title: How to Use Vultr Managed Databases for PostgreSQL with Node.js
url: https://docs.vultr.com/how-to-use-vultr-managed-databases-for-postgresql-with-node-js
description: Learn how to set up and connect a Vultr Managed PostgreSQL database with your Node.js application for improved performance, security, and scalability.
publish_date: 2022-12-13T00:00:00Z
last_updated: 2025-04-01T00:00:00Z
author: Francis Ndungu
header_image: https://docs.vultr.com/public/doc-assets/1476/dae6e2d1652ab0ff.png
Vultr provides production-ready PostgreSQL database clusters that you can use with Node.js to create mission-critical applications. Managed databases automate the most challenging aspects of database administration, allowing you to focus on your app.
This guide shows you how to use the Node.js `pg` library on Ubuntu 20.04 server to pass queries to a managed PostgreSQL database cluster. The library supports all functions for creating data-driven applications like parameterized queries.
To test the guide:
* [Provision an Ubuntu 20.04 server](https://www.vultr.com/servers/ubuntu/).
* [Create a non-root `sudo` user](https://docs.vultr.com/create-a-sudo-user-on-ubuntu-best-practices/).
* [Install Node.js using **Option 2:** (Install via PPA Version)](https://docs.vultr.com/installing-node-js-and-express-on-ubuntu-20-04/).
    > You should skip step 2, "Install Express.js," because this tutorial doesn't require Express.js dependency.
* [Deploy a managed PostgreSQL database cluster](https://www.vultr.com/products/managed-databases/).
* Navigate to the PostgreSQL database cluster **Connection Details** under the **Overview** tab. This guide uses the following sample connection details:
    * **username**: `vultradmin`
    * **password**: `EXAMPLE_POSTGRESQL_PASSWORD`
    * **host**: `SAMPLE_POSTGRESQL_DB_HOST_STRING.vultrdb.com`
    * **port**: `16751`
## 1. Set Up a Sample Database
Every data-driven application requires a database to store data permanently. You need to set up a sample database and a table. In a production environment, you may require more than one table based on the complexity of your application. Follow the steps below to initialize the database:
1. Begin by updating your server's package information index.
1. Install the `postgresql-client` package. This is a lightweight client package for interacting with a managed PostgreSQL cluster without installing a complete PostgreSQL package on your server.
        $ sudo apt install -y postgresql-client
1. Run the command below to log in to your managed PostgreSQL cluster. Replace `SAMPLE_POSTGRESQL_DB_HOST_STRING.vultrdb.com` with the correct host for the PostgreSQL database cluster.
        $ psql -h SAMPLE_POSTGRESQL_DB_HOST_STRING.vultrdb.com -p 16751 -U vultradmin defaultdb
        Password for user vultradmin:
1. Enter your PostgreSQL cluster database password and press :key_enter: to proceed. Then, ensure you get the following output.
        defaultdb=>
1. Issue the command below to create a sample `company_db` database.
        defaultdb=> CREATE DATABASE company_db;
        CREATE DATABASE
1. Connect to the new `company_db` database.
        defaultdb=> \c company_db;
        You are now connected to database "company_db" as user "vultradmin".
1. Create a `customers` table. This table stores customers' information. Later, this guide shows you how to execute `INSERT`, `UPDATE`, `DELETE`, and `SELECT` commands from Node.js code to interact with the `customers` table.
        company_db=> CREATE TABLE customers (
                         customer_id SERIAL PRIMARY KEY,
                         first_name VARCHAR(50),
                         last_name VARCHAR(50)
        CREATE TABLE
1. Insert sample data into the `customers` table to ensure you've got the correct schema.
        company_db=> INSERT INTO customers (first_name, last_name) VALUES ('JOHN', 'DOE');
                     INSERT INTO customers (first_name, last_name) VALUES ('MARY', 'SMITH');
                     INSERT INTO customers (first_name, last_name) VALUES ('PETER', 'JONES');
        INSERT 0 1
1. Query the `customers` to verify the data.
        company_db=> SELECT
                         customer_id,
                         first_name,
                         last_name
                     FROM customers;
         customer_id | first_name | last_name
                   1 | JOHN       | DOE
                   2 | MARY       | SMITH
                   3 | PETER      | JONES
        (3 rows)
1. Log out from the managed PostgreSQL database cluster.
        company_db=> \q
After setting up the database and sample table, proceed to the next step to create a central Node.js database module for interacting with your managed PostgreSQL database cluster.
## 2. Create a Database Gateway Module
Node.js allows you to package your application into different modules to organize complex functionalities that you can reuse in multiple locations throughout your source code. When designing Node.js applications that interact with databases, it's conventional to create a central database module. Later, you can include this module in every file that requires access to the database. Follow the steps below to create a database gateway module:
1. Create a new `project` directory for your application to separate your source code from system files.
        $ mkdir project
1. Switch to the new `project` directory.
        $ cd project
1. Open a new `postgresql_gateway.js` file on a text editor.
        $ nano postgresql_gateway.js
1. Enter the following information into the `postgresql_gateway.js` file. Replace `SAMPLE_POSTGRESQL_DB_HOST_STRING.vultrdb.com` and `EXAMPLE_POSTGRESQL_PASSWORD` with the correct PostgreSQL database cluster hostname and password.
        class postgresql_gateway {
            connectDb() {
                const { Client } = require('pg');
                const client = new Client({
                    user: "vultradmin",
                    database: "company_db",
                    password: "EXAMPLE_POSTGRESQL_PASSWORD",
                    port: 16751,
                    host: "SAMPLE_POSTGRESQL_DB_HOST_STRING.vultrdb.com",
                    ssl: { rejectUnauthorized: false }
                client.connect();
                return client;
            execute_query(callBack, queryString, paramValues) {
               var db_client = this.connectDb();
               db_client.query(queryString, paramValues, (err, res) => {
                   if (err) {
                       callBack(err, null);
                       callBack(null, res.rows);
                   db_client.end();
            save_data(jsonData, callBack) {
               var paramValues = [];
               paramValues.push(jsonData.first_name);
               paramValues.push(jsonData.last_name);
               var queryString = "insert into customers (first_name, last_name) values ($1, $2) RETURNING customer_id, first_name, last_name";
               this.execute_query(callBack, queryString, paramValues);
            update_data(jsonData, callBack) {
               paramValues.push(jsonData.customer_id);
               var queryString = "update customers set first_name = $1, last_name = $2 where customer_id = $3 RETURNING customer_id, first_name, last_name";
            delete_data(jsonData, callBack) {
               var queryString = "delete from customers where customer_id = $1 RETURNING customer_id, first_name, last_name";
            query_data(customerId, callBack) {
               var queryString = "select * from customers";
               if (customerId != "") {
                  queryString += " where customer_id = $1";
                  paramValues.push(customerId);
        module.exports = postgresql_gateway;
1. Save and close the `postgresql_gateway.js` file.
### The `postgresql_gateway.js` file explained:
The `postgresql_gateway.js` file contains one class module (`postgresql_gateway`) with six different methods.
        connectDb() {
The six methods in the `postgresql_gateway` class module perform the following functions:
1. `connectDb()`: This method uses the managed PostgreSQL database cluster's credentials to connect to the database and return a reusable client connection using the `return client;` statement.
1. `execute_query(callBack, queryString, paramValues)`: This method uses the `var db_client = this.connectDb();` statement to connect to the PostgreSQL database. Then, the method calls the `db_client.query(queryString, paramValues, ...)` function to execute different database queries.
1. `save_data(jsonData, callBack)`: This method accepts a JSON payload (`first_name` and `last_name`) containing the customer's details and then calls the `execute_query(...)` method to save data to the database using an `INSERT` command.
1. `update_data(jsonData, callBack)`: This method accepts a JSON payload containing a `customer_id` and queries the database to find a match. Then, the `update_data(...)` method calls the `execute_query(...)` method to update the `first_name` and `last_name` fields of the record matching the `customer_id`.
1. `delete_data(jsonData, callBack)`: This method accepts a JSON payload containing the `customer_id` of the record you want to delete. The `delete_data(...)` method then calls the `this.execute_query(...)` method to send a `DELETE` command to the PostgreSQL database.
1. `query_data(customerId, callBack)`: This method uses the `select * from customers` statement to fetch records from the PostgreSQL `customers` table. If you request a single record, the `query_data()` method uses the following declaration to append a filter parameter to the query.
The `RETURNING customer_id, first_name, last_name` statement at the end of the SQL statements allows you to retrieve the field values for the affected rows.
The `module.exports = postgresql_gateway;` statement at the end of the `postgresql_gateway.js` file allows you to import and use the `postgresql_gateway` module in other Node.js files using the following declarations.
    const postgresql_gateway    = require('./postgresql_gateway.js');
    var dg = new postgresql_gateway();
    dg.save_data(JSON.parse(json_payload), callBack);
    dg.update_data(JSON.parse(json_payload), callBack);
    dg.delete_data(JSON.parse(json_payload), callBack);
    dg.query_data(customerId, callBack);
The `postgresql_gateway` module is now ready. Follow the next step to create the application's entry point.
## 3. Create the Application's Entry Point
Every Node.js application requires an entry point. This is a file that runs when you start the application. This guide uses the `main.js` file to execute the application. Follow the steps below to create the file:
1. Open a new `main.js` on a text editor.
        $ nano main.js
1. Enter the following information into the `main.js` file.
        const http = require('http');
        const hostname = 'localhost';
        const port = 8080;
        const server = http.createServer(httpHandler);
        server.listen(port, hostname, () => {
            console.log(`Server running at http://${hostname}:${port}/`);
        function httpHandler(req, res) {
            var json_payload = "";
            req.on('data', function (data) {
                json_payload += data;
            req.on('end', function () {
                function callBack(err, result) {
                   var response = {};
                    if (err) {
                        response.error = err.message;
                        response.data = result;
                    res.write(JSON.stringify(response, null, 4));
                    res.end();
                switch (req.method) {
                    case "POST":
                        break;
                    case "PUT":
                        break;
                    case "DELETE":
                        break;
                    case "GET":
                       const url = require('url');
                       const queryparams = url.parse(req.url, true).query;
                       var customerId = "";
                       if (queryparams.customer_id) {
                           customerId = queryparams.customer_id
                       break;
1. Save and close the `main.js` file.
### The `main.js` file explained:
The two lines at the beginning of the `main.js` file load the `http` server module and the custom `postgresql_gateway` database gateway module.
The `http` server module creates a `local` web server that listens for incoming connections on port `8080`. The `const server = http.createServer(httpHandler);` delegates incoming HTTP to the custom `httpHandler(){...}` function. The `server.listen(port, hostname, ..);` statement tells the web server to listen for incoming requests on the defined port and host.
    const port = 8080;
The `httpHandler(req, res) {..}` function runs most of the application's logic.
Under the `httpHandler()` function, you're creating a new database gateway object using the `var dg = new postgresql_gateway();` statement.
The following declarations allow you to capture the JSON payload from HTTP clients' requests when creating new customers, updating customer details, and deleting customers from the database.
Under the `req.on(...){...}` function, you're defining a `callBack(err, result)` function that fires every time you make an HTTP request to the server. Then, you're using the Node.js `switch (req.method) {...}` statement to evaluate the HTTP method and route HTTP requests to the appropriate database functions.
           res.end();
The following list shows your application's HTTP request methods and the matching database functions that run the requests.
* `POST`: Runs the `dg.save_data(JSON.parse(json_payload), callBack);` method.
* `PUT`: Runs the `dg.update_data(JSON.parse(json_payload), callBack);` method.
* `DELETE`: Runs the `dg.delete_data(JSON.parse(json_payload), callBack);` method.
* `GET`: Runs the `dg.query_data(customerId, callBack);` method.
After setting up all the required Node.js source code files, proceed to the next step to test your application.
## 4. Test the Node.js and PostgreSQL Application
The final step in this guide is using the Node.js `npm` module to initialize and set up your project's attribute. Then, use the `npm` module to install the `pg` module and run some tests using the Linux `curl` command. Follow the steps below:
1. Ensure the `npm` package is up to date.
        $ sudo npm install npm -g
        removed 14 packages, changed 73 packages, and audited 223 packages in 7s
1. Use the `npm` package to initialize your project.
        $ npm init
1. Enter the following responses when you receive the prompts followed by :key_enter::
        package name: (project) : :key_enter:
        version: (1.0.0) : :key_enter:
        description: Node.js and PostgreSQL application :key_enter:
        entry point: (main.js) :key_enter:
        test command: :key_enter:
        git repository: :key_enter:
        keywords: node.js, postgresql :key_enter:
        author: test author :key_enter:
        license: (ISC) :key_enter:
        About to write to /home/francis/project/package.json: {...}
        Is this OK? (yes) yes :key_enter:
1. Use the `npm` package to install the PostgreSQL `pg` module for Node.js.
        $ npm install pg
        added 15 packages, and audited 16 packages in 2s
1. Use the `node` command to run the application. Remember, the `main.js` file is the application's entry point.
        $ node main.js
        Server running at http://localhost:8080/
1. Do not run any other command in your active `SSH` terminal window because the previous command has a blocking function.
1. Establish another `SSH` session on your server and run the following Linux `curl` commands to send HTTP requests to the application.
    * Retrieve all customers using the HTTP `GET` command:
            $ curl -X GET http://127.0.0.1:8080
                "data": [
                        "customer_id": 1,
                        "first_name": "JOHN",
                        "last_name": "DOE"
                        "customer_id": 2,
                        "first_name": "MARY",
                        "last_name": "SMITH"
                        "customer_id": 3,
                        "first_name": "PETER",
                        "last_name": "JONES"
    * Retrieve a specific customer by appending the `customer_id` in the URL.
            $ curl -X GET http://127.0.0.1:8080?customer_id=2
                "data": [
                        "customer_id": 2,
    * Create a new customer using the HTTP `POST` command and a JSON payload containing the customer's details.
            $ curl -X POST http://127.0.0.1:8080/ -H 'Content-Type: application/json' -d '{"first_name" : "HENRY", "last_name" : "ALLAN"}'
                "data": [
                        "customer_id": 4,
                        "first_name": "HENRY",
                        "last_name": "ALLAN"
    * Update an existing customer using the HTTP `PUT` method. For this command, you must define the `customer_id` of the record you want to update and the new values for the `first_name` and `last_name` fields.
            $ curl -X PUT http://127.0.0.1:8080/ -H 'Content-Type: application/json' -d '{"customer_id" : 4, "first_name" : "FRED", "last_name" : "ALEX"}'
                "data": [
                        "customer_id": 4,
                        "first_name": "FRED",
                        "last_name": "ALEX"
    * Delete a customer using the HTTP `DELETE` command. Include the `customer_id` of the record you want to delete in a JSON payload.
            $ curl -X DELETE http://127.0.0.1:8080/ -H 'Content-Type: application/json' -d '{"customer_id" : 4}'
                "data": [
                        "customer_id": 4,
                        "last_name": "ALEX"
The application is working as expected, and you can run the `SELECT`, `INSERT`, `UPDATE`, and `DELETE` operations without any problems.
This guide shows you how to implement the Node.js `pg` module to interact with a managed PostgreSQL database on Ubuntu 20.04 server. Although this guide demonstrated the PostgreSQL idea using a single table, you may create additional tables depending on your application's logic. The managed PostgreSQL database cluster allows you to implement a cloud database application without any complicated installations and configuration procedures.
Check out the links below for more information on using Vultr's managed databases:
* How to use Vultr Managed Databases for MySQL with WordPress on Ubuntu 20.04.
* [Authenticate a Python Application with Vultr Managed Databases for PostgreSQL and Redis®](https://docs.vultr.com/authenticate-a-python-application-with-vultr-managed-databases-for-postgresql-and-redis/).
* [Implement a Shopping Cart in Python with Vultr Managed Databases for Caching](https://docs.vultr.com/implement-a-shopping-cart-in-python-with-vultr-managed-databases-for-caching).
