Whisper is a foundation model from OpenAI. You can use this model to convert speech to text (transcription) or to automatically translate text from one language to another (translation).
Foundation models are trained on massive amounts of data and form the basis of more advanced or specialized models. For instance, OpenAI trains the Whisper model with an audio dataset containing more than 680,000 hours and 1.4 trillion words. The massive dataset allows Whisper to learn patterns and relationships when performing natural language processing (NLP) tasks.
In this article, you'll deploy a Vultr Cloud GPU and install the required libraries to implement OpenAI's Whisper model with Python to transcribe audio and translate text.
Deploy a new Ubuntu 22.04 A100 Vultr Cloud GPU Server with at least:
Create a non-root user with sudo rights and switch to the account.
The Whisper model requires the FFmpeg package. This package has many useful libraries for processing multimedia content, such as audio and video. Follow the steps below to install FFmpeg:
Choose the appropriate command to install FFmpeg. For Ubuntu and Arch, run the commands below:
Ubuntu or Debian:
Arch Linux:
Use pip to install the openai-whisper model.
Ensure you've installed the Whisper model by checking its version.
In this section, you'll download a sample audio file from Steve Jobs, the visionary co-founder of Apple. Then, you'll use the Whisper model with Python to transcribe the audio file to text. Follow the steps below:
Download the sample steve-jobs.mp3 file using the Linux wget command.
Create a new transcribe.py file using a text editor like nano.
Enter the following information into the transcribe.py file. In the following file, you're loading the sample audio file from Steve Jobs and transcribing the audio into a text output.
Run the transcribe.py file.
Verify the following output.
In addition to transcribing text, you can use the OpenAI's Whisper model to translate text into different languages. Follow the steps below:
Download a sample spanish.mp3 file.
Create a new translate.py file.
Enter the following information into the translate.py file. You're using the Whisper model to load the Spanish audio sample file in the following file. Then, you're defining a task to convert the audio sample to English.
Run the translate.py file.
In this article, you explored how to use OpenAI's Whisper foundation model to transcribe and translate sample audio files. You started with transcribing an English audio file to English text. Then, you've also translated a Spanish audio sample file to English text.
