The Vultr Load Balancer is a fully managed solution to distribute traffic across multiple backend servers. If you are new to Vultr Load Balancers, we recommend reading the Load Balancer Quickstart Guide first.
In this guide, you'll learn the details of each Vultr virtual Load Balancer feature and how to configure them. Features are listed alphabetically.
You'll find this feature in two places; it's in the Load Balancer Configuration section of the Add Load Balancer page, and also on the Configuration menu of the Manage Load Balancer page.
There are two available load balancer types for the algorithm:
This is an optional feature. Vultr Load Balancers can define an internal firewall with similar capabilities to the stand-alone Vultr Firewall. You'll find this feature in two places; it's on the Add Load Balancer page, and also on the Networking menu of the Manage Load Balancer page.
Add firewall rules to the load balancer if you need to restrict the forwarding rule traffic.
Note: Ports 65300 to 65310 are not available because they are used internally by the load balancer.
If you enter cloudflare as your source instead of an IP address range, the load balancer firewall will automatically allow Cloudflare IPs.
This will force all HTTP traffic to redirect to HTTPS. Before setting this option, install an SSL certificate on the load balancer and configure HTTPS forwarding.
You'll find this feature in two places; it's on the Add Load Balancer page, and also on the Configuration tab of the Manage Load Balancer page.
Forwarding rules define how to map a Load Balancer port to an Instance port. You may choose HTTP, HTTPS, or TCP protocol. For example, you can forward HTTP port 80 on the load balancer to port 8000 on the instances. You'll find this feature in two places; it's on the Add Load Balancer page, and also on the Forwarding Rules menu of the Manage Load Balancer page.
You can create a maximum of 15 forwarding rules.
Load balancers support HTTPS via two methods: You can either install your SSL certificate on the load balancer or install the certificate on each instance and transparently pass the session via TCP. Choose the option appropriate for your situation.
In this configuration, users connect to the load balancer via HTTPS, and the load balancer proxies the connection to the instances. This is known as SSL Offloading or SSL Termination.
Choose HTTPS protocol for the load balancer. The configuration screen prompts you to install the SSL certificate.
The instance protocol can be HTTPS or HTTP, depending on your requirements.
In this configuration, the load balancer performs SSL Passthrough, which passes the TCP session to the instances for HTTPS handling.
Choose TCP protocol for the load balancer and install your SSL certificate on each backend instance.
Health checks verify that your instances are healthy and reachable. If an instance fails the health check, the load balancer cuts traffic to that instance.
You'll find this feature in two places; it's on the Add Load Balancer page, and also on the Health Checks menu of the Manage Load Balancer page.
Use these parameters to configure a health check.
Valid protocols are HTTP, HTTPS, and TCP.
The TCP, HTTP, or HTTPS port to test.
The default interval between health checks is 15 seconds.
The number of seconds the virtual Load Balancer waits for a response. If no response is received before the timeout, the health check fails. The default value is five seconds.
The number of times an instance must consecutively fail a health check before the Load Balancer stops forwarding traffic to it. The default value is five failures.
Failures must be consecutive before the load balancer considers the instance unhealthy. For example, if the Unhealthy Threshold is five, and the instance fails four times, then succeeds one time, then fails four times, the instance is still considered healthy.
The number of times an instance must consecutively pass a health check before the Load Balancer forwards traffic to it. The default value is five successes.
The instance must pass the health check this many times, consecutively. For example, if the Healthy Threshold is five, and the unhealthy instance succeeds four times, then fails one time, then succeeds four times, the instance is still considered unhealthy.
The HTTP path that the load balancer should test.
/. -_%+.=&/For example, if your instances have a test page at:
... then your HTTP path should be set to:
This is a descriptive label that identifies your load balancer.
You'll find this feature in the Load Balancer Configuration section.
This is the first option listed on the Add Load Balancer page. The load balancer must be in the same location as the cloud servers you connect to it. You can filter the location list by continent.
Metrics are available after your load balancer has been running for a few minutes. You can view your metrics on the Metrics tab of the Manage Load Balancer page.
On the Overview tab of the Manage Load Balancer page, you'll find the following information, starting at the top of the page:
You can attach and detach your instances to the load balancer from this page.
Proxy Protocol forwards client information to the backend nodes. If this feature is enabled, you must configure your backend nodes to accept Proxy protocol. For more information, see the Proxy Protocol documentation.
If you have added an HTTPS forwarding rule, you can add an SSL certificate to your load balancer. Enter your Private Key, Certificate, and Certificate Chain in this section. If you are using a Let's Encrypt certificate, you should have three files: privkey.pem, cert.pem, and chain.pem. Copy your certificate files into the fields as shown.
privkey.pem to the Private Key field.cert.pem to the Certificate field.chain.pem to the Certificate Chain field.For more information, see our article Use a Wildcard Let's Encrypt Certificate with Vultr Load Balancer.
You'll find this feature in two places; on the Add Load Balancer page, and also on the SSL Certificate menu of the Manage Load Balancer page.
Vultr allows you to create a reverse DNS record for your load balancer. Reverse DNS uses PTR records to map an IP address to a Fully Qualified Domain Name (FQDN). Setting reverse DNS is important for SMTP mail servers. However, the majority of other applications don't need to worry about this DNS record.
To set reverse DNS for your load balancer:
Some applications require users to continue to connect to the same backend server. You must supply a cookie name when configuring sticky sessions.
The load balancer uses application-controlled session persistence for sticky sessions. Your application generates a cookie that determines the duration of session stickiness. The load balancer still issues its session cookie on top of it, but it now follows the lifetime of the application cookie.
This makes sticky sessions more efficient, ensuring that users are never routed to a server after their local session cookie has already expired. However, it's more complex to implement because it requires additional integration between the load balancer and the application.
The VPC option allows you to change the network interface of the load balancer. If your instances are attached to a VPC, you can elect to forward traffic via the VPC instead of the public network. Changing the network interface will briefly disrupt network connections to the instances.
The Vultr API offers several Load Balancer management endpoints.
