title: How to Provision Persistent Volume Claims on Vultr Kubernetes Engine
url: https://docs.vultr.com/how-to-provision-persistent-volume-claims-on-vultr-kubernetes-engine
description: Learn how to provision and manage Persistent Volume Claims (PVCs) on Vultr Kubernetes Engine for reliable data storage in your containerized applications.
publish_date: 2024-03-18T13:51:45.864586Z
author: Mirdul Swarup
header_image: https://docs.vultr.com/public/doc-assets/1762/bc6ce1cff71da4f4.png
Vultr offers persistent storage options for Kubernetes through both **Vultr Block Storage (VBS)** and the **Vultr File System (VFS)**. These storage solutions are integrated with the **Vultr Kubernetes Engine (VKE)** to support a wide range of application needs—from high-performance single-node volumes to shared, multi-node file systems. VKE includes a managed Kubernetes control plane that automatically installs the Vultr [Container Storage Interface (CSI)](https://kubernetes-csi.github.io/docs/), enabling seamless access to these storage types and allowing your applications to scale with ease.
In this guide, you will provision persistent volumes using both Vultr Block Storage (VBS) and Vultr File System (VFS), and learn how to update the configuration to perform PVC expansion where supported.
* Deploy a [Vultr Ubuntu server](https://www.vultr.com/servers/ubuntu/)
* [Deploy a Vultr Kubernetes Engine (VKE) cluster](https://docs.vultr.com/products/kubernetes/provisioning) with at least 2 nodes.
* Access the workstation using SSH as a non-root user with sudo privileges.
* Install and configure Kubectl to access the cluster
* Vultr Container Storage Interface (CSI) Driver v0.14.0 or higher.
* Kubernetes Config (`KUBECONFIG`) for cluster management.
## Understanding Storage Classes
Vultr provides two types of persistent storage technologies for Kubernetes workloads, available in most global regions: **Vultr Block Storage** and **Vultr File System (VFS)**. These options support a variety of performance, capacity, and access mode requirements.
### Vultr Block Storage (VBS)
Vultr Block Storage supports **ReadWriteOnce (RWO)** access mode and is ideal for high-performance or large-capacity workloads where each volume is attached to a single node.
* **HDD Block Storage** – A cost-effective solution using traditional spinning hard drives. Suitable for workloads that require large capacity over speed.
    * **CSI Storage Class**: `vultr-block-storage-hdd`
    * **Minimum Volume Size**: 40 GiB
    * **Maximum Volume Size**: 40 TiB
    * **Technology**: Rotational hard disk drive (HDD)
    * **Availability**: Most Vultr regions
    * **Key Benefit**: Affordable storage with support for very large volumes
* **NVMe Block Storage** – A high-performance option backed by solid-state NVMe drives. Best for latency-sensitive or IOPS-intensive applications.
    * **CSI Storage Class**: `vultr-block-storage`
    * **Minimum Volume Size**: 10 GiB
    * **Maximum Volume Size**: 10 TiB
    * **Technology**: Solid-state NVMe
    * **Availability**: Many Vultr regions
    * **Key Benefit**: Fastest I/O performance for demanding workloads
### Vultr File System (VFS)
The Vultr File System provides **ReadWriteMany (RWX)** access, allowing multiple pods across different nodes to read and write to the same volume simultaneously. It’s ideal for shared data use cases such as content management systems, collaborative apps, and distributed workloads.
* **CSI Storage Class**: `vultr-vfs-storage`
* **Technology**: Network-attached file system
* **Availability**: Selected Vultr regions
* **Key Benefit**: Shared storage for multi-pod and multi-node access (RWX)
To check availability in your region, use the [/v2/regions](https://api.vultr.com/v2/regions) API endpoint.
Look for the following flags in the response:
- `block_storage_storage_opt`: Indicates **HDD Block Storage** availability
- `block_storage_high_perf`: Indicates **NVMe Block Storage** availability
Some locations support both storage classes. If NVMe block storage is available in a location, our CSI uses that class by default.
## Create Persistent Volume Claims (PVCs) with Vultr Block Storage (VBS)
In this section, you are to create a PVC using a YAML configuration file with **ReadWriteOnce (RWO)** access mode.
1. Create a configuration file.
    $ nano create_pvc.yaml
1. Copy and paste the below given configuration.
    kind: PersistentVolumeClaim
      accessModes:
        - ReadWriteOnce
      resources:
        requests:
          storage: 10Gi
      storageClassName: vultr-block-storage
    Save and exit the file.
    In the above configuration, you are requesting an NVMe block storage volume with a size of 10Gi using the `vultr-block-storage` storage class. This PVC uses the **ReadWriteOnce** access mode, meaning it can be mounted as read-write by a single node.
    * Supported Vultr Block Storage types and minimum size requirements:
        - **NVMe Block Storage**
            - `storageClassName`: `vultr-block-storage`
            - Minimum size: `10Gi`
        - **HDD Block Storage**
            - `storageClassName`: `vultr-block-storage-hdd`
            - Minimum size: `40Gi`
        To use HDD block storage, update the `storageClassName` to `vultr-block-storage-hdd` and set the `storage` request to at least `40Gi` in the above configuration.
1. Apply the configuration file.
    $ sudo kubectl apply -f create_pvc.yaml
    Output
    persistentvolumeclaim/csi-pvc created
1. Verify that a new Vultr Block Storage is provisioned.
    $ sudo kubectl get pvc
    Output
    NAME      STATUS   VOLUME                 CAPACITY   ACCESS MODES   STORAGECLASS          VOLUMEATTRIBUTESCLASS   AGE
    csi-pvc   Bound    pvc-36bbc0eb476040a9   10Gi       RWO            vultr-block-storage   <unset>                 56s
1. You can verify the same by navigating to **Cloud Storage** then **Block Storage** on your [Vultr Console](https://console.vultr.com/).
    ![PVC provision](https://docs.vultr.com/public/doc-assets/1762/f51420f451a48b7b.png)
### PVC Expansion
In this section, you are to expand the storage capacity of an existing VBS attached to your instance.
1. Change the configuration file.
1. Increase the storage capacity.
      accessModes:
        - ReadWriteOnce
      resources:
        requests:
          storage: 30Gi
    In the above configuration, you increased the storage capacity for an existing NVMe block storage to 30 GB from the original 10 GB.
1. Apple the configuration changes.
    Output
    persistentvolumeclaim/csi-pvc configured
1. Verify the change.
    Output
    csi-pvc   Bound    pvc-36bbc0eb476040a9   30Gi       RWO            vultr-block-storage   <unset>                 5m1s
1. You can verify the same by navigating to **Cloud Storage** then **Block Storage** on your [Vultr portal](https://console.vultr.com/).
    ![PVC Expansion](https://docs.vultr.com/public/doc-assets/1762/6acf30a8b26575e9.png)
1. It is not advised to reduce the storage capacity of the VBS as the action may result in significant data loss.
## Create Persistent Volume Claims (PVCs) with Vultr File System (VFS)
Vultr File System volumes can be used as Persistent Volumes in Kubernetes using the `vultr-vfs-storage` storage class.
1. Create a new manifest for PVC resource.
      accessModes:
        - ReadWriteMany
      resources:
        requests:
          storage: 10Gi
      storageClassName: vultr-vfs-storage
    In this example, the PVC resource `test-rwx` is created with a capacity of 10Gi and access mode `ReadWriteMany`. The storage class `vultr-vfs-storage` is used to provision the VFS volume.
1. Apply the PVC manifest.
    $ kubectl apply -f pvc.yaml
    persistentvolumeclaim/test-rwx created
1. List the PVC resource.
    $ kubectl get pvc test-rwx
    The PVC resource `test-rwx` should be listed with the status `Bound`.
    test-rwx      Bound    pvc-604cf0c549ad41e3   10Gi       RWX            vultr-vfs-storage   <unset>                 10m
### Troubleshooting
If you are unable to reproduce the same behaviour as noted above, you can try troubleshooting to get more information.
* Describe the PVC resource.
    $ kubectl describe pvc test-rwx
    You can review the events for any issues related to provisioning of the VFS volume.
* List all storage classes.
    $ kubectl get storageclass
    The list must contain `vultr-vfs-storage` in order to provision a VFS volume.
* Ensure sufficient quota allocation.
* Monitor cluster events for storage issues.
In this guide, you learned about the different persistent storage types and classes available globally on Vultr, including both Vultr Block Storage (VBS) and Vultr File System (VFS). You provisioned an HDD block storage volume and also explored how to expand the storage of an existing volume attached to a Kubernetes cluster.
