title: How to Deploy Slurm on Vultr Kubernetes Engine
url: https://docs.vultr.com/how-to-deploy-slurm-on-vultr-kubernetes-engine
description: Learn how to efficiently automate Slurm workload manager on Vultr Kubernetes Engine with step-by-step instructions for seamless high-performance computing deployment.
publish_date: 2025-08-19T15:56:48.170000Z
last_updated: 2026-09-11T16:18:11.863671Z
author: Mirdul Swarup
header_image: https://docs.vultr.com/public/doc-assets/2287/b48dfa83-0f45-45ae-be1a-f9e57b71ff55.png
[Slurm](https://slurm.schedmd.com/) is an open-source job scheduler for High-Performance Computing (HPC) environments. It allocates resources, manages job queues, and orchestrates workloads across clusters, and it powers many of the world's largest supercomputers, offering scalability, flexibility, and support for complex batch workflows.
This guide explains how to deploy a Slurm cluster on Vultr Kubernetes Engine (VKE) using the [Slinky Slurm Operator](https://github.com/SlinkyProject/slurm-operator), a Kubernetes operator for Slurm that [SchedMD](https://www.schedmd.com/) maintains. It covers installing the operator, deploying a Slurm cluster with the controller persisting state to Vultr Block Storage, recording job accounting data in a MariaDB database, exposing controller metrics to Prometheus, and connecting to the cluster over SSH through its login node.
Before you begin, ensure you:
* Have access to a [VKE](https://docs.vultr.com/products/kubernetes/provisioning) cluster.
* Have [`kubectl`](https://docs.vultr.com/how-to-install-and-use-kubectl-to-manage-a-vke-cluster) and `helm` installed on your machine.
* Have an SSH key pair on your machine to connect to the Slurm login node.
## Install cert-manager and the Slurm Operator
The Slurm Operator manages Slurm cluster resources through a set of Custom Resource Definitions (CRDs) and uses cert-manager to issue the certificate for its admission webhook.
1. Install cert-manager and its CRDs.
    $ helm install cert-manager oci://quay.io/jetstack/charts/cert-manager \
        --namespace cert-manager \
        --create-namespace \
        --set crds.enabled=true
1. Install the Slurm Operator CRDs.
    $ helm install slurm-operator-crds oci://ghcr.io/slinkyproject/charts/slurm-operator-crds \
        --version 1.2.1
1. Install the Slurm Operator into the `slinky` namespace.
    $ helm install slurm-operator oci://ghcr.io/slinkyproject/charts/slurm-operator \
        --version 1.2.1 \
        --namespace slinky \
        --create-namespace
1. Verify the operator pods are running.
    $ kubectl get pods --namespace slinky
    NAME                                      READY   STATUS    RESTARTS   AGE
    slurm-operator-5d86d75979-6wflf           1/1     Running   0          1m
    slurm-operator-webhook-567c84547b-kr7zq   1/1     Running   0          1m
## Deploy a Slurm Cluster on Vultr Block Storage
The Slurm chart deploys the controller, worker nodes, login node, and REST API as a single Slurm cluster. By default, the controller persists its state to a Persistent Volume Claim (PVC) that uses the cluster's default storage class, so specify Vultr Block Storage explicitly to control which class it uses.
1. List the storage classes available on the cluster.
    $ kubectl get storageclasses.storage.k8s.io
    The output includes `vultr-block-storage`, the default Vultr Block Storage class for persistent volumes.
1. Install the Slurm cluster with a worker node set, a partition, and controller persistence on Vultr Block Storage.
    $ helm install slurm oci://ghcr.io/slinkyproject/charts/slurm \
        --version 1.2.1 \
        --set-json 'nodesets={"slinky":{}}' \
        --set 'partitions.all.enabled=true' \
        --set 'controller.persistence.storageClassName=vultr-block-storage' \
        --namespace slurm \
        --create-namespace
    > Kubernetes typically does not delete Persistent Volumes when you delete their PVC, so remove unused PVs manually. Disabling controller persistence with `--set 'controller.persistence.enabled=false'` is only appropriate for testing, because it loses the cluster's state on every controller restart.
1. Verify the Slurm cluster pods are running.
    $ kubectl get pods --namespace slurm
    slurm-controller-0                    3/3     Running   0          2m
    slurm-restapi-77b9f969f7-kh4r8        1/1     Running   0          2m
    slurm-worker-slinky-0                 2/2     Running   0          2m
## Enable Job Accounting with MariaDB
Slurm accounting records job history and resource usage in a MariaDB or MySQL-compatible database. Deploy a database using the community-edition [MariaDB Operator](https://github.com/mariadb-operator/mariadb-operator), then point Slurm's accounting service at it.
1. Add the MariaDB Operator Helm repository.
    $ helm repo add mariadb-operator https://helm.mariadb.com/mariadb-operator
1. Update the local Helm repository cache.
    $ helm repo update
1. Install the MariaDB Operator CRDs.
    $ helm install mariadb-operator-crds mariadb-operator/mariadb-operator-crds
1. Install the MariaDB Operator controller into the `mariadb` namespace.
    $ helm install mariadb-operator mariadb-operator/mariadb-operator \
        --namespace mariadb \
        --create-namespace
1. Create a manifest file for the accounting database.
    $ nano mariadb.yaml
1. Add the following configuration:
    apiVersion: k8s.mariadb.com/v1alpha1
    kind: MariaDB
      namespace: slurm
      rootPasswordSecretKeyRef:
        key: password
        generate: true
      username: slurm
      database: slurm_acct_db
      passwordSecretKeyRef:
        key: password
        generate: true
      storage:
        storageClassName: vultr-block-storage
      myCnf: |
        [mariadb]
        bind-address=*
        default_storage_engine=InnoDB
        binlog_format=row
        innodb_autoinc_lock_mode=2
        innodb_buffer_pool_size=4096M
        innodb_lock_wait_timeout=900
        innodb_log_file_size=1024M
        max_allowed_packet=256M
    * `username` and `database`: The credentials and database name the Slurm accounting service connects with. Use these same values later to query the accounting database directly.
    * `storage`: Requests a 16Gi PVC on Vultr Block Storage for the database. This example aligns with the Slurm chart's default `accounting.storageConfig`; update it if your database configuration differs.
    * `rootPasswordSecretKeyRef` and `passwordSecretKeyRef`: Generates and stores the root and application passwords in Kubernetes Secrets automatically.
1. Apply the manifest to create the database in the `slurm` namespace.
    $ kubectl apply -f mariadb.yaml
1. Verify the database is ready.
    $ kubectl get mariadbs.k8s.mariadb.com --namespace slurm
    Verify the `READY` column shows `True` before continuing.
1. Enable accounting on the Slurm cluster.
    $ helm upgrade slurm oci://ghcr.io/slinkyproject/charts/slurm \
        --version 1.2.1 \
        --reuse-values \
        --set 'accounting.enabled=true' \
        --namespace slurm
    The `--reuse-values` flag keeps the node set, partition, and storage class values you set during the initial install.
1. Verify the accounting pod is running.
    $ kubectl get pods --namespace slurm --selector 'app.kubernetes.io/component=accounting'
    Verify the `slurm-accounting-0` pod shows a `Running` status.
## Enable Cluster Metrics with Prometheus
The Slurm controller can expose metrics for [Prometheus](https://prometheus.io/) to scrape through a `ServiceMonitor` resource, which the kube-prometheus-stack chart's Prometheus Operator watches for automatically.
1. Add the Prometheus Community Helm repository.
    $ helm repo add prometheus-community https://prometheus-community.github.io/helm-charts
    $ helm repo update
1. Install the kube-prometheus-stack chart and its CRDs into the `prometheus` namespace.
    $ helm install prometheus prometheus-community/kube-prometheus-stack \
        --set 'installCRDs=true' \
        --namespace prometheus \
        --create-namespace
1. Enable Slurm controller metrics and the Prometheus service monitor.
        --version 1.2.1 \
        --reuse-values \
        --set 'controller.metrics.enabled=true' \
        --set 'controller.metrics.serviceMonitor.enabled=true' \
        --namespace slurm
1. Verify the service monitor was created.
    $ kubectl get servicemonitors.monitoring.coreos.com --namespace slurm
    The output displays a service monitor for the Slurm controller.
## Connect to the Slurm Cluster
The Slurm chart's login node accepts SSH connections and gives you a shell from which to run Slurm client commands against the cluster. Authorize your own SSH public key on the login node rather than configuring an external identity service.
1. Enable the login node and authorize your SSH public key. Replace `SSH-PUBLIC-KEY-PATH` with the path to your own public key, such as `~/.ssh/id_ed25519.pub` or `~/.ssh/id_rsa.pub`.
        --version 1.2.1 \
        --reuse-values \
        --set 'loginsets.slinky.enabled=true' \
        --set-file "loginsets.slinky.rootSshAuthorizedKeys=SSH-PUBLIC-KEY-PATH" \
        --namespace slurm
1. Retrieve the load balancer IP address and port assigned to the login service.
    $ SLURM_LOGIN_IP="$(kubectl get services --namespace slurm slurm-login-slinky -o jsonpath='{.status.loadBalancer.ingress[0].ip}')"
    $ SLURM_LOGIN_PORT="$(kubectl get services --namespace slurm slurm-login-slinky -o jsonpath='{.spec.ports[0].port}')"
    > VKE provisions a [Vultr Load Balancer](https://docs.vultr.com/products/load-balancers) for the login service automatically. Allow a few minutes for VKE to assign an external IP address.
1. Verify both values were retrieved before continuing.
    $ echo "${SLURM_LOGIN_IP}:${SLURM_LOGIN_PORT}"
    The output shows an IP address and port, for example `66.135.9.113:22`. If `SLURM_LOGIN_IP` is empty, the load balancer has not finished provisioning; wait a few minutes and rerun the previous step.
1. Connect to the login node over SSH.
    $ ssh -p ${SLURM_LOGIN_PORT:-22} root@${SLURM_LOGIN_IP}
1. From the login node, check the partition and node status.
    $ sinfo
    The output resembles the following:
    PARTITION AVAIL  TIMELIMIT  NODES  STATE NODELIST
    all*         up   infinite      1   idle slinky-0
    Verify the worker node shows `idle`, not `down` or `drain`.
1. Run a command directly on a worker node.
    $ srun hostname
    The output shows the hostname of the worker node the job ran on, confirming the controller can schedule work:
    slinky-0
1. Submit a batch job.
    $ sbatch --wrap="sleep 60"
    The output confirms the controller accepted the job:
    Submitted batch job 2
1. List jobs in the queue.
    $ squeue
    The output shows the job in a running (`R`) or pending (`PD`) state:
    JOBID PARTITION     NAME     USER ST       TIME  NODES NODELIST(REASON)
        2       all     wrap     root  R       0:04      1 slinky-0
1. Display accounting records for both jobs from the MariaDB database configured earlier.
    $ sacct
    The output includes the earlier `srun` job and the `sbatch` job submitted in the previous step:
    JobID           JobName  Partition    Account  AllocCPUS      State ExitCode
    1              hostname        all       root          2  COMPLETED      0:0
    1.0            hostname                  root          2  COMPLETED      0:0
    2                  wrap        all       root          2    RUNNING      0:0
    2.batch           batch                  root          2    RUNNING      0:0
    The `sleep 60` job still shows `RUNNING` immediately after submission; rerun `sacct` after a minute to see it change to `COMPLETED`.
## Run an Example Batch Script
The commands above submit a job inline with `--wrap`. A batch script defines the job's resource requests and commands in a single file, which is the standard way to submit repeatable work to Slurm.
1. From the login node, create the script.
    $ cat > example.sh <<'EOF'
    #!/bin/bash
    #SBATCH --job-name=example
    #SBATCH --output=example.out
    #SBATCH --ntasks=1
    #SBATCH --time=00:01:00
    echo "Running on $(hostname)"
    date
    sleep 10
    echo "Job complete"
    EOF
    * `--job-name`: The name Slurm displays for this job in `squeue` and `sacct`.
    * `--output`: The file Slurm writes the job's combined stdout and stderr to, relative to the worker node's own filesystem.
    * `--ntasks`: The number of tasks the job requests. This example requests one.
    * `--time`: The job's time limit, after which Slurm cancels it.
1. Submit the script to the queue.
    $ sbatch example.sh
    Submitted batch job 3
    > The `example.out` file is written on the node the job is scheduled to, not the login node.
1. Wait for the job to complete, then verify it succeeded from the login node using `sacct`.
    $ sacct --job 3 --format=JobID,JobName,State,ExitCode
    The output confirms the job ran to completion with a zero exit code:
    JobID           JobName      State ExitCode
    3               example  COMPLETED      0:0
    3.batch           batch  COMPLETED      0:0
You have deployed a Slurm cluster on Vultr Kubernetes Engine using the Slinky Slurm Operator, with the controller persisting state to Vultr Block Storage, job accounting recorded in a MariaDB database, controller metrics exposed to Prometheus, and SSH access through the login node. From here, submit your own batch jobs with `sbatch`, add worker capacity by adjusting the `nodesets` value on the Slurm chart, or define additional partitions to separate workloads by hardware or priority. For more information, visit the [Slinky documentation](https://slinky.schedmd.com/) or the [Slurm documentation](https://slurm.schedmd.com/documentation.html).
