title: How to Deploy Windsurf Projects on Vultr Using Coolify
url: https://docs.vultr.com/how-to-deploy-windsurf-projects-on-vultr-using-coolify
description: Create app with Windsurf, push to GitHub, and deploy on Coolify with HTTPS and auto redeploys.
publish_date: 2026-04-02T16:45:14.180106Z
last_updated: 2026-04-16T00:00:00.077250Z
author: Martin Sustak
header_image: https://lhr1.vultrobjects.com/docs-main-doc-assets-1/2534/054c76fc-055a-4664-89de-38826a90be59.png
[Windsurf](https://windsurf.com/) is an AI-powered, agentic Integrated Development Environment (IDE) built on VS Code that generates complete full-stack applications from natural language prompts. [Coolify](https://coolify.io/) is a self-hosted platform-as-a-service (PaaS) that manages Docker container builds, deployments, and reverse proxy routing through a web dashboard.
This guide explains how to create a full-stack application using Windsurf, pushing the source code to GitHub, and deploying it on Vultr using Coolify.
* Have a [Windsurf](https://windsurf.com/) account.
* Have a [GitHub](https://github.com/) account.
* [Deploy a new instance with the Vultr Marketplace Application for Coolify](https://docs.vultr.com/how-to-use-vultr-s-coolify-marketplace-application#deploy-the-vultr-marketplace-application-for-coolify).
* Set up a domain name, such as `app.example.com`, and point it to your server's public IP address using an [A record](https://docs.vultr.com/products/network/dns/management/manage-records).
## Set Up Windsurf
Download and install Windsurf, then sign in to activate the Cascade AI agent.
1. Download [Windsurf](https://windsurf.com/download) and complete the installation process.
1. Launch the application.
1. Click **Get Started**, and configure the initial workspace preferences.
1. Log in to your Windsurf account in the browser page.
The Cascade agent generates full-stack application files from a text prompt. Push the generated source code to GitHub.
1. Click **Generate a New Project** to initialize the AI agent.
1. Enter a detailed prompt that describes the application and instructs the agent to make it Coolify-compatible. Include all necessary features and the desired service stack, and request either a Dockerfile or a `docker-compose.yaml` file if the application requires multiple services.
1. Press **Enter** to generate the application files.
1. Press :key_ctrl: + :key_backtick: or :key_cmd: + :key_backtick: on Mac to open the integrated terminal.
1. Optionally, test the application locally using the instructions in the generated `README.md` file.
1. [Create](https://github.com/new) a new repository on GitHub.
1. Initialize the local Git repository.
    $ git init
1. Stage the generated files for commit.
    $ git add .
1. Commit the files to the local repository.
    $ git commit -m "Initial commit"
1. Set the default branch to main.
    $ git branch -M main
1. Add your GitHub repository as the remote origin. Replace `YOUR_REPOSITORY_URL` with your repository URL.
    $ git remote add origin YOUR_REPOSITORY_URL
1. Push the source code to GitHub.
    $ git push -u origin main
## Access the Coolify Dashboard
The Vultr Marketplace app provides the Coolify dashboard address in the instance management page. Open it to complete the initial account setup.
1. Access your Vultr instance’s Overview page.
1. In the **App Instructions** section, find the Coolify dashboard address and open it in a new tab.
1. Set your administrator account credentials in the initial configuration wizard.
## Configure a Dashboard Domain
Assigning a domain to your Coolify instance gives GitHub a stable, publicly reachable webhook endpoint and enables HTTPS for the dashboard. Coolify uses this domain when registering the GitHub App.
1. At your DNS registrar, create an A record pointing a subdomain to your server's public IP address, for example `coolify.example.com`.
1. Open the Coolify dashboard at `http://YOUR_SERVER_IP:8000`.
1. Click **Settings** in the left sidebar.
1. Under **General**, enter your fully-qualified domain with the `https://` scheme in the **URL** field, for example `https://coolify.example.com`.
1. Click **Save**.
1. Open `https://coolify.example.com` in a new tab to confirm the dashboard loads over HTTPS.
## Connect GitHub Repository
Authorize Coolify to retrieve your application's source code from the GitHub repository.
1. Click **Sources** in the left sidebar of the Coolify dashboard.
1. Click **Add**.
1. In the **New GitHub App** dialog, optionally update the app name. Leave the **Organization** field empty to use your personal GitHub account.
1. Click **Continue**.
1. On the **GitHub App** configuration page, open the **Webhook Endpoint** dropdown. It lists your server IP, your configured domain, and localhost. Select your domain so GitHub can reach the endpoint over HTTPS.
1. Click **Register Now**. Coolify redirects you to GitHub.
1. Click **Create GitHub App** on GitHub to register the app. GitHub redirects you back to Coolify.
1. On the **GitHub App** page in Coolify, click **Install Repositories on GitHub**. GitHub opens the app installation page.
1. Select **All repositories** or **Only select repositories**, then click **Install**.
## Create a New Project
Projects allow you to isolate Coolify applications into separate environments.
1. Click **Projects** in the left sidebar.
1. Click **Add**.
1. Type a name for your project.
1. Click **Continue** to create your project.
## Configure the Application
Link your GitHub repository to a new Coolify resource and configure the build settings before triggering the first deployment.
1. Click **Add Resource** inside your project’s page.
1. Choose **Private Repository (with GitHub App)** or **Public Repository**, depending on your repository visibility.
1. Choose your GitHub app.
1. Select your application repository from the dropdown.
1. Set the branch to `main`.
1. Select **Docker Compose** or **Dockerfile** in the **Build Pack** dropdown depending on your project.
1. Click **Continue**. Coolify opens the application’s **Configuration** page.
1. In the **Domains** field, click **Generate Domain** to assign a temporary `.sslip.io` domain for testing.
1. Click **Save**.
## Add a Database
Provision a managed database before deploying so the application can connect to it on startup.
1. Navigate back to your Coolify project page.
1. Click **+ New Resource**.
1. Select **Database** and choose the database type that matches your application.
1. Enter a name for your database and click **Create**.
1. Click **Start** to deploy the database container.
1. Copy the internal connection URL from the database configuration page.
## Configure Environment Variables
Set the database connection URL and any other required secrets before the first deploy.
1. Open your application’s configuration page and click **Environment Variables** in the left sidebar.
1. Click **+ Add**.
1. Enter `DATABASE_URL` as the name and paste the internal connection URL as the value.
1. Add any other variables your application requires.
1. Click **Save**.
## Start the Deployment
Trigger the build and verify the application starts correctly using the generated test domain.
1. Click **Deploy** in the top right corner of the application’s configuration page.
1. Click **Links** in the top navigation bar.
1. Click the generated `.sslip.io` domain link and verify the application loads.
    If the deployment fails, click the latest running instance of deployment under the **Deployment** tab to view the full error output. Copy the error and share it with the Windsurf Cascade agent to diagnose and fix the issue. Once the code is updated, push the fix to trigger a new deployment cycle:
    1. Stage the updated files.
        $ git add .
    1. Commit the changes.
        $ git commit -m "Fix deployment error"
    1. Push the fix to the remote repository. Coolify detects the push and redeploys automatically.
        $ git push origin main
## Configure Custom Domain with HTTPS
Replace the temporary test domain with your own domain. Coolify provisions a Let’s Encrypt certificate automatically when the domain uses `https://`.
1. Open your application’s **Configuration** page.
1. In the **Domains** field, replace the `.sslip.io` address with your custom domain, for example `https://app.example.com`. Include the `https://` prefix to trigger automatic Let’s Encrypt certificate provisioning.
1. Click **Save**, then **Redeploy**.
1. Once redeployed, open your custom domain and confirm the padlock icon is visible in the address bar.
You have successfully created a full-stack application with Windsurf, pushed the source code to GitHub, and deployed it on Vultr using Coolify. The application now serves traffic over a custom domain secured with a Let's Encrypt TLS certificate and redeploys automatically on every push to the repository. For more information and advanced configuration options, visit the [official Coolify documentation](https://coolify.io/docs/).
