How to Install Jenkins on Vultr Kubernetes Engine
Updated on 25 July, 2024
How to Install Jenkins on Vultr Kubernetes Engine header image
Jenkins is an open-source continuous-integration (CI) and continuous-delivery (CD) server used for project development, deployment, and automation. Software developers use it to build, test, and deploy their software. It is written in Java and provides hundreds of plugins to automate testing and changes in a larger code base.
This guide shows you how to set up Jenkins on Vultr Kubernetes Engine, which provides many benefits over standalone server-based deployment. Kubernetes-based deployment is a very cost-effective solution and also decreases the time needed for development.
You'll perform the rest of the steps in this guide from your management workstation.
Verify Kubernetes Cluster
Before starting, verify the Vultr Kubernetes Cluster using the following command:
kubectl cluster-info
You will see the Cluster information in the following output:
Kubernetes control plane is running at https://e4737bcd-3971-4624-b896-0181aae56bae.vultr-k8s.com:6443
CoreDNS is running at https://e4737bcd-3971-4624-b896-0181aae56bae.vultr-k8s.com:6443/api/v1/namespaces/kube-system/services/kube-dns:dns/proxy
To check the active status of all Cluster nodes, run the following command:
kubectl get nodes
You should see that all nodes are in ready status:
NAME                           STATUS   ROLES    AGE     VERSION
jenkins-cluster-136e69da18fb   Ready    <none>   3m21s   v1.25.4
jenkins-cluster-97b1dd155b22   Ready    <none>   3m21s   v1.25.4
jenkins-cluster-a329dcb28ac7   Ready    <none>   3m21s   v1.25.4
Install Jenkins on Kubernetes
  1. First, create the Jenkins namespace:
     # kubectl create namespace jenkins-namespace
     namespace/jenkins-namespace created
  2. Next, create a serviceAccount.yaml file.
     # nano serviceAccount.yaml
    Add the following configurations to create a service account called jenkins-account and binds the clusterRole to the service account.
     apiVersion: rbac.authorization.k8s.io/v1
     kind: ClusterRole
       - apiGroups: [""]
         resources: ["*"]
         verbs: ["*"]
     kind: ServiceAccount
       namespace: jenkins-namespace
     kind: ClusterRoleBinding
     roleRef:
       apiGroup: rbac.authorization.k8s.io
       kind: ClusterRole
     subjects:
     - kind: ServiceAccount
  3. Apply the above configuration to Kubernetes Cluster.
     # kubectl apply -f serviceAccount.yaml
     clusterrole.rbac.authorization.k8s.io/jenkins-account created
     serviceaccount/jenkins-account created
     clusterrolebinding.rbac.authorization.k8s.io/jenkins-account created
  4. Create a volume configuration file.
     # nano volume.yaml
    Add the following configuration for persistent volume.
     kind: StorageClass
     apiVersion: storage.k8s.io/v1
     provisioner: kubernetes.io/no-provisioner
     volumeBindingMode: WaitForFirstConsumer
     kind: PersistentVolume
         type: local
       storageClassName: jenkins-storage
       claimRef:
       capacity:
         storage: 10Gi
       accessModes:
         - ReadWriteOnce
       local:
         path: /opt
       nodeAffinity:
         required:
           nodeSelectorTerms:
           - matchExpressions:
             - key: kubernetes.io/hostname
               operator: In
               values:
               - jenkins-cluster-136e69da18fb
     kind: PersistentVolumeClaim
       accessModes:
         - ReadWriteOnce
       resources:
         requests:
           storage: 3Gi
    Note: Replace the jenkins-cluster-136e69da18fb with any of your cluster nodes.
    If you need to know the hostname of your worker node, run the following command.
     # kubectl get nodes
    The above configuration will create a PersistentVolume volume in a cluster node inside the /opt directory. You will also need to properly define the worker node name for the Jenkins pod to get scheduled in the specific node.
  5. Create a persistent volume on the Kubernetes cluster using the kubectl command.
     # kubectl create -f volume.yaml
     storageclass.storage.k8s.io/jenkins-storage created
     persistentvolume/jenkins-pv-volume created
     persistentvolumeclaim/jenkins-pv-claim created
  6. Create a deployment.yaml file.
     # nano deployment.yaml
    Add the following manifest configuration.
       replicas: 1
           app: jenkins-server
             app: jenkins-server
           securityContext:
                 fsGroup: 1000
                 runAsUser: 1000
           serviceAccountName: jenkins-account
             - name: jenkins
               image: jenkins/jenkins:lts
               resources:
                 limits:
                   memory: "2Gi"
                   cpu: "1000m"
                 requests:
                   memory: "500Mi"
                   cpu: "500m"
                 - name: httpport
                   containerPort: 8080
                 - name: jnlpport
                   containerPort: 50000
               livenessProbe:
                 httpGet:
                   path: "/login"
                   port: 8080
                 initialDelaySeconds: 90
                 periodSeconds: 10
                 timeoutSeconds: 5
                 failureThreshold: 5
               readinessProbe:
                 httpGet:
                   path: "/login"
                   port: 8080
                 initialDelaySeconds: 60
                 periodSeconds: 10
                 timeoutSeconds: 5
                 failureThreshold: 3
               volumeMounts:
                 - name: jenkins-data
                   mountPath: /var/jenkins_home
           volumes:
               persistentVolumeClaim:
                   claimName: jenkins-pv-claim
    The above configuration file will:
    • Creates a Jenkins deployment using the latest Jenkins image and opens ports 8080 and 50000 to accept connections from Jenkins workers.
    • Mounts the persistent volume on the /var/jenkins_home directory to hold Jenkins data.
    • Define liveness probes to check the container's health status.
    • Define readiness probes to know when a container can start accepting traffic.
  7. Apply the above deployment to the Kubernetes cluster.
     # kubectl apply -f deployment.yaml
     deployment.apps/jenkins created
    Wait for some time to pull the Jenkins image and get the Jenkins pod running.
  8. Verify the status of the Jenkins pod.
     # kubectl get deployments -n jenkins-namespace
     NAME      READY   UP-TO-DATE   AVAILABLE   AGE
     jenkins   1/1     1            1           94s
  9. Get a detail information about Jenkins deployment.
     # kubectl describe deployments --namespace=jenkins-namespace
     Namespace:              jenkins-namespace
     CreationTimestamp:      Tue, 22 Nov 2022 21:03:42 +0530
     Labels:                 <none>
     Annotations:            deployment.kubernetes.io/revision: 1
     Selector:               app=jenkins-server
     Replicas:               1 desired | 1 updated | 1 total | 1 available | 0 unavailable
     StrategyType:           RollingUpdate
     MinReadySeconds:        0
     RollingUpdateStrategy:  25% max unavailable, 25% max surge
     Pod Template:
       Labels:           app=jenkins-server
       Service Account:  jenkins-account
       Containers:
        jenkins:
         Image:       jenkins/jenkins:lts
         Ports:       8080/TCP, 50000/TCP
         Host Ports:  0/TCP, 0/TCP
         Limits:
           cpu:     1
           memory:  2Gi
         Requests:
           cpu:        500m
           memory:     500Mi
         Liveness:     http-get http://:8080/login delay=90s timeout=5s period=10s #success=1 #failure=5
         Readiness:    http-get http://:8080/login delay=60s timeout=5s period=10s #success=1 #failure=3
         Environment:  <none>
         Mounts:
           /var/jenkins_home from jenkins-data (rw)
       Volumes:
        jenkins-data:
         Type:       PersistentVolumeClaim (a reference to a PersistentVolumeClaim in the same namespace)
         ClaimName:  jenkins-pv-claim
         ReadOnly:   false
     Conditions:
       Type           Status  Reason
       Available      True    MinimumReplicasAvailable
       Progressing    True    NewReplicaSetAvailable
     OldReplicaSets:  <none>
     NewReplicaSet:   jenkins-7b95fb694 (1/1 replicas created)
     Events:
       Type    Reason             Age   From                   Message
       Normal  ScalingReplicaSet  19m   deployment-controller  Scaled up replica set jenkins-7b95fb694 to 1
Create Kubernetes Service for External Access
At this point, Jenkins is successfully deployed and running on the Kubernetes cluster. However, you can not access Jenkins from the remote machine. In this case, you will need to create a service and bind it to the Jenkins deployment.
  1. First, create a service.yaml file using the following command:
     # nano service.yaml
    Add the following configurations to expose port 8080 of the Jenkins pod to port 32000.
           prometheus.io/scrape: 'true'
           prometheus.io/path:   /
           prometheus.io/port:   '8080'
         app: jenkins-server
       type: NodePort
         - port: 8080
           targetPort: 8080
           nodePort: 32000
  2. Next, deploy the service configuration to the Jenkins deployment.
     # kubectl apply -f service.yaml
     service/jenkins-service created
  3. Verify the status of the Jenkins service.
     # kubectl get services --namespace jenkins-namespace
     NAME              TYPE       CLUSTER-IP       EXTERNAL-IP   PORT(S)          AGE
     jenkins-service   NodePort   10.103.86.99   <none>        8080:32000/TCP   6s
Access Jenkins Web Interface
At this point, Jenkins is installed and listens on port 32000 for external access. Now, you will need to retrieve the IP address of the cluster node to access the Jenkins web interface.
  1. First, get a node IP address using the kubectl command.
     # kubectl get nodes -o wide
    You will get the external IP of all nodes in the following output.
     NAME                           STATUS   ROLES    AGE   VERSION   INTERNAL-IP   EXTERNAL-IP    OS-IMAGE                       KERNEL-
     VERSION    CONTAINER-RUNTIME
     jenkins-cluster-7e8eba45f3a6   Ready    <none>   23m   v1.25.4   10.46.96.6    65.20.79.223   Debian GNU/Linux 10 (buster)   4.19.0-22-amd64   containerd://1.6.9
     jenkins-cluster-a45a12e27a63   Ready    <none>   23m   v1.25.4   10.46.96.5    65.20.79.2     Debian GNU/Linux 10 (buster)   4.19.0-22-amd64   containerd://1.6.9
     jenkins-cluster-cfacc64361f5   Ready    <none>   23m   v1.25.4   10.46.96.4    65.20.74.173   Debian GNU/Linux 10 (buster)   4.19.0-22-amd64   containerd://1.6.9
  2. Next, open your web browser and access Jenkins using the URL http://node-external-ip:32000. You will be asked to provide the initial Admin password.
    Jenkins initial Admin password
  3. Get Jenkins pod details using the following command.
     # kubectl get pods --namespace=jenkins-namespace
     NAME                      READY   STATUS    RESTARTS   AGE
     jenkins-7b95fb694-5xqnp   1/1     Running   0          20m
  4. Check the Jenkins pod logs to retrieve the Jenkins Admin password.
     # kubectl logs jenkins-7b95fb694-5xqnp --namespace=jenkins-namespace
     Jenkins initial setup is required. An admin user has been created and a password generated.
     Please use the following password to proceed to installation:
     a1f057cba5f6440f863b6e5a57d880fa
     This may also be found at: /var/jenkins_home/secrets/initialAdminPassword
  5. Copy the password from the above output and enter it on the Jenkins initial Admin password screen to proceed with the Jenkins installation.
This guide shows you how to install and configure Jenkins on Vultr Kubernetes Engine. Jenkins is a core component of CI/CD pipelines. It helps you perform very complex operations and increase productivity. For more information, check out the official Jenkins documentation.
