Yacht is a container management tool that offers a graphical user interface (GUI) for easy deployment of Docker containers. It uses templates to offer 1 click deployment of containers for easy setup and management on your server. In this guide, you will install Yacht with Docker on a Vultr cloud server.
Install Yacht on Docker
Option 1: Install as a Docker Volume
Create the Yacht volume.
# docker volume create yacht
Install Yacht, and assign a listening port, it is recommended to use port 8000
# docker run -d -p 8000:8000 -v /var/run/docker.sock:/var/run/docker.sock -v yacht:/config --name yacht selfhostedpro/yacht
Option 2: Install using Docker compose
Create a new Yacht directory.
# mkdir /opt/yacht
Using your favorite editor, create a new docker-compose.yml
in the Yacht directory.
# nano /opt/yacht/docker-compose.yml
Paste the following contents:
version: "3"
services:
yacht:
container_name: yacht
restart: unless-stopped
- 8000:8000
volumes:
- yacht:/config
- /var/run/docker.sock:/var/run/docker.sock
image: selfhostedpro/yacht
volumes:
yacht:
Save the file.
Change to the Yacht directory.
# cd /opt/yacht
Now, start the application in detached mode.
# docker-compose up -d
Setup Yacht
Allow port 8000
through the firewall.
On Ubuntu:
# ufw allow 8000/tcp
On CentOS:
# firewall-cmd --zone=public --add-port=8000/tcp --permanent
Then, through a web browser load 8000
on your public server IP.
http://vultr-server-ip:8000
Login to the Yacht web dashboard using the following default credentials:
- Username: admin@yacht.local
- Password: pass
To secure your server, change the default administrator username and password through user settings in the top right corner.
Now, create your first template by selecting Templates on the left sidebar, enter the application title and URL. To use the default template, copy the listed Yacht Github URL, and click Submit to create the template.
Then, click on your template, select an app to deploy, navigate through the application details, assign a network port under Networking, set up directories, then click Deploy to create the container on your server.
Once successful, your application will display in the yacht dashboard with its CPU and memory usage statistics.
Congratulations, you have successfully installed Yacht on Docker to manage your containers through the web interface. For further information on how to use Yacht, refer to the official documentation.
