Gollum is the Git-based wiki software used as the backend of the GitHub Wiki. Deploying Gollum will allow you to host a GitHub-like Wiki system on your server.
Interested? Great! Let's take a look at how to install Gollum on CentOS 7.
- A CentOS 7 x64 server instance.
- A sudo user.
- The
EPEL
yum repository.
1. Update the system
Log in to your server via SSH using the sudo user to install epel
, update the system, and restart to apply the updates.
sudo yum install epel-release -y
sudo yum update -y && sudo shutdown -r now
2. Install Gollum using gem
On CentOS 7, the easiest way to install Gollum is by using RubyGems:
sudo yum group install "Development Tools" -y
sudo yum install ruby ruby-devel libicu libicu-devel zlib zlib-devel git -y
sudo gem install gollum
Note: The gem install
command above may take a while to complete. If you are in hurry, you can accelerate the installation by skipping documents as follows. You can also run it in a screen
session
sudo gem install --no-rdoc --no-ri gollum
The Gollum binary will be installed into your system at /usr/local/bin/gollum
, and you can confirm whether or not the installation was a success by running the simple command below:
gollum --v
3. Setup a Gollum wiki
All you need to do to setup a Gollum Wiki is to create a git repository and run the gollum
command inside it:
cd
mkdir my-wiki
cd my-wiki
git init
gollum
Note: When necessary, you can use Ctrl+C
to exit Gollum.
4. Allow web access
Before you can visit your Gollum wiki site in your web browser, you need to modify firewall rules as follows:
sudo firewall-cmd --zone=public --permanent --add-port=4567/tcp
sudo firewall-cmd --reload
5. Access Gollum from web
While Gollum is running, point your web browser to http://203.0.113.1:4567
to start creating the first Gollum wiki page. Feel free to create more wiki pages there, and all the pages your create will be saved as .md
files in current git repo directory.
6. Create or edit Gollum wiki pages from CLI
Apart from creating or modifying pages from a web browser, you can also create or edit pages from the CLI. To do that, you only need to create .md
files in accordance with the MarkDown syntax, and then commit them to the git repo:
cd ~/my-wiki
vi page1.md
git config --global user.email "admin@example.com"
git config --global user.name "admin"
git add page1.md
git commit -m "create page1"
That's it. To learn more about Gollum, type gollum --help
to check out the Gollum help or pay a visit to official Gollum website.
