install vultr community-charts/mlflow
1. View the cluster deployment to verify that MLflow is ready and available
        $ kubectl get deployments
        NAME           READY   UP-TO-DATE   AVAILABLE   AGE
        vultr-mlflow    1/1     1            1           19h
## Expose the MLflow Forwarding Service For External Access
To access your MLflow deployment over the Internet, set up a forwarding service to expose the application for external access as described in the steps below.
1. Create a new file `mlflow-service.yaml`
        $ touch mlflow-service.yaml
1. Edit the file
        $ nano mlflow-service.yaml
            app: mlflow
            - protocol: TCP
              targetPort: 5000
          type: LoadBalancer
1. Apply the service to your cluster
        $ kubectl apply -f mlflow-service.yaml
1. Wait for at least `3` minutes, view the cluster services, and verify the MLflow **External IP** value
         $ kubectl get services
        NAME             TYPE           CLUSTER-IP      EXTERNAL-IP   PORT(S)        AGE
        kubernetes       ClusterIP      10.96.0.1       <none>        443/TCP        40m
        mlflow-service   LoadBalancer   10.110.234.98   192.0.2.100   80:31545/TCP   64s
        vultr-mlflow     ClusterIP      10.102.93.29    <none>        5000/TCP       101s
## Create a sample MLflow Experiment
To test the MLflow functionalities, create a sample linear regression experiment as described in the steps below.
1. Create a new directory `Models`
        $ mkdir Models
1. Switch to the directory
        $ cd Models
1. Using `pip`, install the necessary experiment dependencies
        $ pip install mlflow scikit-learn shap matplotlib
    When using Conda, install the dependencies in your environment:
        $ conda install mlflow scikit-learn shap matplotlib
1. Create a new environment variable with your desired experiment name
        $ export MLFLOW_EXPERIMENT_NAME='my-sample-experiment'
1. Export a new `mlflow_TRACKING_URI` with your MLflow service external IP HTTP URL as the value. For example `192.0.2.100`
        $ export MLFLOW_TRACKING_URI='http://192.0.2.100'
1. Create a new file `main.py`
        $ touch main.py
1. Edit the file
        $ nano main.py
        # Import Libraries
        import os
        import numpy as np
        import shap
        from sklearn.datasets import load_diabetes
        from sklearn.linear_model import LinearRegression
        import mlflow
        from mlflow.artifacts import download_artifacts
        from mlflow.tracking import MlflowClient
        # Prepare the Training Data
        X, y = load_diabetes(return_X_y=True, as_frame=True)
        X = X.iloc[:50, :4]
        y = y.iloc[:50]
        # Train a model
        model = LinearRegression()
        model.fit(X, y)
        # Log an explanation
        with mlflow.start_run() as run:
            mlflow.shap.log_explanation(model.predict, X)
        # List Artifacts
        client = MlflowClient()
        artifact_path = "model_explanations_shap"
        artifacts = [x.path for x in client.list_artifacts(run.info.run_id, artifact_path)]
        print("# artifacts:")
        print(artifacts)
        # Load the logged explanation
        dst_path = download_artifacts(run_id=run.info.run_id, artifact_path=artifact_path)
        base_values = np.load(os.path.join(dst_path, "base_values.npy"))
        shap_values = np.load(os.path.join(dst_path, "shap_values.npy"))
        # Show a Force Plot
        shap.force_plot(float(base_values), shap_values[0, :], X.iloc[0, :], matplotlib=True)
The above Python application imports all necessary libraries and uses the diabetes dataset for training data. The dataset contains a total of 442 samples. Then, the model is trained and an explanation is logged to MLflow using SHAP (Shapley Additive Explanations) that plots the output for a visual representation of the data.
### Test the MLflow Experiement
1. Run the Python application
        $ python3 main.py
1. Using a web browser such as Chrome, visit your MLflow external IP address
        http://192.0.2.100
Verify that the application is included in your MLflow experiments. It uses a linear regression statistical approach to model a relationship between a scalar response and one or more variables.
![MLflow UI showing the diabetes linear regression experiment](https://docs.vultr.com/public/doc-assets/1659/d279b26e85af3c4e.png)
You have deployed MLflow on a Vultr Kubernetes Engine (VKE) cluster. To test the service operations, implement more examples from the [MLflow repository](https://mlflow.org/docs/latest/tutorials-and-examples/index.html). For more information about MLflow, visit the following documentation resources:
* [MLflow documentation](https://mlflow.org/docs/latest/index.html)
* [MLflow Recipes](https://mlflow.org/docs/latest/recipes.html#recipes)
* [MLflow Projects](https://mlflow.org/docs/latest/projects.html#projects)
## Next Steps
To implement more solutions, visit the following resources:
* [Deploy a Machine Learning Model to Production with TensorFlow Serving](https://docs.vultr.com/deploy-a-machine-learning-model-to-production-with-tensorflow-serving/)
* How to Build a Machine Learning Classifier in Python with Scikit Learn
* [Introduction to Vultr Cloud GPUs](https://docs.vultr.com/products/compute/cloud-gpu)
* Fine Tune a Hugging Face Diffuser Model on Vultr Cloud GPU
