How to Expose Services using Vultr Load Balancer and VPC 2.0
Updated on 15 April, 2026
Learn how to securely expose your services to the internet using Vultr Load Balancer with VPC 2.0. Step-by-step guide for optimal network configuration.
How to Expose Services using Vultr Load Balancer and VPC 2.0 header image
Vultr Load Balancer is a network service that distributes traffic across multiple servers connected to optimize the performance, reliability, and availability of hosted applications or services. A Vultr Load Balancer connects directly to all target host servers using a backend network interface. In a VPC 2.0 network, a Vultr load balancer securely exposes internal Vultr VPC2.0 network hosts by forwarding and distributing specific external network traffic to the internal VPC host services.
This article explains how to expose services using a Vultr Load Balancer in a VPC 2.0 network. You will set up multiple servers in a Vultr VPC 2.0 network, run similar services on each server, and securely expose all hosts using a Vultr Load Balancer.
Example VPC2.0 Network Topology
Vultr Load Balancer VPC 2.0 Traffic Distribution Topology
Within the VPC 2.0 network:
  • Vultr Load Balancer: Works as the default gateway to all internal VPC 2.0 host services. All external requests to the public IP address 192.0.2.160 or the associated domain example.com translate to the respective VPC 2.0 services.
  • Host 1: Runs the main internal web server using Nginx and accepts incoming connections on the HTTP port 80.
  • Host 2: Works as a backup web server using Apache.
  • Host 3: Works as a backup web server using Nginx.
  • Host 4: Works as the internal VPC 2.0 host management workstation. A public network interface is available on the server with the IP address 192.0.2.100 and connects to all internal hosts over SSH using the VPC 2.0 interface.
Internal VPC 2.0 Load Balanced Hosts
Internal VPC 2.0 host network addresses:
  • Vultr Load Balancer: 10.49.144.3
  • Host 1: 10.49.144.4
  • Host 2: 10.49.144.5
  • Host 3: 10.49.144.6
  • Host 4: 10.49.144.7
In a single Vultr location:
Note
Add all instances to the same Vultr VPC 2.0 network.
Attach VPC 2.0 Hosts to the Vultr Load Balancer
  1. Open the Vultr Console.
  2. Navigate to Products and click Load Balancers on the main navigation menu.
  3. Click your target load balancer to open the instance control panel.
  4. Click Add Instance within the Linked Instances within the Overview Tab.
    Add Vultr Load Balancer Instances
  5. Select your target VPC host from the list within the Add Instance pop-up. For example, Host 1 and click Attach instance to add the instance to your load balancer.
  6. Repeat the process for all VPC 2.0 hosts host 2 and host 3 to attach them to the load balancer.
  7. Verify that all instances are attached to the load balancer and listed in the Linked Instances section.
    View Linked Load Balancer Instances
Configure the VPC 2.0 Host Management Server
Configure the VPC 2.0 management server to set up access to all internal hosts that run similar services to expose with the Vultr Load Balancer. Based on the example network topology, the host 4 management server is not attached to the load balancer, has a public network interface, and accepts outgoing SSH connections to manage other internal hosts.
  1. Access the Ubuntu internal VPC 2.0 management server using SSH.
    $ ssh root@192.0.2.100
  2. Create a new standard user account with sudo privileges. For example, vpcadmin.
    # adduser vpcadmin && adduser vpcadmin sudo
  3. Switch to the user.
    # su vpcadmin
  4. View the server network interfaces and verify that the VPC 2.0 network interface is active with a private IP address.
    $ ip a
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
        inet 127.0.0.1/8 scope host lo
           valid_lft forever preferred_lft forever
        inet6 ::1/128 scope host
    2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
        link/ether 56:00:04:d5:77:b6 brd ff:ff:ff:ff:ff:ff
        inet 192.0.2.100/23 metric 100 brd 192.0.2.255 scope global dynamic enp1s0
           valid_lft 85764sec preferred_lft 85764sec
        inet6 2a05:f480:3000:2321:5400:4ff:fed5:77b6/64 scope global dynamic mngtmpaddr noprefixroute
           valid_lft 2591659sec preferred_lft 604459sec
        inet6 fe80::5400:4ff:fed5:77b6/64 scope link
    3: enp8s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1450 qdisc mq state UP group default qlen 1000
        link/ether 5a:01:04:d5:77:b6 brd ff:ff:ff:ff:ff:ff
        inet 10.49.144.7/20 brd 10.49.159.255 scope global enp8s0
        inet6 fe80::5801:4ff:fed5:77b6/64 scope link
  5. Test access to the Vultr Load Balancer internal IP using the Ping utility.
    $ ping 10.49.144.3
    PING 10.49.144.3 (10.49.144.3) 56(84) bytes of data.
    64 bytes from 10.49.144.3: icmp_seq=1 ttl=62 time=211 ms
    64 bytes from 10.49.144.3: icmp_seq=2 ttl=62 time=0.868 ms
    64 bytes from 10.49.144.3: icmp_seq=3 ttl=62 time=0.806 ms
    --- 10.49.144.3 ping statistics ---
    3 packets transmitted, 3 received, 0% packet loss, time 2002ms
    rtt min/avg/max/mdev = 0.806/71.053/211.487/99.301 ms
  6. Allow SSH access on the server using the default UFW firewall.
    $ sudo ufw allow ssh
  7. Block all incoming network connections on the server.
    $ sudo ufw default deny incoming
    Default incoming policy changed to 'deny'
    (be sure to update your rules accordingly)
  8. Reload the UFW table rules to apply the firewall changes.
    $ sudo ufw reload
    The VPC 2.0 management server acts as the main gateway to the internal network hosts over SSH while the Vultr Load Balancer acts as the external gateway depending on the exposed ports. Follow the additional sections below to use the management server to establish SSH connections, install services, and apply configuration changes on each of the target internal hosts.
Set Up the Internal VPC 2.0 Host Services
Host 1 (Main Web Server)
  1. Access the Ubuntu server using SSH.
    $ ssh root@10.49.144.4
  2. Create a non-root user with sudo privileges.
    # sudo adduser sysadmin && adduser sysadmin sudo
  3. Switch to the new user.
    # su - sysadmin
  4. View the server network interfaces and note the public network interface name.
    $ ip a
        inet 192.0.2.101/23 metric 100 brd 192.0.2.255 scope global dynamic enp1s0
        inet 10.49.144.4/20 brd 10.49.159.255 scope global enp8s0
  5. Test access to the Vultr Load Balancer VPC address using the Ping utility.
    $ ping 10.49.144.3
  6. Update the server packages.
  7. Install the Nginx web server application.
    $ sudo apt install nginx -y
  8. Verify the Nginx system service status.
    $ sudo systemctl status nginx
    ● nginx.service - A high performance web server and a reverse proxy server
         Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
         Active: active (running) since Fri 2024-03-29 02:36:09 UTC; 15min ago
           Docs: man:nginx(8)
        Process: 1901 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
        Process: 1902 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
       Main PID: 1991 (nginx)
          Tasks: 2 (limit: 1005)
         Memory: 7.6M
            CPU: 33ms
         CGroup: /system.slice/nginx.service
                 ├─1991 "nginx: master process /usr/sbin/nginx -g daemon on; master_process on;"
                 └─1994 "nginx: worker process" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ""
    Mar 29 02:36:09 Host-1 systemd[1]: Starting A high performance web server and a reverse proxy server...
    Mar 29 02:36:09 Host-1 systemd[1]: Started A high performance web server and a reverse proxy server.
  9. Allow incoming connections from the VPC 2.0 network address class to the server HTTP port 80 through the firewall.
    $ sudo ufw allow from 10.49.144.0/20 to any port 80
  10. Restart the firewall to apply changes.
    $ sudo ufw reload
  11. View the firewall table to verify the new VPC network rule.
    $ sudo ufw status
    Status: active
    To                         Action      From
    22/tcp                     ALLOW       Anywhere
    80                         ALLOW       10.49.144.0/20
    22/tcp (v6)                ALLOW       Anywhere (v6)
  12. Navigate to the Nginx web root directory /var/www/html.
    $ cd /var/www/html
  13. Edit the default Nginx HTML file using a text editor such as Nano.
    $ nano index.nginx-debian.html
  14. Change the default HTML <h1> tag value to a custom message such as Served from Host 1.
    html
    <h1>Served by Host 1!</h1>
  15. Restart Nginx to apply the file changes.
    $ sudo systemctl restart nginx
  16. Disable the public network interface.
    $ sudo ip link set enp1s0 down
Host 2 (Backup Web Server)
  1. Access the Rocky Linux server using SSH.
    $ ssh root@10.49.144.5
  2. Create a new non-root user.
    # adduser dbadmin
  3. Assign the user a strong password.
    # passwd dbadmin
  4. Add the user to the privileged wheel group.
    # usermod -aG wheel dbadmin
  5. Switch to the user.
    # su - dbadmin
  6. View the server network interfaces and verify the VPC 2.0 interface name.
    $ ip a
        link/ether 56:00:04:d5:77:bc brd ff:ff:ff:ff:ff:ff
        inet 192.0.2.102/23 brd 192.0.2.255 scope global dynamic noprefixroute enp1s0
           valid_lft 85324sec preferred_lft 85324sec
        inet6 2a05:f480:3000:29a0:5400:4ff:fed5:77bc/64 scope global dynamic noprefixroute
           valid_lft 2591636sec preferred_lft 604436sec
        inet6 fe80::5400:4ff:fed5:77bc/64 scope link noprefixroute
        link/ether 5a:01:04:d5:77:bc brd ff:ff:ff:ff:ff:ff
        inet 10.49.144.5/20 brd 10.49.159.255 scope global noprefixroute enp8s0
        inet6 fe80::5801:4ff:fed5:77bc/64 scope link
  7. Test access to the Vultr Load Balancer VPC 2.0 network address.
    $ ping -c 3 10.49.144.3
    64 bytes from 10.49.144.3: icmp_seq=1 ttl=62 time=0.686 ms
    64 bytes from 10.49.144.3: icmp_seq=2 ttl=62 time=0.731 ms
    64 bytes from 10.49.144.3: icmp_seq=3 ttl=62 time=0.756 ms
    3 packets transmitted, 3 received, 0% packet loss, time 2054ms
    rtt min/avg/max/mdev = 0.686/0.724/0.756/0.028 ms
  8. Update the server packages.
    $ sudo dnf update
  9. Install the Apache web server application.
    $ sudo dnf install httpd
  10. Start the Apache web server.
    $ sudo systemctl start httpd
  11. Configure the default Firewalld application to allow connections to the HTTP port 80 from the internal VPC 2.0 network.
    $ sudo firewall-cmd --permanent --zone=public --add-rich-rule='
      rule family="ipv4"
      source address="10.49.144.0/20"
      port protocol="tcp" port="80" accept'
  12. Reload Firewalld to apply the new firewall rule.
    $ sudo firewall-cmd --reload
  13. Disable the public network interface.
Host 3 (Backup Web Server)
  1. Access the Debian server using SSH.
    $ ssh root@10.44.144.6
  2. Create a new non-root user with sudo privileges.
    # sudo adduser webadmin && adduser webadmin sudo
  3. Switch to the new user account.
    # su - webadmin
  4. View the server network interfaces and verify the associated VPC 2.0 network interface.
    $ ip a
        inet 10.49.144.6/20 brd 10.49.159.255 scope global enp8s0
    $ ping 10.49.144.3
  6. Update the server.
  7. Install Nginx.
  9. Allow connections to the HTTP port 80 from the internet VPC 2.0 network through the firewall.
    $ sudo ufw reload
  11. Navigate to the Nginx web root directory /var/www/html.
    $ cd /var/www/html
  12. Edit the default Nginx file.
  13. Change the default HTML <h1> tag value to Served from Host 3.
    html
    <h1>Served by Host 3!</h1>
  14. Restart Nginx to synchronize the file changes.
  15. Disable the public network interface.
Set Up the Vultr Load Balancer Forwarding Rules to Expose VPC 2.0 Host Services
  1. Access your Vultr Load Balancer instance control panel.
  2. Navigate to the Configuration tab.
  3. Click Forwarding Rules to access the port translation options.
    Set Up Vultr Load Balancer Rules
  4. Verify that the default HTTP port 80 rule is available, and click Add another rule to set up any additional port forwarding rules.
  5. Click Save Changes to apply the Vultr Load Balancer forwarding changes.
Test Access to the VPC 2.0 Host Services
A Vultr Load Balancer accepts all external network requests and distributes traffic to the respective internal VPC network ports depending on the load-balancing strategy and forwarding rules. Follow the sections below to verify that the load balancer distributes traffic to all internal VPC 2.0 web servers.
  1. Visit your domain example.com using a web browser such as Chrome.
    http://example.com
    Verify that the host 1 web page displays in your browser.
    Access the Vultr VPC 2.0 Web Server Host
  2. Open a new browser window and visit your domain example.com again.
    http://example.com
    Verify that the host 2 Apache default web page displays in your browser session.
    Test the host 2 Vultr load balancing strategy
  3. Open another browser window and visit the domain again.
    http://example.com
    Verify that the host 3 web page displays in your browser.
    Test the host 3 Vultr load balancing strategy
    Based on the above web server results, the load balancer distributes traffic between the main web server and the backup servers using the default round-robin algorithm. As a result, all web servers effectively act as one which improves the general web application availability. If one of the servers goes down, the load balancer distributes traffic to other servers within the VPC 2.0 network.
Best Practices
The Vultr Load Balancer accepts multiple connections to internal VPC 2.0 network hosts and distributes traffic based on the defined load balancing algorithm. For the best results, follow the best practices below to secure and correctly distribute traffic to all internal host servers.
  • Add your domain SSL certificate to the Vultr Load Balancer to enable secure HTTPS connections to your web application. Enable the Force HTTP to HTTPS option within the load balancer configuration to activate automatic HTTP to HTTPS redirections.
  • Set up Vultr Load Balancer firewall rules and limit access to special ports such as the SSH port to your IP address or a specific IP range.
  • Configure the Vultr Load Balancer health checks to automatically perform instance checks based on your defined intervals.
    Setup Vultr Load Balancer Health Checks
You have exposed VPC 2.0 host services using a Vultr Load Balancer and forwarded all external network requests to the internal network. Depending on your host services, the load balancer securely exposes all services depending on your forwarding rules. For the best results and improved server security, disable the public interfaces on each server and only enable the interface while updating or installing packages.
