How to Securely Connect to Redis® with TLS/SSL in Go, NodeJS, PHP, Python, and redis-cli
![How to Securely Connect to Redis® with TLS/SSL in Go, NodeJS, PHP, Python, and redis-cli header image](https://docs.vultr.com/public/doc-assets/1455/7e27868b66a8083a.png)
Vultr Managed Database for Caching requires TLS/SSL connections in your source code or CLI. This article has code samples demonstrating how to connect securely with TLS/SSL with redis-cli
and popular programming languages.
How to Find your TLS/SSL Connection URL
To locate your Redis® connection URL, navigate to the Overview section of your Vultr Managed Database for Caching, then click Copy Redis® URL, which places it on your clipboard.
The URL is assembled from the username, password, host, and port values.
All the code in this article uses this example URL, which you should replace with your real one:
rediss://USERNAME:YOUR_PASSWORD@YOUR_HOST:PORT_NUMBER
Important: Note the double ss
in the protocol, rediss://
, which shows that the connection uses TLS/SSL encryption.
Connect with Go
First, get the go-redis/redis
library.
$ go get github.com/go-redis/redis/v8
Next, open a file named main.go
and paste the following. Replace the example Redis® URL with yours.
package main
import (
"context"
"fmt"
"github.com/go-redis/redis/v8"
var ctx = context.Background()
func main() {
redisURL := "rediss://USERNAME:YOUR_PASSWORD@YOUR_HOST:PORT_NUMBER"
addr, err := redis.ParseURL(redisURL)
if err != nil {
panic(err)
rdb := redis.NewClient(addr)
err = rdb.Set(ctx, "key", "Hello Vultr!", 0).Err()
if err != nil {
panic(err)
val, err := rdb.Get(ctx, "key").Result()
if err != nil {
panic(err)
fmt.Println("Value is:", val)
This creates a key named key
, with the value Hello Vultr!
. Then, it retrieves the key and prints its value.
To run this example:
$ go run main.go
Connect with NodeJS
First, install the ioredis
library.
$ npm install --save ioredis
Next, open a file named index.php
const Redis = require("ioredis");
const redisUrl = "rediss://USERNAME:YOUR_PASSWORD@YOUR_HOST:PORT_NUMBER"
const redis = new Redis(redisUrl);
redis.set("key", "Hello Vultr!");
redis.get("key").then(function (result) {
console.log(`Value is: ${result}`);
redis.disconnect();
$ node index.js
Connect with PHP
First, install the predis
library.
$ composer require predis/predis
<?php
require 'vendor/autoload.php';
Predis\Autoloader::register();
$redis_url = 'rediss://USERNAME:YOUR_PASSWORD@YOUR_HOST:PORT_NUMBER';
$client = new Predis\Client($redis_url);
$client->set('key', 'Hello Vultr!');
$value = $client->get('key');
echo "Value is: {$value}";
$ php index.php
Connect with Python
First, install the redis-py library.
$ pip install redis
Next, open a file named main.py
import redis
def main():
redis_client = redis.from_url(redis_url)
redis_client.set('key', 'Hello Vultr!')
key = redis_client.get('key').decode('utf-8')
print('Value is:', key)
if __name__ == '__main__':
main()
$ python main.py
Connect with redis-cli
First, you'll need to have redis-cli
installed.
- Option 1: Install
redis-cli
as part of the Redis® package for your operating system. - Option 2: Install the NodeJS standalone version of
redis-cli
Next, execute the following from a terminal window. Replace the example Redis® URL with yours.
$ redis-cli -u rediss://USERNAME:YOUR_PASSWORD@YOUR_HOST:PORT_NUMBER
To check the connection, run the INFO
command, which returns all the Redis® parameters.
INFO
More Information
These are only a few of the launguages and clients available for Redis® that support TLS/SSL. You'll find even more in the official documentation.
