The CASE statement in PostgreSQL allows you to evaluate conditions and return values based on those conditions. It’s useful when you want to add conditional logic to queries. For example, grading student scores or classifying records based on thresholds.
This article demonstrates how to use the PostgreSQL CASE statement to generate categorized results from database tables. You’ll create a sample schema with student records and marks, then use a CASE statement to assign grades based on score ranges.
- Provision a managed PostgreSQL database and note the connection credentials.
- Have access to a Linux instance to use as your database client.
- Connect to your server via SSH.
- Create a non-root user with
sudoprivileges. - Make sure the PostgreSQL
psqlclient is installed on your server.
Understanding the CASE Statement in PostgreSQL
The CASE statement in PostgreSQL is a conditional expression used to add logic within a SQL query. It evaluates conditions sequentially and returns a result based on the first condition that evaluates to true. This is especially useful when transforming or classifying data during query execution.
A typical CASE block contains the following components:
CASE: Begins the conditional logic block.WHEN: Defines a condition to evaluate.THEN: Specifies the value to return if the correspondingWHENcondition is true.END: Closes theCASEexpression.
Here is a basic example of the CASE syntax within a SELECT query:
SELECT
column1,
column2,
CASE
WHEN condition1 THEN 'Value A'
WHEN condition2 THEN 'Value B'
ELSE 'Default Value'
END AS result_column
FROM your_table;
You can use any standard SQL comparison operators in your conditions, including:
=: Equal to<: Less than<=: Less than or equal to>: Greater than>=: Greater than or equal to
Create a Sample Database and Tables
To demonstrate the CASE statement in action, start by creating a sample database with two tables: students and marks.
Log in to your PostgreSQL server using the
psqlclient. Replace the hostname, port, and username with your actual credentials.console$ psql -h <host> -p <port> -U <username> defaultdb
Create a new database named
school.sqldefaultdb=> CREATE DATABASE school;
Connect to the newly created
schooldatabase.sqldefaultdb=> \c school;
Create a
studentstable with columns for the student ID, first name, and last name.sqlschool=> CREATE TABLE students ( student_id SERIAL PRIMARY KEY, first_name VARCHAR(50), last_name VARCHAR(50) );
Insert sample student records into the
studentstable.sqlschool=> INSERT INTO students (first_name, last_name) VALUES ('JOHN', 'DOE'), ('JANE', 'SMITH'), ('PETER', 'HENRY'), ('MARY', 'ANN'), ('JESSICA', 'WILLIAMS'), ('BOB', 'JAMES'), ('ESTHER', 'CHLOE');
View the
studentstable data to verify the new values.sqlschool=> SELECT student_id, first_name, last_name FROM students;
student_id | first_name | last_name ------------+------------+----------- 1 | JOHN | DOE 2 | JANE | SMITH 3 | PETER | HENRY 4 | MARY | ANN 5 | JESSICA | WILLIAMS 6 | BOB | JAMES 7 | ESTHER | CHLOE (7 rows)Create a
markstable to store student scores.sqlschool=> CREATE TABLE marks ( score_id SERIAL PRIMARY KEY, student_id INT, score INT );
Insert sample scores into the
markstable.sqlschool=> INSERT INTO marks (student_id, score) VALUES (1, 85), (2, 39), (3, 70), (4, 55), (5, 0), (6, 41), (7, 32);
Retrieve data from the
markstable.sqlschool=> SELECT score_id, student_id, score FROM marks;
score_id | student_id | score ----------+------------+------- 1 | 1 | 85 2 | 2 | 39 3 | 3 | 70 4 | 4 | 55 5 | 5 | 0 6 | 6 | 41 7 | 7 | 32 (7 rows)
Implement the CASE Statement to Grade Students
You can use the CASE expression to evaluate each student's score and assign a grade dynamically. By joining the students and marks tables, you can generate a report that includes names, scores, and computed grade categories.
Run the following SQL query:
school=> SELECT
students.student_id,
students.first_name,
students.last_name,
marks.score,
CASE
WHEN marks.score >= 75 THEN 'Distinction'
WHEN marks.score >= 70 THEN 'Credit'
WHEN marks.score >= 40 THEN 'Pass'
ELSE 'Fail'
END AS grade
FROM marks
LEFT JOIN students ON marks.student_id = students.student_id;
This query performs a LEFT JOIN to match each score with the corresponding student record. The CASE block evaluates the score column and returns:
Distinctionfor scores 75 and aboveCreditfor scores between 70 and 74Passfor scores between 40 and 69Failfor scores below 40
student_id | first_name | last_name | score | grade
1 | JOHN | DOE | 85 | Distinction
2 | JANE | SMITH | 39 | Fail
3 | PETER | HENRY | 70 | Credit
4 | MARY | ANN | 55 | Pass
5 | JESSICA | WILLIAMS | 0 | Fail
6 | BOB | JAMES | 41 | Pass
7 | ESTHER | CHLOE | 32 | Fail
(7 rows)This example demonstrates how CASE enables clear, conditional logic directly within a SELECT query, making your SQL both powerful and easy to maintain.
In this article, you created a sample PostgreSQL database and used the CASE statement to classify student scores with readable and maintainable SQL logic. This conditional technique simplifies query structure, especially for grading or rule-based categorization. For more advanced logic, you can explore PostgreSQL features like lookup tables, IF statements, or AI-powered solutions such as semantic search with pgvector. To learn more, visit the official PostgreSQL conditional expressions documentation.
