How to Build an Inference API using Hugging Face Diffusers and FastAPI
The Hugging Face Diffusers library offers access to pre-trained diffusion models in the form of prepackaged pipelines with tools to build and train models. It also includes different core neural network models used as building blocks to create new pipelines.
FastAPI is a Python web framework used to build APIs and web applications. It supports modern Python features such as type hints and async that make it fast and efficient. In addition, it uses the Asynchronous Server Gateway Interface (ASGI) standard for asynchronous, concurrent connectivity with clients, and can integrate with WSGI when needed.
This guide describes how you can build an Inference API using Hugging Face Diffusers and FastAPI on a Vultr NVIDIA A100 Cloud GPU server. You are to execute each of the building steps and have a functional inference API that utilizes the pre-trained Stable Diffusion 2.1 model. This process involves leveraging the capabilities of FastAPI for efficient implementation.
- Deploy a Ubuntu 22.04 A100 Cloud GPU server with at least:
- 1/2 GPU
- 40 GB GPU RAM
- Using SSH, access the server
- Create a non-root sudo user and switch to the new user
- Update the server
API Inference Overview
API inference is the process of deploying and executing a model on new data to generate a specific output without implementing the full model. To serve a model to users over the internet, you need to build an inference API and deploy the model to a production environment.
To build an inference API, you need:
- An AI model, such as a pre-trained or fine-tuned model
- A web framework to build and serve APIs
- A system configured to accept and serve requests over the internet
Set Up the FastAPI Environment
To efficiently use FastAPI, create a Python virtual environment, install the necessary dependencies, and the Fast API Python framework to build your API application as described in the steps below.
Install the Python virtual environment package
$ sudo apt install python3-venv
Create a new Python virtual environment for your project
$ python3 -m venv venv
A virtual environment is a Python tool for dependency management and project isolation. Each project can have any locally installed packages in an isolated directory.
Enter the virtual environment
$ source venv/bin/activate
Install the
torch
andtorchvision
packages(venv) $ pip install torch torchvision --index-url https://download.pytorch.org/whl/cu118
The above command installs the PyTorch module with its dependencies
torch
andtorchvision
. The--index-url
flag installs a specific package index for the PyTorch-compatible module with the required CUDA version. To install the latest version, visit the PyTorch installation page.Install the required dependencies
(venv) $ pip install diffusers transformers accelerate
Below are the installed dependency packages:
Transformer
: These are pre-trained models used for Natural Language Processing (NLP), Named Entity Recognition (NER), machine translation, and sentiment analysisDiffusers
: Provides the tools for building and training diffusion models. It also includes many different core neural network models used as building blocks to create new pipelinesAccelerate
: Enables PyTorch to run across any distributed configuration. It leverages accelerators such as GPUs and TPUs to improve efficiency, scalability, and speed up NLP workflows
Install the
fastapi
,gunicorn
, anduvicorn
packages(venv) $ pip install fastapi gunicorn uvicorn
Below are the installed packages:
gunicorn
: Python-based HTTP server based on the Web Server Gateway Interface (WSGI) standard to serve the API,uvicorn
: to handle asynchronous applications based on the Asynchronous Server Gateway Interface (ASGI) standard.
Inference API for Image Generation
In this section, set up a basic API to serve a text-to-image generation model. Create a Python application file, import dependency packages, set up a pipeline and scheduler, and create a basic API to serve the image generation model as described below.
Using a text editor such as
nano
, create a new Python fileapp.py
(venv) $ nano app.py
Add the following code to the file
import io import torch from diffusers import StableDiffusionPipeline, DPMSolverMultistepScheduler from fastapi import FastAPI, Response app = FastAPI() pipe = StableDiffusionPipeline.from_pretrained("stabilityai/stable-diffusion-2-1", torch_dtype=torch.float16, use_safetensors=True) pipe.scheduler = DPMSolverMultistepScheduler.from_config(pipe.scheduler.config) pipe.to("cuda") @app.get("/generate") def generate(prompt: str): image_store = io.BytesIO() images = pipe(prompt).images images[0].save(image_store, "PNG") return Response(content=image_store.getvalue(), media_type="image/png")
Save and close the file
The above application code imports all necessary packages, and uses the Hugging Face
to declare the image-generation model.app = FastAPI()
packages the pipeline into an API endpoint and initiates the App. Then:- The GET endpoint applies a decorator that defines an HTTP GET endpoint at the path
"/generate"
. Then, thegenerate
function defines the behavior of the"/generate"
endpoint that takes a single parameter prompt of typestr
io.BytesIO()
creates an in-memory bytes buffer used to store the generated imageimages[0].save(image_store, 'PNG')
saves the first generated image from the images list to theimage_store
buffer inPNG
formatreturn Response
constructs an HTTP response that contains the generated image data. Then,image_store.getvalue()
retrieves the content of the image buffer, andmedia_type
defines thetype "image/png"
Using
uvicorn
, run the App as a background process(venv) $ uvicorn app:app &
INFO: Started server process [19329] INFO: Waiting for application startup. INFO: Application startup complete. INFO: Uvicorn running on http://127.0.0.1:8000 (Press CTRL+C to quit)
Using curl, test the application using a prompt such as
An astronaut landing on planet
(venv) $ curl -G http://127.0.0.1:8000/generate --data-urlencode "prompt=An astronaut landing on planet" -o image.png
To view the generated image, use a file transfer program such as SFTP, SCP, or FTP to download the image file to your computer.
To stop the
uvicorn
server, view the available background tasks(venv) $ jobs
[1]+ Running uvicorn app:app &
Stop the target job ID
(venv) $ kill %1
Expose the API Server to the Internet
Using
UFW
, allow connections to the API Server port8000
(venv) $ sudo ufw allow 8000/tcp
Using
uvicorn
, run the App in the background(venv) $ uvicorn app:app --host 0.0.0.0 &
Using a web browser such as Firefox, access the inference API with a prompt on your Server IP Address
http://SERVER-IP:8000/generate?prompt=An astronaut landing on planet
Verify that the image displays in your web browser session
To stop the
uvicorn
server, view the background job ID(venv) $ jobs
[1]+ Running uvicorn app:app --host 0.0.0.0 &
Stop the server
(venv) $ kill %1
Using Gunicorn with
uvicorn.workers
, run the app in the background(venv) $ gunicorn app:app --timeout 60 --worker-class uvicorn.workers.UvicornWorker --bind 0.0.0.0:8000 &
In your web browser, test the application with a different prompt such as
adventure hills
http://SERVER-IP:8000/generate?prompt=adventure hills
Stop the
gunicorn
server background process(venv) $ kill %1
Serve Fine-Tuned Models
The process of serving fine-tuned models matches serving pre-trained models. Before deploying a fine-tuned model, either train your model and save it, or download and save an already fine-tuned model as described below.
For example, in your app.py
Python application, instead of:
pipe.to('cuda')
Use the path to a saved fine-tuned model:
lora_model_id = "/path/to/output/model"
base_model_id = "stabilityai/stable-diffusion-2-1"
pipe = StableDiffusionPipeline.from_pretrained(base_model_id, torch_dtype=torch.float16)
pipe.unet.load_attn_procs(lora_model_id)
pipe.to("cuda")
Replace the placeholder path "/path/to/output/model"
with your actual model path.
Enable Multithreading
To run the server with multiple workers, run
gunicorn
as a background process with the--workers
option(venv) $ gunicorn app:app --workers 2 --timeout 60 --worker-class uvicorn.workers.UvicornWorker --bind 0.0.0.0:8000 &
The above
gunicorn
command starts the application with the following options:--workers
: Defines the number of running worker processes that handle incoming requests concurrently--timeout
: Sets the maximum allowed time (in seconds) for a worker to process a request. If a worker takes longer than this timeout, it's forcibly killed--worker-class
: ConfiguresGunicorn
to use the Uvicorn worker class designed to run Asynchronous Server Gateway Interface (ASGI) applications like FastAPI
Using
ps
, view the system processes$ ps -ax | grep python
View the different worker forks displayed in your output like the one below:
11147 pts/0 Sl+ 0:18 /home/user/venv/bin/python3 /home/user/venv/bin/gunicorn app:app --workers 2 --timeout 60 --worker-class uvicorn.workers.UvicornWorker --bind 0.0.0.0:8000 11148 pts/0 Sl+ 0:29 /home/user/venv/bin/python3 /home/user/venv/bin/gunicorn app:app --workers 2 --timeout 60 --worker-class uvicorn.workers.UvicornWorker --bind 0.0.0.0:8000
Each line is a fork of the main thread. Verify that each of the forked processes uses its own GPU memory space.
View the GPU memory usage
$ watch nvidia-smi
The above
watch
command runs thenvidia-smi
command every 2 seconds to display the realtime GPU memory usage.To decide on the number of workers, apply the following rule:
N = number of threads + 1
On standard cloud servers,
1
vCPU is equal to1
thread, while on dedicated servers with hyper-threading equates to2
threads per CPU core. When using multiple workers, verify that the available GPU memory is enough to accommodateN
instances of the model. Otherwise, the system generates an out-of-memory error.Sometimes, even with enough GPU memory, loading a large model with multiple workers can display worker termination warnings as below:
[11147] [WARNING] Worker with pid 11148 was terminated due to signal 9
Using
dmesg
, view a more detailed output$ sudo dmesg
oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-0.slice/session-3.scope,task=gunicorn,pid=11148,uid=0 [ 4412.006670] Out of memory: Killed process 11148 (gunicorn) total-vm:38942992kB, anon-rss:30142812kB, file-rss:2304kB, shmem-rss:0kB, UID:0 pgtables:68700kB oom_score_adj:0
Based on the above output, an out-of-memory error occurred while loading the worker objects. Typically, the system automatically initiates another process and recovers from this error. If the warnings persist, increase the server timeout value.
Python functions are either defined using
def
orasync def
. When employingasync def
in conjunction withN
number of Uvicorn workers,N
forks of the main thread generate. Incoming requests distribute among theseN
processes. Due to the asynchronous nature of the function, the program can accept new requests while the slow task (such as generating output) from a previous request is still processed. Sequentially each thread handles the requests assigned to it.
Test the Application Performance
To enhance your comprehension, evaluate the system's performance using both async def
and def
while varying the number of workers. To study performance differences, use a smaller model. For example, test how fast the API server responds to requests.
Using curl, test how long the server takes to respond to a single HTTP POST request
$ curl -o /dev/null -w 'Total: %{time_total}s\n' -G http://127.0.0.1:8000/generate --data-urlencode "prompt=An astronaut landing on planet"
The above command tests the total time taken to receive a server response. This helps when testing the response time (without the effect of network latencies) of the server.
To evaluate how the server responds to concurrent requests, set up two additional SSH sessions, and issue the above curl command in quick succession per session. While the system processes the requests, use a system monitoring utility such as top
to view the number of threads and CPU in use. Take note of the time taken for each request to complete.
In this guide, you set up an API server to run inference using a Hugging Face Diffuser model and built an image generation API on a Vultr Cloud GPU Server. You built an API that utilizes the pre-trained Stable Diffusion 2.1 model and discovered how to serve any fine-tuned model on the server with minimal code adjustments.
More Information
To implement more solutions on your Vultr Cloud GPU server, visit the following resources:
