Vultr DocsLatest Content
How to Use Vultr Managed Databases for Valkey in Python
Updated on 06 January, 2025
Guide
Learn to use Vultr Managed Databases for Valkey in Python, ensuring high availability and performance for your applications.
Valkey is an in-memory data store that offers a flexible data structure, high performance, and on-demand scalability. A Vultr Managed Database for Valkey offers high availability, high throughput, and low latency for mission-critical applications. This guide explains how to use a Vultr Managed Database for Valkey in Python to create highly available applications.
Set Up the Python Development Environment
To integrate a Vultr Managed Database for Valkey to your Python application, install the Python redis module and set up a sample project directory to store the application files.
  1. Upgrade the Python pip package manager.
     $ pip install --upgrade pip
  2. Install the Python redis driver to connect to the Valkey database.
     $ pip install redis
  3. Create a new project directory.
     $ mkdir project
  4. Navigate to the new project directory.
     $ cd project
Create the Redis® Gateway Class
To use your Vultr Managed Database for Valkey connection in your Python application files, create a central Python module that connects to the database. You can then reuse the module by declaring the database module using the import clause in your application. Follow the steps below to create the Valkey connection module
  1. Using a text editor such as Vim, create a new redis_gateway.py file
     $ nano redis_gateway.py
  2. Add the following code to the file. Replace the vultr-prod-abcd.vultrdb.com, 16752, and example-password values with your correct Vultr Managed Database for Valkey details
     import redis
     class RedisGateway:
         def __init__(self):
             r_host = 'vultr-prod-abcd.vultrdb.com'
             r_port = 16752
             r_pass = 'example-password'
             self.r_client = redis.Redis(
                 host     = r_host,
                 port     = r_port,
                 password = r_pass,
                 ssl      = 'true'
    Save and close the file
    The above Python application code declares a RedisGateway class with an __init__(self) method. This method executes every time you create an instance of the RedisGateway class. Then, it connects to the Valkey database using the self.r_client = redis.Redis(...) function.
    To import the Valkey database module to other Python source code files, use the following declarations:
     import redis_gateway
     r_gateway = redis_gateway.RedisGateway()
     r_client  = r_gateway.r_client
Implement Valkey Strings
In Valkey, a string is a sequence of bytes and it's the most used data type. You can use the string data type to store session IDs, user passwords, product information, and static HTML content. To create a key in a Valkey server, use the set keyword. To retrieve a key value, use the get keyword. In this section, create a Python application to implement Valkey strings as described below.
  1. Create a new redis_strings.py file
     $ nano redis_strings.py
  2. Add the following contents to the file
     r_key   = "john_doe"
     r_value = "example-password"
     r_client.set(r_key, r_value)
     print("...\r\n You've successfully set the Redis key.\r\n")
     if r_client.exists(r_key):
         r_value = r_client.get(r_key).decode("utf-8")
         print("The value for the " + r_key + " key is " + r_value + "\r\n ...")
    The above application file imports the redis_gateway module you created earlier, then:
    • r_key: Defines the name of the string key you're setting in the Valkey database
    • r_value: Defines the Valkey key value
    • r_client.set(r_key, r_value): Sets the key in the Valkey database
    • if r_client.exists(r_key): Verifies whether the key exists in the Valkey database server before retrieving it to avoid run time errors
    • r_client.get(r_key).decode("utf-8"): Retrieves the key from the Valkey database
  3. Run the Valkey strings application file
     $ python3 redis_strings.py
     The value for the john_doe key is example-password
    As displayed in the above output, Python correctly connects to the Valkey database and sets the value example-password for the string key john_doe.
Implement Valkey Lists
A Valkey list is an ordered collection of strings used to implement queueing mechanisms. Valkey allows you to add elements to the head or tail of a list using the lpush and rpush commands. Create a new Python application to test the Valkey Lists functionality as described below.
  1. Create a new redis_lists.py file
     $ nano redis_lists.py
     import json
     r_list   = "sample_customer_job_list"
     sample_job_1 = {
         "firstName": "JOHN",
         "lastName": "DOE",
         "email": "john_doe@example.com"
     sample_job_2 = {
         "firstName": "MARY",
         "lastName": "SMITH",
         "email": "mary_smith@example.com"
     r_list_value_1  = json.dumps(sample_job_1)
     r_list_value_2  = json.dumps(sample_job_2)
     r_client.lpush(r_list, r_list_value_1, r_list_value_2)
     print("...\r\n You've successfully added a customer registration jobs to the Redis list.\r\n...")
     while(r_client.llen(r_list) != 0):
         print("The values for the " + r_list + "\r\n...")
         print(r_client.lpop(r_list).decode("utf-8") + "\r\n...")
    Below is what the above application code does:
    • The r_list variable represents the key of your sample Valkey list.
    • sample_job_1 = {...} and sample_job_1 = {...} are sample list values.
    • The r_client.lpush(r_list, r_list_value_1, r_list_value_2) function inserts the two sample jobs into the Valkey list
    • The while(r_client.llen(r_list) != 0): loop queries the Valkey server and iterates through the r_list variable to print the list values
  3. Run the redis_lists.py application file
     $ python3 redis_lists.py
     The values for the sample_customer_job_list
     {"firstName": "MARY", "lastName": "SMITH", "email": "mary_smith@example.com"}
     {"firstName": "JOHN", "lastName": "DOE", "email": "john_doe@example.com"}
Implement Valkey Hashes
Valkey hashes are record types that map keys to value pairs. Implement Valkey hashes in the form of company data in a Python application as described below.
  1. Create a new redis_hash.py file
     $ nano redis_hash.py
     import json
     r_hash = "company_profile"
     r_client.hset(r_hash, "company_name", "XYZ COMPANY")
     r_client.hset(r_hash, "add_line_1", "123 SAMPLE STREET")
     r_client.hset(r_hash, "add_line_2", "APT BUILDING")
     r_client.hset(r_hash, "county", "3RD COUNTY")
     r_client.hset(r_hash, "city", "SUN CITY")
     r_client.hset(r_hash, "zip", "123456")
     print("...\r\nYou've successfully set a company profile.\r\n...")
     print("Company profile information \r\n" )
     print(json.dumps(str(r_client.hgetall(r_hash))))
     print("Company Name : " + r_client.hget(r_hash, "company_name").decode("utf-8"))
    In the above application:
    • The r_hash variable represents the hash key in the Valkey database.
    • The r_client.hset(r_hash, "company_name", "XYZ COMPANY") function sets a hash in the Redis server. This function is the same as:
        company_profile['company_name'] =  "XYZ COMPANY"
    • r_client.hgetall(r_hash): Retrieves all key-value pairs for a given hash
    • r_client.hget(r_hash, "company_name"): Retrieves the value of a given key in the hash
  3. Run the application
     $ python3 redis_hash.py
     "{b'company_name': b'XYZ COMPANY', b'add_line_1': b'123 SAMPLE STREET', b'add_line_2': b'APT BUILDING', b'county': b'3RD COUNTY', b'city': b'SUN CITY', b'zip': b'123456'}"
     Company Name : XYZ COMPANY
Implement Valkey Sorted Sets
Sorted sets represent a collection of strings arranged by an associated score. An element can only appear once in a sorted set. Valkey offers the zadd and zrange functions for adding and retrieving sorted sets values. Implement these functions in a Python application as described below.
  1. Create a new redis_sorted_set.py file
     $ nano redis_sorted_set.py
     import json
     r_sorted_set = "database_ratings"
     database_scores = {
         'MySQL': 1,
         'PostgreSQl': 2,
         'SQLite': 3,
         'MongoDB': 4
     r_client.zadd(r_sorted_set, database_scores)
     print("...\r\nYou've successfully entered four database ratings.\r\n...")
     print("Database rating information: \r\n")
     print(r_client.zrange(r_sorted_set, 0, 3))
    • r_sorted_set: Declares a key for the sorted set
    • database_scores = {...}: Contains four elements with a matching score
    • r_client.zadd(r_sorted_set, database_scores): Adds the set elements to the Valkey server
    • r_client.zrange(r_sorted_set, 0, 3): Returns all sorted set values from the database
     $ python3 redis_sorted_set.py
     [b'MySQL', b'PostgreSQl', b'SQLite', b'MongoDB']
In this guide, you have implemented different data types using a Vultr Managed Database for Valkey with Python. Based on your application use case, implement the relevant Valkey data type to cache and store data in your database.
