title: How to Install and Use Istio on Vultr Kubernetes Engine (VKE)
url: https://docs.vultr.com/how-to-install-and-use-istio-on-vultr-kubernetes-engine-vke
description: Learn how to install and configure Istio service mesh on Vultr Kubernetes Engine (VKE) with step-by-step instructions for traffic management and observability.
publish_date: 2023-08-28T00:00:00Z
last_updated: 2025-04-01T00:00:00Z
author: Donald Le
header_image: https://docs.vultr.com/public/doc-assets/1614/f84fba80d1ba3006.png
Istio is a service mesh implementation that enables observability of your services to monitor how services communicate with each other through a visual dashboard. In addition, Istio also allows you to simplify the canary deployment process so that you can safely deploy a new version of your application to a small number of users and monitor how they interact with it. It also supports the mutual transport layer security (mutual TLS) for requests sent amongst your services, which adds an extra layer of security defense system for your cluster applications.
Istio consists of two main components, the data and control planes as below:
* The data plane is a group of proxies that enable communication between your services.
* The control plane manages the proxies to apply observability, traffic management, and security enhancement.
This article explains how to install and use Istio on a Vultr Kubernetes Engine (VKE) Cluster. You are to apply Istio to your applications to achieve observability, traffic management, and security improvement in your cluster.
* Deploy a [VKE cluster](https://www.vultr.com/kubernetes/) with at least 3 nodes
* Deploy a [Ubuntu management server](https://www.vultr.com/servers/ubuntu/) to work as the client machine to connect to the VKE cluster
On the management machine:
* Using [SSH](https://docs.vultr.com/how-to-use-ssh-with-vultr-servers/), access the server
* Create a non-root user with sudo privileges and switch to the account
* Install Kubectl to access the VKE cluster
* Install Nginx to enable access to the Kiali dashboard
## Installation
### Install the Istio Command Line tool
1. Download and install `istioctl` that lets you install Istio components to your cluster
        $ curl -L https://istio.io/downloadIstio | sh -
2. Switch to the downloaded Istio directory. Replace `1.18.2` with your actual Istio version number
        $ cd istio-1.18.2
3. Add the `istioctl` command to your environment variables to allow usage from any directory.
        $ export PATH=$PWD/bin:$PATH
4. Verify that you can access the `istioctl` tool
        $ istioctl
        Istio configuration command line utility for service operators to
        debug and diagnose their Istio mesh.
        Usage:
          istioctl [command]
          Available Commands:
### Export the Kubernetes Environment Variable
To connect to your VKE cluster, verify that you installed `kubectl`, then export the `KUBECONFIG` environment variable with your VKE cluster YAML file as described below.
1. Export the `KUBECONFIG` environment variable with the path to your VKE configuration file
        $ export KUBECONFIG=/home/user/downloads/vke-config-file.yaml
2. View the cluster notes to verify that `kubectl` connects to the VKE cluster
        $ kubectl get nodes
    You should see a similar result as below:
        NAME                STATUS   ROLES    AGE     VERSION
        test-46b7042bfeea   Ready    <none>   4d16h   v1.27.2
        test-682460cea1fb   Ready    <none>   4d16h   v1.27.2
        test-df51b2c65bc2   Ready    <none>   4d16h   v1.27.2
### Install Istio Components on the VKE Cluster
Istio supports built-in configuration profiles and customized profiles to match the vendor-specific platform. Use the `default` profile to deploy Istio in production deployment. For this article, use the `demo` profile to install Istio as described below.
1. Run the following command to install Istio using the `demo` profile
        $ istioctl install --set profile=demo -y
    You should see a similar output as below:
        - Istio core installed
        - Istiod installed
        - Egress gateways installed
        - Ingress gateways installed
        - Installation complete
        Making this installation the default for injection and validation.
    The above components install in the `istio-system` namespace. With the `demo` profile, Istio installs `istiod`, `istio-egressgateway`, and `istio-ingressgateway` components as below:
    * `istiod`: The Istio control plane component responsible for managing proxies and traffic routing
    * `istio-ingressgateway`: Allows you to define entry points for your services
    * `istio-egressgateway`: Allows you to define exit points for your services
2. Run the following command to list the Istio pods
        $ kubectl get pods --namespace istio-system
        NAME                                    READY   STATUS    RESTARTS   AGE
        istio-egressgateway-77db8d5479-qkhtj    1/1     Running   0          3h35m
        istio-ingressgateway-5ccb67cdc7-phg8t   1/1     Running   0          3h35m
        istiod-64b55f66f-gxvfp                  1/1     Running   0          3h35m
    As displayed in the output, verify that all Istio components are ready and running.
## Configuration
In this section, configure Istio to apply service mesh for the demo application deployed on your VKE cluster.
### Enable the Istio Envoy Proxy
Istio injects Envoy proxies into the application pods to enforce constant communication with each other. As a result, the Istio control plane can apply traffic management, observability, and security enhancement through the Envoy proxies.
To allow Istio mark pods it should inject with the Envoy proxy, label the namespace that the pods belong to with the `is-injection=enabled` option. For example. run the following command to mark the `default` namespace with `is-injection=enabled`
    $ kubectl label namespace default istio-injection=enabled
    namespace/default labeled
The `is-injection=enabled` label marks all pods in the default namespace. Deploy a sample application to test the Envoy proxy functionality
### Deploy a Sample Application
In this section, deploy a sample `bookinfo` application that has the following services:
* `product page`: Retrieves book information from the `details` and `reviews` services.
* `reviews`: Contains the book review. It has three versions: `v1`, `v2`, and `v3`.
* `ratings`: Stores the book ranking information
* `details`: Stores the book information
Within the Istio package directory you downloaded on installation, sample deployment scripts for the `bookinfo` app are available within the `sample` sub-directory
1. Switch to the Istio data directory
        $ cd istio-1.18.2
1. Deploy the `bookinfo` application to the `default` namespace.
        $ kubectl apply -f samples/bookinfo/platform/kube/bookinfo.yaml
        service/details created
        serviceaccount/bookinfo-details created
        deployment.apps/details-v1 created
        service/ratings created
        serviceaccount/bookinfo-ratings created
        deployment.apps/ratings-v1 created
        service/reviews created
          serviceaccount/bookinfo-reviews created
          deployment.apps/reviews-v1 created
          deployment.apps/reviews-v2 created
          deployment.apps/reviews-v3 created
          service/productpage created
          serviceaccount/bookinfo-productpage created
          deployment.apps/productpage-v1 created
1. After a few minutes, verify the status of the pods
        $ kubectl get pods
        details-v1-7c7dbcb4b5-tvkml       2/2     Running   0          2m53s
        productpage-v1-664d44d68d-7pg6k   2/2     Running   0          2m47s
        ratings-v1-844796bf85-f9jqz       2/2     Running   0          2m51s
        reviews-v1-5cf854487-xwsdj        2/2     Running   0          2m50s
        reviews-v2-955b74755-7tfmj        2/2     Running   0          2m49s
        reviews-v3-797fc48bc9-sv8w2       2/2     Running   0          2m48s
    As displayed in the above output, each pod has two running containers, the application container, and the envoy proxy container
1. To view the containers inside a pod, for example, pod `details-v1-7c7dbcb4b5-tvkml`, run the following command:
        $ kubectl get pods details-v1-7c7dbcb4b5-9dxsr -o jsonpath='{.spec.containers[*].name}'
        details istio-proxy
    In the above output:
    * `details` is the container name of the application container
    * `istio-proxy` is the Envoy proxy name injected by Istio into the pod
### Expose the Application
Your sample application requires customers to retrieve book information using the `productpage` service. To enable access to the `bookinfo` application, you need to:
* Create an Istio gateway that acts as a load balancer for your application
* Forward requests from the gateway to the `productpage` service
#### Create an Istio Gateway
1. Within the Istio data directory, use a text editor such as `Nano` to create a new file named `istio-gateway.yaml`
        $ nano istio-gateway.yaml
2. Add the following contents to the file
        apiVersion: networking.istio.io/v1alpha3
        kind: Gateway
            istio: ingressgateway # use istio default controller
          servers:
          - port:
              number: 80
              protocol: HTTP
            hosts:
      In the above configuration, you set the Istio gateway named `bookinfo-gateway` and chose the selector type as `ingressgateway`. This means incoming traffic forwards to the Istio service mesh. The gateway on port `80` accepts HTTP traffic and sets the gateway to accept any hostname.
3. Apply the configuration to create the Istio gateway
        $ kubectl apply -f istio-gateway.yaml
        gateway.networking.istio.io/bookinfo-gateway created
4. View the `EXTERNAL-IP` of the Istio gateway
        $ kubectl get svc istio-ingressgateway -n istio-system
    Your output should appear like the one below:
        NAME                   TYPE           CLUSTER-IP      EXTERNAL-IP       PORT(S)        AGE
        istio-ingressgateway   LoadBalancer   10.111.89.113   192.0.2.100       15021:32290/TCP,80:30270/TCP,443:31066/TCP,31400:31694/TCP,15443:30141/TCP   5h41m
5. Using `curl`, make an HTTP request to the gateway
        $ curl "http://192.0.2.100"
    The request returns an empty result because you need to implement a mechanism to forward the request to the target application.
#### Forward External Requests to the Application Service
1. Create a new file named `product-page-virtual-service.yml`
        $ nano product-page-virtual-service.yaml
2. Add the following configurations to the file
        kind: VirtualService
          hosts:
          gateways:
          - bookinfo-gateway
          http:
          - match:
            - uri:
                exact: /productpage
            route:
            - destination:
                host: productpage
                port:
                  number: 9080
    The above configuration defines an Istio `VirtualService` to forward requests with the URL `$GATEWAY-URL/productpage` to the `productpage` service on port `9080`.
3. Run the following command to create the `VirtualService` for the above configuration
        $ kubectl apply -f product-page-virtual-service.yaml
        virtualservice.networking.istio.io/productpage created
4. Make an HTTP request to the Istio gateway again
        $ curl "http://192.0.2.100/productpage"
    You should view the content of your product page service as below:
        <!DOCTYPE html>
        <html>
          <head>
            <title>Simple Bookstore App</title>
        <meta charset="utf-8">
        <meta http-equiv="X-UA-Compatible" content="IE=edge">
        <meta name="viewport" content="width=device-width, initial-scale=1">
## Set Up the Istio Service Mesh
Enable observability, traffic management, and security enhancement for your application using Istio as described in the following sections.
### Observability
To enable observability in the application, install Kiali to visualize how services communicate with each other. Additionally, implement addon services like Prometheus or Jaeger to collect service metrics as described in the steps below.
1. The Istio data directory contains all necessary addons, install them to your cluster using the following command
        $ kubectl apply -f samples/addons
    Wait for a few minutes for the installation of all required addons to complete. When successful, your output should look like the one below:
        service/kiali created
        deployment.apps/kiali created
        serviceaccount/loki created
        configmap/loki created
        configmap/loki-runtime created
        service/loki-memberlist created
        service/loki-headless created
        service/loki created
        statefulset.apps/loki created
        serviceaccount/prometheus created
        configmap/prometheus created
        clusterrole.rbac.authorization.k8s.io/prometheus created
        clusterrolebinding.rbac.authorization.k8s.io/prometheus created
        service/prometheus created
        deployment.apps/prometheus created
2. Start the Kiali dashboard in the background to view how services in the `bookinfo` app communicate
        $ istioctl dashboard kiali &
    The above command forwards your Kiali cluster port to your localhost machine IP address. When successful, your output should appear like the one below:
        http://localhost:20001/kiali
    Later, to stop the Kiali dashboard background process, view the job ID
        $ jobs
    Stop the background process by job ID. For example, job id `1`.
        $ kill %1
3. By default, the `istioctl dashboard kiali` port forwarding command only accepts connections from the localhost hostname address `127.0.0.1`. To access the dashboard using your public management Server IP, set up a new configuration file to enable Nginx as a reverse proxy using the command below
        $ sudo nano /etc/nginx/sites-enabled/kiali.conf
4. Add the following configurations to the file
        server {
            listen 8080;
            server_name _;
            location / {
                proxy_pass http://localhost:20001;
                proxy_set_header Host $host;
                proxy_set_header X-Real-IP $remote_addr;
                proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
                proxy_set_header X-Forwarded-Proto $scheme;
    Save and close the file
    The above configuration securely forwards all requests to the Nginx listening port `8080` to the Kiali dashboard localhost port `20001` for further processing.
5. Enable the listening port `8080` through the firewall
        $ sudo ufw allow 8080/tcp
6. Using a web browser such as Chrome, access the Kiali dashboard
        http://SERVER-IP:8080/kiali
    The main Kiali dashboard interface should display in your browser window.
    ![Access the Kiali Dashboard](https://docs.vultr.com/public/doc-assets/1614/a9832bde508a063d.png)
7. In your terminal session, send sample requests to the `bookinfo` application to view how the services interact with each other. Replace `192.0.2.100` with your actual cluster external address
        $ for i in $(seq 1 1000); do curl -s -o /dev/null "http://192.0.2.100/productpage"; done
8. On the main navigation menu, click **Graph**
9. On the top bar, click the **Select Namespaces** button, and check **Select all** to read all cluster namespaces
10. Verify that the graph displays how services send requests to each other
    ![View the Kiali services graph](https://docs.vultr.com/public/doc-assets/1614/0adbc2271e057130.png)
    As displayed in the graph, requests distribute evenly for the `reviewers` service version `v1`, `v2`, `v3`, this is the built-in support for traffic management that Istio offers. By default, Istio applies the `least request` load balancing algorithm to distribute requests to the pods.
    In your terminal session, press :key_ctrl: + :key_c: to stop sending sample requests
### Traffic Management
To apply customized traffic management for your services, create a new virtual service and destination rule to distribute the traffic to different versions of the `reviewer` service as described below.
1. In your terminal session, create a new file named `custom-traffic-management.yaml`
        $ nano custom-traffic-management.yaml
              hosts:
                - reviews
              http:
                - route:
                  - destination:
                      host: reviews
                      subset: v1
                    weight: 10
                  - destination:
                      host: reviews
                      subset: v2
                    weight: 70
                  - destination:
                      host: reviews
                      subset: v3
                    weight: 20
            kind: DestinationRule
              host: reviews
              trafficPolicy: ~
              subsets:
                - labels:
                    version: v1
                - labels:
                    version: v2
                - labels:
                    version: v3
    In the above configuration, the `DestinationRule` resource definition instructs Istio to label the `reviews` service versions into different `subsets` as `v1`, `v2`, and `v3`.
    The `VirtualService` resource definition instructs Istio to distribute different traffic weights to different versions of the `reviews` service by their `subsets` label as below:
    * 10 percent of the traffic to the `reviews` service version 1
    * 70 percent of the traffic to the `reviews` service version 2
    * 20 percent of the traffic to the `reviews` service version 3
3. Apply the resource to your cluster
        $ kubectl apply -f custom-traffic-management.yml
4. Again, send some requests to the `bookinfo` application
5. In your browser session, access the Kiali dashboard, find, and click the refresh button in the top right corner to view the traffic graph again.
    ![New Kiali Graph data](https://docs.vultr.com/public/doc-assets/1614/05fe5a909241c79b.png)
    As displayed in the updated graph, the ratio of requests for each `reviews` service version is different. The `reviews` service version 2 should have the most significant number of traffic.
### Security Enhancement
To enable services inside the Kubernetes cluster to securely communicate with each other and prevent MITM (Man in the Middle) type of attacks, enable TLS authentication on external traffic requests. However, using TLS for every service in your application is time consuming depending on the number of running services. With this difficulty, Istio supports TLS using mutual TLS that allows both the client and server to verify the identities of each other.
Below are the supported Istio mutual TLS authentication modes:
* **Permissive mode**: It's the default supported mode in which the Envoy proxies accept mutual TLS and non-mutual TLS traffic. You can send HTTP requests to the application pods outside the Kubernetes cluster.
* **Strict mode**: The Envoy proxies only accept mutual TLS traffic. You cannot send HTTP requests to the application pods outside the Kubernetes cluster. Instead, you must send HTTPS requests to the pods.
To better note the difference between the permissive and strict mode, send an HTTP request to the `productpage` service without using the gateway endpoint.
1. Run the following command to list the services in your Kubernetes cluster
        $ kubectl get svc
        details           ClusterIP   10.102.170.227   <none>        9080/TCP            20h
        kubernetes        ClusterIP   10.96.0.1        <none>        443/TCP             22h
        loki              ClusterIP   10.99.14.65      <none>        3100/TCP,9095/TCP   20h
        loki-memberlist   ClusterIP   None             <none>        7946/TCP            20h
        productpage       ClusterIP   10.106.169.43    <none>        9080/TCP            20h
        ratings           ClusterIP   10.108.144.95    <none>        9080/TCP            20h
        reviews           ClusterIP   10.101.40.10     <none>        9080/TCP            20h
    As displayed in the output, the `productpage` service uses the `ClusterIP` type with no `EXTERNAL-IP` value for you to access it.
2. To set the service `EXTERNAL-IP` value, change the `ClusterIP` type to `LoadBalancer` using the following command
        $ kubectl edit svc productpage
    The above command opens the service YAML configuration in the `vim` text editor. Scroll the **Selector** section, find the `type: ClusterIP` entry, press :key_i: on your keyboard to edit the file, and change the value `type: LoadBalancer`
    Press :key_esc:, enter `:`, and add :key_w: + :key_q: to save the file, and close the editor.
3. Wait for a few minutes for Kubernetes to apply changes, and check the cluster services again
        $ kubectl get svc
        productpage       LoadBalancer   10.106.169.43    192.0.2.100       9080:30933/TCP      20h
    Verify that the `productpage` service now has your loadbalancer's external IP value.
4. Run the following command to make a HTTP request to the `productpage` service using its `EXTERNAL-IP` address
        $ curl http://external-ip:9080/productpage --> able to capture the content
    The `productpage` service response should look like the one below:
        <!DOCTYPE html>
        <html>
        <head>
        <meta name="viewport" content="width=device-width, initial-scale=1.0">
        <div class="navbar navbar-inverse navbar-fixed-top">
        <div class="container">
          <div class="navbar-header pull-left">
            <a class="navbar-brand" href="#">Microservices Fabric BookInfo Demo</a>
          </div>
        </div>
        </div>
    Because Istio applies the `permissive` mutual TLS mode by default, a client can send HTTP requests to the service.
5. To change the mutual TLS mode to `strict` mode, create a new file named `strict-mode-tls.yaml`
        $ nano strict-mode-tls.yaml
6. Add the following contents to the file
        apiVersion: "security.istio.io/v1beta1"
        kind: "PeerAuthentication"
          namespace: "istio-system"
          mtls:
            mode: STRICT
    The above configuration instructs Istio to apply the `strict` mode to the `PeerAuthentication` resource within the `istio-system` namespace.
7. Apply the change to your cluster
        $ kubectl apply -f strict-mode-tls.yaml
8. Wait for a few seconds for Istio to apply the change. Then, try to make an HTTP request to the `productpage` again
        $ curl https://external-ip:9080/productpage
    This time, you should receive an error message from the `productpage` service as below:
        curl: (52) Empty reply from server
    The above error displays because Istio now applies a `strict` mode for the mutual TLS authentication. If the client does not send an HTTPS request to the service, Istio does not allow the client to interact with the service.
In this article, you used Istio to apply observability, traffic management, and security enhancement for your application. To further implement Istio in your cluster, visit [How to Use Istio for Ingress Gateway without TLS Termination on VKE](https://docs.vultr.com/how-to-use-istio-for-ingress-gateway-without-tls-termination-on-vke/) to send encrypted SSL requests directly to the NGINX server.
## More Information
For more information about Istio, visit the following resources:
* [Istio Traffic Management](https://istio.io/latest/docs/concepts/traffic-management/)
* [Istio Observability](https://istio.io/latest/docs/concepts/observability/)
* [Istio Security](https://istio.io/latest/docs/concepts/security/)
