Jaeger is a distributed tracing platform used to monitor and troubleshoot a complex microservices environment. Implementing distributed tracing is essential for modern software applications when troubleshooting and tracking performance issues, especially in the micro-services architecture.
Jaeger monitors and analyzes the requests flow between different microservices in distributed systems and helps developers identify bottlenecks, latency issues, and errors within the system.
Jaeger is made up of several components that work together to offer distributed tracing capabilities. Below are the major components responsible for the different aspects of trace collection, storage, and visualization.
- Agent: Retrieves the incoming trace data, processes it, and forwards the processed version to the appropriate backends
- Query: Offers a web-based that allows you to search, retrieve, view trace data, and analyze the flow of requests in your applications
- Collector: Collects incoming traces from the Jaeger agent, runs validations, and sends them to the backend storage
This article explains how you can deploy Jaeger on a Vultr Kubernetes Engine (VKE) cluster. You will set up Jaeger to trace a Golang application within the cluster.
Before you start:
Deploy a Vultr Kubernetes Engine cluster with at least
3
nodesDeploy a Vultr Debian server to use as the management machine
Using SSH, access the server
Install and Configure Kubectl to access the cluster
Install the Helm package manager
$ snap install helm --classic
Install the Jaeger Operator
Using Helm, add the Jaeger Tracing repository to your charts
$ helm repo add jaegertracing https://jaegertracing.github.io/helm-charts
Update the Helm repository index
$ helm repo update
Install Jaeger Operator to your cluster
$ helm install jaeger-operator jaegertracing/jaeger-operator --namespace observability --create-namespace --set rbac.clusterRole=true
NAME: jaeger-operator LAST DEPLOYED: Sun Oct 29 20:11:39 2023 NAMESPACE: observability STATUS: deployed REVISION: 1 TEST SUITE: None NOTES: jaeger-operator is installed. Check the jaeger-operator logs export POD=$(kubectl get pods -l app.kubernetes.io/instance=jaeger-operator -l app.kubernetes.io/name=jaeger-operator --namespace observability --output name) kubectl logs $POD --namespace=observability
Verify the list of installed Helm packages in your VKE cluster
$ helm list -A
NAME NAMESPACE REVISION UPDATED STATUS CHART APP VERSION jaeger-operator observability 1 2023-10-25 14:17:40.390191139 +0530 IST deployed jaeger-operator-2.49.0 1.49.0
Verify that the Jaeger Operator pod is ready and running in your cluster
$ kubectl get pod -n observability
NAME READY STATUS RESTARTS AGE jaeger-operator-b89c6b9b-9x65d 1/1 Running 0 53m
Deploy the Jaeger All-In-One image
The Jaeger Operator is installed and available in your cluster, but it cannot function without supporting Jaeger resources. Install the Jaeger All-In-One image to deploy the necessary instances to develop and test cluster operations.
Using a text editor such as Nano, create a new
jaeger.yml
file to define the Jaeger instance$ nano jaeger.yml
Add the following configurations to the file
apiVersion: jaegertracing.io/v1 kind: Jaeger metadata: name: jaeger spec: query: serviceType: LoadBalancer
Save and close the file
Apply the Jaeger resource to your clusterabove resources to the Kubernetes.
$ kubectl apply -f jaeger.yml
Verify that Jaeger is running with an
allinone
strategy$ kubectl get jaegers
NAME STATUS VERSION STRATEGY STORAGE AGE jaeger Running 1.49.0 allinone memory 8s
Verify the running Jaeger pod name
$ kubectl get pods -l app.kubernetes.io/instance=jaeger
NAME READY STATUS RESTARTS AGE jaeger-8b48f49db-tjq6v 1/1 Running 0 55m
View the Jaeger pod logs to verify the background activity
$ kubectl logs -l app.kubernetes.io/instance=jaeger
{"level":"info","ts":1697896855.8030396,"caller":"grpc@v1.57.0/clientconn.go:565","msg":"[core][Channel #10] Channel Connectivity change to READY","system":"grpc","grpc_log":true} {"level":"info","ts":1697896855.8032107,"caller":"grpc@v1.57.0/clientconn.go:1301","msg":"[core][Channel #6 SubChannel #8] Subchannel Connectivity change to READY","system":"grpc","grpc_log":true} {"level":"info","ts":1697896855.803359,"caller":"base/balancer.go:177","msg":"[roundrobin]roundrobinPicker: Build called with info: {map[SubConn(id:8):{{Addr: \":14250\", ServerName: \"\", }}]}","system":"grpc","grpc_log":true} {"level":"info","ts":1697896855.8034499,"caller":"grpc@v1.57.0/clientconn.go:565","msg":"[core][Channel #6] Channel Connectivity change to READY","system":"grpc","grpc_log":true} {"level":"info","ts":1697896855.803539,"caller":"grpc/builder.go:124","msg":"Agent collector connection state change","dialTarget":":14250","status":"READY"} {"level":"info","ts":1697896856.7546606,"caller":"grpc@v1.57.0/clientconn.go:1303","msg":"[core][Channel #1 SubChannel #2] Subchannel Connectivity change to IDLE, last error: connection error: desc = \"transport: Error while dialing: dial tcp [::1]:4317: connect: connection refused\"","system":"grpc","grpc_log":true} {"level":"info","ts":1697896856.7552433,"caller":"grpc@v1.57.0/clientconn.go:1301","msg":"[core][Channel #1 SubChannel #2] Subchannel Connectivity change to CONNECTING","system":"grpc","grpc_log":true} {"level":"info","ts":1697896856.7554233,"caller":"grpc@v1.57.0/clientconn.go:1414","msg":"[core][Channel #1 SubChannel #2] Subchannel picks a new address \"localhost:4317\" to connect","system":"grpc","grpc_log":true} {"level":"info","ts":1697896856.7570865,"caller":"grpc@v1.57.0/clientconn.go:1301","msg":"[core][Channel #1 SubChannel #2] Subchannel Connectivity change to READY","system":"grpc","grpc_log":true} {"level":"info","ts":1697896856.7573693,"caller":"grpc@v1.57.0/clientconn.go:565","msg":"[core][Channel #1] Channel Connectivity change to READY","system":"grpc","grpc_log":true}
Verify the list of available Jaeger services
$ kubectl get svc -l app=jaeger
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE jaeger-agent ClusterIP None <none> 5775/UDP,5778/TCP,6831/UDP,6832/UDP,14271/TCP 55m jaeger-collector ClusterIP 10.108.94.104 <none> 9411/TCP,14250/TCP,14267/TCP,14268/TCP,14269/TCP,4317/TCP,4318/TCP 55m jaeger-collector-headless ClusterIP None <none> 9411/TCP,14250/TCP,14267/TCP,14268/TCP,14269/TCP,4317/TCP,4318/TCP 55m jaeger-query LoadBalancer 10.98.215.158 192.0.2.1 16686:32086/TCP,16685:32707/TCP,16687:32697/TCP 55m
Verify and copy the Load Balancer public IP address included in the
jaeger-query
EXTERNAL-IP field.Using a web browser such as Firefox, load the Jaeger web interface on port
16686
using your external IP address. Replace the example IP192.0.2.1
with your actual public IPhttp://192.0.2.1:16686
Deploy a Sample Golang Application to Trace
In this section, you will deploy a Golang Application on Kubernetes using an image ovhplatform/what-is-my-pod-with-tracing:1.0.2
hosted on the Docker Hub. This application will send traces to the Jaeger collector for distributed tracing and monitoring.
Create a new deployment YAML file to define the Golang application
$ nano deployment.yml
apiVersion: apps/v1 kind: Deployment metadata: name: tracing-deployment labels: app: tracing-deployment spec: replicas: 3 selector: matchLabels: app: tracing-deployment template: metadata: labels: app: tracing-deployment spec: containers: - name: tracing-deployment image: ovhplatform/what-is-my-pod-with-tracing:1.0.2 ports: - containerPort: 8080 env: - name: MY_POD_NAME valueFrom: fieldRef: fieldPath: metadata.name
The above configuration creates a new Golang application deployment using the
and the custom pods nameMY_POD_NAME
. Replace these values with your desired source image and pods name for smooth cluster operations.Deploy the application to your cluster
$ kubectl apply -f deployment.yml
Verify that your Golang application is available and running
$ kubectl get pod -l app=tracing-deployment
NAME READY STATUS RESTARTS AGE tracing-deployment-7f94fffb89-5c2zn 1/1 Running 0 24m tracing-deployment-7f94fffb89-nsx56 1/1 Running 0 24m tracing-deployment-7f94fffb89-wz25d 1/1 Running 0 24m
Create a service manifest to expose the Golang application on port
8080
$ nano service.yml
Add the following configuration to the file.
apiVersion: v1 kind: Service metadata: labels: app: tracing-deployment name: tracing-deployment spec: ports: - port: 8080 selector: app: tracing-deployment type: LoadBalancer
Apply the configuration to your cluster
$ kubectl apply -f svc.yml
View the new load balancer IP address assignment to the Golang application
$ kubectl get svc -l app=tracing-deployment
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE tracing-deployment LoadBalancer 10.96.48.102 192.0.2.2 8080:31733/TCP 24m
Verify and keep note of the EXTERNAL-IP value to use when accessing the application.
Visualize Traces using the Jaeger UI
The sample Golang application is deployed to your cluster and able to send traces to Jaeger. Test and visualize all active traces using the Jaeger web interface as described below.
Using Curl, access the Golang application on the service port
8080
using the application's external IP to start tracingcurl http://203.0.113.2:8080
When successful, your output should look like the one below:
Hello "tracing-deployment-7f94fffb89-nsx56"!
In your web browser session, access the Jaeger web interface again
Navigate to
go-what-is-my-pod-with-tracing
in the service menu and click the Find Traces button to view the available tracesClick any of the traces and visualize useful information
To send more traces, access your Golang application again and keep track of the available traces in your Jaeger interface
You have deployed Jaeger on a Vultr Kubernetes Engine (VKE) cluster and set up a sample Golang application to send traces for visualization within the cluster. For more information about Jaeger, visit the official documentation.
