Learn how to change the operating system on your Vultr Cloud GPU instance.
Changing the instance operating system wipes all data on your server and installs a new file system. This is important when changing your default operating system while maintaining your instance's IP networking information.
Follow this guide to change the operating system on a Vultr Cloud Compute instance using the Vultr Console, API, CLI, or Terraform.
Navigate to Products and click Compute.
Click your target Cloud GPU instance to open its management page.
Navigate to the Settings tab.
Find and click Change OS on the left navigation menu.
Click the Choose new OS drop-down and select a new operating system to install on your instance.
Click Change OS to change the instance operating system.
Check the Change OS confirmation prompt and click Change OS to apply the new instance changes.
Start the conversation
