Vultr Push Zones offers a solution for efficiently delivering static assets to users across the globe. By leveraging Vultr Content Delivery Network (CDN), Push Zones ensure that your files are distributed and cached on servers strategically placed around the world, reducing latency and improving load times. This makes them an ideal choice for websites and applications that need to serve images, videos, scripts, and other static files to a large audience with minimal delay.
In this article, you'll be setting up a Vultr Push Zone. You'll cover everything from creating a Push Zone and uploading your assets to configuring a webpage to serve these static assets. Additionally, you'll be setting up Nginx for optimal performance, applying SSL for secure access, and accessing your content via a URL.
Deploy an Ubuntu 24.04 server instance on Vultr.
Set up your domain A record pointing to the server IP address.
Open the Vultr Console.
Click CDN within the Products navigation menu.
Click Push Zone to set up CDN Push Zones.
Click Add CDN to add the Push Zones
Enter a descriptive name in the Label field to identify your Vultr CDN resource. For example my_cdn.
Select optional CDN features to enable on your Vultr CDN URL.
Click Add CDN Push Zone to create your Vultr CDN Push Zone endpoint.
Manage your CDN Push Zone.
Click on Files to upload your static asset.
Upload a static asset.
In this section, you are to create webpage that is going to serve the static asset you uploaded to the CDN Push Zones. Then you are configure Nginx as a reverse proxy server and at last install an SSL certificate for your domain using Certbot.
Create a directory for your webpage.
Create a new HTML file in the directory.
Copy and paste the below code.
Install Nginx on your Vultr Ubuntu server.
Open your Nginx virtual host configuration using a text editor such as Nano.
Add the following sub_filter configurations in the location block.
Make sure to the swap <cdn_url> with the actual CDN URL in your Vultr dashboard.
The above configuration substitutes all matching request patterns with your Vultr CDN URL. Within the configuration:
sub_filter '' '';: Modifies the original request URL '' to the destination URL ''. For example, all requests that match the URL pattern <domain_url> are modified to your Vultr CDN URL. File requests within the same URL scheme such as example.com/images/image.png match the request pattern to your Vultr CDN URL.sub_filter_once off;: Enables multiple content modification rules to consistently modify requests with your Vultr CDN URL.Your modified Nginx configuration should look like the one below:
Restart Nginx to apply your configuration changes.
Allow incoming connections on the HTTP port 80.
Allow incoming connections on the HTTPS port 443.
Install the certbot package using the snap package manager.
Request a new SSL certificate for your domain. Make sure to replace your_domain with your actual domain name.
Open the Nginx configuration.
Verify the new Certbot directives in your configuration similar to the one below.
Access the webpage using your domain https://your_domain. To confirm that the image is being served from the CDN Push Zone, right-click on the page and select inspect element. Verify that the index page includes the CDN URL to serve your static image from the nearest CDN Push Zone.
Enhanced Website Performance
Faster Load Times: By caching assets at multiple edge locations, a Vultr Push Zone ensures that users receive content from the nearest server, significantly reducing load times.
Reduced Server Load: Offloading static content delivery to the Vultr CDN Push Zone decreases the burden on your origin server, allowing it to handle dynamic requests more efficiently.
Improved User Experience
Consistency: Regardless of where your users are located, they can experience consistent performance due to the global content distribution.
Scalability: As your website traffic grows, a Vultr CDN Push Zone can handle increased load without requiring significant changes to your infrastructure.
Cost Efficiency
Bandwidth Savings: By utilizing Vultr CDN Push Zone, you can reduce bandwidth costs associated with serving static content from your origin server.
Optimized Resources: Efficient distribution and caching mean you can achieve high performance without investing in additional hardware.
You have explored the step-by-step process of creating a Push Zone, uploading assets, and configuring your web server to serve assets securely and efficiently. Implementing a Vultr Push Zone not only enhances user experience by reducing load times but also offloads traffic from your origin server, leading to better overall performance and scalability. Learn More
