title: Implement a CI/CD Pipeline with Jenkins and Vultr Kubernetes Engine
url: https://docs.vultr.com/implement-a-ci-cd-pipeline-with-jenkins-and-vultr-kubernetes-engine
description: Learn how to set up a continuous integration and deployment pipeline using Jenkins and Vultr Kubernetes Engine to automate your application deployment workflow.
publish_date: 2024-01-12T15:47:32.161731Z
last_updated: 2024-07-25T21:07:54.218344Z
author: Hitesh Jethva
header_image: https://docs.vultr.com/public/doc-assets/1733/7f864f199704c9e3.png
Rapid and reliable delivery of applications is an important aspect of software development that ensures the timely execution of solutions in production environments. Jenkins is a popular open-source automation service that enables Continuous Integration (CI) and Continuous Deployment (CD) in software development. It plays a crucial role in automating the application building, testing, and deployment processes to streamline the software development lifecycle.
Implementing a CI/CD pipeline with Jenkins and Kubernetes offers many software development and delivery advantages. These include streamlining development processes, enhancing collaboration, and speed up the delivery of high-quality applications. In this guide, you will deploy a Node.js containerized application to a Vultr Kubernetes Engine (VKE) cluster using the Jenkins CI/CD Pipeline.
Before you start, you need to:
* [Deploy a Vultr Kubernetes Engine (VKE) cluster](https://www.vultr.com/docs/vultr-kubernetes-engine/#How_to_Deploy_a_VKE_Cluster) with at least `3` nodes.
* [Create a Vultr Container Registry](https://www.vultr.com/docs/vultr-container-registry/) to store Docker images.
* Deploy a One-Click Docker instance with at least `4` GB RAM and `2` vCPUs to use as the management server.
* Access the server using SSH as a [non-root user with sudo privileges](https://www.vultr.com/docs/create-a-sudo-user-on-ubuntu-best-practices/).
* Install and Configure [Kubectl to access the VKE cluster](https://www.vultr.com/docs/beginners-guide-to-kubernetes-using-kubectl/).
* Log in to your GitHub account and [generate a personal access token](https://github.com/settings/tokens) to access your repositories using Git.
> To avoid deployment time errors in your cluster due to container registry, generate a Kubernetes `Secret` resource from the registry control panel and deploy it to your cluster.
## Install Jenkins
1. Install the Java OpenJDK 11 dependecy package.
    $ sudo apt install openjdk-11-jdk -y
1. Download the Jenkins repository key to your server.
    $ curl -fsSL https://pkg.jenkins.io/debian-stable/jenkins.io-2023.key | sudo tee /usr/share/keyrings/jenkins-keyring.asc > /dev/null
1. Add Jenkins repository to APT repository sources.
    $ echo deb [signed-by=/usr/share/keyrings/jenkins-keyring.asc] https://pkg.jenkins.io/debian-stable binary/ | sudo tee /etc/apt/sources.list.d/jenkins.list > /dev/null
1. Update the server repository index.
    $ sudo apt update -y
1. Install Jenkins on the server.
    $ sudo apt install jenkins -y
1. View the Jenkins status to verify that it's successfully installed and running.
    $ sudo systemctl status jenkins
    ● jenkins.service - Jenkins Continuous Integration Server
         Loaded: loaded (/lib/systemd/system/jenkins.service; enabled; vendor preset: enabled)
         Active: active (running) since Wed 2023-11-15 06:23:57 UTC; 5min ago
       Main PID: 5491 (java)
          Tasks: 36 (limit: 1006)
         Memory: 313.3M
            CPU: 1min 12.574s
         CGroup: /system.slice/jenkins.service
                 └─5491 /usr/bin/java -Djava.awt.headless=true -jar /usr/share/java/jenkins.war --webroot=/var/cache/jenkins/war --httpPort=8080
    Nov 15 06:22:50 ubuntu jenkins[5491]: ff1f768ed659416695b3decdff0e9473
    Nov 15 06:22:50 ubuntu jenkins[5491]: This may also be found at: /var/lib/jenkins/secrets/initialAdminPassword
1. Add the Jenkins user to the Docker users group to enable communications with the Docker daemon.
    $ sudo usermod -aG docker jenkins
1. Allow the default Jenkins port `8080` through the default UFW firewall to enable access to the web interface.
    $ sudo ufw allow 8080
1. View the default Jenkins administrator password.
    $ sudo cat /var/lib/jenkins/secrets/initialAdminPassword
    Copy the generated password similar to the output below:
    243e47a2921746db9f14c95e264b3eb1
1. Access the Jenkins port `8080` using your Server IP Address to access the Jenkins dashboard in a web browser such as Google Chrome.
    http://SERVER-IP:8080
1. Enter the default password you copied earlier and click **Continue** to start the Jenkins Set Up process.
    ![Unlock Jenkins](https://docs.vultr.com/public/doc-assets/1733/8c3690c882829bf7.png)
1. Click **Install suggested plugins** to start installing all necessary Jenkins packages on your server.
    ![Install Jenkins Plugins](https://docs.vultr.com/public/doc-assets/1733/5009a090ac59b0d0.png)
1. Enter a new Jenkins administrator username and password. Then, click **Save and Continue** to access the instance configuration page.
    ![Jenkins initial setup](https://docs.vultr.com/public/doc-assets/1733/e098a4dfcf5d412f.png)
1. Keep your Server IP address structure in the Jenkins URL field, and click **Save and Finish** to save the access URL structure.
    ![Jenkins Instance Configuration](https://docs.vultr.com/public/doc-assets/1733/e85295707305fc1a.png)
1. Click **Start using Jenkins** to finish the configuration process and access the Jenkins dashboard.
    ![Jenkins Dashboard](https://docs.vultr.com/public/doc-assets/1733/14996a085ed3e84f.png)
## Install Jenkins Plugins
To integrate Jenkins with your VKE cluster, GitHub, and the Vultr container registry, install all necessary plugins to enable all pipeline resources. Follow the below steps to install all required Docker, GitHub, and Kubernetes plugins within your Jenkins dashboard.
1. Access your Jenkins dashboard.
1. Navigate to **Manage Jenkins** on the main navigation menu.
1. Click **Manage Plugins** to access the plugins page.
1. Click **Available Plugins**, and enter the keyword `Docker` in the search field.
1. Select `Docker`, `Docker Pipeline`, and `docker-build-step` from the plugin search results.
    ![Install Docker Plugin](https://docs.vultr.com/public/doc-assets/1733/6f19080c0dc14893.png)
1. Enter `Kubernetes` in the search field, and select `Kubernetes`, `Kubernetes Credentials`, `Kubernetes CLI`, and `Kubernetes Pipeline` from the plugin results.
1. Click **Install** to start the installation process.
1. Scroll and check the `Restart Jenkins when installation is complete and no jobs are running` option on the installation progress page to automatically restart Jenkins.
    ![Install Kubernetes Plugin](https://docs.vultr.com/public/doc-assets/1733/cc2e3348c9f078c2.png)
## Create a New GitHub Repository Webhook
A GitHub repository webhook triggers Jenkins to automatically start the build process whenever push and pull events occur in the linked repository. This integration facilitates Continuous Integration and Delivery (CI/CD) workflows. Follow the steps below to create a new GitHub repository webhook to integrate with your Jenkins dashboard.
1. Log in to your GitHub account.
1. Click the `+` sign in the top right corner and select **New repository** to set up a new repository.
1. Enter your desired repository name, for example, `node-application`. Then, choose your desired visibility type, and click **Create repository** to publish the new repository.
    ![Create a Git Repository](https://docs.vultr.com/public/doc-assets/1733/e01358e78832ef6c.png)
1. Navigate to the repository page, and click **Settings** on the top navigation bar.
1. Click **Webhooks** on the left navigation menu.
    ![GitHub Webhook](https://docs.vultr.com/public/doc-assets/1733/cc6c877d230cfe6a.png)
1. Click **Add webhook** to set up a new webhook.
    ![Create a GitHub Webhook](https://docs.vultr.com/public/doc-assets/1733/fd973e9223fd1faa.png)
   * Enter your Jenkins server URL in the **Payload URL** to receive payloads.
   * Keep the **Just the push event** radio button selected.
1. Click **Add webhook** to apply your new repository webhook.
## Create New Jenkins Credentials
To communicate with your GitHub repository, the Vultr Container Registry, and your VKE cluster, set up new credentials within your Jenkins dashboard to store the access details for each platform as described in the steps below.
1. Navigate to your Jenkins dashboard and click **Manage Jenkins**.
1. Click **Credentials** from the list of available options to set up a new profile.
     ![Jenkins Credentials Page](https://docs.vultr.com/public/doc-assets/1733/a4de260b5f582af1.png)
1. Click the `(global)` **Domains** value and select **Add credentials** from the list of options.
    ![Add Jenkins Credentials](https://docs.vultr.com/public/doc-assets/1733/3892d7fbff372d58.png)
1. Keep **Username with password** as the credential type and enter your Vultr Container Registry username and password in the respective fields.
1. Enter `vcr-credentials` in the **ID** field and click **Create** to save the new credential.
    ![Add Vultr Registry Credentials](https://docs.vultr.com/public/doc-assets/1733/4cc9eccc3f9495e2.png)
1. When successful, click **Add credentials** to set up a new GitHub credential.
1. Keep **Username with password** selected as the credential type, and enter your GitHub username, and password in the respective fields.
1. Enter `github-credential` in the **ID** field and click **Create** to save the new credential.
    ![Add Git Hub Credentials](https://docs.vultr.com/public/doc-assets/1733/d35ed3c5d07c91a0.png)
1. When successful, click Add credentials to set up a new GitHub credential. To set up the Kubernetes credential, click **Add credentials**.
1. Click the **Kind** drop-down and select **Secret file** from the list of options.
1. Click the **Choose File** button in the **File** section, browse, and upload your VKE cluster YAML file.
1. Enter `kubeconfig` in the **ID** field and click **Create** to save the new credential.
    ![Add Kubernetes Credentials](https://docs.vultr.com/public/doc-assets/1733/75f41372338b059c.png)
## Create a Node.js Application
1. Clone your GitHub `node-application` repository you created earlier.
    $ git clone https://github.com/example-user/node-application.git
1. Switch to the new repository directory.
    $ cd node-application
1. Create a new `package.json` file to define the application dependencies.
    $ nano package.json
1. Add the following configurations to the file.
    ```json
      "name": "simple-node-app",
      "version": "1.0.0",
      "description": "Node Hello World Application",
      "main": "app.js",
      "scripts": {
        "start": "node app.js"
      "dependencies": {
        "express": "4.17.1"
1. Create a new `app.js` file to define the application structure.
    $ nano app.js
1. Add the following contents to the file.
    ```js
    'use strict';
    const express = require('express');
    const PORT = process.env.PORT || 8080;
    const app = express();
    app.get('/', function (req, res) {
      res.send('Node Hello World Application!\n');
    app.listen(PORT);
    console.log('Running on http://localhost:' + PORT);
    The above Node.js application code sets up a basic server that listens on port `8080` and responds with `Node Hello World Application!` when accessed.
1. Create a new `Dockerfile` to define the application image structure.
    $ nano Dockerfile
    ```dockerfile
    FROM node:18-alpine as builder
    ENV NODE_ENV="production"
    # Copy app's source code to the /app directory
    COPY . /app
    # The application's directory will be the working directory
    WORKDIR /app
    # Install Node.js dependencies defined in '/app/package.json'
    RUN npm install
    FROM node:18-alpine
    COPY --from=builder /app /app
    WORKDIR /app
    ENV PORT 8080
    EXPOSE 8080
    # Start the application
    CMD ["npm", "start"]
## Set Up the Pipeline Kubernetes Resources
In this section, create the necessary Kubernetes resources that pull your Node.js application container image from the Vultr Container Registry and deploy it to your cluster. Each time Jenkins starts the build process, the resource files run again to update your cluster.
1. Create a `deployment.yml` file.
    $ nano deployment.yml
1. Add the following configurations to the file. Replace `example-user` with your actual GitHub username.
      replicas: 1
          app: node-app
            app: node-app
          - name: node-app
            image: example-user/node-app:latest
            - containerPort: 8080
    The above deployment configuration defines your application replicas, Docker image, and port to expose the application within the cluster.
1. Create a new Service resource file `service.yml` to expose the Node.js application outside the Kubernetes cluster.
    $ nano service.yml
        app: node-app
      type: LoadBalancer
      - port: 8080
        targetPort: 8080
        app: node-app
## Create the Pipeline Jenkinsfile
A `Jenkinsfile` file defines a Jenkins Pipeline for your CI/CD processes. It includes the entire build process steps from pulling the source code to deploying the application to your cluster. Follow the steps in this section to set up a new `Jenkinsfile` that includes all build processes to prepare the Node.js application for deployment in your cluster.
1. Create a new `Jenkinsfile`.
    $ nano Jenkinsfile
1. Add the following configurations to the file. Replace `https://sjc.vultrcr.com/jenkinsregistry` with your actual Vultr Container Registry URL.
    ```json
    pipeline {
    agent any
     environment {
         PROJECT_ID = 'jenkins'
         CLUSTER_NAME = 'cluster'
         LOCATION = 'usa'
         CREDENTIALS_ID = 'vultr'
     stages {
         stage("Checkout code") {
             steps {
                 checkout scm
         stage("Build image") {
             steps {
                 script {
                     myapp = docker.build("sjc.vultrcr.com/jenkinsregistry/node-app:${env.BUILD_ID}")
         stage("Push image") {
             steps {
                 script {
                     docker.withRegistry('https://sjc.vultrcr.com/jenkinsregistry', 'vcr-credentials') {
                             myapp.push("latest")
                             myapp.push("${env.BUILD_ID}")
     stage("Deploy to Vultr Kubernetes") {
         steps {
             sh "sed -i 's/node-app:latest/node-app:${env.BUILD_ID}/g' deployment.yml"
                     script {
         withKubeConfig([credentialsId: 'kubeconfig'])
           sh "kubectl apply -f deployment.yml"
           sh "kubectl apply -f service.yml"
    Below is what the above pipeline executes:
    * `agent any`: Specifies that the pipeline can run on any available agent (Jenkins node).
    * `stage("Checkout code")`: Checks out the source code from the version control system (specified by scm), and enables the pipeline to access the application code.
    * `stage("Build image")`: Builds a new Docker image of the Node.js applicatiom tagged with a version identifier based on the Jenkins build number `(${env.BUILD_ID})`.
    * `stage("Push image")`: Pushes the application Docker image to your defined registry `sjc.vultrcr.com/jenkinsregistry` using the `vcr-credentials` variable.
    * `stage("Deploy to Vultr Kubernetes")`: Updates the Kubernetes deployment configuration `deployment.yml` to use the new Docker image tagged with the latest Jenkins build number. Then, it applies the updated deployment and service configurations to your cluster using `kubectl`.
    * `sed`: Replaces all occurrences of the previous image tag `node-app:latest` with the new image tag `node-app:${env.BUILD_ID}` in the `deployment.yml` file.
    * `withKubeConfig`: Specifies the Kubernetes configuration `kubeconfig` to use in the pipeline processes. The `sh` command runs `kubectl` to deploy the deployment and service configurations to your VKE cluster.
    > ![NOTE]
    > If you applied different ID values in your Jenkins dashboard, replace `vcr-credentials` with your Vultr Container Registry credential, and `kubeconfig` with your actual cluster credential ID.
## Upload the Application Files to your GitHub Repository
All files, including your Node.js application, Dockerfile, Jenkinsfile, and Kubernetes resources, are ready for deployment. Configure Git to commit and push all files from your management machine to the GitHub repository as described in the steps below.
1. Configure a global username to associate with your Git operations. Replace `Example User` with your actual username.
    $ git config --global user.name "Example User"
1. Configure a global email. Replace `user@example.com` with your active email address.
    $ git config --global user.name "user@example.com"
1. Initialize the Git repository.
    $ git init
1. Add your GitHub repository as the remote repository to push changes.
    $ git remote add origin https://github.com/example-user/node-application.git
1. Stage all files in your working directory.
    $ git add .
1. Commit the staged changes with a descriptive commit message of your choice. For example, `Initial Commit`.
    $ git commit -m "Initial commit"
1. Push the changes to your GitHub repository.
    $ git push origin HEAD:master
    When prompted, enter your GitHub username and personal access token to successfully push changes to your repository.
1. When successful, visit your GitHub repository and verify that the new files are available.
    ![GitHub repository page](https://docs.vultr.com/public/doc-assets/1733/13d085f96de7a53e.png)
## Create a Jenkins Pipeline for Kubernetes Deployment
At this point, you have Jenkins integrated with the Kubernetes cluster. Now, you will create a Jenkins pipeline to deploy your application. Follow the steps below to create a new pipeline.
1. Access your Jenkins dashboard and click **New Item**.
1. Enter a name for your project. For example `myproject`.
1. Select **Multibranch Pipeline**, and click **OK** to save changes.
    ![Add Jenkins Project](https://docs.vultr.com/public/doc-assets/1733/6f0cc91fde668c3f.png)
1. Apply the following changes on the project configuration page:
    * Enter a name and description for your new project.
    * In the **Branch Sources** section, click the **Add Source** drop-down and select **GitHub**.
    * Select your Jenkins GitHub credentials ID.
    ![Define GitHub Configuration](https://docs.vultr.com/public/doc-assets/1733/feb5fd8aa548b734.png)
    * Enter your GitHub repository URL in the `Repository HTTPS URL` field.
    * Scroll to the **Properties** section, and enter your desired Docker label.
    * Enter your Vultr Container Registry URL in the **Docker registry URL** field, and click the **Registry credentials** drop-down to select the credential you created earlier.
    ![Define Docker Configuration](https://docs.vultr.com/public/doc-assets/1733/f36bbd1d91f88d7a.png)
1. Click **Save** to apply your new project configuration.
1. Monitor the new Jenkins scan progress and verify that the scan log includes a `FINISHED SUCCESS` result.
    ![Jenkins Scan Repository Log](https://docs.vultr.com/public/doc-assets/1733/1404a048aba32c48.png)
## Run the Jenkins Pipeline
1. Navigate to the pipeline project **Status** page.
1. Verify that a green checkmark is available and the **Last Success** field includes a time value that represents a successful build process.
    ![Jenkins pipeline dashboard](https://docs.vultr.com/public/doc-assets/1733/51ede887a718a72d.png)
1. Click the `main` value to view the pipeline processes page and verify that all processes are successful.
    ![Jenkins pipeline execution screen](https://docs.vultr.com/public/doc-assets/1733/62625a27fe1bce77.png)
1. Access your server terminal session to verify the new deployment in your cluster.
    $ kubectl get deployment
    NAME       READY   UP-TO-DATE   AVAILABLE   AGE
    node-app   1/1     1            1           36m
    As displayed in the above output, the Node.js application deployment is available in your cluster.
1. View the cluster services and verify that a new `LoadBalancer` service is available.
    $ kubectl get services
    NAME            TYPE           CLUSTER-IP       EXTERNAL-IP     PORT(S)          AGE
    kubernetes      ClusterIP      10.96.0.1        <none>          443/TCP          5h4m
    load-balancer   LoadBalancer   10.101.168.242   172.16.10.10   8080:32732/TCP   35m
    Keep note of the Node.js application `LoadBalancer` **EXTERNAL-IP** value to use when accessing your Node.js application.
1. Access your Node.js application using the Load Balancer IP on port `8080`. Replace the example IP `172.16.10.10` with your actual IP Address.
    http://172.16.10.10:8080
    Verify that the `Node Hello World Application` prompt displays in your browser session.
    ![Node.js application](https://docs.vultr.com/public/doc-assets/1733/8b0bdebdd1dcaaf5.png)
## Verify the CI/CD Pipeline
1. Switch to your `node-application` directory.
1. Change the `Node Hello World Application` message in the `app.js` file using the `sed` command to the `Node Hello World Application Updated`.
    $ sed -i 's/Node Hello World Application/Node Hello World Application Updated/g' app.js
1. Stage changes in your local repository.
    $ git add .
1. Commit new changes.
    $ git commit -m "Modify Node App"
1. Wait for at least `2` minutes for Jenkins to trigger the pipeline, rebuild the Node.js container image, and deploy it to your Kubernetes cluster.
1. When the pipeline execution process is successful. Visit your cluster Load Balancer IP to view the updated application.
    ![Node.js updated application](https://docs.vultr.com/public/doc-assets/1733/d344c6ab9b7e8405.png)
You have implemented a CI/CD pipeline with Jenkins on a Vultr Kubernetes Engine (VKE) cluster. By setting up a CI/CD pipeline with Jenkins and Kubernetes, you can generate an efficient, reliable, and scalable software delivery cycle. This integration automates the software deployment process and allows you to focus on innovation and collaboration. For more information, visit the [official Jenkins documentation](https://www.jenkins.io/doc/book/pipeline/).
