Learn how to properly stop a Vultr Cloud GPU instance to pause resources while maintaining your configuration.
Stopping an instance shuts it down and disables connectivity to the main network interface. The operating system and all running processes are stopped, but the instance normal billing cycle continues unless destroyed.
Follow this guide to stop a Vultr Cloud GPU instance using the Vultr Console, API, or CLI.
