Monitoring Laravel Queues with Horizon and Vultr Managed Databases for Caching
![Monitoring Laravel Queues with Horizon and Vultr Managed Databases for Caching header image](https://docs.vultr.com/public/doc-assets/1556/ef4a1d59347ce57c.png)
Horizon is a queue manager for Laravel that gives you a dashboard and code-driven configuration to monitor and manage your queues. This guide explains how to use the Vultr Managed Database for Caching with Laravel Horizon, including the steps to make Laravel Horizon production-ready.
- Deploy a Ubuntu 22.04 server on Vultr.
- Create a non-root user with sudo privileges.
- Install LEMP on the server.
- Install NodeJS on the server.
- Deploy a Vultr Managed Database for Caching.
Create the MySQL Database
Log in to MySQL.
$ sudo mysql
Create a new database.
CREATE DATABASE example_database;
Create a new MySQL user.
CREATE USER 'example_user'@'%' IDENTIFIED WITH caching_sha2_password BY 'password';
Grant the user permission to the database.
GRANT ALL ON example_database.* TO 'example_user'@'%';
Exit MySQL.
EXIT
Log in to MySQL with the new user.
mysql -u example_user -p
Check if the user has access to the database.
SHOW DATABASES;
Set Up the Web Server
This guide uses the LEMP stack, and Laravel 10 requires at least PHP version 8.1. Verify the installed PHP version on your server using the following command.
$ php --version
PHP 8.1.2-1ubuntu2.11 (cli) (built: Feb 22 2023 22:56:18(NTS)
Copyright (c) The PHP Group
Zend Engine v4.1.2, Copyright (c) Zend Technologies with Zend OPcache v8.1.2-1ubuntu2.11, Copyright (c)by Zend Technologies
Install the necessary PHP extensions.
$ sudo apt install php-{cli,fpm,mysql,gd,soap,mbstring,bcmath,common,xml,curl,imagick,zip,redis}
Install Composer using the following commands.
$ php -r "copy('https://getcomposer. installer'composer-setup.php');" $ php composer-setup.php $ php -r "unlink('composer-setup.php');" $ sudo mv composer.phar /usr/local/bin/composer
Create a new user for the PHP FastCGI Process Manager (PHP-FPM) pool. This user runs the PHP-FPM process and has full privileges to the website files. Setting up a new user adds improves the security and isolation for your website.
$ sudo adduser website
Add the user to the Nginx web server group.
$ sudo usermod -a -G website www-data
Create the website files directory.
$ sudo mkdir /var/www/website
Grant the user ownership privileges to the directory.
$ sudo chown website:website /var/www/website
Copy the default PHP-FPM pool configuration as a template for the new pool.
$ sudo cp /etc/php/8.1/fpm/pool.d/www.conf /etc/php/8.1/fpm/pool.d/website.conf
Open the pool configuration file.
$ sudo nano /etc/php/8.1/fpm/pool.d/website.conf
Make changes to the file as follows:
[www]
to[website]
.user = www-data
touser = website
.group = www-data
togroup = website
.listen = /run/php/php8.1-fpm.sock
tolisten = /run/php/php8.1-fpm-website.sock
Delete the default PHP-FPM pool configuration.
$ sudo rm /etc/php/8.1/fpm/pool.d/www.conf
Restart PHP-FPM:
$ sudo systemctl restart php8.1-fpm
Configure Nginx
Disable the default Nginx configuration.
$ sudo unlink /etc/nginx/sites-enabled/default
Create a new Nginx configuration file.
$ sudo nano /etc/nginx/sites-available/website
Add the following configurations to the file. Replace
example.com
with your domain name.server { listen 80; listen [::]:80; server_name example.com; root /var/www/website/public; index index.html index.htm index.php; charset utf-8; client_max_body_size 10m; client_body_timeout 60s; location / { try_files $uri $uri/ /index.php?$query_string; } location = /favicon.ico { access_log off; log_not_found off; } location = /robots.txt { access_log off; log_not_found off; } access_log /var/log/example.com-access.log; error_log /var/log/example.com-error.log error; error_page 404 /index.php; location ~ \.php$ { include snippets/fastcgi-php.conf; fastcgi_pass unix:/run/php/php8.1-fpm-website.sock; fastcgi_buffers 32 32k; fastcgi_buffer_size 32k; } }
Enable Nginx configuration.
$ sudo ln -s /etc/nginx/sites-available/website /etc/nginx/sites-enabled/
Check the Nginx configuration for errors.
$ sudo nginx -t
Restart Nginx.
$ sudo systemctl restart nginx
Create a Laravel Project
The example project in this guide is a newsletter app that sends emails to subscribers. It utilizes the Laravel queues to process email delivery in the background. The app also uses the Laravel Breeze starter kits to scaffold the user authentication system.
You need to run the Laravel configuration tasks as the
website
user. Switch to the account by running the following command.$ sudo su - website
Change to the website directory.
$ cd /var/www/website
Using Composer, create a new Laravel project.
$ composer create-project laravel/laravel .
Open the
.env
file.$ nano .env
Set the Laravel mail driver to log. This blocks Laravel from sending the actual email and writes all emails to your log files for inspection.
MAIL_MAILER=log
Add your MySQL database configurations.
DB_DATABASE=example_database DB_USERNAME=example_user DB_PASSWORD=password
Replace the above values with your actual database settings as follows:
DB_DATABASE
: MySQL database name.DB_USERNAME
: MySQL username that has permission to the database.DB_PASSWORD
: MySQL user password.
Save and close the
.env
file.Install Laravel Breeze.
$ composer require laravel/breeze --dev
Scaffold your application using the Breeze Blade stacks.
$ php artisan breeze:install blade
Create a Subscriber Eloquent model and migration.
$ php artisan make:model Subscriber -m
Open the migration file.
$ nano database/migrations/2023_05_14_165944_create_subscribers_table.php
Add the following columns for the
subscribers
schema.Schema::create('subscribers', function (Blueprint $table) { $table->id(); $table->string('name'); $table->string('email'); $table->timestamps(); });
Create a factory for the Subscriber model.
$ php artisan make:factory SubscriberFactory -m Subscriber
Open the factory class.
$ nano database/factories/SubscriberFactory.php
Update the definition method with the following code.
public function definition() { return [ 'name' => fake()->name(), 'email' => fake()->unique()->safeEmail(), ]; }
Open the database seeder file.
$ nano database/seeders/DatabaseSeeder.php
Add the following code to the run method.
public function run() { \App\Models\User::factory()->create([ 'name' => 'Test User', 'email' => 'test@example.com', ]); \App\Models\Subscriber::factory()->count(100)->create(); }
Run the database migrations.
$ php artisan migrate
Run the database seeder.
$ php artisan db:seed
Create Mailable Class
Generate a Mailable class using the Artisan command.
$ php artisan make:mail SendNewsletter -m
Open the Mailable class.
$ nano app/Mail/SendNewsletter.php
Add subject and content property to the class.
/** * The email subject. * * @var string */ public $subject; /** * The email content. * * @var string */ public $content;
Update the constructor method with the following code.
public function __construct($subject, $content) { $this->subject = $subject; $this->content = $content; }
Update the envelope method with the following code.
public function envelope() { return new Envelope( subject: $this->subject, ); }
The full Mailable class function should lok like the one below.
<?php namespace App\Mail; use Illuminate\Bus\Queueable; use Illuminate\Contracts\Queue\ShouldQueue; use Illuminate\Mail\Mailable; use Illuminate\Mail\Mailables\Content; use Illuminate\Mail\Mailables\Envelope; use Illuminate\Queue\SerializesModels; class SendNewsletter extends Mailable { use Queueable, SerializesModels; public $subject; /** * The email content. * * @var string */ public $content; /** * Create a new message instance. * * @param string $subject * @param string $content * @return void */ public function __construct($subject, $content) { $this->subject = $subject; $this->content = $content; } /** * Get the message envelope. * * @return \Illuminate\Mail\Mailables\Envelope */ public function envelope() { return new Envelope( subject: $this->subject, ); } /** * Get the message content definition. * * @return \Illuminate\Mail\Mailables\Content */ public function content() { return new Content( markdown: 'mail.send-newsletter', ); } /** * Get the attachments for the message. * * @return array */ public function attachments() { return []; } }
Open the mail template.
$ nano resources/views/mail/send-newsletter.blade.php
Update it with the following code.
<x-mail::message> {{ $content }} </x-mail::message>
Create the Controller Class
Generate the
DashboardController
class.$ php artisan make:controller DashboardController
Open the
DashboardController
class.$ nano app/Http/Controllers/DashboardController.php
Load necessary classes at the top of the file.
use Illuminate\Support\Facades\Mail; use App\Models\Subscriber; use App\Mail\SendNewsletter;
Create the
index
action with the following code.public function index() { $subscribers = Subscriber::paginate(20); return view('dashboard', compact('subscribers')); }
Create the
newsletter
action that shows a form to broadcast the email.public function newsletter() { return view('newsletter'); }
Create the
sendNewsletter
action that processes the email delivery to all subscribers.public function sendNewsletter(Request $request) { $request->validate([ 'subject' => 'required', 'content' => 'required', ]); $subscribers = Subscriber::get(); foreach ($subscribers as $subscriber) { Mail::to($subscriber->email)->queue(new SendNewsletter($request->subject, $request->content)); } return redirect()->route('newsletter.form')->with('message', 'Success'); }
Below is the full content of the
DashboardController
class:<?php namespace App\Http\Controllers; use Illuminate\Http\Request; use Illuminate\Support\Facades\Mail; use App\Models\Subscriber; use App\Mail\SendNewsletter; class DashboardController extends Controller { public function index() { $subscribers = Subscriber::paginate(20); return view('dashboard', compact('subscribers')); } public function newsletter() { return view('newsletter'); } public function sendNewsletter(Request $request) { $request->validate([ 'subject' => 'required', 'content' => 'required', ]); $subscribers = Subscriber::get(); foreach ($subscribers as $subscriber) { Mail::to($subscriber->email)->queue(new SendNewsletter($request->subject, $request->content)); } return redirect()->route('newsletter.form')->with('message', 'Success'); } }
Defining Routes
Open the
routes/web.php
file.$ nano routes/web.php
Add the
DashboardController
at the top of the file.use App\Http\Controllers\DashboardController;
Update the dashboard route with the following code.
R oute::get('/dashboard', [DashboardController::class, 'index'])->middleware(['auth', 'verified'])->name('dashboard');
Add the newsletter routes:
Route::get('/newsletter', [DashboardController::class, 'newsletter'])->middleware(['auth', 'verified'])->name('newsletter.form'); Route::post('/newsletter', [DashboardController::class, 'sendNewsletter'])->middleware(['auth', 'verified'])->name('newsletter.send');
Create Views
Open the
resources/views/dashboard.blade.php
file.$ nano resources/views/dashboard.blade.php
<x-app-layout> <x-slot name="header"> <h2 class="font-semibold text-xl text-gray-800 leading-tight"> {{ __('Dashboard') }} </h2> </x-slot> <div class="py-12"> <div class="max-w-7xl mx-auto sm:px-6 lg:px-8"> <div class="sm:flex sm:items-center"> <div class="sm:flex-auto"> <h3 class="text-xl font-semibold text-gray-900">Subscribers ({{ $subscribers->total() }})</h3> </div> <div class="mt-4 sm:mt-0 sm:ml-16 sm:flex-none"> <a href="{{ route('newsletter.form') }}" class="inline-flex items-center justify-center rounded-md border border-transparent bg-indigo-600 px-4 py-2 text-sm font-medium text-white shadow-sm hover:bg-indigo-700 focus:outline-none focus:ring-2 focus:ring-indigo-500 focus:ring-offset-2 sm:w-auto"> Send Newsletter </a> </div> </div> <div class="overflow-hidden shadow ring-1 ring-black ring-opacity-5 md:rounded-lg mt-8"> <table class="min-w-full divide-y divide-gray-300"> <thead class="bg-gray-50"> <tr> <th scope="col" class="py-3.5 pl-4 pr-3 text-left text-sm font-semibold text-gray-900 sm:pl-6">Name</th> <th scope="col" class="px-3 py-3.5 text-left text-sm font-semibold text-gray-900">Email</th> </tr> </thead> <tbody class="divide-y divide-gray-200 bg-white"> @foreach ($subscribers as $subscriber) <tr> <td class="whitespace-nowrap py-4 pl-4 pr-3 text-sm font-medium text-gray-900 sm:pl-6">{{ $subscriber->name }}</td> <td class="whitespace-nowrap px-3 py-4 text-sm text-gray-500">{{ $subscriber->email }}</td> </tr> @endforeach </tbody> </table> </div> <div class="mt-8">{{ $subscribers->links() }}</div> </div> </div> </x-app-layout>
Create a
resources/views/newsletter.blade.php
file with the following code.<x-app-layout> <x-slot name="header"> <h2 class="font-semibold text-xl text-gray-800 leading-tight"> {{ __('Send Newsletter') }} </h2> </x-slot> <div class="py-12"> <div class="max-w-7xl mx-auto sm:px-6 lg:px-8"> <div class="p-4 sm:p-8 bg-white shadow sm:rounded-lg"> <div class="max-w-xl mx-auto"> @if (session()->has('message')) <div class="rounded-md bg-green-50 p-4 text-sm font-medium text-green-800">{{ session('message') }}</div> @endif <form method="post" action="{{ route('newsletter.send') }}" class="mt-6 space-y-6"> @csrf <div> <x-input-label for="subject" :value="__('Subject')" /> <x-text-input id="subject" name="subject" type="text" class="mt-1 block w-full" required autofocus autocomplete="subject" /> <x-input-error class="mt-2" :messages="$errors->get('subject')" /> </div> <div> <x-input-label for="content" :value="__('Content')" /> <textarea id="content" rows="10" name="content" class="mt-1 block w-full border-gray-300 focus:border-indigo-500 focus:ring-indigo-500 rounded-md shadow-sm" required autocomplete="content"></textarea> <x-input-error class="mt-2" :messages="$errors->get('content')" /> </div> <div class="flex items-center gap-4"> <x-primary-button>{{ __('Send') }}</x-primary-button> </div> </form> </div> </div> </div> </div> </x-app-layout>
Compile the front-end assets.
$ npm run build
Install and Configure Laravel Horizon
Install Horizon using Composer.
$ composer require laravel/horizon
Publish Horizon assets.
$ php artisan horizon:install
Configure the Horizon Queue Worker
Open the Horizon configuration file.
$ nano config/horizon.php
Navigate to the environments configuration option.
'environments' => [ 'production' => [ 'supervisor-1' => [ 'maxProcesses' => 10, 'balanceMaxShift' => 1, 'balanceCooldown' => 3, ], ], 'local' => [ 'supervisor-1' => [ 'maxProcesses' => 3, ], ], ],
In this option, configure the queue worker behavior for each environment. For example, set the value of the
maxProcesses
option in the production environment to 20. This allows the worker to scale up to 20 processes in production.'production' => [ 'supervisor-1' => [ 'maxProcesses' => 20, 'balanceMaxShift' => 1, 'balanceCooldown' => 3, ], ],
Configure the Redis® Connection
Open the
.env
file.$ nano .env
Update the queue connection to Redis®.
QUEUE_CONNECTION=redis
Add Vultr Managed Database for Caching configurations.
REDIS_HOST=tls://[YOUR_VULTR_REDIS_HOST] REDIS_PASSWORD=password REDIS_PORT=6379
Replace the default values with your actual database details as below.
REDIS_HOST
– Vultr Managed Database for Caching host.REDIS_PASSWORD
– Enter your Vultr Managed Database for Caching password.REDIS_PORT
– The Vultr Managed Database for Caching port.
Save and close the
.env
file.
Prepare Horizon for Production
Horizon exposes the dashboard at the /horizon
path. In production, you should protect this path using the authorization gate that controls access to the dashboard.
Open the
HorizonServiceProvider.php
file.$ nano app/Providers/HorizonServiceProvider.php
In the gate method, add the user's email that you want to allow to the Horizon dashboard.
protected function gate(): void { Gate::define('viewHorizon', function ($user) { return in_array($user->email, [ 'test@example.com' ]); }); }
Open the
.env
file.$ nano .env
Disable debug messages.
APP_DEBUG=false
Change the app environment to production.
APP_ENV=production
Run Horizon on Production using Supervisor
Install Supervisor.
$ sudo apt-get install supervisor
Create a Supervisor configuration file for Horizon.
$ sudo nano /etc/supervisor/conf.d/horizon.conf
[program:horizon] process_name=%(program_name)s command=php /var/www/website/artisan horizon autostart=true autorestart=true user=website redirect_stderr=true stdout_logfile=/var/log/horizon.log stopwaitsecs=3600
Start the Supervisor process as below.
$ sudo supervisorctl reread $ sudo supervisorctl update $ sudo supervisorctl start horizon
Secure the Website with Trusted Let's Encrypt SSL Certificates
Install the Certbot Let's Encrypt tool.
$ sudo snap install --classic certbot
Activate the Certbot command.
$ sudo ln -s /snap/bin/certbot /usr/bin/certbot
Generate the SSL certificates. Replace
example.com
with your actual domain name, anduser@example.com
with your email address.$ sudo certbot --nginx -d example.com -d www.example.com -m user@example.com --agree-tos
Test that Certbot auto-renews the SSL certificate.
$ certbot renew --dry-run
In a web browser, visit your domain and verify that it serves HTTPS requests.
https://example.com
Configure Firewall
By default, Uncomplicated Firewall (UFW) is active on Vultr servers, configure the firewall to allow HTTP and HTTPS traffic as below.
Allow the HTTP port
80
.$ sudo ufw allow 80/tcp
Allow HTTPS port
443
.$ sudo ufw allow 443/tcp
Restart the firewall to save changes.
$ sudo ufw reload
Verify that the rules are added to the firewall table.
$ sudo ufw status
Test the Application
In a web browser, open the application.
https://example.com
The default Laravel landing page should display.
Click the login link and log in with a user from the database seeder.
Click the Send Newsletter button on the dashboard page.
Fill in the Subject and Content field.
Click the Send button.
The application then creates a job queue to send the email newsletter to each subscriber.
Monitor the Jobs in Horizon Dashboard
- Log in as a user with access to the Horizon dashboard.
- Visit the Horizon dashboard at the
https://[YOUR_DOMAIN_NAME]/horizon
path. - Check the Horizon status. If it's active, it means that Horizon is running and can process all your job queues.
- See your job queues at the Pending Jobs, Completed Jobs, or Failed Jobs menus depending on their status.
- If the job fails, see the job exception logs.
Check the Email Delivery
For testing purposes, this guide uses the log driver for the Laravel mail. It means that the sample app doesn't send the actual emails. It writes all emails in the log file. To check if the app successfully sends an email, open the laravel.log
file.
$ nano storage/logs/laravel.log
All email content should display in the log file as below:
[2023-05-14 12:11:52] local.DEBUG: From: Laravel <hello@example.com>
To: jschmitt@example.org
Subject: tes
MIME-Version: 1.0
Date: Sun, 14 May 2023 12:11:52 +0000
Message-ID: <8dc916eb3d9248ee1b10a99f5576b424@example.com>
Content-Type: multipart/alternative; boundary=mxw5N1XT
In this guide you have used the Vultr Managed Database for Caching with Laravel Horizon and used it to set up a production-ready application. Laravel Horizon allows you to monitor job queues in a single dashboard. You can see the exception logs if a job fails and can retry it. It also has a queue worker that you can configure differently in each environment using a single configuration file.
