title: How to use ownCloud with Vultr Block Storage and Object Storage
url: https://docs.vultr.com/how-to-use-owncloud-with-vultr-block-storage-and-object-storage
description: Learn how to integrate ownCloud with Vultr Block Storage and Object Storage to enhance your cloud storage capabilities, improve performance, and scale efficiently.
publish_date: 2021-11-02T00:00:00Z
last_updated: 2026-09-11T16:40:42.008372Z
author: Kenn Carlo Gutierrez
header_image: https://docs.vultr.com/public/doc-assets/1077/92f84c57a9624da4.png
**ownCloud** is an open-source file hosting server on the cloud that enables secure storage, collaboration, and sharing. This guide explains how to use ownCloud with **Vultr's Block Storage** and **Object Storage**.
* Deploy a [one-click ownCloud Application](https://console.vultr.com/deploy/?app=owncloud) cloud server instance from Vultr Marketplace Apps
* [Add Block Storage to your account](https://console.vultr.com/blockstorage/add/)
    > **Note:** Your cloud server instance must be in the same server location with your Vultr Block Storage, or you will not be able to attach your block storage to your server instance otherwise.
* [Add Object Storage to your account](https://console.vultr.com/objectstorage/add/)
## Use ownCloud with Vultr Block Storage
Vultr's Cloud Block Storage technology is ideal for ownCloud because of its scalability and high-performance SSDs. You can deploy volumes as large as 10,000GB, which is perfect for file hosting.
### Mounting the Block Storage
1. [Attach your Block Storage to your ownCloud server instance](https://docs.vultr.com/block-storage#Attach_to_a_Server_Instance)
2. SSH to your ownCloud server instance as **root**.
3. List all block storage devices to verify the new device name. The first **block storage** device is connected to your server as `/dev/vdb`.
        # lsblk
4. Create a new disk label using **parted**.
        # parted -s /dev/vdb mklabel gpt
5. Make a primary partition to fill the entire disk.
        # parted -s /dev/vdb unit mib mkpart primary 0% 100%
6. Create an EXT4 filesystem on the primary partition and format it.
        # mkfs.ext4 /dev/vdb1
7. Make a mount point. This is also where your ownCloud files will be stored.
        # mkdir -p //owncloud/data
8. Add a blank line and a mount entry to /etc/fstab. This will automatically mount the block storage at `/owncloud/data` at reboot.
        # echo >> /etc/fstab
        # echo /dev/vdb1 /owncloud/data ext4 defaults,noatime,nofail 0 0 >> /etc/fstab
You can also manually mount the block storage without rebooting.
        # mount /owncloud/data
## Setting up ownCloud
1. On your browser, navigate to your server's IP Address.
2. Log in to your ownCloud file server using the credentials that can be found on [your cloud instance's control panel](https://console.vultr.com/).
3. After you are logged in, go to **Settings** by clicking your **username** on the upper-right corner.
4. On the **Admin** section, click **Storage**.
5. **Enable the external storage** by **clicking the checkbox**.
6. Enter a **Folder name**. This folder is where you save your files, which will then be stored in your **block storage**.
7. Click the **Add Storage** dropdown menu under the **External Storage** column, then select **SFTP**.
8. For the authentication, select **Username and password**.
9. Enter your **server's IP address** on the **Host** text box.
10. Enter `/owncloud/data` on the **Root** text box. Notice that the `/owncloud/data` directory is where you mount your Block Storage.
11. Enter your cloud server instance's **username** and **password** on the **Username** and **Password** text boxes.
12. A **green dot** will appear beside the **Folder name** to confirm that ownCloud is now connected to your mounted block storage via **SFTP** through the **mount point `/owncloud/data`**.
13. Test if everything works fine. Create a test file using **touch** on your SSH terminal.
        # touch /owncloud/data/testfile.txt
14. Check if `testfile.txt` appears in the folder that you have created on your ownCloud file server.
## Use ownCloud with Vultr Object Storage
1. Create a **Bucket** from the **Buckets** tab on your [Object Storage's Control Panel](https://console.vultr.com/objectstorage/).
2. On your browser, navigate to your server's IP Address.
3. Log in to your ownCloud file server using the credentials that can be found on [your cloud server instance's Control Panel](https://console.vultr.com/).
4. Go to ownCloud Market. Click the **triple horizontal bar** icon on the upper-left corner, then select **Market**.
5. From the **Categories** section on the **sidebar menu**, select **Storage**.
6. Look for **External Storage: S3** and **Install** it.
7. After you install **External Storage: S3**, go to **Settings** by clicking your **username** on the upper-right corner.
8. On the **Admin** section, click **Storage**.
9. **Enable the external storage** by **clicking the checkbox**.
10. Enter a **Folder name**. This folder is where you need to save your files, which will then be stored in your **Object Storage Bucket**.
11. Click the **Add Storage** dropdown menu under the **External Storage** column, and select **Amazon S3 Compatible (SDK v3)**.
12. On the **Bucket** text box, enter the **name** of the **Bucket** you created on step 1.
13. On the **Hostname** text box, enter your **Object Storage's Hostname** which can be found on your [Object Storage's Control Panel](https://console.vultr.com/objectstorage)
14. Look for your **Access Key** and **Secret Key** on your [Object Storage's Control Panel](https://console.vultr.com/objectstorage) and copy it, then paste it on the **Access Key** and **Secret Key** text boxes.
15. A **green dot** will appear beside the **Folder name** to confirm that your ownCloud file server is now connected to your Object Storage (Bucket).
16. Test if everything works fine. Go to your ownCloud Files and select the Folder you have created.
17. Upload any file (test file), then check if it appears on your **Bucket** from your [Object storage's control panel](https://console.vultr.com/objectstorage).
## More Information
For more information about **ownCloud**, **Vultr Block Storage**, and **Vultr Object Storage**, please see these resources:
* [Vultr Block Storage Documentation](https://docs.vultr.com/block-storage)
* [Vultr Object Storage Documentation](https://docs.vultr.com/vultr-object-storage)
* [Vultr One-click ownCloud Documentation](https://docs.vultr.com/one-click-owncloud/)
* [ownCloud Documentation](https://doc.owncloud.com/)
