How to Apply Kubernetes Policies Using Kyverno
How to Apply Kubernetes Policies Using Kyverno header image
Kyverno is a Kubernetes tool that validates resources and tests Kubernetes policies. This tool is essential because it blocks objects that do not meet the set policy requirements from being applied to the cluster. In addition, it enables you to mutate objects that do not have metadata information, such as labels.
In this tutorial, you will learn how to install Kyverno and apply Kubernetes policies and rules using Kyverno.
You need:
What Are Kubernetes Policies and Rules?
Kubernetes policies are a group of rules that enforce cluster security compliance and best practices. Policies add the governance layer in Kubernetes as they enable Kubernetes administrators to choose what end users can apply to the cluster. They block manifests that are not compliant when someone tries to apply them to the cluster. Policies can be applied at the cluster level or namespace level. There are different kinds of policies in Kubernetes. Here are examples of Kubernetes policies:
  • Network policies
  • Volume policies
  • Resource usage and consumption policies
  • Access control policies
  • Security policies
How to Install and Set Up Kyverno
  1. Use the following command to install Kyverno using Kubectl:
     $ kubectl create -f https://raw.githubusercontent.com/kyverno/kyverno/release-1.5/definitions/release/install.yaml
  2. After successfully installing the Kyverno plugin, you will have to apply Kyverno policies using the kubectl apply command. However, Kyverno has a CLI that you can use; instead of using the kubectl apply command, you will use the kubectl kyverno apply command. This tutorial will detail how to use these commands in the next sections. Use the following command to install Kyverno CLI:
      $ kubectl krew install kyverno
  3. You will get the following output:
     Updated the local copy of plugin index.
     Installing plugin: kyverno
     Installed plugin: kyverno
      | Use this plugin:
      |      kubectl kyverno
      | Documentation:
      |      https://github.com/kyverno/kyverno
      | Caveats:
      |  | The plugin requires access to create Policy and CustomResources
  4. Use the following command to check if Kyverno was installed successfully and also to see the details of the Kyverno namespace:
     $ kubectl get all -n kyverno
  5. You will get the following output that shows you the details of the Kyverno namespace created when installing Kyverno:
     NAME                           READY   STATUS    RESTARTS   AGE
     pod/kyverno-56646d79c4-sgp99   0/1     Running   0          19s
     NAME                          TYPE        CLUSTER-IP       EXTERNAL-IP   PORT(S)    AGE
     service/kyverno-svc           ClusterIP   10.107.200.47    <none>        443/TCP    22s
     service/kyverno-svc-metrics   ClusterIP   10.101.157.245   <none>        8000/TCP   23s
     NAME                      READY   UP-TO-DATE   AVAILABLE   AGE
     deployment.apps/kyverno   0/1     1            0           22s
     NAME                                 DESIRED   CURRENT   READY   AGE
     replicaset.apps/kyverno-56646d79c4   1         1         0       21s
  6. Use the following command to know more about the Kyverno pod configurations and details:
     $ kubectl describe pod -l app=kyverno -n kyverno
Kyverno can be used to check if the resource being applied to the cluster has the optimum resource limits set in the policy. Here is a Kyverno policy that validates pods based on resource limits; all pods being created in the cluster will have a CPU resource limit of 200m and a memory limit of 1Gi. If a certain pod exceeds these limits, it will be blocked. Create a YAML file and add the following contents:
    apiVersion: kyverno.io/v1
    kind: ClusterPolicy
      namespace: earth
      validationFailureAction: enforce
      - name: validate-resource-limits
        match:
          resources:
            kinds:
            - Pod
        validate:
          message: "Please make sure that you have resource limits with a max of 200m of CPU and 1Gi of memory."
          pattern:
              - resources:
                  limits:
                    memory: "<=1Gi"
                    cpu: "<=200m"
Apply the above policy using the following command:
    $ kubectl apply -f kyverno-policy.yaml
    clusterpolicy.kyverno.io/require-pod-requests-and-limits created
The Kyverno policy you just created has enforced the validationFailureAction field, which will block the resource being applied to the cluster if Kyverno validation fails. The resource map states what resources will be validated by Kyverno policies. In this case, the require-pod-requests-and-limits policy will be applied to pods only.
The message field carries the message that will be displayed when a resource has been blocked from being applied to the cluster:
Use the following command to see all policies that have been created successfully:
    $ kubectl get clusterpolicies
You will get the following output if the policy has been created successfully:
    NAME                              BACKGROUND   ACTION    READY
    require-pod-requests-and-limits   true         enforce   true
Because the require-pod-requests-and-limits policy has been created successfully, test it by creating a pod that has resource limits that pass the resource limits set in the previous policy:
    kind: Pod
      namespace: earth
      - name: nginx
        image: nginx:1.14.2
        - containerPort: 80
        resources:
          requests:
            memory: "64Mi"
            cpu: "100m"
          limits:
                  memory: "2Gi"
                  cpu: "100m"
Apply the above pod to your cluster using the following command:
          $ kubectl apply -f new-pod.yaml
You will get the following error message that shows that the pod has exceeded the resource limits set by Kyverno; the pod was supposed to have a memory limit of 1Gi as stated in the previous policy, but it had a memory limit of 2Gi:
          Error from server: error when creating "new-pod.yaml": admission webhook "validate.kyverno.svc-fail" denied the request:
          resource Pod/earth/nginx was blocked due to the following policies
          require-pod-requests-and-limits:
            validate-resource-limits: 'validation error: Please make sure that you have resource
              limits with a max of 200m of CPU and 1Gi of memory. Rule validate-resource-limits
              failed at path /spec/containers/0/resources/limits/cpu/'
Kyverno Mutations
Suppose a certain resource is applied to a cluster that does not have necessary labels or an ImagePolicy. You can patch the resource using a Kyverno mutation. In this tutorial, you will learn how to add labels to objects being applied to the cluster using Kyverno mutations.
Create a YAML file for a policy and add the following contents that will add labels to objects that do not have the author and state labels:
          kind: ClusterPolicy
            - name: add-labels
              match:
                resources:
                  kinds:
                  - Pod
                  - Service
                  - ConfigMap
                  - Secret
              mutate:
                patchStrategicMerge:
                      author: boemo
                      state: average
The above policy will be applied at the cluster level because it uses the ClusterPolicy kind. The labels will be added to the following objects that do not have the labels:
  • Pod
  • Service
  • ConfigMap
  • Secret
The patchStrategicMerge map contains the labels you want to add to your cluster. You can even add labels such as color and deadline. In this case, add the author label, which will state the name of the author who wrote the manifest, and the state label, which will specify the state and quality of the cluster.
$ kubectl apply -f labels.yaml
clusterpolicy.kyverno.io/add-labels created
Create a service that will be mutated by the policy you just created previously:
            namespace: default
            type: LoadBalancer
            - name: boemo-app-http
              protocol: TCP
              targetPort: 80
              app: boemo-app
Apply the above service. If you describe the above service using the following command:
$ kubectl describe service boemo-app
You will get the following output that shows that the service you created has new labels added by the add-labels policy:
          Namespace:                default
          Labels:                   author=boemo
                                    state=average
          Annotations:              policies.kyverno.io/last-applied-patches: add-labels.add-labels.kyverno.io: added                             /metadata/labels
          Selector:                 app=boemo-app
          Type:                     LoadBalancer
          IP Family Policy:         SingleStack
          IP Families:              IPv4
          IP:                       10.104.227.203
          IPs:                      10.104.227.203
          Port:                     boemo-app-http  80/TCP
          TargetPort:               80/TCP
          NodePort:                 boemo-app-http  31850/TCP
          Endpoints:                <none>
          Session Affinity:         None
          External Traffic Policy:  Cluster
          Events:                   <none>
How to Use the Kyverno CLI
The Kyverno CLI validates and tests resources that are outside of the cluster. Use the following command to validate resources using Kyverno policy:
$ kubectl kyverno apply [add kyverno policy yaml here] --resource [add the yaml file you want to validate here]
For example, test the previous pod using the require-pod-requests-and-limits policy you created earlier on:
$ kubectl kyverno apply kyverno-policy.yaml --resource new-pod.yaml
You will get the following output if the resource does not violate the Kyverno policy:
          Applying 1 policy to 1 resource...
          (Total number of result count may vary as the policy is mutated by Kyverno. To check the mutated policy please try               with log level 5)
          pass: 1, fail: 0, warn: 0, error: 0, skip: 2
If your resource violates the Kyverno policy you will get the following output:
          policy require-pod-requests-and-limits -> resource earth/Pod/nginx failed:
          1. validate-resource-limits: validation error: Please make sure that you have resource limits with a max of 200m of               CPU and 1Gi of memory. Rule validate-resource-limits failed at path /spec/containers/0/resources/limits/memory/
          pass: 0, fail: 1, warn: 0, error: 0, skip: 2
          Error: exit status 1
Learn More
To learn more about Kyverno, see the project documentation.
