title: How to Deploy Vercel v0 Projects on Vultr Using Coolify
url: https://docs.vultr.com/how-to-deploy-vercel-v0-projects-on-vultr-using-coolify
description: Generate app with v0, deploy via Coolify on Vultr, and automate deployments using GitHub CI/CD.
publish_date: 2026-04-02T17:01:49.747508Z
last_updated: 2026-04-16T00:00:00.077250Z
author: Martin Sustak
header_image: https://lhr1.vultrobjects.com/docs-main-doc-assets-1/2537/36df7aca-9901-415f-93e6-9c9f0413adc6.png
[v0](https://v0.dev/) is a browser-based generative AI tool by Vercel that converts natural language descriptions into deployable full-stack applications. It produces complete project scaffolding, including frontend components, backend logic, and container configuration files. [Coolify](https://coolify.io/) is a self-hosted platform-as-a-service that handles Docker image builds, Traefik-based reverse proxying, and automatic TLS certificate provisioning on your own infrastructure.
This guide explains how to generate a full-stack application with v0, export the source code to GitHub, and deploy it on a Vultr server using Coolify.
* Have a [v0](https://v0.app/) account.
* Have a [GitHub](https://github.com) account.
* [Deploy the Vultr Marketplace Application for Coolify](https://docs.vultr.com/how-to-use-vultr-s-coolify-marketplace-application#deploy-the-vultr-marketplace-application-for-coolify) with at least 2 GB RAM and 1 CPU core.
* Configure a [DNS A record](https://docs.vultr.com/products/network/dns/management/manage-records) pointing to your server's IP address (for example, `app.example.com`).
v0 generates a complete project from a single prompt and can push the resulting code directly to a GitHub repository. The application needs at least a Dockerfile so Coolify can build and run it. For projects with multiple services, such as a separate database container, request a `docker-compose.yml` as well.
1. Navigate to [v0](https://v0.app) in a web browser and log in with your account.
1. Type a detailed description of your application in the prompt field. Specify the technology stack and all required features. Ask v0 to include a Dockerfile, or a `docker-compose.yml` if the project involves multiple services. v0 generates the source files, directory structure, and container configuration based on your prompt.
1. Click the arrow button to submit the prompt.
1. Wait for v0 to finish building the application.
1. Inspect the result in the interactive preview panel. Confirm that the generated features match your requirements.
1. Click the **Project Settings** icon in the top header on the right side.
1. Select **GitHub** in the left sidebar.
1. Click **Connect repository**.
1. Sign in with GitHub and authorize v0 to access your repositories.
1. Enter a name for your repository and click **Create Repository**.
1. v0 pushes your application's source code automatically to the new repository. The repository now contains all generated files including the Dockerfile or `docker-compose.yml`.
## Access the Coolify Dashboard
The Vultr Marketplace deploys Coolify with a pre-configured web interface. Log in to create the administrator account before connecting any repositories or projects.
1. Open your instance's Management Page in the [Vultr Console](https://console.vultr.com/) and scroll down to **App Instructions**. The Coolify endpoint URL appears there in the format `http://SERVER_IP:8000`.
1. Open the URL in a browser. The first-run wizard asks for an email address and password. Enter the credentials for your administrator account.
1. Coolify opens the dashboard after the account is created. The administrator account controls all deployments, team members, and server settings.
## Connect GitHub Repository
Coolify requires a GitHub source connection before it can pull code from your repositories. Use the OAuth flow to grant Coolify read access to your selected repositories.
1. Click **Sources** in the Coolify dashboard.
1. Click **Add Source** and select **GitHub**.
1. Coolify redirects to GitHub for OAuth authorization. Click **Authorize** to grant access.
1. GitHub redirects back to Coolify after successful authorization. Coolify displays your GitHub account in the Sources list.
## Create a New Project
A Coolify project groups related applications and services under one namespace, making it easier to manage environment variables, domains, and resources together.
1. Click **Projects** in the Coolify dashboard.
1. Click **Add Project**.
1. Enter a project name, such as `my-v0-app`.
1. Click **Create**. Coolify displays the project details page.
## Deploy the Application
Coolify pulls source code from the linked GitHub repository, builds a Docker image using the Dockerfile or `docker-compose.yml` in the repository root, and starts the resulting containers.
1. Click **Add Resource** in the project details page.
1. Select **Application** as the resource type.
1. Choose **GitHub** as the source.
1. Select your v0 application repository from the dropdown.
1. Enter the branch name, typically `main`.
1. Coolify scans the repository and identifies the container configuration. Select **Docker Compose** as the build pack for multi-container applications.
1. Click **Continue**.
1. Coolify generates a temporary domain in the format `RANDOM_ID.SERVER_IP.sslip.io` for immediate testing. Configure a custom domain later for production use.
1. Click **Save**. Coolify redirects to the application configuration page.
## Configure Environment Variables
Store secrets such as API keys and database credentials in Coolify's environment variable manager rather than hardcoding them in source files. Coolify injects these values into the container at runtime.
1. Open the application details page.
1. Click **Environment Variables**.
1. Click **+Add** to create a new variable.
1. Enter the variable name and value. Common variables for v0 applications include:
    * `DATABASE_URL`: PostgreSQL connection string, such as `postgresql://user:pass@db:5432/dbname`
    * `API_KEY`: External service API key, such as `sk_live_abc123`
    * `NODE_ENV`: Runtime environment, such as `production`
    * `NEXT_PUBLIC_API_URL`: Frontend API endpoint, such as `https://api.example.com`
1. Click **Save** after adding all required variables.
## Start the Deployment
With the repository connected and environment variables saved, trigger the build to compile and launch the application containers.
1. Click **Deploy** to trigger the deployment process.
1. Coolify starts the build. Click **Logs** to watch the output in real time.
    Coolify works through the following steps:
    1. Cloning the repository
    1. Building Docker images for each service
    1. Starting containers
    1. Configuring Traefik routing rules
    1. Requesting TLS certificates
    Most applications are live within 3-5 minutes.
1. When deployment completes successfully, the application status changes to **Running**.
## Verify Deployment
Check that the application is reachable before switching to a production domain.
1. Click **Links** in the application details page to view accessible URLs.
1. Click the Coolify-generated domain link to open your application.
1. Your application loads at `http://RANDOM_ID.SERVER_IP.sslip.io`. Verify that all features function correctly.
## Configure Custom Domain with HTTPS
Replace the temporary `sslip.io` domain with your custom domain for production use. Coolify automatically provisions Let's Encrypt TLS certificates.
1. Select **Configuration** from the left sidebar.
1. Locate the **Domains** field and replace the Coolify-generated domain with your custom domain. Enter `https://app.example.com` in the field.
1. Enable **Automatic HTTPS** to provision Let's Encrypt certificates.
1. Click **Save**.
1. Click **Redeploy** to apply the domain configuration.
1. Coolify reissues the build with the updated domain and requests a certificate from Let's Encrypt. Allow 2-3 minutes for the process to finish.
1. Open the domain in a browser and confirm the padlock icon appears in the address bar, indicating an active TLS certificate.
## Add a Database
Coolify can run a managed PostgreSQL container within the same project. The database container shares an internal Docker network with your application, keeping the connection string off the public internet.
1. Return to the project details page.
1. Click **Add Resource**.
1. Select **Database**.
1. Choose **PostgreSQL** as the database type.
1. Enter a name for the database, such as `app-db`.
1. Click **Create**. Coolify generates the database and its credentials automatically.
1. Copy the internal connection string from the database details page.
1. Open the **Environment Variables** section of your application.
1. Set `DATABASE_URL` to the copied connection string.
1. Click **Restart** to apply the new connection.
## Configure CI/CD Pipeline
Coolify supports continuous deployment through GitHub webhooks, automatically rebuilding and redeploying your application on every push.
### Enable Automatic Deployments
1. Click **Settings**.
1. Enable **Automatic Deployment**.
1. Coolify displays a webhook URL. Copy the URL.
1. Open your GitHub repository and click **Settings**.
1. Click **Webhooks** in the left sidebar, then click **Add webhook**.
1. Paste the copied URL into the **Payload URL** field.
1. Set the content type to **application/json**.
1. Select **Just the push event**.
1. Click **Add webhook** to save.
1. GitHub sends a test payload to Coolify. Verify that the webhook shows a green checkmark.
### Test the CI/CD Pipeline
Push a small code change to confirm that Coolify picks up the update and redeploys automatically.
1. Edit any file in your application code.
1. Stage the changes.
    $ git add .
1. Commit the changes.
    $ git commit -m "Update application feature"
1. Push to GitHub.
    $ git push origin main
1. Coolify detects the push event and starts a new deployment automatically.
1. Open the application details page in Coolify.
1. Click **Deployments** to view the deployment history.
1. The most recent entry appears at the top with a **Building** status.
1. Click **Logs** to follow the build output in real time.
1. When the build completes, the deployment status changes to **Finished** and the application restarts with the updated code.
### Configure GitHub Actions for Testing
Add a GitHub Actions workflow to run automated tests on every push. Coolify only receives the webhook trigger after all workflow checks pass, preventing broken builds from reaching production.
1. Create the GitHub Actions workflow directory.
    $ mkdir -p .github/workflows
1. Open a new workflow file in a text editor.
    $ nano .github/workflows/ci.yaml
1. Paste the following configuration into the file. Update the test commands to match your application stack.
    on:
      push:
        branches: [ main ]
      pull_request:
        branches: [ main ]
    jobs:
      test:
        runs-on: ubuntu-latest
        steps:
          - uses: actions/checkout@v4
          - name: Run tests
            run: |
              # Add your test commands here
              # Example for Node.js:
              # npm install && npm test
              # Example for Go:
              # go test ./...
              echo "Tests passed"
1. Stage the workflow file.
    $ git add .github/workflows/ci.yaml
    $ git commit -m "Add CI workflow"
1. Push to GitHub.
1. GitHub Actions runs the tests on every push. Coolify deploys the application only after the workflow completes successfully.
You have successfully generated a full-stack application with Vercel v0, exported the project to GitHub, and deployed it on Vultr using Coolify. The application runs behind a custom domain secured with a Let's Encrypt TLS certificate and redeploys automatically on every code push. For more information, visit the [official Coolify documentation](https://coolify.io/docs).
