title: How to Install MongoDB on Vultr Kubernetes Engine (VKE)
url: https://docs.vultr.com/how-to-install-mongodb-on-vultr-kubernetes-engine-vke
description: Learn how to install MongoDB on Vultr Kubernetes Engine (VKE) with our step-by-step guide. Deploy a scalable, reliable database for your cloud applications.
publish_date: 2022-07-06T00:00:00Z
last_updated: 2026-09-11T16:40:54.326789Z
header_image: https://docs.vultr.com/public/doc-assets/1353/6cbf16eb2c59c9f6.png
MongoDB is an open-source database program. Classified as a NoSQL database program, the data stored in MongoDB is in JSON-like format. Instead of tables and rows, it stores data in collections of documents. Each collection contains related documents, and each document is a JSON-like object. The data model of MongoDB provides the flexibility in storing data with an optional schema.
The MongoDB Kubernetes Operator is an extension for Kubernetes. It allows deployment and management of MongoDB server on a Kubernetes cluster. It supports the deployment of replica sets in which a group of MongoDB servers stores the same data providing redundancy and high availability for production usage.
This guide walks you through the deployment of a MongoDB replica set on Vultr Kubernetes Engine (VKE) using the MongoDB Kubernetes Operator, securing the deployment with a TLS certificate generated using `cert-manager`, and deploying Vultr Load Balancers for external access.
* [Deploy a Vultr Ubuntu 20.04 instance](https://www.vultr.com/servers/ubuntu) to use as a management workstation.
* [Deploy a Kubernetes cluster at Vultr](https://docs.vultr.com/vultr-kubernetes-engine/#How_to_Deploy_a_VKE_Cluster) with at least three or more nodes with 2GB RAM and 2 CPUs.
On the management workstation:
* Install [kubectl](https://kubernetes.io/docs/tasks/tools/install-kubectl-linux/).
* Download your VKE configuration and [configure kubectl](https://docs.vultr.com/vultr-kubernetes-engine/#How_to_Manage_a_VKE_Cluster).
* Install [Vultr Container Storage Interface](https://github.com/vultr/vultr-csi).
* Install [Vultr Cloud Controller Manager](https://github.com/vultr/vultr-cloud-controller-manager).
You'll perform the rest of the steps in this guide from your management workstation.
## Install the MongoDB Kubernetes Operator
The MongoDB Kubernetes Operator is a custom resource definition and a controller that simplifies the MongoDB server's deployment and management. This section explains the steps to install the custom resource definition, the role bindings, and the operator.
Clone the MongoDB Kubernetes Operator repository.
    # git clone https://github.com/mongodb/mongodb-kubernetes-operator.git
Switch to the repository directory.
    # cd mongodb-kubernetes-operator
Install the custom resource definition.
    # kubectl apply -f config/crd/bases/mongodbcommunity.mongodb.com_mongodbcommunity.yaml
The above command installs the `MongoDBCommunity` resource type in the cluster. This resource allows the deployment and scaling of the MongoDB replica set. You use this resource for defining the configuration of the MongoDB replica set.
Create a new namespace.
    # kubectl create namespace mongodb
A namespace isolates the resources related to a single application in the cluster. The above command creates a new namespace named **mongodb** that you use in the next steps to contain all the resources related to the MongoDB replica set.
Install the necessary roles and role bindings.
    # kubectl apply -k config/rbac -n mongodb
The above command installs a specific set of permissions required by the MongoDB Kubernetes Operator to interact with the resources in the cluster. The `-n` flag specifies the namespace to apply the changes.
Install the MongoDB Kubernetes Operator.
    # kubectl apply -f config/manager/manager.yaml -n mongodb
The above command installs the MongoDB Kubernetes Operator in the cluster. It creates a new pod in the **mongodb** namespace and watches for state changes related to the `MongoDBCommunity` resource type.
Verify the installation.
    # kubectl get pods -n mongodb
    NAME                                           READY   STATUS    RESTARTS   AGE
    mongodb-kubernetes-operator-648bf8cc59-mc5sm   1/1     Running   0          10s
## Install the `cert-manager` Add-On
The `cert-manager` add-on for Kubernetes provides custom resource definitions that allow issuing TLS certificates. It installs three custom resources in the cluster: `Issuer`, `ClusterIssuer`, and `Certificate`. The `Certificate` resource requires an issuer parent resource, and it generates a Kubernetes secret which contains a pair of the TLS certificate and the private key.
Install the `cert-manager` add-on.
    # kubectl apply -f https://github.com/cert-manager/cert-manager/releases/download/v1.8.0/cert-manager.yaml
The above command installs all the Kubernetes resources provided by the `cert-manager` add-on in the cluster.
Create a new configuration directory.
    # mkdir ~/mongodb-replica-set
Switch to the configuration directory.
    # cd ~/mongodb-replica-set
This guide uses a self-signed TLS certificate to secure the MongoDB replica set. A valid TLS certificate requires a certificate authority signature. To sign the TLS certificate for the MongoDB replica set, you create an issuer that generates a self-signed certificate authority.
Using a text editor, create a new file named **certificate.yaml**.
    # nano certificate.yaml
    kind: Issuer
      selfSigned: {}
    kind: Certificate
      isCA: true
      commonName: mongodb-ca-cert
      secretName: mongodb-ca-cert-key-pair
      privateKey:
        algorithm: ECDSA
      issuerRef:
        kind: Issuer
    kind: Issuer
      ca:
    kind: Certificate
      commonName: '*.mongodb-svc.mongodb.svc.cluster.local'
      secretName: mongodb-cert-key-pair
      dnsNames:
      - '*.mongodb-svc.mongodb.svc.cluster.local'
      - 'mongodb-0.example.com'
      - 'mongodb-1.example.com'
      - 'mongodb-2.example.com'
      issuerRef:
        kind: Issuer
The above configuration creates four resources: the **mongodb-ca-issuer** `Issuer` resource allows the creation of the **mongodb-ca-cert** `Certificate` resource, which is a self-signed certificate authority. It uses the self-signed certificate authority to create the **mongodb-issuer** `Issuer` resource, which allows creating the **mongodb-cert** `Certificate` resource, which you use to secure the MongoDB replica set.
The `commonName` and the `dnsName` attributes in the **mongodb-cert** `Certificate` resource contain the certificate's hostnames. The `commonName` attribute is a wildcard followed by the syntax of the hostname used by the MongoDB Kubernetes Operator to provision the servers locally. The syntax of the hostname is as follows:
    <metadata.name>-<member-number>.<metadata.name>-svc.<namespace>.svc.cluster.local
The `<metadata.name>` is the name of the `MongoDBCommunity` resource. In the next steps, you build the configuration for the MongoDB replica set using **mongodb** as the metadata name and the number of MongoDB replica set members you want to spawn in the cluster.
Replace and add a list of additional hostnames for external access in the `dnsName` attribute according to the number of members you want to spawn. You use these additional hostnames as replica set horizons in the next steps.
Apply the configuration.
    # kubectl apply -f certificate.yaml -n mongodb
Verify the certificate state.
    # kubectl get certificate -n mongodb
    NAME              READY   SECRET                     AGE
    mongodb-ca-cert   True    mongodb-ca-cert-key-pair   11s
    mongodb-cert      True    mongodb-cert-key-pair      10s
## Deploy MongoDB Replica Set
A MongoDB replica set is a group of two or more instances of the MongoDB server that store the same data to enable redundancy and high availability for production usage. The MongoDB Kubernetes Operator enables you to deploy a MongoDB replica set on your VKE cluster using a single declarative configuration file instead of deploying and configuring multiple servers. This section explains the configuration and deployment of a MongoDB replica set using the MongoDB Kubernetes Operator.
Create a new file named **replica-set.yaml**.
    # nano replica-set.yaml
    kind: Secret
    type: Opaque
    stringData:
      password: 'your_password'
    apiVersion: mongodbcommunity.mongodb.com/v1
    kind: MongoDBCommunity
      members: 3
      type: ReplicaSet
      version: "5.0.5"
      replicaSetHorizons:
      - horizon: mongodb-0.example.com:27017
      - horizon: mongodb-1.example.com:27017
      - horizon: mongodb-2.example.com:27017
      security:
        authentication:
          modes: ["SCRAM"]
        tls:
          enabled: true
          certificateKeySecretRef:
          caCertificateSecretRef:
      users:
        - name: demo-admin
          db: admin
          passwordSecretRef:
          roles:
            - name: clusterAdmin
              db: admin
            - name: userAdminAnyDatabase
              db: admin
          scramCredentialsSecretName: my-scram
      statefulSet:
            volumeClaimTemplates:
              - metadata:
                  accessModes: ["ReadWriteOnce"]
                  storageClassName: vultr-block-storage
                  resources:
                    requests:
                      storage: 20Gi
              - metadata:
                  storageClassName: vultr-block-storage-hdd
                  resources:
                    requests:
                      storage: 40Gi
The above configuration creates a `MongoDBCommunity` resource in the cluster and a Kubernetes secret containing a password for the administrator user. When you apply the configuration, the MongoDB Kubernetes Operator creates a Kubernetes StatefulSet to provision the MongoDB replica set. Each replica set member is a pod with two containers: a container for the `mongod` process binary and a container for the MongoDB agent, which handles the provisioning of the `mongod` process. Each pod consists of 2 volumes: a volume for storing the database and a volume for storing logs.
The following are the highlights of the configuration:
* **metadata.name** - The name of the `MongoDBCommunity` resource, used as prefix of related resources.
* **spec.version** - The version of MongoDB community server installed in the replica set.
* **spec.members** - The number of replica set members.
* **spec.replicaSetHorizons** - The DNS hostnames used for external access. They should match the number of replica set members. Ensure that the TLS certificate includes these hostnames.
* **spec.security.tls** - Enable TLS security and define the Kubernetes secret created by `cert-manager` containing the TLS certificate key-pair.
* **spec.users** - The name of the administrator user, the Kubernetes secret referring to the administrator user's password, and the name of the collection for storing authentication information.
* **spec.statefulSet.spec.volumeClaimTemplates** - The storage class and the storage size for volumes created for each member in the replica set. The above configuration uses the storage classes defined by Vultr Container Storage Interface (CSI) to provision Vultr Block Storage for each volume. Refer to the [Vultr Container Storage Interface documentation](https://github.com/vultr/vultr-csi/tree/master/docs/kubernetes) for more information.
If you want to set non-default values for the Kubernetes StatefulSet deployed by the MongoDB Kubernetes Operator, you can use the **spec.statefulSet** attribute. It provides direct access to the Kubernetes Staefulset configuration. Refer to the [configuration samples](https://github.com/mongodb/mongodb-kubernetes-operator/tree/master/config/samples) for more information.
    # kubectl apply -f replica-set.yaml -n mongodb
Follow the replica set deployment progress.
    # watch -n 0.1 kubectl get pods -n mongodb
> It takes around 5 to 10 minutes to finish the deployment.
    Every 0.1s: kubectl get pods -n mongodb
    mongodb-0                                      2/2     Running   0          3m6s
    mongodb-1                                      2/2     Running   0          102s
    mongodb-2                                      2/2     Running   0          55s
    mongodb-kubernetes-operator-648bf8cc59-mc5sm   1/1     Running   0          10m
Verify the deployment.
    # kubectl get mongodbcommunity -n mongodb
    NAME      PHASE     VERSION
    mongodb   Running   5.0.5
If the deployment stops making any progress, you can use the following commands to troubleshoot and find the issue causing the delay.
    # kubectl describe mongodbcommunity mongo -n mongodb
    # kubectl describe pod mongo-0 -n mongodb
    # kubectl get pvc -n mongodb
    # kubectl get pv -n mongodb
The following are the issues you might face during the deployment of the replica set:
* Not having enough CPU.
* Not having enough Memory.
* Vultr Block Storage limit exceeded.
Ensure that your VKE cluster has enough resources available and you do not exceed the total number of Vultr Block Storage volumes limit.
## Access MongoDB Shell
You can fetch the connection string and the credentials to connect to the MongoDB replica set inside the cluster with the credentials stored by the MongoDB Kubernetes Operator in the Kubernetes secrets.
This is the syntax for the name of the Kubernetes secrets resource that contains the credentials:
    <metadata.name>-<auth-db>-<username>
Fetch the connection string.
    # kubectl get secret mongodb-admin-demo-admin -n mongodb -o json
The above command returns JSON response with BASE64 encoded values.
Install the `jq` package.
    # apt install jq
The above package lets you decode the BASE64 values in the JSON response.
Fetch the usable connection string.
    # kubectl get secret mongodb-admin-demo-admin -n mongodb -o json | jq -r '.data | with_entries(.value |= @base64d)'
      "connectionString.standard": "mongodb://demo-admin:your_password@mongodb-0.mongodb-svc.mongodb.svc.cluster.local:27017,mongodb-1.mongodb-svc.mongodb.svc.cluster.local:27017,mongodb-2.mongodb-svc.mongodb.svc.cluster.local:27017/admin?ssl=true",
      "connectionString.standardSrv": "mongodb+srv://demo-admin:your_password@mongodb-svc.mongodb.svc.cluster.local/admin?ssl=true",
      "password": "your_password",
      "username": "demo-admin"
You use the `connectionString.standardSrv` value and the TLS certificate to connect to the MongoDB replica set inside the cluster.
Enter the `mongod` container.
    # kubectl exec -it mongodb-0 -c mongod -n mongodb -- /bin/bash
Connect to the MongoDB replica set using `mongosh`.
    $ mongosh --tls --tlsCAFile /var/lib/tls/ca/*.pem --tlsCertificateKeyFile /var/lib/tls/server/*.pem "mongodb+srv://demo-admin:your_password@mongodb-svc.mongodb.svc.cluster.local/admin?ssl=true"
Fetch all databases.
    mongodb [primary] admin> show dbs
    admin   176 kB
    config  172 kB
    local   545 kB
Exit the `mongosh` session.
    mongodb [primary] admin> quit()
Exit the `mongod` container.
    $ exit
## Fetch the TLS Certificate
You secured the MongoDB replica set deployed in the cluster using the TLS certificate key pair. You need that certificate and the private key to connect to the MongoDB replica set. Every pod provisioned by the MongoDB Kubernetes Operator contains the certificate and the private key in `/var/lib/tls` in the `mongod` container.
You can manually enter the `mongod` container of the first pod using `kubectl exec -it mongodb-0 -c mongod -n mongodb -- /bin/bash` to copy and paste the certificate and the private key files or use the following shortcuts to fetch them.
Fetch the certificate file.
    # kubectl exec mongodb-0 -c mongod -n mongodb -- /bin/bash -c "cat /var/lib/tls/ca/*.pem" > crt.pem
The above command creates a file named **crt.pem** in the working directory containing the certificate contents.
Fetch the private key file.
    # kubectl exec mongodb-0 -c mongod -n mongodb -- /bin/bash -c "cat /var/lib/tls/server/*.pem" > key.pem
The above command creates a file named **key.pem** in the working directory containing the private key contents.
## Set Up External Access
The Vultr Cloud Controller Manager provides the ability to provision Vultr Load Balancer with Kubernetes. It binds the `LoadBalancer` service type with the Vultr Load Balancer service. When you create a new `LoadBalancer` service, the Vultr Cloud Controller Manager provisions a new Vultr Load Balancer in your account and configures it according to the object specifications and the annotations. This section explains how to set up external access for the MongoDB replica using load balancers and DNS records.
Create a new file named **external-access.yaml**.
    # nano external-access.yaml
      namespace: mongodb
        service.beta.kubernetes.io/vultr-loadbalancer-protocol: "tcp"
      type: LoadBalancer
      - name: mongodb
        port: 27017
        protocol: TCP
        app: mongodb-svc
        statefulset.kubernetes.io/pod-name: mongodb-0
      namespace: mongodb
      type: LoadBalancer
      - name: mongodb
        port: 27017
        protocol: TCP
        app: mongodb-svc
        statefulset.kubernetes.io/pod-name: mongodb-1
      namespace: mongodb
      type: LoadBalancer
      - name: mongodb
        port: 27017
        protocol: TCP
        app: mongodb-svc
        statefulset.kubernetes.io/pod-name: mongodb-2
The above configuration creates three `LoadBalancer` service objects in the cluster. You can adjust the number of load balancers according to the number of members in the replica set. Each `LoadBalancer` service object provisions a Vultr Load Balancer, which forwards TCP traffic on port `27017` (default MongoDB port) to individual members in the replica set.
    # kubectl apply -f external-access.yaml -n mongodb
Follow the load balancer deployment progress.
    # watch -n 0.1 kubectl get service -n mongodb
> It takes around 5 minutes to finish the deployment.
    NAME              TYPE           CLUSTER-IP       EXTERNAL-IP       PORT(S)           AGE
    mongodb-arb-svc   ClusterIP      None             <none>            27017/TCP         155m
    mongodb-lb-0      LoadBalancer   10.110.133.138   104.207.153.207   27017:31808/TCP   2m7s
    mongodb-lb-1      LoadBalancer   10.98.170.249    45.32.70.189      27017:32151/TCP   2m7s
    mongodb-lb-2      LoadBalancer   10.97.161.16     66.42.101.239     27017:30036/TCP   2m7s
    mongodb-svc       ClusterIP      None             <none>            27017/TCP         155m
Configure the following DNS records in your domain to set up the A records and the Service (SRV) records for each load balancer.
|table|100|
|thead|
|tr|
|th|20|Type|
|th|40|Name|
|th|40|Content|
|tbody|
|tr|
|td|**A**|
|td|mongodb-0.example.com|
|td|LB-0-IP|
|tr|
|td|**A**|
|td|mongodb-1.example.com|
|td|LB-1-IP|
|tr|
|td|**A**|
|td|mongodb-2.example.com|
|td|LB-2-IP|
|tr|
|td|**SRV**|
|td|\_mongodb.\_tcp.mongodb.example.com|
|td|0 50 27017 mongodb-0.example.com|
|tr|
|td|**SRV**|
|td|0 50 27017 mongodb-1.example.com|
|tr|
|td|**SRV**|
|td|0 50 27017 mongodb-2.example.com|
Verify DNS records.
    # nslookup mongodb-0.example.com
    # nslookup mongodb-1.example.com
    # nslookup mongodb-2.example.com
    # nslookup -q=SRV _mongodb._tcp.mongodb.example.com
The following is the connection string for external access.
    mongodb+srv://demo-admin:your_password@mongodb.example.com/admin
You must pass the TLS certificate fetched in the previous section along with the connection string.
Verify the connection using the [MongoDB Shell](https://www.mongodb.com/try/download/shell) tool on your local system.
    mongosh --tls --tlsCAFile /path/to/certificate/file --tlsCertificateKeyFile /path/to/private_key/file "mongodb+srv://demo-admin:your_password@mongodb.example.com/admin"
    Current Mongosh Log ID: 62a71d81196f9e1982eefd7a
    Connecting to:          mongodb+srv://<credentials>@mongodb.example.com/admin?appName=mongosh+1.3.1
    Using MongoDB:          5.0.5
    Using Mongosh:          1.3.1
    For mongosh info see: https://docs.mongodb.com/mongodb-shell/
You deployed a MongoDB replica set on a Vultr Kubernetes Engine (VKE) cluster, which stores data on the Vultr Block Storage service using the MongoDB Kubernetes Operator. You secured the replica set using a TLS certificate created using the `cert-manager` add-on. You used the Vultr Load Balancer service for setting up external access to the MongoDB replica set.
## More Information
* [Vultr Kubernetes Engine](https://docs.vultr.com/vultr-kubernetes-engine)
* [MongoDB Kubernetes Operator](https://github.com/mongodb/mongodb-kubernetes-operator)
* [Vultr Container Storage Interface](https://github.com/vultr/vultr-csi)
* [Vultr Cloud Controller Manager](https://github.com/vultr/vultr-cloud-controller-manager)
