title: How to Install and Use Linkerd on Vultr Kubernetes Engine (VKE)
url: https://docs.vultr.com/how-to-install-and-use-linkerd-on-vultr-kubernetes-engine-vke
description: Learn how to install and configure Linkerd service mesh on Vultr Kubernetes Engine (VKE) to enhance observability, security, and reliability for your applications.
publish_date: 2025-10-29T14:54:49.867683Z
last_updated: 2025-11-06T14:06:09.326000Z
author: Mary Ogunmola
header_image: https://lhr1.vultrobjects.com/docs-main-doc-assets-1/2355/d7af74d4-bdc1-4c00-bc0c-a18ebeccc766.png
Linkerd is a lightweight, open-source service mesh for Kubernetes that provides observability, security, and traffic management features. It uses a sidecar proxy model where lightweight proxies handle pod-to-pod communication, while a control plane manages configuration and routing.
This guide explains how to install Linkerd on a Vultr Kubernetes Engine (VKE) cluster. You will deploy a sample application, configure Ingress for external access, and implement traffic management features.
* Have a [Vultr Kubernetes Engine (VKE) cluster](https://www.vultr.com/kubernetes/).
* A [domain name with an A record](https://docs.vultr.com/products/network/dns/management/manage-records) pointing to your cluster's load balancer IP address (such as `linkerd.example.com`).
* Have access to a [Ubuntu-based server or local machine](https://www.vultr.com/servers/ubuntu/) as your workstation for managing your VKE cluster and using Linkerd CLI.
* [Install and Configure Kubectl](https://docs.vultr.com/how-to-install-and-use-kubectl-to-manage-a-vke-cluster) to access your Kubernetes cluster.
* [Install Helm](https://helm.sh/docs/intro/install/) on your workstation.
## Install the Linkerd CLI
Install the Linkerd command-line interface on your workstation to manage your service mesh deployment.
1. Update the system package index.
1. Download and install the Linkerd CLI.
    $ curl --proto '=https' --tlsv1.2 -sSfL https://run.linkerd.io/install-edge | sh
1. Add Linkerd to your PATH.
    $ export PATH=$PATH:$HOME/.linkerd2/bin
1. Make the PATH change permanent.
    $ echo 'export PATH=$PATH:$HOME/.linkerd2/bin' >> ~/.bashrc
    $ source ~/.bashrc
1. Verify the CLI installation.
    $ linkerd version --client
    Client version: edge-25.10.3
    The server version appears unavailable because the control plane has not yet been installed.
## Validate the Kubernetes Cluster
Ensure your cluster meets Linkerd's requirements before installation.
1. Run pre-installation checks.
    $ linkerd check --pre
    All checks should pass with the message `Status check results are √`. If any checks fail, resolve the issues before proceeding.
## Install Linkerd Control Plane
Deploy Linkerd's core components to your cluster.
1. Install the Gateway API CRDs.
    $ kubectl apply -f https://github.com/kubernetes-sigs/gateway-api/releases/download/v1.3.0/standard-install.yaml
1. Install Linkerd CRDs.
    $ linkerd install --crds | kubectl apply -f -
1. Install the control plane.
    $ linkerd install | kubectl apply -f -
1. Verify the installation.
    $ linkerd check
1. Check control plane pods.
    $ kubectl get pods -n linkerd
    NAME                                     READY   STATUS    RESTARTS   AGE
    linkerd-destination-7b4657cfd8-btqdv     4/4     Running   0          4m40s
    linkerd-identity-5584896d84-6pmdm        2/2     Running   0          4m40s
    linkerd-proxy-injector-995fcbf47-dv6qr   2/2     Running   0          4m40s
## Install Linkerd Viz Extension
The viz extension provides observability features and the web dashboard.
1. Install the viz extension.
    $ linkerd viz install | kubectl apply -f -
1. Verify the viz installation.
    $ linkerd viz check
## Expose Linkerd Dashboard
You can expose the Linkerd dashboard securely via Kubernetes Ingress. In this section, expose the Linkerd dashboard securely using TLS encryption.
### Install Nginx Ingress Controller
Deploy Nginx Ingress Controller to handle external traffic routing.
1. Add the Nginx Ingress Helm repository.
    $ helm repo add ingress-nginx https://kubernetes.github.io/ingress-nginx
1. Update Helm.
    $ helm repo update
1. Install Nginx Ingress Controller.
    $ helm install ingress-nginx ingress-nginx/ingress-nginx \
        --create-namespace --namespace ingress-nginx
1. Wait for the LoadBalancer to get an external IP.
    $ kubectl get service -n ingress-nginx ingress-nginx-controller
    Sample output:
    NAME                       TYPE           CLUSTER-IP      EXTERNAL-IP       PORT(S)                      AGE
    ingress-nginx-controller   LoadBalancer   10.99.177.190   192.0.20.11       80:31460/TCP,443:32364/TCP   3m51s
    Note the `EXTERNAL-IP` address value. This is where you should point your domain's A record.
1. Verify that the Nginx Ingress controller pods are running.
    $ kubectl get pods -n ingress-nginx
### Configure Dashboard Authentication
Create basic authentication credentials to secure dashboard access.
1. Install the htpasswd utility.
    $ sudo apt install apache2-utils -y
1. Generate authentication credentials. Replace `admin` with your preferred username.
    $ htpasswd -c auth admin
    Enter a strong password when prompted.
1. Create a Kubernetes secret with the credentials.
    $ kubectl create secret generic web-ingress-auth \
        --from-file=auth \
        --namespace=linkerd-viz
1. Remove the local auth file.
    $ rm auth
### Install cert-manager
Using cert-manager, you can secure your dashboard with HTTPS using Let's Encrypt TLS certificates.
1. Add the Jetstack repository to Helm.
   $ helm repo add jetstack https://charts.jetstack.io
1. Update Helm.
   $ helm repo update
1. Install cert-manager and all required CRDs in your Kubernetes cluster.
   $ helm install cert-manager jetstack/cert-manager \
     --namespace cert-manager --create-namespace \
     --set crds.enabled=true
1. Check the cert-manager resources and wait until they become ready.
    $ kubectl get all -n cert-manager
1. Create a ClusterIssuer for Let's Encrypt.
    $ nano letsencrypt-issuer.yaml
1. Add the following content. Replace `admin@example.com` with your email.
    kind: ClusterIssuer
      acme:
        server: https://acme-v02.api.letsencrypt.org/directory
        email: admin@example.com
        privateKeySecretRef:
        solvers:
        - http01:
            ingress:
              class: nginx
    Save the file and close the editor.
1. Apply the ClusterIssuer.
    $ kubectl apply -f letsencrypt-issuer.yaml
### Create Ingress for Linkerd Dashboard
Create an Ingress resource to expose the Linkerd dashboard externally.
1. Update the `ingress-nginx-controller` ConfigMap so the latest version of cert-manager can verify your domain. Without this change, a strict Nginx setting may block cert-manager’s automatic domain check, stopping it from issuing TLS certificates.
    $ kubectl patch configmap ingress-nginx-controller -n ingress-nginx --patch '{"data":{"strict-validate-path-type":"false"}}'
1. Create an Ingress manifest file.
    $ nano linkerd-dashboard-ingress.yaml
1. Add the following content. Replace `linkerd.example.com` with your domain.
    kind: Ingress
      namespace: linkerd-viz
        cert-manager.io/cluster-issuer: "letsencrypt-prod"
        nginx.ingress.kubernetes.io/upstream-vhost: web.linkerd-viz.svc.cluster.local:8084
        nginx.ingress.kubernetes.io/auth-type: basic
        nginx.ingress.kubernetes.io/auth-secret: web-ingress-auth
        nginx.ingress.kubernetes.io/auth-realm: 'Authentication Required'
        nginx.ingress.kubernetes.io/proxy-body-size: "0"
        nginx.ingress.kubernetes.io/proxy-read-timeout: "600"
        nginx.ingress.kubernetes.io/proxy-send-timeout: "600"
      ingressClassName: nginx
      tls:
      - hosts:
        - linkerd.example.com
        secretName: linkerd-dashboard-tls
      - host: linkerd.example.com
        http:
          paths:
          - path: /
            pathType: Prefix
            backend:
              service:
                port:
                  number: 8084
    This Ingress routes external traffic from your domain to the Linkerd dashboard service running in the `linkerd-viz` namespace. It enforces basic authentication, sets proxy timeouts, and ensures the request is sent to the correct backend service on port 8084.
1. Apply the Ingress manifest.
    $ kubectl apply -f linkerd-dashboard-ingress.yaml
1. Verify the Ingress resource.
    $ kubectl get ingress -n linkerd-viz
1. Verify the TLS certificate creation.
    $ kubectl get certificate -n linkerd-viz
    Wait until the certificate shows `READY` as `True`.
## Access the Dashboard
Access your secured Linkerd dashboard through the configured domain.
1. Open a web browser and navigate to your domain.
    https://linkerd.example.com
1. Enter the username and password you created earlier.
1. Explore the dashboard to view cluster metrics, service mesh topology, and traffic flow.
## Deploy a Sample Application
Test Linkerd's features with the Emojivoto sample application.
1. Deploy the Emojivoto application.
    $ curl -sL https://run.linkerd.io/emojivoto.yml | kubectl apply -f -
1. Verify the deployment.
    $ kubectl get pods -n emojivoto
1. Add the application to the mesh.
    $ kubectl get -n emojivoto deploy -o yaml | linkerd inject - | kubectl apply -f -
1. View the meshed application in the dashboard or via CLI.
    $ linkerd viz -n emojivoto stat deploy
## Configure Traffic Splitting
Implement canary deployments using HTTPRoute to split the traffic.
1. Create a second version of the web deployment.
    $ kubectl get deploy web -n emojivoto -o yaml | \
        sed 's/name: web/name: web-v2/' | \
        kubectl apply -f -
    This command copies the existing `web` Deployment, renames the copy to `web-v2`, and applies it to create a new Deployment.
1. Create a service for the new version.
    $ cat <<EOF | kubectl apply -f -
      namespace: emojivoto
      - name: http
        targetPort: 80
        app: web
        version: v2
    EOF
    This Service exposes the `web-v2` pods on port `80` inside the `emojivoto` namespace. It routes traffic to pods labeled `app: web`, `version: v2`.
1. Add the new deployment to the mesh.
    $ kubectl get deploy web-v2 -n emojivoto -o yaml | \
        linkerd inject - | \
        kubectl apply -f -
    This command injects the Linkerd proxy into the `web-v2` Deployment and updates the cluster so new pods run with the proxy.
1. Create a manifest to split the traffic.
    $ nano traffic-split.yaml
1. Add the following content to the file:
    apiVersion: policy.linkerd.io/v1beta2
    kind: HTTPRoute
      parentRefs:
        - name: web-svc
          group: core
        - backendRefs:
            - name: web-svc
              weight: 80
            - name: web-v2
              weight: 20
    This HTTPRoute configuration routes 80% of traffic to the original `web-svc` service and 20% to the new `web-v2` service.
1. Apply the manifest.
    $ kubectl apply -f traffic-split.yaml
1. Verify traffic distribution in the dashboard or via CLI.
    $ linkerd viz -n emojivoto stat --from deploy/vote-bot deploy
You have successfully installed Linkerd on a VKE cluster, exposed the dashboard securely through Nginx Ingress with TLS encryption and authentication, and deployed a sample application with traffic splitting capabilities. For more information about advanced Linkerd features, visit the [official Linkerd documentation](https://linkerd.io/2-edge/getting-started/).
