title: How to Deploy Replit Projects on Vultr Using Coolify
url: https://docs.vultr.com/how-to-deploy-replit-projects-on-vultr-using-coolify
description: Create app with Replit, push to GitHub, and deploy on Coolify with HTTPS domain.
publish_date: 2026-04-02T16:45:49.549470Z
last_updated: 2026-04-16T00:00:00.077250Z
author: Martin Sustak
header_image: https://lhr1.vultrobjects.com/docs-main-doc-assets-1/2535/9ef54741-b638-4a8b-bfef-51f45e493c3a.png
[Replit](https://replit.com/) is an AI-driven web-based tool that uses natural-language prompts to automate the creation of full-stack applications, feature implementation, and environment configuration. [Coolify](https://coolify.io/) is an open-source platform-as-a-service that automates infrastructure provisioning and Docker orchestration for self-hosted environments.
This guide explains how to create an application using Replit, export the source code to GitHub, and deploy it onto a Vultr server using Coolify.
* Have a [Replit](http://replit.com) account.
* Have a [GitHub](https://github.com/) account.
* [Deploy a new instance with the Vultr Marketplace Application for Coolify](https://docs.vultr.com/how-to-use-vultr-s-coolify-marketplace-application#deploy-the-vultr-marketplace-application-for-coolify).
* Set up a domain name, such as `app.example.com`, and point it to your server's public IP address using an [A record](https://docs.vultr.com/products/network/dns/management/manage-records).
1. Navigate to [Replit](http://replit.com) in a web browser and log in to your account.
1. Describe the application in detail in the prompt field, including an instruction for the agent to make it Coolify compatible. Specify all necessary features, the preferred technology stack, and request either a `Dockerfile` or, for multi-service applications, a `docker-compose.yaml` file.
1. Click **Start** to create the application using AI.
1. Verify the application functionality within the internal **Preview** panel.
1. Click the **+** icon next to the active workspace tabs.
1. Search for the **Git** tool and select it in the menu.
1. Click **Settings**.
1. Press **Sign In** next to GitHub.
1. Click **Continue to GitHub**.
1. Review the Authorization options, and click **Authorize replit-integrations**.
1. Click **Create Remote**.
1. Specify a repository name and confirm the action to create a new repository for your application’s source code.
1. Click **Create Repository on GitHub**.
1. Return to the Git section. A **Pass GitHub Credentials** dialog appears.
1. Click **Confirm for this session** to authorize Replit to use your GitHub credentials.
1. Click **Push branch as origin/main** to push the source code.
1. Your application’s source code is now available in the repository.
## Access the Coolify Dashboard
The Vultr Marketplace app provides the Coolify dashboard address in the instance management page. Open it to complete the initial account setup.
1. Access your Vultr instance’s Overview page.
1. In the **App Instructions** section, find the Coolify dashboard address and open it in a new tab.
1. Set your administrator account credentials in the initial configuration wizard.
## Configure a Dashboard Domain
Assigning a domain to your Coolify instance gives GitHub a stable, publicly reachable webhook endpoint and enables HTTPS for the dashboard. Coolify uses this domain when registering the GitHub App.
1. At your DNS registrar, create an A record pointing a subdomain to your server’s public IP address, for example `coolify.example.com`.
1. Open the Coolify dashboard at `http://YOUR_SERVER_IP:8000`.
1. Click **Settings** in the left sidebar.
1. Under **General**, enter your fully-qualified domain with the `https://` scheme in the **URL** field, for example `https://coolify.example.com`.
1. Click **Save**.
1. Click **Servers** in the left sidebar, then click **localhost**.
1. Open the **Proxy** tab and click **Start** to deploy the Traefik reverse proxy. Traefik provisions the Let’s Encrypt SSL certificate for your domain.
1. Open `https://coolify.example.com` in a new tab to confirm the dashboard loads over HTTPS.
## Connect GitHub Repository
Authorize Coolify to retrieve your application’s source code from the GitHub repository.
1. Click **Sources** in the left sidebar of the Coolify dashboard.
1. Click **Add**.
1. In the **New GitHub App** dialog, optionally update the app name. Leave the **Organization** field empty to use your personal GitHub account.
1. Click **Continue**.
1. On the **GitHub App** configuration page, open the **Webhook Endpoint** dropdown. It lists your server IP, your configured domain, and localhost. Select your domain so GitHub can reach the endpoint over HTTPS.
1. Click **Register Now**. Coolify redirects you to GitHub.
1. Click **Create GitHub App** on GitHub to register the app. GitHub redirects you back to Coolify.
1. On the **GitHub App** page in Coolify, click **Install Repositories on GitHub**. GitHub opens the app installation page.
1. Select **All repositories** or **Only select repositories**, then click **Install**.
## Create a New Project
Projects allow you to isolate Coolify applications into separate environments.
1. Click **Projects** in the left sidebar.
1. Click **Add**.
1. Type a name for your project.
1. Click **Continue** to create your project.
## Configure the Application
Link your GitHub repository to a new Coolify resource and configure the build settings before triggering the first deployment.
1. Click **Add Resource** inside your project’s page.
1. Choose **Private Repository (with GitHub App)** or **Public Repository**, depending on your repository visibility.
1. Choose your GitHub app.
1. Select your application repository from the dropdown.
1. Set the branch to `main`.
1. Select **Docker Compose** or **Dockerfile** in the **Build Pack** dropdown depending on your project.
1. Click **Continue**. Coolify opens the application’s **Configuration** page.
1. In the **Domains** field, click **Generate Domain** to assign a temporary `.sslip.io` domain for testing.
1. Click **Save**.
## Add a Database
Provision a managed database before deploying so the application can connect to it on startup.
1. Navigate back to your Coolify project page.
1. Click **+ New Resource**.
1. Select **Database** and choose the database type that matches your application.
1. Enter a name for your database and click **Create**.
1. Click **Start** to deploy the database container.
1. Copy the internal connection URL from the database configuration page.
## Configure Environment Variables
Set the database connection URL and any other required secrets before the first deploy.
1. Open your application’s configuration page and click **Environment Variables** in the left sidebar.
1. Click **+ Add**.
1. Enter `DATABASE_URL` as the name and paste the internal connection URL as the value.
1. Add any other variables your application requires.
1. Click **Save**.
## Start the Deployment
Trigger the build and verify the application starts correctly using the generated test domain.
1. Click **Deploy** in the top right corner of the application’s configuration page.
1. Click **Links** in the top navigation bar.
1. Click the generated `.sslip.io` domain link and verify the application loads.
    If the deployment fails, click the latest running instance of deployment under the **Deployment** tab to view the full error output. Copy the error and share it with the Replit agent to diagnose and fix the issue. Once the code is updated, push the fix to trigger a new deployment cycle:
    1. Stage the updated files.
        $ git add .
    1. Commit the changes.
        $ git commit -m "Fix deployment error"
    1. Push the fix to the remote repository.
        $ git push origin main
    Coolify detects the push and redeploys automatically.
## Configure Custom Domain with HTTPS
Replace the temporary test domain with your own domain. Coolify provisions a Let’s Encrypt certificate automatically when the domain uses the `https://` scheme.
1. Open your application’s **Configuration** page.
1. In the **Domains** field, replace the `.sslip.io` address with your custom domain, for example `https://app.example.com`. Include the `https://` prefix to trigger automatic Let’s Encrypt certificate provisioning.
1. Click **Save**, then **Redeploy**.
1. Once redeployed, open your custom domain and confirm the padlock icon is visible in the address bar.
You have successfully created an application using Replit, exported the generated source code to GitHub, and deployed it to a Vultr instance using Coolify. For more information, visit the [official Coolify documentation](https://coolify.io/docs/).
