A container registry is a centralized storage and distribution system for container images, that enables users to store, manage, and retrieve images for deployment across different environments. Vultr Container Registry provides a reliable and scalable solution for storing container images and artifacts. It offers cost efficiency with a predictable pricing model and a user-friendly interface with straightforward configurations.
Migrating container registries from AWS Elastic Container Registry (ECR) to Vultr Container Registry requires a well-structured approach to ensure data integrity, uphold security, and reduce downtime for your active applications.
Follow this guide to migrate from AWS Elastic Container Registries to Vultr Container Registry.
Before migrating, ensure that the AWS CLI is installed and configured on your migration workstation and you have enough permissions to pull images from AWS Elastic Container Registry (ECR).
Log in to AWS Elastic Container Registry.
Replace <aws_account_id> with your AWS Account ID and <aws_region> with the AWS Region where your ECR is located.
List all the available ECR Repositories.
List all the image tags across all repositories.
The above command returns a list of all the image tags present in your AWS Elastic Container Registry (ECR) repositories.
Create a new pull_images_script.sh script using a text editor such as vim.
Add the following code to the pull_images_script.sh file. Replace <aws_account_id> with your AWS Account ID and <aws_region> with the AWS Region where your ECR is located.
Press Esc then : + W + Q and press enter to save and close the file.
The above script automates the process of pulling all the images from AWS Elastic Container Registry (ECR) along with their associated tags.
Grant the execution permission to the script.
Execute the script to pull all the images from ECR to your workstation.
Set up a Vultr Container Registry to store and manage your container images. Follow the steps below to create and configure your registry if not available in your account.
Log in to your Vultr Console.
Visit the Vultr Container Registry Documentation to provision a new container registry.
Select the newly created Vultr Container Registry.
In this example, the Vultr Registry's name is testvultrregistry.
Copy the registry URL from the Registry Details page.
Log in to Vultr Container Registry.
Replace <vultr_registry_url> with the URL of your Vultr Container Registry, <your_vultr_username> with your Vultr Registry username, and <your_vultr_password> with the Vultr Registry API Key.
You can migrate individual container images or entire repositories from AWS Elastic Container Registry (ECR) to Vultr Container Registry. Follow the steps below to migrate all repositories, including all tagged images, to Vultr Container Registry.
Create a new migrate_to_vultr.sh script using a text editor such as vim.
Add the following code to the migrate_to_vultr.sh file. Replace <aws_account_id> with your AWS Account ID, <aws_region> with the AWS Region and <vultr_registry_url> with your Vultr Registry URL.
The above script automates the process of pushing all the images to Vultr Container Registry along with their associated tags.
Replace <vultr_registry_url> with your actual Vultr Container Registry URL, eliminating the preceding https://.
Execute the migration script to push all the images to Vultr Container Registry.
Skopeo simplifies the migration process by allowing you to copy container images directly between AWS Elastic Container Registry (ECR) and Vultr Container Registry without pulling them to your local machine. This approach reduces disk space usage and speeds up the migration. Follow the steps below to install Skopeo on your workstation and migrate your repositories.
Before migrating your repositories, you need to install Skopeo. It’s a lightweight tool that makes image transfers seamless.
Update the server's APT package index.
Install Skopeo.
View the installed Skopeo version.
To migrate repositories, you need to authenticate with both AWS ECR and Vultr Container Registry. Follow the steps below to log in to the container registries.
Follow the steps below to migrate the container images using Skopeo and automate it using a script.
Skopeo Command Syntax:
Replace:
<aws_account_id>: Your AWS account ID.<aws_region>: Your AWS region.<repo_name>: The repository name.<tag>: The image tag.<vultr_registry_url>: Your Vultr Container Registry URL.Create a migrate_with_skopeo.sh script to automate the migration.
Add the following code to the migrate_with_skopeo.sh file. Replace <aws_account_id> with your AWS Account ID, <aws_region> with the AWS Region and <vultr_registry_url> with your Vultr Registry URL.
Verifying the integrity of migrated container images is essential to ensure a successful migration and prevent corruption during the migration process. Follow the steps below to verify that your images were transferred to the Vultr Container Registry. This includes listing the container images, checking their digests, running test containers to confirm functionality.
Visit the Vultr Container Registry page.
Select your registry.
Navigate to the Repositories tab.
In the above image, you can view all your container images that have been migrated to the Vultr Container Registry.
Verify image integrity with digests.
Each image has a unique SHA-256 digest, which you can compare between AWS ECR and the Vultr Container Registry to confirm they match. Follow the steps below to perform this check.
Retrieve the digest of an image stored in AWS ECR.
Pull the same image from the Vultr Container Registry using the correct tag.
Retrieve the digest of the same image stored in Vultr Container Registry.
In the example above, the image integrity has been preserved, meaning both digests are the same, indicating a successful transfer.
Run a test container to ensure the image functions as expected.
Cutting over to Vultr Container Registry after migrating your existing images allows you to seamlessly transition your applications and services. Follow the recommendations below after a successful migration to cut over your containers to Vultr Container Registry.
Update your Dockerfiles to use the Vultr Container Registry.
Before:
After:
Replace <vultr_registry_url> with the actual URL of your Vultr registry.
Update CI/CD pipelines to use the Vultr Container Registry.
Before (AWS ECR in GitHub Actions):
After (Vultr Container Registry in GitHub Actions):
Replace <vultr_registry_url> with the actual URL of your Vultr registry, and <your_vultr_username> and <your_vultr_password> with your actual Vultr credentials.
Redeploy your services to use the Vultr Container Registry.
Docker Compose.
Before: Update the app image URL.
After:
Redeploy the docker compose services.
Update the image under the container section in the definition to use Vultr Container Registry.
Before:
After:
Apply the changes made in the definition file.
You have migrated container images from AWS Elastic Container Registry (ECR) to Vultr Container Registry. This guide helps you with updating Dockerfiles, configuring CI/CD pipelines, and redeploying services using Docker Compose and Kubernetes. The migration process minimizes downtime, reduces costs, and streamlines your container management. For more information on managing your Vultr Container Registry, visit the Vultr Container Registry documentation.
