A guide explaining how to properly restart your Vultr Cloud GPU instance when needed.
Restarting an instance performs a hard reboot and stops all running processes on your server before starting them again. Restarting does not alter the instance data or file system and enables the application of updates or configuration changes that require a reboot.
Follow this guide to restart a Vultr Cloud GPU instance using the Vultr Console, API, or CLI.
Send a GET request to the List Instances endpoint and note the target instance's ID.
Send a POST request to the Reboot Instances endpoint to restart the instance.
$ curl "https://api.vultr.com/v2/instances/reboot" \
-X POST \
--data '{
"instance_ids" : [
"instance_id"
List all instances in your Vultr account and note the target instance's ID.
$ vultr-cli instance list
Restart the target instance.
$ vultr-cli instance restart <instance_id>
