title: How to Use Vultr Managed Databases for Valkey in Python
url: https://docs.vultr.com/how-to-use-vultr-managed-databases-for-valkey-in-python
description: Learn how to connect to Vultr Managed Databases for Valkey using Python. This step-by-step guide covers setup, configuration, and basic operations for developers.
publish_date: 2023-10-16T00:00:00Z
last_updated: 2025-01-06T21:16:05.503648Z
author: Francis Ndungu
Valkey is an in-memory data store that offers a flexible data structure, high performance, and on-demand scalability. A Vultr Managed Database for Valkey offers high availability, high throughput, and low latency for mission-critical applications. This guide explains how to use a Vultr Managed Database for Valkey in Python to create highly available applications.
* Deploy a [Vultr Managed Database for Valkey](https://www.vultr.com/products/managed-databases/)
* Deploy a [Vultr Linux server](https://www.vultr.com/servers/) to use as the development machine
* Use [SSH](https://docs.vultr.com/how-to-use-ssh-with-vultr-servers/) to access the server as a non-root user
## Set Up the Python Development Environment
To integrate a Vultr Managed Database for Valkey to your Python application, install the Python `redis` module and set up a sample project directory to store the application files.
1. Upgrade the Python `pip` package manager.
        $ pip install --upgrade pip
1. Install the Python `redis` driver to connect to the Valkey database.
        $ pip install redis
1. Create a new `project` directory.
        $ mkdir project
1. Navigate to the new `project` directory.
        $ cd project
## Create the Redis® Gateway Class
To use your Vultr Managed Database for Valkey connection in your Python application files, create a central Python module that connects to the database. You can then reuse the module by declaring the database module using the `import` clause in your application. Follow the steps below to create the Valkey connection module
1. Using a text editor such as Vim, create a new `redis_gateway.py` file
        $ nano redis_gateway.py
1. Add the following code to the file. Replace the `vultr-prod-abcd.vultrdb.com`, `16752`, and `example-password` values with your correct Vultr Managed Database for Valkey details
        import redis
        class RedisGateway:
            def __init__(self):
                r_host = 'vultr-prod-abcd.vultrdb.com'
                r_port = 16752
                r_pass = 'example-password'
                self.r_client = redis.Redis(
                    host     = r_host,
                    port     = r_port,
                    password = r_pass,
                    ssl      = 'true'
    Save and close the file
    The above Python application code declares a `RedisGateway` class with an `__init__(self)` method. This method executes every time you create an instance of the `RedisGateway` class. Then, it connects to the Valkey database using the `self.r_client = redis.Redis(...)` function.
    To import the Valkey database module to other Python source code files, use the following declarations:
        import redis_gateway
        r_gateway = redis_gateway.RedisGateway()
        r_client  = r_gateway.r_client
## Implement Valkey Strings
In Valkey, a string is a sequence of bytes and it's the most used data type. You can use the string data type to store session IDs, user passwords, product information, and static HTML content. To create a key in a Valkey server, use the `set` keyword. To retrieve a key value, use the `get` keyword. In this section, create a Python application to implement Valkey strings as described below.
1. Create a new `redis_strings.py` file
        $ nano redis_strings.py
2. Add the following contents to the file
        r_key   = "john_doe"
        r_value = "example-password"
        r_client.set(r_key, r_value)
        print("...\r\n You've successfully set the Redis key.\r\n")
        if r_client.exists(r_key):
            r_value = r_client.get(r_key).decode("utf-8")
            print("The value for the " + r_key + " key is " + r_value + "\r\n ...")
    The above application file imports the `redis_gateway` module you created earlier, then:
    * `r_key`: Defines the name of the string key you're setting in the Valkey database
    * `r_value`: Defines the Valkey key value
    * `r_client.set(r_key, r_value)`: Sets the key in the Valkey database
    * `if r_client.exists(r_key)`: Verifies whether the key exists in the Valkey database server before retrieving it to avoid run time errors
    * `r_client.get(r_key).decode("utf-8")`: Retrieves the key from the Valkey database
3. Run the Valkey strings application file
        $ python3 redis_strings.py
        The value for the john_doe key is example-password
    As displayed in the above output, Python correctly connects to the Valkey database and sets the value `example-password` for the string key `john_doe`.
## Implement Valkey Lists
A Valkey list is an ordered collection of strings used to implement queueing mechanisms. Valkey allows you to add elements to the head or tail of a list using the `lpush` and `rpush` commands. Create a new Python application to test the Valkey Lists functionality as described below.
1. Create a new `redis_lists.py` file
        $ nano redis_lists.py
        import json
        r_list   = "sample_customer_job_list"
        sample_job_1 = {
            "firstName": "JOHN",
            "lastName": "DOE",
            "email": "john_doe@example.com"
        sample_job_2 = {
            "firstName": "MARY",
            "lastName": "SMITH",
            "email": "mary_smith@example.com"
        r_list_value_1  = json.dumps(sample_job_1)
        r_list_value_2  = json.dumps(sample_job_2)
        r_client.lpush(r_list, r_list_value_1, r_list_value_2)
        print("...\r\n You've successfully added a customer registration jobs to the Redis list.\r\n...")
        while(r_client.llen(r_list) != 0):
            print("The values for the " + r_list + "\r\n...")
            print(r_client.lpop(r_list).decode("utf-8") + "\r\n...")
    Below is what the above application code does:
    * The `r_list` variable represents the key of your sample Valkey list.
    * `sample_job_1 = {...}` and `sample_job_1 = {...}` are sample list values.
    * The `r_client.lpush(r_list, r_list_value_1, r_list_value_2)` function inserts the two sample jobs into the Valkey list
    * The `while(r_client.llen(r_list) != 0):` loop queries the Valkey server and iterates through the `r_list` variable to print the list values
3. Run the `redis_lists.py` application file
        $ python3 redis_lists.py
        The values for the sample_customer_job_list
        {"firstName": "MARY", "lastName": "SMITH", "email": "mary_smith@example.com"}
        {"firstName": "JOHN", "lastName": "DOE", "email": "john_doe@example.com"}
## Implement Valkey Hashes
Valkey hashes are record types that map keys to value pairs. Implement Valkey hashes in the form of company data in a Python application as described below.
1. Create a new `redis_hash.py` file
        $ nano redis_hash.py
        import json
        r_hash = "company_profile"
        r_client.hset(r_hash, "company_name", "XYZ COMPANY")
        r_client.hset(r_hash, "add_line_1", "123 SAMPLE STREET")
        r_client.hset(r_hash, "add_line_2", "APT BUILDING")
        r_client.hset(r_hash, "county", "3RD COUNTY")
        r_client.hset(r_hash, "city", "SUN CITY")
        r_client.hset(r_hash, "zip", "123456")
        print("...\r\nYou've successfully set a company profile.\r\n...")
        print("Company profile information \r\n" )
        print(json.dumps(str(r_client.hgetall(r_hash))))
        print("Company Name : " + r_client.hget(r_hash, "company_name").decode("utf-8"))
    In the above application:
    * The `r_hash` variable represents the hash key in the Valkey database.
    * The `r_client.hset(r_hash, "company_name", "XYZ COMPANY")` function sets a hash in the Redis server. This function is the same as:
            company_profile['company_name'] =  "XYZ COMPANY"
    * `r_client.hgetall(r_hash)`: Retrieves all key-value pairs for a given hash
    * `r_client.hget(r_hash, "company_name")`: Retrieves the value of a given key in the hash
3. Run the application
        $ python3 redis_hash.py
        "{b'company_name': b'XYZ COMPANY', b'add_line_1': b'123 SAMPLE STREET', b'add_line_2': b'APT BUILDING', b'county': b'3RD COUNTY', b'city': b'SUN CITY', b'zip': b'123456'}"
        Company Name : XYZ COMPANY
## Implement Valkey Sorted Sets
Sorted sets represent a collection of strings arranged by an associated score. An element can only appear once in a sorted set. Valkey offers the `zadd` and `zrange` functions for adding and retrieving sorted sets values. Implement these functions in a Python application as described below.
1. Create a new `redis_sorted_set.py` file
        $ nano redis_sorted_set.py
        import json
        r_sorted_set = "database_ratings"
        database_scores = {
            'MySQL': 1,
            'PostgreSQl': 2,
            'SQLite': 3,
            'MongoDB': 4
        r_client.zadd(r_sorted_set, database_scores)
        print("...\r\nYou've successfully entered four database ratings.\r\n...")
        print("Database rating information: \r\n")
        print(r_client.zrange(r_sorted_set, 0, 3))
    * `r_sorted_set`: Declares a key for the sorted set
    * `database_scores = {...}`: Contains four elements with a matching score
    * `r_client.zadd(r_sorted_set, database_scores)`: Adds the set elements to the Valkey server
    * `r_client.zrange(r_sorted_set, 0, 3)`: Returns all sorted set values from the database
        $ python3 redis_sorted_set.py
        [b'MySQL', b'PostgreSQl', b'SQLite', b'MongoDB']
In this guide, you have implemented different data types using a Vultr Managed Database for Valkey with Python. Based on your application use case, implement the relevant Valkey data type to cache and store data in your database.
