Installing Fuel CMS on FreeBSD 12.0
Fuel CMS is a CodeIgniter based content management system. Its source code is hosted on GitHub. This guide will show you how to install Fuel CMS on a fresh FreeBSD 12.0 Vultr instance.
Requirements
- Nginx or Apache server with
.htaccess
. This tutorial will use Nginx. - PHP version 5.4 or greater.
- A MySQL 5.0 (or newer) database if using the Fuel admin. Currently, it does not support other databases.
Before you begin
Check the FreeBSD version.
uname -ro
# FreeBSD 12.0-RELEASE
Ensure that your FreeBSD system is up to date.
freebsd-update fetch install
pkg update && pkg upgrade -y
Install the necessary packages.
pkg install -y sudo vim unzip curl wget bash socat git
Create a new user account with your preferred username. We will use johndoe
adduser
# Username: johndoe
# Full name: John Doe
# Uid (Leave empty for default): <Enter>
# Login group [johndoe]: <Enter>
# Login group is johndoe. Invite johndoe into other groups? []: wheel
# Login class [default]: <Enter>
# Shell (sh csh tcsh nologin) [sh]: bash
# Home directory [/home/johndoe]: <Enter>
# Home directory permissions (Leave empty for default): <Enter>
# Use password-based authentication? [yes]: <Enter>
# Use an empty password? (yes/no) [no]: <Enter>
# Use a random password? (yes/no) [no]: <Enter>
# Enter password: your_secure_password
# Enter password again: your_secure_password
# Lock out the account after creation? [no]: <Enter>
# OK? (yes/no): yes
# Add another user? (yes/no): no
# Goodbye!
Run the visudo
command and uncomment the %wheel ALL=(ALL) ALL
line, to allow members of the wheel
group to execute any command.
visudo
# Uncomment by removing hash (#) sign
# %wheel ALL=(ALL) ALL
Now, switch to your newly created user with su
su - johndoe
NOTE: Replace johndoe
with your username.
Set up the timezone.
sudo tzsetup
Install PHP
Install PHP, as well as the necessary PHP extensions.
sudo pkg install -y php72 php72-mbstring php72-tokenizer php72-pdo php72-pdo_mysql php72-openssl php72-hash php72-json php72-phar php72-filter php72-zlib php72-dom php72-xml php72-xmlwriter php72-xmlreader php72-pecl-imagick php72-curl php72-session php72-ctype php72-iconv php72-gd php72-simplexml php72-zip php72-filter php72-tokenizer php72-calendar php72-fileinfo php72-intl php72-phar php72-soap php72-xmlrpc php72-opcache php72-mysqli php72-bcmath php72-gmp
Check the version.
php --version
# PHP 7.2.20 (cli) (built: Jul 25 2019 01:28:14) ( NTS )
# Copyright (c) 1997-2018 The PHP Group
# Zend Engine v3.2.0, Copyright (c) 1998-2018 Zend Technologies
# with Zend OPcache v7.2.20, Copyright (c) 1999-2018, by Zend Technologies
Soft-link php.ini-production
to php.ini
sudo ln -s /usr/local/etc/php.ini-production /usr/local/etc/php.ini
Enable and start PHP-FPM.
sudo sysrc php_fpm_enable=yes
sudo service php-fpm start
Install MariaDB
Install MariaDB.
sudo pkg install -y mariadb102-client mariadb102-server
Check the version.
mysql --version
# mysql Ver 15.1 Distrib 10.2.25-MariaDB, for FreeBSD12.0 (amd64) using readline 5.1
Start and enable MariaDB.
sudo sysrc mysql_enable="yes"
sudo service mysql-server start
Run the mysql_secure_installation
script to improve the security of your MariaDB installation.
sudo mysql_secure_installation
Log into MariaDB as the root user.
mysql -u root -p
# Enter password:
Create a new MariaDB database and user. Remember the credentials for this new user.
CREATE DATABASE dbname;
GRANT ALL ON dbname.* TO 'username' IDENTIFIED BY 'password';
FLUSH PRIVILEGES;
exit;
NOTE: Replace dbname
and username
with appropriate names for your setup. Replace password
with a strong password.
Install Nginx
Install Nginx.
sudo pkg install -y nginx
Check the version.
nginx -v
# nginx version: nginx/1.16.0
Enable and start Nginx.
sudo sysrc nginx_enable=yes
sudo service nginx start
Run sudo vim /usr/local/etc/nginx/fuel.conf
and set up Nginx for Fuel CMS.
server {
listen 80;
listen [::]:80;
server_name example.com;
root /usr/local/www/fuel;
index index.php index.html;
location / {
try_files $uri $uri/ /index.php?q=$uri&$args;
location ~ \.php$ {
fastcgi_index index.php;
try_files $uri =404;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_pass 127.0.0.1:9000;
Save the file and exit.
Now we need to include fuel.conf
in the main nginx.conf
file.
Run sudo vim /usr/local/etc/nginx/nginx.conf
and add the following line to the http {}
block.
include fuel.conf;
Test the configuration.
sudo nginx -t
Reload Nginx.
sudo service nginx reload
Install Fuel CMS
Create a document root directory.
sudo mkdir -p /usr/local/www/fuel
Change ownership of the /usr/local/www/fuel
directory to johndoe
sudo chown -R johndoe:johndoe /usr/local/www/fuel
Navigate to the document root folder.
cd /usr/local/www/fuel
Download the latest release of ExpressionEngine and unzip the files to a folder on your server.
wget https://github.com/daylightstudio/FUEL-CMS/archive/master.zip
unzip master.zip
rm master.zip
mv FUEL-CMS-master/* .
rm -rf FUEL-CMS-master
Configure the fuel/application/config/database.php
file with the proper database connection settings.
vim fuel/application/config/database.php
Import the fuel/install/fuel_schema.sql
file into the newly created database.
mysql -u username -p password < fuel/install/fuel_schema.sql
NOTE: Replace username
and password
with your database credentials.
Change the $config['encryption_key']
on line 327
found in the fuel/application/config/config.php
file. To generate a random key you can use the openssl
tool.
vim fuel/application/config/config.php
Enable the admin backend by changing $config['admin_enabled'] = FALSE;
to TRUE
vim fuel/application/config/MY_fuel.php
Create the /usr/local/var/lib/php/session
directory and change its ownership to the user www
sudo mkdir -p /usr/local/var/lib/php/session && sudo chown -R www:www /usr/local/var/lib/php/session
Run vim fuel/application/config/config.php
to change the $config['sess_save_path']
configuration property to a writable folder above the webroot to save session files.
$config['sess_save_path'] = '/usr/local/var/lib/php/session'
directory to www
sudo chown -R www:www /usr/local/www/fuel
Using your preferred web browser, open your site and follow the Fuel CMS installer. After following the installer, you will have Fuel CMS up and running. To access the Fuel admin area, append /fuel
to your site URL. Use the following login credentials Username: admin
and Password: admin
. After logging in, you need to change your admin password.
