Using Vault with Kubernetes Authentication
Using Vault with Kubernetes Authentication header image
This guide will walk you through configuring HashiCorp Vault running on a VKE cluster to exchange service accounts for a scoped client Vault token. This can be useful when you want your services running on a Kubernetes cluster to self-authenticate against Vault without the need to pass around Vault credentials.
Before you begin, you should have the following:
  • A running VKE cluster
  • HashiCorp Vault installed with the Web UI started
  • Kubernetes administration experience
Auth Delegators
The first thing you want to set up is a ClusterRoleBinding that has a roleRef which uses system:auth-delegator
This role allows delegated authentication and authorization checks. Add-on API servers commonly use this for unified authentication and authorization.
apiVersion: rbac.authorization.k8s.io/v1beta1
kind: ClusterRoleBinding
    namespace: default
roleRef:
    apiGroup: rbac.authorization.k8s.io
    kind: ClusterRole
subjects:
- kind: ServiceAccount
    namespace: default
Note: Change the namespace to something more appropriate than default.
Next, create a service account which will get bound to this ClusterRoleBinding. Ensure the ServiceAccount namespace matches the ServiceAccount specified in the ClusterRoleBinding.
    namespace: default
Required information
Before you continue to set up Vault, gather some extra data from the cluster and the newly created service account. In your terminal, collect the following information in your environment.
Service Account Token
$ export VAULT_SA_NAME=$(kubectl get sa vault-auth --output jsonpath="{.secrets[*]['name']}")
Service Account JWT
$ export SA_JWT_TOKEN=$(kubectl get secret $VAULT_SA_NAME --output 'go-template={{ .data.token }}'| base64 --decode)
Service Account CA CRT
$ export SA_CA_CRT=$(kubectl config view --raw --minify --flatten --output 'jsonpath={.clusters[].cluster.certificate-authority-data}' | base64 --decode)
K8 Hostname
$ export K8S_HOST=$(kubectl config view --raw --minify --flatten --output 'jsonpath={.clusters[].cluster.server}')
JWT Issue
If the cluster is on VKE 1.21+, you must pass the following:
https://kubernetes.default.svc
This is required for version 1.21 and later because those versions use a different auth method.
Vault Setup
Now you can set up your Kubernetes auth on Vault.
  1. Connect to the Vault Web UI.
  2. In the Access section, click enable new method to navigate to a selection screen.
  3. Click Kubernetes.
  4. The path that you should use is kubernetes. This is the default path, and there is no need to change it unless you want to add a different Kubernetes auth engine.
  5. On the next page, fill in three fields:
  • Kubernetes Host: equal to echo ${K8S_HOST}
  • Kubernetes SA CA Certificate: equal to echo ${SA_CA_CRT}
  • Token Reviewer JWT (in Kubernetes Options): equal to echo ${SA_JWT_TOKEN}
With this configured, there is now an accessible v1/auth/kubernetes/login endpoint. This is where your services must send requests to get a client token.
Role Setup
Policies and roles are created on a per-service basis. Here is an example of the setup required to get a scoped client token.
Policy creation
Go to the Policies section of Vault and click create ACL Policy. Then, give it a name and a policy. Here is an example policy for a path that would already exist on Vault. Note that these paths must be created as new engines.
path "my-app/*" {
    capabilities = ["read", "list"]
Service Account
While every namespace has a default service account that gets attached to a pod if you do not provide one, we will create one for the sake of this guide and the want/need to scope pods to Vault ACLs.
kubectl create sa {MY SA NAME} -n {NAMESPACE}
To assign this service account to your pods that will interact with Vault, define the serviceAccountName field in your spec definition.
    serviceAccountName: {MY SA NAME}
In the Vault access section, click view configuration on your Kubernetes auth, leading to a page with two tabs. Click the Roles tab, then Create Role. Complete the form with the following:
  • Name: The name of this role. A good choice is the name of the service that uses it.
  • Bound service account names: The service account name.
  • Bound service account namespace: The namespace that the service account lives in.
  • Generated Tokens Policies: Name of the policy to use.
Service integration
Now, your services have scoped identities and no longer require the root client token to be passed to them. Instead, you will have to set up the services to call /v1/auth/kubernetes/login with a JSON body that consists of role and jwt.
  • Role: Name of role on Vault.
  • JWT: The service account token that is mounted to the pod. This can be found at /run/secrets/kubernetes.io/serviceaccount/token inside of the pod.
Wrapping up
After successful validation, Vault returns a JSON body describing your auth status, which includes your scoped client token. This eliminates the need to store any information within your applications about Vault, as it is entirely driven by the native login functionality of VKE.
To learn more about Vault and Kubernetes auth, see these resources.
