title: How to Migrate Linode Block Storage Volumes to Vultr Block Storage
url: https://docs.vultr.com/how-to-migrate-linode-block-storage-volumes-to-vultr-block-storage
description: Learn the step-by-step process to migrate your Linode Block Storage volumes to Vultr Block Storage efficiently with our comprehensive guide.
publish_date: 2025-04-04T12:42:34.222059Z
last_updated: 2026-09-09T22:13:06.438590Z
author: Mary Ogunmola
header_image: https://docs.vultr.com/public/doc-assets/2140/11f9e5e9-1506-4785-8311-cb290c777be4.png
Block storage is a reliable solution for storing data in fixed volumes, offering low-latency access to persistent storage. Vultr provides high-performance, highly available block storage options using HDD or NVMe SSDs. Similarly, Linode offers block storage volumes that can be attached to its compute instances.
Follow this guide to migrate a block storage volume from Linode to Vultr. You’ll configure both storage volumes, transfer your data, and verify the integrity of the migration process.
* Have an existing [Linode instance running Ubuntu 24.04](https://cloud.linode.com/linodes) with an attached [Block Storage Volume](https://cloud.linode.com/volumes), and access as a non-root user with sudo privileges.
* Have access to a [Vultr Cloud Compute instance running Ubuntu 24.04](https://www.vultr.com/servers/ubuntu/) as a non-root user with sudo privileges.
* A [Vultr Block Storage Volume](https://console.vultr.com/blockstorage/) that's [attached to the instance](https://docs.vultr.com/products/cloud-storage/block-storage/management/attach-instances).
## Set Up the Migration Environment
This section walks you through setting up both ends of the migration. You'll mount the source block storage on your Linode instance and prepare the destination block storage on your Vultr instance to receive the data.
### Set Up the Linode Block Storage Volume
Follow these steps to mount your Linode Block Storage volume and prepare it with sample data for migration.
1. List all available block devices on your Linode instance.
    $ lsblk
    You should see an output similar to the following:
    NAME MAJ:MIN RM  SIZE RO TYPE  MOUNTPOINTS
    sda   8:0    0 24.5G  0 disk    /
    sdb   8:16   0  512M  0 disk    [SWAP]
    sdc   8:32   0   10G  0 disk
    In the output, `sda` is the primary disk, and `sdb` is used for swap space. `sdc` represents the attached Linode Block Storage volume. Linode assigns block device names in alphabetical order based on detection, so additional volumes would appear as `sdd`, `sde`, and so on.
    Check the `MOUNTPOINT` column. If it's empty for `sdc`, the volume is not mounted and likely doesn't have a filesystem yet.
1. Format the volume with EXT4. Replace `VOLUME_LABEL` with your actual volume label.
    $ sudo mkfs.ext4 "/dev/disk/by-id/scsi-0Linode_Volume_<VOLUME_LABEL>"
    mke2fs 1.47.0 (5-Feb-2023)
    Discarding device blocks: done
    Creating filesystem with 2621440 4k blocks and 655360 inodes
    Filesystem UUID: 077d477d-2d1b-4be1-8a81-2420c3f86440
    Superblock backups stored on blocks:
            32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632
    Allocating group tables: done
    Writing inode tables: done
    Creating journal (16384 blocks): done
    Writing superblocks and filesystem accounting information: done
    > [!WARNING]
    > This step will erase all data on the volume. Skip it if the volume already has content.
1. Create a mount point directory.
    $ sudo mkdir "/mnt/<VOLUME_LABEL>"
1. Mount the volume to the created directory.
    $ sudo mount "/dev/disk/by-id/scsi-0Linode_Volume_<VOLUME_LABEL>" "/mnt/<VOLUME_LABEL>"
    Replace `VOLUME_LABEL` with your volume label.
1. Verify that the volume is mounted by listing all block devices.
    $ lsblk
    sdc   8:32   0   10G  0 disk    /mnt/sample-volume
    Output should now show `/mnt/<VOLUME_LABEL>` under the `MOUNTPOINTS` column for sdc.
1. Add sample data to test the migration. First, create a test directory and file.
    $ sudo mkdir /mnt/<VOLUME_LABEL>/sample-directory
    $ sudo nano /mnt/<VOLUME_LABEL>/sample-directory/file1.txt
1. Add this text and save the file.
    This is a sample file.
1. Create a large file to simulate real data.
    $ sudo fallocate -l 500M /mnt/<VOLUME_LABEL>/sample-directory/largefile.bin
    The command above creates a file with a size of 500 megabytes.
1. Verify the files.
    $ ls -lh /mnt/<VOLUME_LABEL>/sample-directory
    You should see an output similar to:
    total 501M
    -rw-r--r-- 1 root root   23 Mar 14 15:14 file1.txt
    -rw-r--r-- 1 root root 500M Mar 14 15:51 largefile.bin
    This confirms that your sample files were created successfully in the Linode Block Storage volume.
1. Verify the installed Rsync version to use when migrating volumes.
    $ rsync --version
    rsync  version 3.2.7  protocol version 31
### Set Up the Vultr Block Storage Volume
In this section, you’ll configure your Vultr Block Storage volume to receive data from the Linode instance.
1. List all available block devices on the Vultr instance.
    $ lsblk
    sr0     11:0    1 1024M  0 rom
    vda    253:0    0   25G  0 disk
    ├─vda1 253:1    0  512M  0 part /boot/efi
    └─vda2 253:2    0 24.5G  0 part /
    vdb    253:16   0   40G  0 disk
    In this output, `vdb` is the Vultr Block Storage volume. The empty `MOUNTPOINT` column shows that it's not mounted and has no filesystem.
1. Create an `EXT4` filesystem on the volume.
    $ sudo mkfs.ext4 /dev/vdb
    Creating filesystem with 10485760 4k blocks and 2621440 inodes
    Filesystem UUID: f14b343c-6520-4c0b-a0d1-f4bc8d4e24e7
            32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
            4096000, 7962624
    Creating journal (65536 blocks): done
1. Create a mount point. Replace `<VULTR_STORAGE>` with your storage label.
    $ sudo mkdir /mnt/<VULTR_STORAGE>
1. Mount the volume to the directory you created.
    $ sudo mount /dev/vdb /mnt/<VULTR_STORAGE>
1. Reload `systemd` to recognize mount changes.
    $ sudo systemctl daemon-reload
1. Verify the volume is mounted and check its size.
    $ df -h
    Filesystem      Size  Used Avail Use% Mounted on
    tmpfs            96M  1.3M   95M   2% /run
    efivarfs        256K   19K  233K   8% /sys/firmware/efi/efivars
    /dev/vda2        23G  6.3G   16G  29% /
    tmpfs           478M     0  478M   0% /dev/shm
    tmpfs           5.0M     0  5.0M   0% /run/lock
    /dev/vda1       511M  6.2M  505M   2% /boot/efi
    tmpfs            96M   12K   96M   1% /run/user/0
    /dev/vdb         40G   24K   38G   1% /mnt/vultr-storage
    You should see `/dev/vdb` mounted on `/mnt/<VULTR_STORAGE>`.
1. Grant full ownership to your user for access. By default, a mounted block storage volume is owned by root, which can restrict access for non-root users.
    $ sudo chown -R <USER>:<USER> /mnt/<VULTR_STORAGE>/
    Replace `<USER>` and `<VULTR_STORAGE>` accordingly.respectively.
1. Get the UUID of the mounted volume.
    $ sudo blkid /dev/vdb
    /dev/vdb: UUID="ea527cb1-81c4-469d-a697-b219af936a86" BLOCK_SIZE="4096" TYPE="ext4"
    Take note of the UUID, which is `ea527cb1-81c4-469d-a697-b219af936a86`, in this example.
1. Open the fstab file to enable persistent mounting.
    $ sudo nano /etc/fstab
1. Add the following entry to the bottom of the file.
    /dev/disk/by-uuid/<VULTR_STORAGE_UUID> /mnt/<VULTR_STORAGE> ext4 defaults 0 2
    * `/dev/disk/by-uuid/<VULTR_STORAGE_UUID>`: Specifies the block storage device identifier.
    * `/mnt/<VULTR_STORAGE>`: Defines where the volume will be mounted.
    * `ext4`: Defines the type of filesystem, which is `ext4` in this case.
    * The mount option `defaults`: Uses default mount options such as read/write and allows execution.
    * The dump option `0`: Determines if dump should back up the filesystem. `0` means the backup is disabled.
    * The filesystem check order `2`: Runs the filesystem check on boot, after the root filesystem.
1. Save the file, then apply the changes:
    $ sudo mount -a
## Migrate the Linode Block Storage Volume to Vultr Block Storage
With both storage volumes configured, you can now transfer data from the Linode volume to the Vultr Block Storage using `rsync` over SSH. This method encrypts the data in transit and efficiently syncs only the necessary files.
1. On your Linode instance, run the following command to start the migration. Replace the placeholders with your actual values:
    * `<LINODE_VOLUME_LABEL>`: Linode volume label
    * `<VULTR_USER>`: Username on the Vultr instance
    * `<VULTR_INSTANCE_IP>`: Vultr instance’s IP address
    * `<VULTR_STORAGE>`: Vultr volume mount point
    $ sudo rsync -avz --progress --exclude="lost+found" /mnt/<LINODE_VOLUME_LABEL>/ <VULTR_USER>@<VULTR_INSTANCE_IP>:/mnt/<VULTR_STORAGE>/
    From the above command, the options used with `rsync` are:
    * `-a`: Preserves file attributes (archive mode)
    * `-v`: Enables verbose output
    * `-z`: Compresses data during transfer
    * `--progress`: Displays real-time progress
    * `--exclude="lost+found"`: Skips the system-generated `lost+found` directory
    > Depending on the volume of data and your network speed, this process may take some time. The `--progress`option helps you monitor it.
    When prompted, enter your Vultr instance's user password.
    sending incremental file list
    sample-dir/
    sample-dir/file1.txt
                 23 100%    0.00kB/s    0:00:00 (xfr#1, to-chk=1/4)
    sample-dir/largefile.bin
        524,288,000 100%  631.31MB/s    0:00:00 (xfr#2, to-chk=0/4)
    sent 16,267 bytes  received 65 bytes  1,555.43 bytes/sec
    total size is 524,288,023  speedup is 32,101.89
    > If the transfer fails or gets interrupted, simply rerun the same `rsync` command. It will resume by copying only the remaining files.
1. After the transfer completes, compare the directory sizes on both instances to confirm that all data was migrated.
    On the Linode instance:
    $ sudo du -sh /mnt/<VOLUME_LABEL>/
    501M    /mnt/sample-volume/
    On the Vultr instance:
    $ sudo du -sh /mnt/<VULTR_STORAGE>/
    501M    /mnt/vultr-storage/
## Test the Migration
While comparing directory sizes helps confirm the data transfer, using checksums offers a more reliable method to verify data integrity. In this section, you'll generate and compare checksum files on both Linode and Vultr instances.
1. Generate checksums on the Linode volume. Replace `<VOLUME_LABEL>` with your Linode volume label.
    $ sudo find /mnt/<VOLUME_LABEL>/ -type f -exec md5sum {} \; | sort -k 2 > linode_checksums.txt
    From the above command:
    * `find /mnt/<VOLUME_LABEL>/ -type f`: Locates all files in the mounted block storage.
    * `-exec md5sum {} \;`: Computes the MD5 checksum for each file.
    * `sort -k 2 > linode_checksums.txt`: Sorts the output by filename and writes it to `linode_checksums.txt`.
    >[!NOTE]
    >For stronger cryptographic integrity checking, you can replace `md5sum` with `sha256sum` in both checksum generation and comparison steps. This provides enhanced protection against rare collision scenarios.
1. Transfer the checksum file to the Vultr instance. Replace `<USER>` and `<VULTR_INSTANCE_IP>` with your Vultr instance's SSH username and IP address.
    $ rsync -avz linode_checksums.txt <USER>@<VULTR_INSTANCE_IP>:~
    Enter the SSH password when prompted.
    sent 228 bytes  received 35 bytes  21.04 bytes/sec
    total size is 152  speedup is 0.58
1. Generate checksums on the Vultr volume. Replace `<VULTR_STORAGE>` with your Vultr block storage label.
    $ sudo find /mnt/<VULTR_STORAGE>/ -type f -exec md5sum {} \; | sort -k 2 > vultr_checksums.txt
1. Compare both checksum files.
    $ diff linode_checksums.txt vultr_checksums.txt
    If the files differ only in mount paths but not checksums, the migration was successful. For example:
    1,2c1,2
    < a60319cd0397d5c9bcc0652f9a54c56c  /mnt/sample-volume/sample-dir/file1.txt
    < d8b61b2c0025919d5321461045c8226f  /mnt/sample-volume/sample-dir/largefile.bin
    > a60319cd0397d5c9bcc0652f9a54c56c  /mnt/vultr-storage/sample-dir/file1.txt
    > d8b61b2c0025919d5321461045c8226f  /mnt/vultr-storage/sample-dir/largefile.bin
    > For stronger cryptographic integrity checking, you can replace md5sum with sha256sum in both checksum generation and comparison steps. This provides enhanced protection against rare collision scenarios.
## Cutover to Vultr Block Storage
Once you’ve verified that all data has been migrated successfully, follow these final steps to complete the transition to Vultr.
1. Update your DNS records to point to the public IP address of your Vultr instance.
1. Stop any applications or services still using the Linode Block Storage volume.
1. Detach the Linode volume from your Linode instance to avoid conflicts.
1. Update your application's configuration files to reference the new storage location on the Vultr instance.
1. Test your application thoroughly on the Vultr instance to ensure everything works as expected.
1. Decommission any unused Linode resources, including block storage volumes and compute instances.
In this guide, you migrated data from a Linode Block Storage volume to a Vultr Block Storage volume using `rsync` over SSH. You validated the integrity of the transfer using checksums and configured the Vultr volume for persistent access. This process enables you to take full advantage of Vultr’s fast, reliable block storage for your workloads.
For additional configuration options or advanced usage, refer to the [official Vultr Block Storage documentation](https://docs.vultr.com/products/cloud-storage/block-storage).
