Build Scalable and Resilient Apps with Dapr on Vultr Kubernetes Engine
![Build Scalable and Resilient Apps with Dapr on Vultr Kubernetes Engine header image](https://docs.vultr.com/public/doc-assets/1508/951b36bc827482bd.png)
Dapr is a portable, event-driven runtime to build scalable and resilient applications. It is platform agnostic, meaning you can run Dapr-based applications anywhere, ranging from your local workstation and virtual machines to a Kubernetes cluster, different cloud providers, or even at the edge. Dapr is also language agnostic, so that you can choose any language or framework for your application.
This article explains how to start with Dapr on Vultr Kubernetes Engine (VKE). After setting up Dapr on VKE, you will deploy microservices that communicate with each other via the Dapr runtime and store data in a Vultr Managed Database for Redis.
The following topics will be covered in this article:
- An overview of Dapr, including basic concepts.
- How to set up VKE, deploy Dapr to it, and integrate Dapr with Redis.
- An end-to-end example of microservices running on VKE, integrated via Dapr.
- Best practices for running Dapr-based applications.
Introduction to Dapr
Dapr runs alongside an application and provides capabilities such as persistence, service invocation, security, distributed tracing, and so on. This is possible because Dapr adopts a sidecar architecture pattern and exposes its APIs via HTTP and gRPC. Thus, applications do not need to interact directly with the Dapr runtime and remain agnostic of the underlying implementation details. This provides a clear separation of concerns and makes it easy to integrate Dapr with other platforms, runtimes or services. Dapr also provides SDKs for multiple languages such as Java, JavaScript, Python, .NET, PHP, Go, Rust and C++. These SDKs expose the functionality of Dapr building blocks through a language-specific API.
Dapr Building Blocks
Although Dapr offers features similar to that of a Service Mesh, it's quite different. While a Service Mesh is focused on infrastructure concerns such as networking, Dapr is focused on the application layer. It exposes different capabilities in the form of APIs called Building Blocks, thereby codifying best practices for building platform and language-agnostic microservices. A building block is nothing but an HTTP or gRPC API that can be invoked from the application code.
Here is an overview of the building blocks that Dapr offers:
- State management - Provides persistence for applications based on key/value-based query and state APIs backed by pluggable state store implementations.
- Inter-service invocation - Allows applications to communicate with each other using HTTP or gRPC endpoints.
- Publish and subscribe - This allows decoupled applications where senders (or publishers) publish messages to a topic that subscribers can consume.
- Bindings - Enables bi-directional integration with Dapr by allowing applications to invoke an external service and triggering applications via events sent by an external service.
- Observability - You can configure Dapr to emit tracing data using standard protocols such as Open Telemetry and integrate with observability tools.
- Secrets - This building block integrates Dapr with custom secret stores.
- Configuration - Enables you to integrate configuration stores to retrieve application-specific configuration information.
- Distributed lock - Use the distributed lock API to allow multiple instances of an application to access a resource in a conflict-free manner using locks.
- Actors - Dapr has a virtual actor based implementation and provides a single-threaded programming model where actors are garbage collected when not in use.
You can choose the building block(s) based on your application requirements. Because each of these building block APIs is independent, you integrate one or more such blocks in your application.
Dapr State Store
You can use a State Store to save and retrieve application states from underlying databases that Dapr integrates with. All the state store implementations offer a set of features that are commonly required by applications. These include traditional CRUD operations, transactions, and bulk operations, along with the ability to configure concurrency and consistency parameters.
You can query state with the Dapr state management query API or directly with the data store's native client library/SDK. It's recommended to use the Query API since it allows you to retrieve state store data irrespective of underlying database-specific implementation.
Dapr on Kubernetes
In Kubernetes, Dapr runs alongside the application in the same Pod as a sidecar container. All you need to do is add a few annotations to your application manifest Pod schema. Here is an example:
dapr.io/enabled: "true"
dapr.io/app-id: "myapp"
dapr.io/app-port: "8080"
dapr.io/config: "tracing"
The following control-plane components are the key to running Dapr on Kubernetes:
- dapr-sidecar-injector: Responsible for injecting Dapr as a sidecar container into Pods.
- dapr-operator: It manages Dapr component updates and Kubernetes services endpoints.
- dapr-placement: It is only used by actors to create mapping tables that map actor instances to Pods.
- dapr-sentry: Provides mutual TLS (mTLS) between services and also acts as a certificate authority.
Application Overview
The solution demonstrated in this article consists of two microservices. One is a Python application that generates messages, and the other one is a Node.js application that consumes these messages. The Node.js application exposes two HTTP endpoints:
- A POST endpoint to receive messages. The message data is persisted to a Vultr Redis Managed database instance.
- A GET endpoint to query data. This invokes the Vultr Redis Managed database instance to extract the latest state.
Now you have an understanding of core Dapr concepts and the architecture overview, let's move on to the configuration and deployment of the solution.
Make sure you complete the steps below to follow the rest of the instructions in this article.
Deploy a Vultr Managed Database for Redis by following the Quickstart guide.
After Redis is deployed, click the Manage icon to open the Overview tab to retrieve the username, password, host, and port from the Connection Details section.
Install kubectl, which is a Kubernetes command-line tool that allows you to run commands against Kubernetes clusters.
Deploy a VKE cluster using the Reference Guide. Once it's deployed, from the Overview tab, click the Download Configuration button in the upper-right corner to download your kubeconfig file and save it to a local directory.
Point kubectl to the VKE cluster by setting the KUBECONFIG environment variable to the path where you downloaded the cluster kubeconfig file in the previous step.
export KUBECONFIG=<path to VKE kubeconfig file>
Verify the same using the following command:
kubectl config current-context
Install curl which is a popular command-line HTTP client.
Install the Redis CLI.
Install Dapr CLI
Use the following command to install Dapr CLI locally:
curl -fsSL https://raw.githubusercontent.com/dapr/cli/master/install/install.sh | /bin/bash
Verify Dapr CLI installation:
dapr --version
Run the following command to deploy Dapr on the VKE cluster. Because the --wait
flag is specified, the CLI will wait until Dapr is completely deployed and running on the cluster.
dapr init --kubernetes --wait
You should see the following output:
Deploying the Dapr control plane to your cluster...
Unless specified, Dapr will be installed to the dapr-system namespace by default (it will be created if it does not already exist). Use -n
to specify a different namespace.
Once Dapr is deployed, you should see the following output:
Success! Dapr has been installed to namespace dapr-system. To verify, run `dapr status -k` in your terminal. To get started, go here: https://aka.ms/dapr-getting-started
To verify the deployment, run the following command in the terminal:
dapr status -k
You should see an output similar to this (the VERSION might differ in your case):
NAME NAMESPACE HEALTHY STATUS REPLICAS VERSION AGE
dapr-sentry dapr-system True Running 1 1.9.5 37s
dapr-dashboard dapr-system True Running 1 0.11.0 37s
dapr-placement-server dapr-system True Running 1 1.9.5 36s
dapr-operator dapr-system True Running 1 1.9.5 37s
dapr-sidecar-injector dapr-system True Running 1 1.9.5 37s
Configure a Dapr State Store
Create a directory and switch to it:
mkdir vultr-dapr
cd vultr-dapr
Create a new file redis-state-store.yaml
touch redis-state-store.yaml
Enter the below contents in redis-state-store.yaml
and save the file. Make sure to replace the required attributes with the host, username, and password for the Redis database.
apiVersion: dapr.io/v1alpha1
kind: Component
type: state.redis
version: v1
- name: redisHost
value: <replace with hostname for Vultr managed redis database>:16752
- name: redisUsername
value: <replace with username for Vultr managed redis database>
- name: redisPassword
value: <replace with password for Vultr managed redis database>
- name: enableTLS
value: true
The redis-state-store.yaml
file defines a statestore component of type state.redis.
- redisHost - Connection string for the Redis host in the form of host:port.
- redisUsername - Username for Redis host.
- redisPassword - Password for Redis host.
- enableTLS - Whether the Redis instance supports TLS.
Create the state store:
kubectl apply -f redis-state-store.yaml
component.dapr.io/statestore created
Deploy the Node.JS Application to VKE
Create a new file node-app.yaml
touch node-app.yaml
Enter below contents in node-app.yaml
and save the file.
app: node
app: node
- protocol: TCP
targetPort: 3000
app: node
replicas: 1
app: node
app: node
dapr.io/app-id: "nodeapp"
dapr.io/app-port: "3000"
dapr.io/enable-api-logging: "true"
- name: node
image: ghcr.io/dapr/samples/hello-k8s-node:latest
env:
- name: APP_PORT
value: "3000"
- containerPort: 3000
imagePullPolicy: Always
Deploy the Node.js application to the cluster:
kubectl apply -f node-app.yaml
deployment.apps/nodeapp created
Check the deployment. Wait for the STATUS to transition to Running.
kubectl get pods -l=app=node
#output
NAME READY STATUS RESTARTS AGE
nodeapp-7bbf67cd77-jhv2r 2/2 Running 0 47s
Verify the Service (CLUSTER-IP might differ in your case):
kubectl get service/nodeapp
#output
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
nodeapp ClusterIP 10.109.80.71 <none> 80/TCP 10s
Deploy the Python Application to VKE
Create a new file, python-app.yaml
touch python-app.yaml
Enter the below contents in python-app.yaml
and save the file.
app: python
replicas: 1
app: python
app: python
dapr.io/app-id: "pythonapp"
- name: python
image: ghcr.io/dapr/samples/hello-k8s-python:latest
To deploy the Python application to the cluster:
kubectl apply -f python-app.yaml
deployment.apps/pythonapp created
kubectl get pods -l=app=python
#output
pythonapp-6bdf8dd995-fvz6h 2/2 Running 0 12s
Test the Solution
Use port forwarding to access the Node.js application running in the VKE cluster.
kubectl port-forward service/nodeapp 8080:80
Forwarding from 127.0.0.1:8080 -> 3000
Forwarding from [::1]:8080 -> 3000
Open a new terminal and point kubectl to the VKE cluster by setting the KUBECONFIG environment variable to the path where you downloaded the cluster kubeconfig file in the previous step.
Check the logs of the Node.js application.
kubectl logs -f -l=app=node -c node
You should see logs similar to this:
Got a new order! Order ID: 1
Successfully persisted state
Got a new order! Order ID: 2
Got a new order! Order ID: 3
Use curl to invoke the Node.js application HTTP GET endpoint to query the latest order ID.
curl localhost:8080/order
You should see a JSON output similar to this (the order ID might differ in your case):
{"orderId":419}
Query Data from Redis
To connect to the Vultr Redis Managed database using Redis CLI, click the Manage icon to open the Overview tab and click Copy Connection String in the Connection Details section.
Paste the contents in the terminal. Once you are connected to the Redis instance, execute the below command:
keys *
This will give you the name of the key in which the Node.js application data is stored. You should see the following output:
1) "nodeapp||order"
This is a Redis Hash data structure. To check the data, execute this command:
hgetall "nodeapp||order"
You should see an output similar to this (the order ID and version might differ in your case):
1) "data"
2) "{\"orderId\":800}"
3) "version"
4) "799"
Best Practices for Production
So far, you have deployed a set of microservices to a Kubernetes cluster and integrated them using Dapr. Although this was a simple way to get started, there are a few best practices you should bear in mind while using Dapr in production.
Cluster capacity - The recommended cluster size is at-least three Kubernetes worker nodes to support a highly-available Dapr installation.
Dapr HA mode - A HA Dapr control plane configuration consists of three replicas of each control plane Pod in the dapr-system namespace.
Sidecar settings - Explicitly configure the resource assignments for the Dapr sidecar using the following annotations:
dapr.io/sidecar-cpu-limit dapr.io/sidecar-memory-limit dapr.io/sidecar-cpu-request dapr.io/sidecar-memory-request
Tracing and metrics configuration - Configure distributed tracing and metrics for your applications and the Dapr control plane in production.
Security configuration - Make sure to enable mTLS, Dapr API authentication, Dapr to App API authentication, and install the Dapr control plane on a dedicated namespace such as dapr-system.
In this article, you learned how to integrate microservices on Kubernetes using Dapr. Along the way, you learned the key concepts of Dapr and also configured a Vultr Managed Database for Redis as the Dapr state store. Finally, you explored some best practices for production-grade Dapr deployments.
You can also learn more in the following documentation:
