title: How to use a Vultr Load Balancer with VKE
url: https://docs.vultr.com/how-to-use-a-vultr-load-balancer-with-vke
description: Learn how to set up and configure a Vultr Load Balancer with Vultr Kubernetes Engine (VKE) to efficiently distribute traffic across your containerized applications.
publish_date: 2023-02-02T00:00:00Z
author: Quan Hua Hong
header_image: https://docs.vultr.com/public/doc-assets/1346/d349270c5c46ecff.png
Vultr Load Balancer is a fully-managed solution to distribute traffic to groups of servers which decouples the availability of a backend service from the health of a single server. Vultr Load Balancer ensures your service stay online by distributing the load across multiple servers to ensure that servers don't get overloaded.
If you are new to Vultr Load Balancers, you should read the [Load Balancer Quickstart Guide](https://docs.vultr.com/vultr-load-balancers) first.
Vultr Kubernetes Engine (VKE) is a fully-managed Kubernetes product. When deploying an application to VKE, Kubernetes automatically spreads Pods across different nodes in a cluster for better availability.
Vultr Load Balancers are compatible with VKE to distribute traffic across multiple Pods in different nodes. Vultr Load Balancer in VKE offers all the same features and capabilities as the fully-managed solution for standalone scenarios.
This guide explains how to deploy and configure Vultr Load Balancers in Vultr Kubernetes Engine (VKE) with detailed configuration information.
* Deploy a Vultr Kubernetes Cluster with at least three nodes.
* Configure `kubectl` and git in your machine.
* Have a domain name if you want to follow the TLS/SSL certificates sections.
## 1. Deploy Web Servers
This section shows how to deploy web servers to the Kubernetes cluster using a Deployment.
The web server in this article is a Python web server that returns the hostname of the pod and HTTP request headers.
This example application has a [public Docker image (quanhua92/whoami)](https://hub.docker.com/r/quanhua92/whoami) in the Docker Hub. You can go to [this GitHub repository](https://github.com/quanhua92/whoami) to see the application's source code.
1. Create a file named `deployment.yaml` with the following content:
            replicas: 3
                        - name: whoami
                          image: quanhua92/whoami:latest
                          imagePullPolicy: Always
                              - containerPort: 8080
2. Deploy the application using `kubectl`
        $ kubectl apply -f deployment.yaml
Notice that the deployment name in this example is `whoami`, and the Pod listens to requests on the port `8080`.
## 2. Deploy a Load Balancer for HTTP traffic
This section shows how to deploy a load balancer for HTTP traffic on port 80. You deploy a Kubernetes Service with the `LoadBalancer` type and use metadata annotations to configure VKE Load Balancer.
The default load-balancing algorithm is the Round Robin algorithm. This works by using each server behind the load balancer in turns.
1. Create a file named `service.yaml` with the following content. The app selector `whoami` matches the existing deployment, and the target port `8080` matches the container port in the previous step.
                service.beta.kubernetes.io/vultr-loadbalancer-protocol: "http"
            type: LoadBalancer
                - name: http
                  targetPort: 8080
2. Deploy the Service using `kubectl`
        $ kubectl apply -f service.yaml
3. Run the following command to see the VKE Load Balancer setup progress:
        $ kubectl get service whoami-lb -w
The result should look like:
    NAME        TYPE           CLUSTER-IP       EXTERNAL-IP   PORT(S)        AGE
    whoami-lb   LoadBalancer   10.108.167.185   <pending>     80:32365/TCP   9s
    whoami-lb   LoadBalancer   10.108.167.185   139.180.143.107   80:32365/TCP   81s
You can also go to [the Load Balancer page in the Vultr Console](https://console.vultr.com/loadbalancers/) to inspect your Load Balancers.
You can navigate to the IP address of your Load Balancer to access the application.
Notice that it may take a few minutes before you can access the application through the Load Balancer IP address.
The response of the application should look like:
    Hostname: whoami-84798c47cd-2gnhd
    Host: 139.180.143.107
    Cache-Control: max-age=0
    Dnt: 1
    Upgrade-Insecure-Requests: 1
    User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.0.0 Safari/537.36
    Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9
    Accept-Encoding: gzip, deflate
    Accept-Language: en-US,en;q=0.9,vi;q=0.8,la;q=0.7,nl;q=0.6
    Cookie: session=eyJteV9zZXNzaW9uIjoiVDk4UVUifQ.YoqD3g.o1pyE6s6vTkQqnbvPhG08_6tvOI
    X-Forwarded-Proto: http
    X-Forwarded-For: 113.172.203.231
    Connection: close
    Session: T98QU
Refresh the website a few times. Notice that the Hostname changes after a few requests, meaning the Load Balancer can distribute the traffic across multiple pods.
## 3. Using the Least Connections Load Balancing Algorithm
The least connections load balancing algorithm is a dynamic load balancing algorithm that distributes the client requests to the application server with the least number of active connections at the time the load balancer receives the client request. This algorithm works best in environments where the application servers have similar capabilities.
1. Change the `service.yaml` as follows:
                service.beta.kubernetes.io/vultr-loadbalancer-algorithm: "least_connections"
            type: LoadBalancer
                - name: http
                  targetPort: 8080
## 4. Configure Health Check on the VKE Load Balancer
Vultr Load Balancers provides health checks to determine if the application servers respond to client requests.
Here are some configurations that you can customize:
* `healthcheck-protocol`: The protocol that load balancers use to perform health check. Two possible values are `tcp` and `http`. The default value is `tcp`
* `healthcheck-path`: The URL path that load balancers use to check on the application server. The default value is the root path, `/`.
* `healthcheck-port`: The port that load balancers use to check on the application server. The Kubernetes defines this value. You should not change this value in normal scenarios.
* `healthcheck-check-interval`: The interval between health checks in seconds. The default value is `15`.
* `healthcheck-response-timeout`: The response timeout in seconds. The default value is `5`.
* `healthcheck-unhealthy-threshold`: The number of unhealthy requests before the load balancer removes the application server from the server pool. The default value is `5`.
* `healthcheck-healthy-threshold`: The number of healthy requests before load balancers adds the application server back to the server pool. The default value is `5`.
The example application in this article has an endpoint for the health check, /health. The benefit of using /health instead of / is that:
* You can reduce the computation required to run the health check.
* You can reduce the response time and content length.
In the example application code, the endpoint returns an empty response with 200 status without any complex computation.
1. Change the service.yaml as follows:
                service.beta.kubernetes.io/vultr-loadbalancer-healthcheck-protocol: "http"
                service.beta.kubernetes.io/vultr-loadbalancer-healthcheck-path: "/health"
                service.beta.kubernetes.io/vultr-loadbalancer-healthcheck-check-interval: "10"
                service.beta.kubernetes.io/vultr-loadbalancer-healthcheck-response-timeout: "5"
                service.beta.kubernetes.io/vultr-loadbalancer-healthcheck-unhealthy-threshold: "5"
                service.beta.kubernetes.io/vultr-loadbalancer-healthcheck-healthy-threshold: "5"
            type: LoadBalancer
                - name: http
                  targetPort: 8080
## 5. Expose the Application With Free TLS/SSL Certificates from Let's Encrypt
This section shows how to deploy a load balancer for HTTPS traffic on port 443.
Here are some approaches to obtaining TLS/SSL Certificates:
* `Self-Signed Certificates`: Use your own Certificate Authority to create and sign TLS/SSL certificates. This is a great option for development environments.
* `Purchase TLS/SSL Certificates`: You need to buy a TLS/SSL certificate from a well-known Certificate Authority for production use-cases.
* `Use Free TLS/SSL Certificates`: Use free TLS/SSL certificates from Let's Encrypt or ZeroSSL.
In this section, you install **NGINX Ingress Controller** to handle incoming SSL/TLS traffic and **Cert Manager** to manage free TLS/SSL certificates from Let's Encrypt.
**NGINX Ingress Controller** creates a `LoadBalancer` service to handle incoming traffic. This `LoadBalancer` service is also a VKE Load Balancer, so you don't need the service created in the previous sections.
VKE Load Balancer routes incoming traffics to a pool of server nodes. Then, each server node routes the load into the `NGINX Ingress Controllers`. Each **NGINX Ingress Controller** routes the requests into the corresponding application pods.
By default, there is only one **NGINX Ingress Controller**. You can scale the **NGINX Ingress Controller** depending on the traffic of your system.
**Cert Manager** automates the creation and management of TLS/SSL certificates from various issuing sources, including Let's Encrypt, HashiCorp Vault, Venafi, and private public key infrastructure.
You need a domain name to issue and manage free TLS/SSL Let's Encrypt certificates.
### 5.1. Prepare the Application Service
1. (Optional) Delete the Service in the previous section by using the following command:
        $ kubectl delete -f service.yaml
2. Create a `Service` file `service-02.yaml` with the following content. The app selector `whoami` matches the existing deployment, and the target port `8080` matches the container port in the previous step. Notice that this service is not a `LoadBalancer` type, and the name of this service is `whoami-service`.
                - name: http
                  targetPort: 8080
3. Run the command to create the service
        $ kubectl apply -f service-02.yaml
### 5.2. Install NGINX Ingress Controller
1. Install NGINX Ingress Controller (ingress-nginx)
        $ kubectl apply -f https://raw.githubusercontent.com/kubernetes/ingress-nginx/controller-v1.5.1/deploy/static/provider/cloud/deploy.yaml
2. Go to [your Load Balancers dashboard](https://console.vultr.com/loadbalancers/) and get the IP Address of the newly created Load Balancer. This is the Load Balancer created for the NGINX ingress.
3. (Optional) Run the following command to wait for IP of the newly created Load Balancer. The IP is in the `EXTERNAL-IP` column.
        $ kubectl get services ingress-nginx-controller -n ingress-nginx -w
4. Create an A record in your domain DNS that points to the above IP address.
5. (Optional) Scale NGINX Ingress Controller to `03` replicas.
        $ kubectl scale deployment --namespace ingress-nginx ingress-nginx-controller --replicas=3 
### 5.3. Install Cert Manager
This section shows how to set up Cert Manager to use HTTP01 challenge solver to verify the ownership. If you want to use DNS01 challenge solver, see the article [How to Automate DNS/TLS with External DNS and Let's Encrypt on Vultr Kubernetes Engine](https://docs.vultr.com/how-to-automate-dns-tls-with-external-dns-and-let--s-encrypt-on-vultr-kubernetes-engine/)
1. Install cert-manager to manage SSL certificates
        $ kubectl apply -f https://github.com/jetstack/cert-manager/releases/download/v1.10.1/cert-manager.yaml
2. Create a manifest file `letsencrypt.yaml` to handle Let's Encrypt certificates. Replace <YOUR_EMAIL> with your actual email.
        kind: ClusterIssuer
          acme:
            # The ACME server URL
            server: https://acme-staging-v02.api.letsencrypt.org/directory
            preferredChain: "ISRG Root X1"
            # Email address used for ACME registration
            email: <YOUR_EMAIL>
            # Name of a secret used to store the ACME account private key
            privateKeySecretRef:
            solvers:
              - http01:
                  ingress:
                    class: nginx
        kind: ClusterIssuer
          acme:
            server: https://acme-v02.api.letsencrypt.org/directory
            email: <YOUR_EMAIL>
            solvers:
              - http01:
                  ingress:
                    class: nginx
3. Run the command to install the above Let's Encrypt issuers.
        $ kubectl apply -f letsencrypt.yaml
### 5.4. Expose Application with Ingress
1. Create an `Ingress` manifest file `ingress.yaml` with the following content. Replace <YOUR_DOMAIN> with the domain that you have created A record in the above step. Replace `whoami-service` with your service name.
        kind: Ingress
            kubernetes.io/ingress.class: nginx
            cert-manager.io/cluster-issuer: letsencrypt-prod
          tls:
            - secretName: whoami-tls
              hosts:
                - <YOUR_DOMAIN>
            - host: <YOUR_DOMAIN>
              http:
                paths:
                  - path: /
                    pathType: Prefix
                    backend:
                      service:
                        port:
                          number: 80
2. Run the command to create the ingress
        $ kubectl apply -f ingress.yaml
3. Run the command `kubectl get ingress` to see the newly created ingress. The result should look like:
        NAME                      CLASS    HOSTS               ADDRESS        PORTS     AGE
        whoami-ingress   <none>   <YOUR_DOMAIN>      140.82.41.69   80, 443   37s
4. Check the certificates
        $ kubectl get certificates
5. Navigate to `https://<YOUR_DOMAIN>` to access your application.
## 6. Using Sticky Sessions
By default, a load balancer routes each request independently to a pool of servers based on the load-balancing algorithm. However, you can use the sticky session (also known as session affinity) feature to bind a user's session to a specific server.
In a Kubernetes environment, the sticky session feature helps keep the session from the client to a specific application pod. If the application pod is not available, the load balancer re-routes the requests to another application pod.
This section shows how to achieve sticky sessions using the NGINX Ingress Controller from the previous section.
You need to add the following annotations to the Ingress manifest file:
* `nginx.ingress.kubernetes.io/affinity`: enable the Sticky Session. The value has to be cookie".
* `nginx.ingress.kubernetes.io/session-cookie-name`: name of the cookie to track the instance for each request to each application pod.
* `nginx.ingress.kubernetes.io/session-cookie-max-age`: time until the cookie expires in seconds
* `nginx.ingress.kubernetes.io/session-cookie-expires`: a legacy version of the previous annotation for compatibility with old browsers.
1. Change the `ingress.yaml` as follows:
        kind: Ingress
                nginx.ingress.kubernetes.io/affinity: "cookie"
                nginx.ingress.kubernetes.io/session-cookie-name: "sticky"
                nginx.ingress.kubernetes.io/session-cookie-max-age: "172800"
                nginx.ingress.kubernetes.io/session-cookie-expires: "172800"
            tls:
                  hosts:
                      - <YOUR_DOMAIN>
                  http:
                      paths:
                          - path: /
                            pathType: Prefix
                            backend:
                                service:
                                    port:
                                        number: 80
2. Apply the changes using `kubectl`
3. Confirm that the `Ingress` works
        $ kubectl describe ingress whoami-ingress
4. Check if the server responds a `Set-Cookie` header
        $ curl -I https://<YOUR_DOMAIN>
5. The result should look like:
        HTTP/2 200
        date: Tue, 24 May 2022 17:34:58 GMT
        content-type: text/html; charset=utf-8
        content-length: 372
        set-cookie: sticky=1653413699.542.140.602576|38fb12998d06bbfbeaeccec9bf71c761; Expires=Thu, 26-May-22 17:34:58 GMT; Max-Age=172800; Path=/; Secure; HttpOnly
        set-cookie: session=eyJteV9zZXNzaW9uIjoiVDBSQUsifQ.Yo0XQg.qaDgq6kq_P2gMC1vgqLPqN1KQfE; HttpOnly; Path=/
        vary: Cookie
        strict-transport-security: max-age=15724800; includeSubDomains
Notice that the response contains a `set-cookie` header with the `sticky` key. This cookie contains information about the upstream server. The NGINX Ingress Controller tries to route requests with the same cookie to the same application pod.
Refresh the website a few times. Notice that the Hostname doesn't change until the cookie expires, meaning the sticky session works as expected.
## 7. Using Proxy Protocol
Proxy Protocol is a network protocol for preserving a client's connection information (such as IP addresses) when the client's connection passes through a proxy. The ability to preserve the client information is essential to analyze the traffic logs or change the application functionality based on the geographic IP address.
This section shows how to set up a Vultr Load Balancer with Proxy Protocol to distribute traffic to the NGINX Ingress Controller and preserve client information.
Notice that you should set up Cert Manager to use the DNS01 challenge solver to issue TLS/SSL certificates and avoid problems with the HTTP01 challenge.
1. Download the installation manifest of the NGINX Ingress Controller
        $ wget https://raw.githubusercontent.com/kubernetes/ingress-nginx/controller-v1.5.1/deploy/static/provider/cloud/deploy.yaml
2. Open the `deploy.yaml` with your favorite text editor
3. Search for the text `kind: ConfigMap` and replace the content of the `ConfigMap` resource as follows. Replace the text `1.5.1` with your NGINX Ingress Controller version.
        data:
          allow-snippet-annotations: "true"
        kind: ConfigMap
            app.kubernetes.io/component: controller
            app.kubernetes.io/instance: ingress-nginx
            app.kubernetes.io/name: ingress-nginx
            app.kubernetes.io/part-of: ingress-nginx
            app.kubernetes.io/version: 1.5.1
          namespace: ingress-nginx
        data:
          use-proxy-protocol: 'true'
          use-forwarded-headers: 'true'
          compute-full-forwarded-for: 'true'
          ssl-redirect: 'false'
4. Search for the text `type: LoadBalancer` and replace the content of that `Service` as follows. Replace the text `1.5.1` with your NGINX Ingress Controller version.
            service.beta.kubernetes.io/vultr-loadbalancer-proxy-protocol: 'true'
          externalTrafficPolicy: Local
          ipFamilies:
          - IPv4
          ipFamilyPolicy: SingleStack
          - appProtocol: http
            protocol: TCP
            targetPort: 80
          - appProtocol: https
            port: 443
            protocol: TCP
            targetPort: 443
          type: LoadBalancer
5. Apply the changes using `kubectl`
        $ kubectl apply -f deploy.yaml
## More Information
* [Load Balancer Quickstart Guide](https://docs.vultr.com/vultr-load-balancers)
* [VKE Load Balancers](https://github.com/vultr/vultr-cloud-controller-manager/blob/master/docs/load-balancers.md)
* [NGINX Ingress Examples](https://kubernetes.github.io/ingress-nginx/examples/)
