Nuxt.js is an open-source server-side framework based on Vue.js, Node.js, and Babel.js. It acts as the backbone of your Vue.js project to offer a structure to build your project and deploy it on a serverless platform. However, to deploy your Nuxt.js application to a controlled server and scale it in your infrastructure, use a Kubernetes platform such as the Vultr Kubernetes Engine (VKE) to deploy, manage, automate, and scale containerized applications.
This article explains how to deploy a Nuxt.js application on a Vultr Kubernetes Engine (VKE) cluster. You will prepare the application, dockerize, deploy it to a cluster, and expose it for external access.
- Deploy a Vultr Kubernetes Engine (VKE) cluster with at least three nodes.
- Install Kubectl on your local machine to access the cluster.
- Install Docker on your local machine.
Create a Nuxt.js Application
To create a Nuxt.js application, you must install Node.js on your local machine and use it to enable Nuxt.js as described below.
Import the Node source repository.
$ curl -sL https://deb.nodesource.com/setup_18.x -o nodesource_setup.sh && sudo bash nodesource_setup.sh
Install Node.js.
$ sudo apt install nodejs
Verify the installed Node.js version.
$ node -v
v18.16.0
Nuxt.js has a built-in tool
create-nuxt-app
that lets you create a Nuxt.js app. Using thenpx
command, create a new application callednuxtjs-tutorial
as below.$ npx create-nuxt-app nuxtjs-tutorial
Need to install the following packages: create-nuxt-app@5.0.0 Ok to proceed? (y)
Reply to each of the Installation prompts as below:
create-nuxt-app v5.0.0 ✨ Generating Nuxt.js project in nuxtjs-tutorial ? Project name: nuxtjs-tutorial ? Programming language: JavaScript ? Package manager: Npm ? UI framework: None ? Template engine: HTML ? Nuxt.js modules: (Press <space> to select, <a> to toggle all, <i> to invert selection) ? Linting tools: (Press <space> to select, <a> to toggle all, <i> to invert selection) ? Testing framework: None ? Rendering mode: Universal (SSR / SSG) ? Deployment target: Server (Node.js hosting) ? Development tools: (Press <space> to select, <a> to toggle all, <i> to invert selection) ? What is your GitHub username? YOUR_GITHUB_ID ? Version control system: None
When successful, change to the application directory.
$ cd nuxtjs-tutorial
Build the application for production use.
$ HOST=0.0.0.0 PORT=3000 npm run build
Start the Nuxt.js Application in the background.
$ HOST=0.0.0.0 PORT=3000 npm run start &
Your output should look like the below:
╭──────────────────────────────────────────╮ │ │ │ Nuxt @ v2.17.0 │ │ │ │ ▸ Environment: production │ │ ▸ Rendering: server-side │ │ ▸ Target: server │ │ │ │ Memory usage: 48.5 MB (RSS: 142 MB) │ │ │ │ Listening: http://192.0.2.1:3000/ │ │ │ ╰──────────────────────────────────────────╯
In a web browser such as Chrome, verify that you can access the Nuxt.js application dashboard.
Dockerize Nuxt.js Application
In this section, create a new container image from your Nuxt.js application to deploy it in your Vultr Kubernetes Engine (VKE) cluster as described below.
In the Nuxt.js application directory, create a Dockerfile.
$ nano Dockerfile
# Dockerfile FROM node:16-alpine # create the destination directory RUN mkdir -p /usr/src/nuxtapp WORKDIR /usr/src/nuxtapp # update and install dependency packages RUN apk update && apk upgrade RUN apk add git # copy the app, note .dockerignore COPY . /usr/src/nuxtapp/ RUN npm install RUN npm run build EXPOSE 3000 ENV NUXT_HOST=0.0.0.0 ENV NUXT_PORT=3000 CMD [ "npm", "start" ]
The above configuration has the following key components:
FROM
: Specifies the underlying OS architecture to build the image.RUN
: Runs the specified command in the container.WORKDIR
: Define the working directory of a Docker container at a given point of time.COPY
: Makes a copy of all application files from the local machine to the docker image.EXPOSE
: Expose the docker port for the external access.ENV
: Defines the required environment variables before starting the application.CMD
: Executes the specified command inside the container.
Create a docker image using the
docker build
command.$ sudo docker build -t nuxtjs-tutorial .
When successful, check the created image and its size.
$ sudo docker images
REPOSITORY TAG IMAGE ID CREATED SIZE nuxtjs-tutorial latest a23b9414f800 20 seconds ago 256MB
To run the docker container on port
3000
. Kill the previous application background process.$ sudo kill %1
Verify the PID before killing the process using the
jobs
command.$ jobs
Run the container you have just built using Docker:
$ sudo docker run -dit -p 3000:3000 nuxtjs-tutorial
The above command runs the container and forwards the exposed port 3000 to port 3000 on your local machine.
Verify the status of the running container.
$ sudo docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES 0dcd861eab96 nuxtjs-tutorial "docker-entrypoint.s…" 6 seconds ago Up 5 seconds 0.0.0.0:3000->3000/tcp, :::3000->3000/tcp musing_montalcini
In a web browser, verify that you can access the Nuxt.js application using the URL
http://127.0.0.1:3000
in your web browser.
Build Nuxt.js Docker Image and Push it to DockerHub Registry
To use your Nuxt.js docker image in Kubernetes, push the image to DockerHub. To complete the steps in this section, make sure you have a Docker Hub profile to push the application.
Stop the running
nuxtjs-tutorial
docker container.$ docker container stop [nuxtjs-container-id or name]
Log in to your DockerHub account.
$ docker login
When prompted, enter your DockerHub credentials to build and push the image. Your output should look like the one below.
Login with your Docker ID to push and pull images from Docker Hub. If you don't have a Docker ID, head over to https://hub.docker.com to create one. Username: example-user Password: YOUR_DOCKER_HUB_PASSWORD Login Succeeded
Tag the Docker Image with your Docker Hub ID.
$ sudo docker tag nuxtjs-tutorial <example-user>/nuxtjs-tutorial:latest
Push the image to Docker Hub. Replace
example-user
with your actual username.$ sudo docker push example-user/nuxtjs-tutorial:latest
Verify that your tagged image exists.
$ docker images
REPOSITORY TAG IMAGE ID CREATED SIZE nuxtjs-tutorial latest a23b9414f800 2 minutes ago 256MB example-user/nuxtjs-tutorial latest a23b9414f800 2 minutes ago 256MB node 16-alpine d22e42cbfdbb 18 hours ago 118MB
Run the docker image to verify that it can render your Nuxt.js application.
$ sudo docker run --rm -d -p 3000:3000 example-user/nuxtjs-tutorial
In your web browser, access port
3000
to access the application. For example:http://127.0.0.1:3000
Deploy the Nuxt.js Application on a VKE Cluster
Create a new
deployment.yaml
file.$ nano deployment.yaml
kind: Deployment apiVersion: apps/v1 metadata: name: nuxtjs-tutorial spec: replicas: 3 selector: matchLabels: app: nuxtjs-tutorial template: metadata: labels: app: nuxtjs-tutorial spec: containers: - name: nuxtjs-tutorial image: example-user/nuxtjs-tutorial:latest ports: - containerPort: 80
Apply the deployment to your cluster.
$ kubectl apply -f deployment.yaml
Verify the deployment status.
$ kubectl get deployment
NAME READY UP-TO-DATE AVAILABLE AGE nuxtjs-tutorial 3/3 3 3 33s
Verify the pods created by your deployment.
$ kubectl get pods
NAME READY STATUS RESTARTS AGE nuxtjs-tutorial-74c8cd8584-hsrr7 1/1 Running 0 82s nuxtjs-tutorial-74c8cd8584-j8hbv 1/1 Running 0 82s nuxtjs-tutorial-74c8cd8584-kcs55 1/1 Running 0 82s
As displayed in the above output, the first Pod name is
.Check the pod logs of your running application using the
kubectl logs
command.$ kubectl logs nuxtjs-tutorial-74c8cd8584-hsrr7
Verify that your Nuxt.js application is running on three pods on port
3000
as below.> nuxtjs-tutorial@1.0.0 start > nuxt start ℹ Listening on: http://10.244.152.66:3000/
To access the application on your local machine, port forward the pod to your host port
3002
as below:$ kubectl port-forward nuxtjs-tutorial-74c8cd8584-hsrr7 3002:3000 &
Forwarding from 127.0.0.1:3002 -> 3000 Forwarding from [::1]:3002 -> 3000
You can now access your Nuxt.js application using the URL
http://localhost:3002
from your local machine.
Expose the Nuxt.js Application for External Access
Your Nuxt.js application is deployed on the Vultr Kubernetes Engine cluster. However, it can be accessed only from your local machine through port forwarding. In this section, create a Service
resource to expose your application to the outside world.
Create a new
service.yaml
file.$ nano service.yaml
apiVersion: v1 kind: Service metadata: name: load-balancer labels: app: nuxtjs-tutorial spec: type: LoadBalancer ports: - port: 80 targetPort: 3000 protocol: TCP nodePort: 32000 selector: app: nuxtjs-tutorial
Apply your configuration to the Kubernetes cluster.
$ kubectl apply -f service.yaml
Run the following command to get the IP Address of the new Load Balancer created for the Nuxt.js application.
$ kubectl get services
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE kubernetes ClusterIP 10.96.0.1 <none> 443/TCP 16m load-balancer LoadBalancer 10.100.199.83 203.0.113.1 80:32000/TCP 3m5s
Verify that the Load Balancer has a public IP address as displayed in the above output.
In your web browser, access your Nuxt.js application using the Load Balancer IP. Replace the example IP
203.0.113.1
with your actual Address.http://203.0.113.1
Scale the Nuxt.js Deployment
To efficiently handle incoming traffic and avoid any pod failures, scale the number of replicas for your Nuxt.js deployment depending on your needs as described below.
View the number of replicas for your Nuxt.js deployment.
NAME READY UP-TO-DATE AVAILABLE AGE nuxtjs-tutorial 3/3 3 3 5m49s
As per the above output, the Nuxt.js deployment has three replicas.
To increase the number of replicas to 10, run the following command.
$ kubectl scale --replicas=10 deployment/nuxtjs-tutorial
Verify the changes.
NAME READY UP-TO-DATE AVAILABLE AGE nuxtjs-tutorial 10/10 10 10 12m
Verify the number of running Pods.
$ kubectl get pods
NAME READY STATUS RESTARTS AGE nuxtjs-tutorial-74c8cd8584-55m8j 1/1 Running 0 25s nuxtjs-tutorial-74c8cd8584-886k5 1/1 Running 0 25s nuxtjs-tutorial-74c8cd8584-hsrr7 1/1 Running 0 12m nuxtjs-tutorial-74c8cd8584-j8hbv 1/1 Running 0 12m nuxtjs-tutorial-74c8cd8584-kcs55 1/1 Running 0 12m nuxtjs-tutorial-74c8cd8584-p69qg 1/1 Running 0 25s nuxtjs-tutorial-74c8cd8584-qwtp8 1/1 Running 0 25s nuxtjs-tutorial-74c8cd8584-sngfh 1/1 Running 0 25s nuxtjs-tutorial-74c8cd8584-t5n75 1/1 Running 0 25s nuxtjs-tutorial-74c8cd8584-zpzlg 1/1 Running 0 25s
To view detailed information about your deployment, run the following command.
$ kubectl describe deployments nuxtjs-tutorial
Name: nuxtjs-tutorial Namespace: default CreationTimestamp: Fri, 23 Jun 2023 07:36:46 +0530 Labels: <none> Annotations: deployment.kubernetes.io/revision: 1 Selector: app=nuxtjs-tutorial Replicas: 10 desired | 10 updated | 10 total | 10 available | 0 unavailable StrategyType: RollingUpdate MinReadySeconds: 0 RollingUpdateStrategy: 25% max unavailable, 25% max surge Pod Template: Labels: app=nuxtjs-tutorial Containers: nuxtjs-tutorial: Image: example-user/nuxtjs-tutorial:latest Port: 80/TCP Host Port: 0/TCP Environment: <none> Mounts: <none> Volumes: <none> Conditions: Type Status Reason ---- ------ ------ Progressing True NewReplicaSetAvailable Available True MinimumReplicasAvailable OldReplicaSets: <none> NewReplicaSet: nuxtjs-tutorial-74c8cd8584 (10/10 replicas created) Events: Type Reason Age From Message ---- ------ ---- ---- ------- Normal ScalingReplicaSet 16m deployment-controller Scaled up replica set nuxtjs-tutorial-74c8cd8584 to 3 Normal ScalingReplicaSet 4m43s deployment-controller Scaled up replica set nuxtjs-tutorial-74c8cd8584 to 10 from 3
View detailed information about your replicas.
$ kubectl describe replicasets
Name: nuxtjs-tutorial-74c8cd8584 Namespace: default Selector: app=nuxtjs-tutorial,pod-template-hash=74c8cd8584 Labels: app=nuxtjs-tutorial pod-template-hash=74c8cd8584 Annotations: deployment.kubernetes.io/desired-replicas: 10 deployment.kubernetes.io/max-replicas: 13 deployment.kubernetes.io/revision: 1 Controlled By: Deployment/nuxtjs-tutorial Replicas: 10 current / 10 desired Pods Status: 10 Running / 0 Waiting / 0 Succeeded / 0 Failed Pod Template: Labels: app=nuxtjs-tutorial pod-template-hash=74c8cd8584 Containers: nuxtjs-tutorial: Image: example-user/nuxtjs-tutorial:latest Port: 80/TCP Host Port: 0/TCP Environment: <none> Mounts: <none> Volumes: <none> Events: Type Reason Age From Message ---- ------ ---- ---- ------- Normal SuccessfulCreate 17m replicaset-controller Created pod: nuxtjs-tutorial-74c8cd8584-hsrr7 Normal SuccessfulCreate 17m replicaset-controller Created pod: nuxtjs-tutorial-74c8cd8584-j8hbv Normal SuccessfulCreate 17m replicaset-controller Created pod: nuxtjs-tutorial-74c8cd8584-kcs55 Normal SuccessfulCreate 5m32s replicaset-controller Created pod: nuxtjs-tutorial-74c8cd8584-sngfh Normal SuccessfulCreate 5m32s replicaset-controller Created pod: nuxtjs-tutorial-74c8cd8584-886k5 Normal SuccessfulCreate 5m32s replicaset-controller Created pod: nuxtjs-tutorial-74c8cd8584-p69qg Normal SuccessfulCreate 5m32s replicaset-controller Created pod: nuxtjs-tutorial-74c8cd8584-qwtp8 Normal SuccessfulCreate 5m32s replicaset-controller Created pod: nuxtjs-tutorial-74c8cd8584-t5n75 Normal SuccessfulCreate 5m32s replicaset-controller Created pod: nuxtjs-tutorial-74c8cd8584-55m8j Normal SuccessfulCreate 5m32s replicaset-controller Created pod: nuxtjs-tutorial-74c8cd8584-zpzlg
In this article, you have created a Nuxt.js application, containerized it, and deployed it on a Vultr Kubernetes Engine (VKE) cluster. For more information about Nuxt.js, visit the official documentation.
